path: root/drivers/usb/misc/ldusb.c
2009-09-23USB: ldusb should signal an error in poll if the device is disconnectedOliver Neukum
poll() should test for a disconnection of the device. Signed-off-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: remove vernier labpro from ldusbsware
Labpro device is in both ldusb and vstusb device tables. Should only be a vstusb device. Signed-off-by: stephen ware <stephen.ware@eqware.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-14USB: remove PICDEM FS USB demo (04d8:000c) device from ldusbXiaofan Chen
Microchip has changed the PICDEM FS USB demo device (0x04d8:000c) to use bulk transfer and not interrupt transfer. So I've updated the libusb based program here (Post #31). http://forum.microchip.com/tm.aspx?m=106426&mpage=2 So I believe that the in-kernel ldusb driver will no longer work with the demo firmware. It should be removed. Signed-off-by: Xiaofan Chen <xiaofanc@gmail.com> Cc: Michael Hund <MHund@LD-Didactic.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-02usb: ldusb: ld_usb semaphore to mutexDaniel Walker
Signed-off-by: Daniel Walker <dwalker@mvista.com> Acked-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21USB: add new vernier product id to ldusb.cStephen Ware
I have a new ldusb device to go into the device table. Jiri has merged the change for hiddev quirks already. From: Stephen Ware <stephen.ware@eqware.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-19USB: misc: ldusb: clean up urb->status usageGreg Kroah-Hartman
This done in anticipation of removal of urb->status, which will make that patch easier to review and apply in the future. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: prevent char device open/deregister raceAlan Stern
This patch (as908) adds central protection in usbcore for the prototypical race between opening and unregistering a char device. The spinlock used to protect the minor-numbers array is replaced with an rwsem, which can remain locked across a call to a driver's open() method. This guarantees that open() and deregister() will be mutually exclusive. The private locks currently used in several individual drivers for this purpose are no longer necessary, and the patch removes them. The following USB drivers are affected: usblcd, idmouse, auerswald, legousbtower, sisusbvga/sisusb, ldusb, adutux, iowarrior, and usb-skeleton. As a side effect of this change, usb_deregister_dev() must not be called while holding a lock that is acquired by open(). Unfortunately a number of drivers do this, but luckily the solution is simple: call usb_deregister_dev() before acquiring the lock. In addition to these changes (and their consequent code simplifications), the patch fixes a use-after-free bug in adutux and a race between open() and release() in iowarrior. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-22USB: ldusb bugfixOliver Neukum
This patch fixes a problem reported with consecutive reads in the ldusb driver. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: add picdem device to ldusbJoey Goncalves
Hi Greg: I have found that /drivers/usb/misc/ldusb.c works with the "PICDEM Full Speed USB" http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en021940 Signed-off-by: Joey S Goncalves <jgoncalves@peragrin.com> Cc: Michael Hund <MHund@LD-Didactic.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27USB: ldusb: Use usb_endpoint_* functions.Luiz Fernando N. Capitulino
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27USB: Make file operations structs in drivers/usb const.Luiz Fernando N. Capitulino
Making structs const prevents accidental bugs and with the proper debug options they're protected against corruption. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: convert a bunch of USB semaphores to mutexesArjan van de Ven
the patch below converts a bunch of semaphores-used-as-mutex in the USB code to mutexes Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: kzalloc in ldusbOliver Neukum
another one for kzalloc Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-02-13[PATCH] USB: add new device ids to ldusbMichael Hund
Signed-off-by: Michael Hund <mhund@ld-didactic.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-31[PATCH] USB: remove some left over devfs droppings hanging around in the usb ↵Greg Kroah-Hartman
drivers As there is no more usb devfs support, these bits would just confuse people. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB ldusb: fmt warnings fixes for 64-bit platformsAlexey Dobriyan
Fix drivers/usb/misc/ldusb.c: In function `ld_usb_read': drivers/usb/misc/ldusb.c:467: warning: int format, different type arg (arg 4) drivers/usb/misc/ldusb.c: In function `ld_usb_write': drivers/usb/misc/ldusb.c:531: warning: int format, different type arg (arg 4) drivers/usb/misc/ldusb.c:532: warning: int format, different type arg (arg 5) drivers/usb/misc/ldusb.c:532: warning: int format, different type arg (arg 6) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-29[PATCH] USB: ldusb fixesMichael Hund
below you will find the forgotten kmalloc check (sorry). Signed-off-by: Michael Hund <mhund@ld-didactic.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] USB: add ldusb driverMichael Hund
The following driver provides complete interrupt-in and interrupt-out reports (raw data) to a user program. Until now it uses the HIDIOCGDEVINFO ioctl call, because I don't know better :-(. Perhaps, it will be ok for you - and I will be happy, if you assign 8 minor numbers. I have tested it in several environments and it works very well for me. However, it has a problem with two or more devices at the same hub, if the two or more devices need 1 ms interrupt-in transfers. Unfortunately more than one interrupt-in transfer every ms isn't possible (ehci driver?). This is why the min_interrupt_in_interval and min_interrupt_out_interval are increased to 2 ms (see the corresponding module parameters). This way, I can use two devices simultaneously at the same hub. Signed-off-by: Michael Hund <mhund@ld-didactic.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
