Driver doesn't need to run a kernel thread to collect firmware log
if release build firmware is loaded. Only debug build firmware is
capable of generating logs. This commit checks firmware CFGTBL to
know whether a firmware generates logs or not.
bug 1487603
Change-Id: I8b147710dae58332d68625fedd3173e2d2f6074b
Signed-off-by: JC Kuo <jckuo@nvidia.com>
Reviewed-on: http://git-master/r/663769
(cherry picked from commit bc339c3a63ea18fbbe568c99e33d06d637ad1f71)
Reviewed-on: http://git-master/r/744725
GVS: Gerrit_Virtual_Submit
Tested-by: Mark Kuo <mkuo@nvidia.com>
Reviewed-by: WK Tsai <wtsai@nvidia.com>
Reviewed-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-by: Matthew Pedro <mapedro@nvidia.com>
Reviewed-by: Ashutosh Jha <ajha@nvidia.com>
Loading firmware from filesystem takes much time. Enabing vbus regualtor
before loading firmware will cause the time gap between vbus ON and host
controller ready too large. So, we move the time of firmware loading
earlier.
Bug 200067006
Change-Id: I63ecbd9e65f3bb56db564f72cc417fc4f76adbc3
Signed-off-by: Henry Lin <henryl@nvidia.com>
Signed-off-by: Bibek Basu <bbasu@nvidia.com>
Reviewed-on: http://git-master/r/736193
(cherry picked from commit 6875a1752b3ed4e121efcc3fddca0810ffd22546)
Reviewed-on: http://git-master/r/746074
Reviewed-by: Venkat Moganty <vmoganty@nvidia.com>
The sysfs_attr_init() macro expects a pointer to a struct attribute as
argument and not a pointer to a struct device_attribute. This was
bulding with lockdep disabled because in this case the
sysfs_attr_init() macro does nothing.
Bug 1618089
Change-Id: I6225c5c26beccae3848d8d5360a0efabcba60ce5
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
Reviewed-on: http://git-master/r/741614
When re-applying the configuration after a successful usb device reset,
xhci_discover_or_reset_device has already dropped the endpoints, and free-ed
the rings.
The endpoints already being dropped is expected, and should not lead to
warnings. Use the fact that the rings are also free-ed in this scenario to
detect this, and suppress the "xHCI xhci_drop_endpoint called with disabled
ep ..." message in this case.
Bug 200040915
Changes in v2:
Move the ring check to only guard the xhci_warn, so as to avoid side-effects
in case we have a scenario where the rings are free-ed, but the endpoint is
not yet dropped.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Change-Id: I94392cf985208f96c7102e5115268c3460338a46
Signed-off-by: Petlozu Pravareshwar <petlozup@nvidia.com>
Reviewed-on: http://git-master/r/721398
Reviewed-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
We have VDD_CORE on when LP1. xusb use padctl interrupt to
wake from LP1. Keep interrupt enabled when system suspend.
Bug 1583860
Bug 200081242
Change-Id: I276594d69a051ea84034c32015589a6574ded7f1
Signed-off-by: Joy Wang <joyw@nvidia.com>
Reviewed-on: http://git-master/r/658281
(cherry picked from commit 0031edc18b385eb5dc67eb419f2c50aa5f0a15a2)
Reviewed-on: http://git-master/r/726127
Reviewed-by: Ajay Gupta <ajayg@nvidia.com>
PCIe powergating dependency is now handled internally in the powergating module
for t12x/t13x. This patch removes PCIe related powergating calls from XHCI
driver for tegra.
Bug 1451279
Bug 1524744
Bug 200027067
Change-Id: I0752cd745f218266e1636cc7c40a6c29dee3b3d4
Reviewed-on: http://git-master/r/424036
(cherry picked from commit 91e2bd6728ca1969615081c70be6b2f21acd43d5)
Signed-off-by: Vidya Sagar <vidyas@nvidia.com>
Reviewed-on: http://git-master/r/498662
The powergate module now maintains reference count for PCIE. Remove conditional
checks in XHCI driver before invoking powergating APIs.
Bug 1451279
Bug 1455032
Bug 200027067
Change-Id: I186270dc86fba78a8c321ba5923382e642b14b60
Reviewed-on: http://git-master/r/418061
(cherry picked from commit b0f746945fccf025e2ab1764c0cc35eb1bc780b3)
Reviewed-on: http://git-master/r/498660
1. The kernel resume (from LP0 to the time
when app tasks start unfreezing) is shorter than 200ms.
When app tasks start running, the RIL/framework/app
will hold their wake lock to block suspending.
Furthermore, tegra_usb_modem_post_remote_wakeup()
in tegra_usb_modem_power.c will hold another timeout
(1 second) wake lock, which should start later than
the wake lock "tegra-ehci.1".
So, 1s timeout for wake lock "tegra-ehci.1" in kernel
should be enough.
2. Per our experience, many system resume/suspend
(with screen off) caused by remote wake-up is
able to finish in 1.5 seconds, or even shorter.
So, 3 seconds timeout could cause more unnecessary
power consumption.
bug 1519797
Change-Id: If7b20ea490007e1df0639b4ece8f32fdb3fa757e
Signed-off-by: Robert Shih <rshih@nvidia.com>
Reviewed-on: http://git-master/r/419279
(cherry picked from commit 3ee5cc88a7db04b2087937e8ddb27f69ab934544)
Reviewed-on: http://git-master/r/423626
Reviewed-by: Martin Chi <mchi@nvidia.com>
Tested-by: Martin Chi <mchi@nvidia.com>
into promotion_build
Change-Id: I9418a05ad5c56b2e902249218bac2fa594d99f56
For now, only apply it in tegra_ehci_irq when it's
triggered by remote wake-up irq, since, without
wake lock hold here, device may continue the
suspend if remote wake-up comes in suspending.
bug 1402295
Change-Id: I49223c0fb80fd793e8886688a96e66101405fdd6
Signed-off-by: Martin Chi <mchi@nvidia.com>
Reviewed-on: http://git-master/r/359426
Reviewed-on: http://git-master/r/385478
(cherry picked from commit a06d6d9eb47428e8a7be09c988fe83cff260acd0)
Reviewed-on: http://git-master/r/419225
Reviewed-by: Suresh Mangipudi <smangipudi@nvidia.com>
Bug 200004122
drivers/cpufreq/cpufreq.c
drivers/regulator/core.c
sound/soc/codecs/max98090.c
Signed-off-by: Ishan Mittal <imittal@nvidia.com>
commit 01bb59ebffdec314da8da66266edf29529372f9b upstream.
When CONFIG_PCI and CONFIG_PM are not selected, xhci.c gets this
warning:
drivers/usb/host/xhci.c:409:13: warning: ‘xhci_msix_sync_irqs’ defined
but not used [-Wunused-function]
Instead of creating nested #ifdefs, this patch fixes it by defining the
xHCI PCI stubs as inline.
This warning has been in since 3.2 kernel and was
caused by commit 421aa841a134f6a743111cf44d0c6d3b45e3cf8c
"usb/xhci: hide MSI code behind PCI bars", but wasn't noticed
until 3.13 when a configuration with these options was tried
Signed-off-by: David Cohen <david.a.cohen@linux.intel.com>
commit 6db249ebefc6bf5c39f35dfaacc046d8ad3ffd70 upstream.
After suspend another Renesas PCI-X USB 3.0 card doesn't work.
[root@fedora-20 ~]# lspci -vmnnd 1912:
Device: 03:00.0
Class: USB controller [0c03]
Vendor: Renesas Technology Corp. [1912]
Device: uPD720202 USB 3.0 Host Controller [0015]
SVendor: Renesas Technology Corp. [1912]
SDevice: uPD720202 USB 3.0 Host Controller [0015]
Rev: 02
ProgIf: 30
This patch should be applied to stable kernel 3.14 that contain
the commit 1aa9578c1a9450fb21501c4f549f5b1edb557e6d
"xhci: Fix resume issues on Renesas chips in Samsung laptops"
Reported-and-tested-by: Anatoly Kharchenko <rfr-bugs@yandex.ru>
Reference: http://redmine.russianfedora.pro/issues/1315
Signed-off-by: Igor Gnatenko <i.gnatenko.brain@gmail.com>
commit bcffae7708eb8352f44dc510b326541fe43a02a4 upstream.
xHCI driver has its own pci probe function that will call usb_hcd_pci_probe
to register its usb-2 bus, and then continue to manually register the
usb-3 bus. usb_hcd_pci_probe does a pm_runtime_put_noidle at the end and
might thus trigger a runtime suspend before the usb-3 bus is ready.
Prevent the runtime suspend by increasing the usage count in the
beginning of xhci_pci_probe, and decrease it once the usb-3 bus is
ready.
xhci-platform driver is not using usb_hcd_pci_probe to set up
busses and should not need to have it's usage count increased during probe.
Acked-by: Dan Williams <dan.j.williams@intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Clear SMI INTR status bits in smi irq handler.
Bug 1481790
Change-Id: I7b5e37ece1996ab2e2d97d561cff05fc6652b2d5
Reviewed-on: http://git-master/r/385512
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
Enable mailbox after load firmware and ISR registered.
Bug 1481790
Change-Id: I965ea8834f710a67ffc3b446c638e5a6c2f679a4
Reviewed-on: http://git-master/r/385504
Change-Id: I30baee4084399b8078232f31296c4d891a903d47
Signed-off-by: Prashant Gaikwad <pgaikwad@nvidia.com>
Reviewed-on: http://git-master/r/395123
commit 1aa9578c1a9450fb21501c4f549f5b1edb557e6d upstream.
Don Zickus <dzickus@redhat.com> writes:
Some co-workers of mine bought Samsung laptops that had mostly usb3 ports.
Those ports did not resume correctly (the driver would timeout communicating
and fail). This led to frustration as suspend/resume is a common use for
laptops.
Poking around, I applied the reset on resume quirk to this chipset and the
resume started working. Reloading the xhci_hcd module had been the temporary
workaround.
Reported-by: Don Zickus <dzickus@redhat.com>
Tested-by: Prarit Bhargava <prarit@redhat.com>
Bug 1456092
Change-Id: I3021247ec68a3c2dddd9e98cde13d70a45191d53
Signed-off-by: Deepak Nibade <dnibade@nvidia.com>
commit a1227f3c1030e96ebc51d677d2f636268845c5fb upstream.
ehci_irq() and ehci_hrtimer_func() can deadlock on ehci->lock when
threadirqs option is used. To prevent the deadlock use
spin_lock_irqsave() in ehci_irq().
This change can be reverted when hrtimer callbacks become threaded.
Signed-off-by: Stanislaw Gruszka <sgruszka@redhat.com>
Let xusb can own ports with any combination.
Bug 1345723
Change-Id: I6532a44150bea1113ebee1483263158fb3c04117
Reviewed-on: http://git-master/r/354888
This is WAR for HW Bug#1320346, PEX partition need
to be unpowergated whenever XUSB is used. Also
powergate it in suspend to save power.
Bug 1451279
Change-Id: I29d6c5182a8b38559911fb3b78d0074f990530f7
Signed-off-by: Jay Agarwal <jagarwal@nvidia.com>
Reviewed-on: http://git-master/r/361864
Set HS_DISCON_LEVEL in xusb padctl register
USB2_BIAS_PAD_CTL_0 from 3'b101 to 3'b111.
Bug 1454282
Change-Id: I48916435e9a142a0674195d8b690c7f8ff376525
Reviewed-on: http://git-master/r/364302
Reviewed-by: Henry Lin <henryl@nvidia.com>
commit feffe09f510c475df082546815f9e4a573f6a233 upstream.
According to Freescale imx28 Errata, "ENGR119653 USB: ARM to USB
register error issue", All USB register write operations must
use the ARM SWP instruction. So, we implement a special ehci_write
for imx28.
Discussion for it at below:
http://marc.info/?l=linux-usb&m=137996395529294&w=2
Without this patcheset, imx28 works unstable at high AHB bus loading.
If the bus loading is not high, the imx28 usb can work well at the most
of time. There is a IC errata for this problem, usually, we consider
IC errata is a problem not a new feature, and this workaround is needed
for that, so we need to add them to stable tree 3.11+.
Cc: robert.hodaszi@digi.com
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de>
Tested-by: Marc Kleine-Budde <mkl@pengutronix.de>
commit 9005355af23856c55a5538c9024355785424821b upstream.
If CONFIG_PCI is enabled, make sure xhci_cleanup_msix()
doesn't try to free a bogus PCI IRQ or dereference an invalid
pci_dev when the xHCI device is actually a platform_device.
This patch should be backported to kernels as old as 3.9, that
contain the commit 52fb61250a7a132b0cfb9f4a1060a1f3c49e5a25
"xhci-plat: Don't enable legacy PCI interrupts."
Signed-off-by: Jack Pham <jackp@codeaurora.org>
Cc: stable@vger.kernel.org
Change-Id: I6601c3db7a0a4f5ebef6c64118eb62a67701c42a
Reviewed-on: http://git-master/r/358200
Reviewed-on: http://git-master/r/361700
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Tested-by: Thomas Cherry <tcherry@nvidia.com>
The function dma_set_mask() tests internally whether the dma_mask pointer
for the device is initialized and fails if the dma_mask pointer is NULL.
On pci platforms, the device dma_mask pointer is initialized, when pci
devices are enumerated, to point to the pci_dev->dma_mask which is 0xffffffff.
However, for non-pci platforms, the dma_mask pointer may not be initialized
and in that case dma_set_mask() will fail.
This patch initializes the dma_mask and the coherent_dma_mask to 32bits
in xhci_plat_probe(), before the call to usb_create_hcd() that sets the
"uses_dma" flag for the usb bus and the call to usb_add_hcd() that creates
coherent dma pools for the usb hcd.
Moreover, a call to dma_set_mask() does not set the device coherent_dma_mask.
Since the xhci-hcd driver calls dma_alloc_coherent() and dma_pool_alloc()
to allocate consistent DMA memory blocks, the coherent DMA address mask
has to be set explicitly.
This patch sets the coherent_dma_mask to 64bits in xhci_gen_setup() when
the xHC is capable for 64-bit DMA addressing.
If dma_set_mask() succeeds, for a given bitmask, it is guaranteed that
the given bitmask is also supported for consistent DMA mappings.
Other changes introduced in this patch are:
- The return value of dma_set_mask() is checked to ensure that the required
dma bitmask conforms with the host system's addressing capabilities.
- The dma_mask setup code for the non-primary hcd was removed since both
primary and non-primary hcd refer to the same generic device whose
dma_mask and coherent_dma_mask are already set during the setup of
the primary hcd.
- The code for reading the HCCPARAMS register to find out the addressing
capabilities of xHC was removed since its value is already cached in
xhci->hccparams.
- hcd->self.controller was replaced with the dev variable since it is
already available.
Change-Id: I4fae4a4c8cd419bb80fcf623da3e6b2a797440f4
Reviewed-on: http://git-master/r/357120
Signed-off-by: Xenia Ragiadakou <burzalodowa@gmail.com>
Reviewed-on: http://git-master/r/361699
Change emc_clk depending on usb devices
connected.
Bug 1402923
Change-Id: I54e63904350344a87d779b2ae0fc53d6c39f0f89
Signed-off-by: Preetham Chandru R <pchandru@nvidia.com>
Reviewed-on: http://git-master/r/350544
currently regulator names are passed as platform data to driver
this has been deprecated and moving reg names to soc config
Bug 1409002
Change-Id: I2f35d5a839e1b8f04ed2ee822c4e69f8a398cfed
Signed-off-by: Krishna Yarlagadda <kyarlagadda@nvidia.com>
Reviewed-on: http://git-master/r/333430
Tested-by: Laxman Dewangan <ldewangan@nvidia.com>
Boost CPU freq only for High-Speed devices as
low-speed deivces do not need to run the CPU at
High freq.
Bug 1431729
Change-Id: I57e3a43459ae950d88c06fcff9577510669cb8c7
Signed-off-by: Rohith Seelaboyina <rseelaboyina@nvidia.com>
Reviewed-on: http://git-master/r/356462
Support for HSIC device power on/off by sending
MBOX_CMD_AIRPLANE_MODE_DISABLED/MBOX_CMD_AIRPLANE_MODE_ENABLED
mailbox message to firmware.
Bug 1390301
Change-Id: If1f314b09fd0887305765cb5bda9c420b11fafa1
Reviewed-on: http://git-master/r/355041
Reviewed-by: Jui Chang Kuo <jckuo@nvidia.com>
enable_irq_wake call moved from probe function to suspend.
Resume function has disable_irq_wake call
Bug 992448
Change-Id: I7612887dd8db274a1994eb0ca1713becba69eca8
Signed-off-by: Suresh Mangipudi <smangipudi@nvidia.com>
Reviewed-on: http://git-master/r/354182
Coverity id : 25406
Bug 1416640
Change-Id: Ib0f6dd43ca12a502cd861e3d7e9e20080d49dd41
Reviewed-on: http://git-master/r/352258
Reviewed-by: Sri Krishna Chowdary <schowdary@nvidia.com>
Reviewed-by: Sumit Singh <sumsingh@nvidia.com>
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Do not perform host initiate resume when we have
resuming_ports flag set. Due to having resuming_ports
set indicate we got a device remote resume event.
Bug 1405568
Change-Id: I5f728a0b94b0d297f30eb2ff4786986353aa0433
Reviewed-on: http://git-master/r/350929
Update HSIC pad tracking circuit programming sequence.
Bring HSIC pad tracking circuit out of power-down mode
and wait for 25 usec. This allow calibration complete.
Then power down again by setting PD_TRX to 1.
Bug 1417885
Change-Id: I9e55c3d59b5674c562ca3d270511ce7f718ce9b3
Reviewed-on: http://git-master/r/337742
The mechanism of getting xusb firmware from bootloader is not supported
now. All of its implementation are removed.
Bug 1419667
Change-Id: I1227e01d08f936617c75e2817e6b2a4adfef2c34
Reviewed-on: http://git-master/r/345665
Reviewed-by: Joy Wang <joyw@nvidia.com>
Change to load xusb firmware from file and also remove unused kernel
options related to xusb firmware loading.
Bug 1419667
Change-Id: I393384eb238fd743fb51b61eda081e2f3103c8de
Reviewed-on: http://git-master/r/338653
On Shield we are disabling the vbus on suspend
and enabling it back on resume. After resume device
gets disconnected and re-enumerated.
Acquire a temporary wakelock on resume to enumerate
the device properly before it goes to LP0.
Bug 1415958
Change-Id: If67e9d8ca96b94161f4757b2f5a031ca82d8cdc7
Reviewed-on: http://git-master/r/343632
(cherry picked from commit 31896a8dd19ee9e16f06478dc3f1ea18614e54b5)
Reviewed-on: http://git-master/r/345648
If xhci driver fails to loading firmware from file during
initialization, it frees all resources it uses and set its
driver data to NULL. But xhci driver doesn't unbind it with
xhci platform device. So, system still calls tegra_xhci_suspend()
during system suspend. And, kernel panic happens when xhci
driver trying to access NULL pointer in system suspend.
Bug 1414486
Change-Id: I7b52ca01508b35f5c9c7523a75318fc3d049122b
Reviewed-on: http://git-master/r/336069
Few regulators are dependant on gpio and might not be
available when xhci loads. Try defer probe to avoid this issue
Bug 1409005
Change-Id: I477fbbc2e0c868f04506fbb3d923bddf32ce4857
Reviewed-on: http://git-master/r/333429
device_remove_file() uses hcd->self.controller, but hcd is
already freed by usb_put_hcd(). This causes kernel panic
when USB device is being removed.
Fix this issue by calling the sysfs_remove_file() before kref_put()
Bug 1409766
Change-Id: I026b9fe193d93bb65c16d454083a270c410e62dc
Signed-off-by: Vinayak Pane <vpane@nvidia.com>
Reviewed-on: http://git-master/r/334154
mutex_destroy to be called when the driver is removed.
BUG 1401358
Change-Id: I43b3a92b06830acc85fd7d218b32d75cb5c34d24
Reviewed-on: http://git-master/r/334848
Update the print message when interrupts occur.
Bug 1395732
Change-Id: I8b9a64d290d20ca888725ec279e761baf1bf80ab
Reviewed-on: http://git-master/r/332821
In dt all constants are considered to be u32 and when read back in
driver we would get msb (which is zero always for a u8). changing
driver to read the value as u32 and then save to u8. this will
ensure proper conversion
Change-Id: I23e5ad3476a2f4eace759560e50eb073cfad9cdd
Reviewed-on: http://git-master/r/330208
Changes to read hsic cofig data from dt and change header
to have all u8 values which simplifies parsing dt
Bug 1342607
Change-Id: I0c547a32a347e561eccd35acc16c824cd105e69c
Reviewed-on: http://git-master/r/330163
While resuming from LP0, ehci getting reset that causes
ip address lost if usb-ethernet dongle is used for
network connection, this is happend because usb-ehci resume
functionality called twice and therefore USB_PORTSC_CCS bit
in register USB_PORTSC get changed, which causes reset command
sent to the utmi.
To maintain uniformity, changes also done in tegra_ehci_suspend.
In the tegra_ehci_probe, unnecessary tried to resume ehci. So,
removing resume functionality while probing ehci.
Bug 1355760
Change-Id: I6b170131704b36e722ed2b8ec2abb770770fd859
Signed-off-by: Jeetesh Burman <jburman@nvidia.com>
To generate USB testmode pattern by accessing usb debugfs. It
need to be enabled with enable "CONFIG_USB_DEBUG" in def_config.
And disable autosuspend by sysfs before test as below:
echo on > /sys/bus/usb/devices/.../power/control
Bug 1323709
Change-Id: I2c9d4cb304435e9d36f11a97a8db2d2ffd582ecf
Signed-off-by: Neil Chen <neilc@nvidia.com>
Reviewed-on: http://git-master/r/303705
cleanup fuse.h inclusion to avoid
build errors
Bug 1380004
Change-Id: I4e91fbca4ffdefe8db118c70f73f71976bb4a599
Signed-off-by: Shardar Shariff Md <smohammed@nvidia.com>
Reviewed-on: http://git-master/r/327681
Reviewed-by: Venu Byravarasu <vbyravarasu@nvidia.com>
Add dt support for xhci driver
Bug 1357627
Change-Id: Ibdaebd8bb68e8000ab6a9e0fbe8de7fe62dc52e0
Reviewed-on: http://git-master/r/301796
Regulators should be enabled only if port is enabled
PMC port and xhci port are different in case of dalmore
Bug 1357627
Change-Id: Ieb0019d9d7b86be1f4616129fd0dd5a7dcff174b
Reviewed-on: http://git-master/r/301793
