path: root/drivers/usb/image/microtek.c
2011-11-18USB: convert drivers/usb/* to use module_usb_driver()Greg Kroah-Hartman
This converts the drivers in drivers/usb/* to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Simon Arlott <cxacru@fire.lp0.eu> Cc: Duncan Sands <duncan.sands@free.fr> Cc: Matthieu CASTET <castet.matthieu@free.fr> Cc: Stanislaw Gruszka <stf_xl@wp.pl> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Oliver Neukum <oliver@neukum.name> Cc: Juergen Stuber <starblue@users.sourceforge.net> Cc: Cesar Miquel <miquel@df.uba.ar> Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Cc: Matthew Wilcox <willy@linux.intel.com> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Lucas De Marchi <lucas.demarchi@profusion.mobi> Cc: Michael Hund <mhund@ld-didactic.de> Cc: Zack Parsons <k3bacon@gmail.com> Cc: Melchior FRANZ <mfranz@aon.at> Cc: Tomoki Sekiyama <tomoki.sekiyama@gmail.com> Cc: Dan Carpenter <error27@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-16SCSI host lock push-downJeff Garzik
Move the mid-layer's ->queuecommand() invocation from being locked with the host lock to being unlocked to facilitate speeding up the critical path for drivers who don't need this lock taken anyway. The patch below presents a simple SCSI host lock push-down as an equivalent transformation. No locking or other behavior should change with this patch. All existing bugs and locking orders are preserved. Additionally, add one parameter to queuecommand, struct Scsi_Host * and remove one parameter from queuecommand, void (*done)(struct scsi_cmnd *) Scsi_Host* is a convenient pointer that most host drivers need anyway, and 'done' is redundant to struct scsi_cmnd->scsi_done. Minimal code disturbance was attempted with this change. Most drivers needed only two one-line modifications for their host lock push-down. Signed-off-by: Jeff Garzik <jgarzik@redhat.com> Acked-by: James Bottomley <James.Bottomley@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10drivers/usb: Remove unnecessary return's from void functionsJoe Perches
Greg prefers this to go through the trivial tree. http://lkml.org/lkml/2010/6/24/1 There are about 2500 void functions in drivers/usb Only a few used return; at end of function. Standardize them a bit. Moved a statement down a line in drivers/usb/host/u132-hcd.c Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-02USB image: make USB device id constantNémeth Márton
The id_table field of the struct usb_device_id is constant in <linux/usb.h> so it is worth to make the initialization data also constant. The semantic match that finds this kind of pattern is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ disable decl_init,const_decl_init; identifier I1, I2, x; @@ struct I1 { ... const struct I2 *x; ... }; @s@ identifier r.I1, y; identifier r.x, E; @@ struct I1 y = { .x = E, }; @c@ identifier r.I2; identifier s.E; @@ const struct I2 E[] = ... ; @depends on !c@ identifier r.I2; identifier s.E; @@ + const struct I2 E[] = ...; // </smpl> Signed-off-by: Németh Márton <nm127@freemail.hu> Cc: Julia Lawall <julia@diku.dk> Cc: cocci@diku.dk Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: remove unneeded printks from microtek driverOliver Neukum
These printks can be removed as they only provide information about the driver not the device and nobody has ever provided feedback. Signed-off-by: Oliver Neukum <oliver@neukum.org>
2009-01-07USB: change interface to usb_lock_device_for_reset()Alan Stern
This patch (as1161) changes the interface to usb_lock_device_for_reset(). The existing interface is apparently not very clear, judging from the fact that several of its callers don't use it correctly. The new interface always returns 0 for success and it always requires the caller to unlock the device afterward. The new routine will not return immediately if it is called while the driver's probe method is running. Instead it will wait until the probe is over and the device has been unlocked. This shouldn't cause any problems; I don't know of any cases where drivers call usb_lock_device_for_reset() during probe. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24usb: replace remaining __PRETTY_FUNCTION__ occurrencesHarvey Harrison
The kernel is written in C, not C++, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: microtek: remove unused semaphoreDaniel Walker
No current references, so removing it. Signed-off-by: Daniel Walker <dwalker@mvista.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28USB: make the microtek driver and HAL cooperateOliver Neukum
to make HAL like the microtek driver's devices the parent must be correctly set. Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-22[SG] Update drivers to use sg helpersJens Axboe
2007-10-12[SCSI] microtek: use data accessors and !use_sg cleanupBoaz Harrosh
- use scsi_cmnd data accessors - Clean the !use_sg code paths Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> [jejb: merge conflict fix] Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-19USB: image: microtek: clean up urb->status usageGreg Kroah-Hartman
This done in anticipation of removal of urb->status, which will make that patch easier to review and apply in the future. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-01usb: microtek possible memleak fixMariusz Kozlowski
Possible memleak fix on error path. The changes: - out_kfree2 and out_free_urb replaced - missing scsi_host_put() added Here it goes: Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-28USB: microtek usb scanner: Scsi_Cmnd conversionHenrik Kretzschmar
Converts obsolete typedef'd Scsi_Cmnd into struct scsi_cmnd. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-06[SCSI] fix up request buffer reference in various scsi driversChristoph Hellwig
Various scsi drivers use scsi_cmnd.buffer and scsi_cmnd.bufflen in their queuecommand functions. Those fields are internal storage for the midlayer only and are used to restore the original payload after request_buffer and request_bufflen have been overwritten for EH. Using the buffer and bufflen fields means they do very broken things in error handling. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-24[PATCH] s/;;/;/gAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] turn "const static" into "static const"Jesper Juhl
ICC likes to complain about storage class not being first, GCC doesn't care much (except for cases like "inline static"). have a hard time seeing how it could break anything. Thanks to Gabriel A. Devenyi for pointing out http://linuxicc.sourceforge.net/ which is what made me create this patch. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-17[PATCH] USB: Adapt microtek driver to new scsi featuresOliver Neukum
the scsi layer now uses very short sg lists. This breaks the microtek driver. Here is a patch fixes this and some other issues. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[SCSI] remove Scsi_Host_Template typedefChristoph Hellwig
2005-10-28[PATCH] USB: microtek patch to use kzallocOliver Neukum
here is another one to use kzalloc. Please apply. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-04-22[PATCH] USB: compilation failure on usb/image/microtek.cHideaki YOSHIFUJI
maybe typo? Signed-off-by: Hideaki YOSHIFUJI <yoshfuji@linux-ipv6.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] kill old EH constants
Fix up two drivers that incorrectly were using the old return values for their new-style EH methods and kill off scsi_obsolete.h that defined the constants. The initio driver has all these constansts defined locally and uses them internally, I'll fix that up some time later. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
