path: root/drivers/usb/misc/cytherm.c
2007-10-25USB: fix read vs. disconnect race in cytherm driverOliver Neukum
the disconnect method of this driver set intfdata to NULL before removing attribute files. The attributes' read methods will happily follow the NULL pointer. Here's the correct ordering. Signed-off-by : Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2006-09-27USB: fix __must_check warnings in drivers/usb/misc/Greg Kroah-Hartman
2006-03-20[PATCH] USB: kzalloc in cythermOliver Neukum
another one for kzalloc. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-20[PATCH] Driver Core: drivers/usb/input/aiptek.c - ↵Yani Ioannou
drivers/zorro/zorro-sysfs.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
