* As submitted by RMC for modem support *
Bug 1054808
Change-Id: Ia3344591b4b56e61857dc4813bb1007807b4c445
Signed-off-by: Raj Jayaraman <rjayaraman@nvidia.com>
Reviewed-on: http://git-master/r/160035
(cherry picked from commit 8931bc3cbf9c9f31a895509985f6cd167dc9d228)
Reviewed-on: http://git-master/r/162295
Reviewed-by: WK Tsai <wtsai@nvidia.com>
Reviewed-by: Steve Lin <stlin@nvidia.com>
For all modules, change <module>-objs to <module>-y; remove
if-statements and replace with lists using the kbuild idiom; move
flags to the top of the file; and fix alignment while trying to
maintain the original scheme in each file.
None of the dependencies are modified.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Felipe Balbi <balbi@ti.com>
Replace EXTRA_CFLAGS with ccflags-y.
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
Meywa-Denki/Kayac YUREX is a leg-shakes sensor device.
See http://bbu.kayac.com/en/about/ for further information.
This driver support read/write the leg-shakes counter in the device
via a device file /dev/yurex[0-9]*.
[minor coding style cleanups fixed by gregkh]
Signed-off-by: Tomoki Sekiyama <tomoki.sekiyama@gmail.com>
Cc: Jiri Kosina <jkosina@suse.cz>
devices and spectrometers
This patch removes the vstusb driver and support from the Linux tree.
This driver provided support for Vernier Software & Technology devices
and spectrometers (Ocean Optics). This driver is being replaced by a
user space - libusb - implementation.
Signed-off-by: Jim Collar <jim.collar@eqware.net>
The Barry project's userspace program, bcharge, can better handle this
device and functionality, and it also works with the latest phones,
which this driver does not support. So remove it, as the userspace code
should be used instead.
Cc: Chris Frey <cdfrey@foursquare.net>
These devices are better controlled with the LGPL userspace library
found at:
http://www.phidgets.com/downloads.php?os_id=3
and full documentation at:
http://www.phidgets.com/documentation/web/cdoc/index.html
Cc: Chester Fitchett <fitchett@phidgets.com>
Acked-by: Sean Young <sean@mess.org>
Technology, Inc.
This patch adds the vstusb driver to the drivers/usb/misc directory.
This driver provides support for Vernier Software & Technology
spectrometers, all made by Ocean Optics. The driver provides both IOCTL
and read()/write() methods for sending raw data to spectrometers across
the bulk channel. Each method allows for a configured timeout.
Signed-off-by: Dennis O'Brien <dennis.obrien@eqware.net>
Added basic support for a Delcom USB 7-segment LED Display
Signed-off by: Harrison Metzger <harrisonmetz@gmail.com>
This patch removes the auerswald USB driver from the linux kernel
2.6.26.
This driver was included into the kernel mainly to connect to the ISDN
framework. This was done in linux 2.4.x. For 2.6.x, due to the fragile
and moving ISDN support, this connection was never realized, and the
only use of this driver was for device configuration. In the age of DSL,
the demand of ISDN support is getting very low.
Meanwhile, with the advent of libusb, an userspace driver was done for
the device configuration which works fine for linux and mac. (Thanks to
the libusb developers!). The userspace driver is downloadable from the
auerswald web site.
So this driver is obsolete now and has to be removed. Many thanks to all
developers which helped me to bring this driver up and working.
Signed-off-by: Wolfgang Muees <wolfgang@iksw-muees.de>
Uninitialised Apple iSight drivers present with a distinctive USB ID.
Once firmware has been uploaded, they disconnect and reconnect with a
new ID. At this point they can be driven by the uvcvideo driver. As this
is unique to the Apple cameras and not functionality shared by any other
UVC devices, it makes sense to provide the firmware loading
functionality in a separate driver. This driver will read an isight.fw
file extracted from the Apple driver using the tools at
http://bersace03.free.fr/ift/ and upload it to the camera. It will also
handle the case where the device loses its firmware during hibernation
and must have it reloaded.
The ioctl is commented out for now, until we verify some userspace
application issues.
Cc: Christian Lucht <lucht@codemercs.com>
Cc: Robert Marquardt <marquardt@codemercs.com>
A simple driver to turn on the charging capability of a USB BlackBerry
device when it is plugged into the machine. It does not bind to the
device, so all userspace programs can still sync properly with it.
Note, if CONFIG_USB_SUSPEND is enabled, it can play havoc with this
device as the power to the port will be shut down. This device id will
have to be added to the global blacklist table when it is created.
We do already have both the code and a config option, so why not build
this driver? ;-)
It's not a input driver, so it doesn't belong in the input directory.
Cc: Sam Hocevar <sam@zoy.org>
Cc: Dmitry Torokhov <dtor@insightbb.com>
This "ftdi-elan" module is one half of the "driver" for
ELAN's Uxxx series adapters which are USB to PCMCIA CardBus
adapters. Currently only the U132 adapter is available and
it's module is called "u132-hcd".
When the USB hot plug subsystem detects a Uxxx series adapter
it should load this module.
Upon a successful device probe() the jtag device file interface
is created and the status workqueue started up.
The jtag device file interface exists for the purpose of
updating the firmware in the Uxxx series adapter, but as
yet it had never been used.
The status workqueue initializes the Uxxx and then sits there
polling the Uxxx until a supported PCMCIA CardBus device is
detected it will start the command and respond workqueues
and then load the module that handles the device. This will
initially be only the u132-hcd module. The status workqueue
then just polls the Uxxx looking for card ejects.
The command and respond workqueues implement a command
sequencer for communicating with the firmware on the other
side of the FTDI chip in the Uxxx. This "ftdi-elan" module
exports some functions to interface with the sequencer.
Note that this module is a USB client driver.
Note that the "u132-hcd" module is a (cut-down OHCI)
host controller.
Thus we have a topology with the parent of a host controller
being a USB client! This really stresses the USB subsystem
semaphore/mutex handling in the module removal.
Signed-off-by: Tony Olech <tony.olech@elandigitalsystems.com>
This patch adds support for Ontrak ADU USB devices.
Fixed for printk issues by Randy Dunlap <rdunlap@xenotime.net>
Signed-off-by: Steven Haigh <netwiz@crc.id.au>
This patch creates a device class phidget and add the phidget drivers to
them.
Signed-off-by: Sean Young <sean@mess.org>
This driver add support for the Phidgets Inc., MotorControl via sysfs. Also
some minor fixes for the InterfaceKit.
tiny things
This is a new driver for the Cypress CY7C63xxx mirco controller series.
It currently supports the pre-programmed CYC63001A-PC by AK Modul-Bus
GmbH. It's based on a kernel 2.4 driver (cyport) by Marcus Maul which I
ported to kernel 2.6 using sysfs. I intend to support more controllers
of this family (and more features) as soon as I get hold of the required
IDs etc. Please see the source code's header for more information.
Signed-off-by: Oliver Bock <o.bock@fh-wolfenbuettel.de>
This is a driver to control the brightness of an Apple Cinema Display over
USB. It updates the local brightness value if the user presses a button on
the display.
Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch>
Cc: Oliver Neukum <oliver@neukum.org>
This lets us remove a lot of code in the drivers that were all checking
the same thing. It also found some bugs in a few of the drivers, which
has been fixed up.
The following driver provides complete interrupt-in and interrupt-out
reports (raw data) to a user program. Until now it uses the
HIDIOCGDEVINFO ioctl call, because I don't know better :-(. Perhaps, it
will be ok for you - and I will be happy, if you assign 8 minor numbers.
I have tested it in several environments and it works very well for me.
However, it has a problem with two or more devices at the same hub, if
the two or more devices need 1 ms interrupt-in transfers. Unfortunately
more than one interrupt-in transfer every ms isn't possible (ehci
driver?). This is why the min_interrupt_in_interval and
min_interrupt_out_interval are increased to 2 ms (see the corresponding
module parameters). This way, I can use two devices simultaneously at
the same hub.
Signed-off-by: Michael Hund <mhund@ld-didactic.de>
infrastructure for it.
Let it rip!
