commit 236c448cb6e7f82096101e1ace4b77f8b38f82c8 upstream.
Report the number of dropped packets instead of zero
when using the binary usbmon interface with tcpdump.
# tcpdump -i usbmon1 -w dump
tcpdump: listening on usbmon1, link-type USB_LINUX_MMAPPED (USB with padded Linux header), capture size 65535 bytes
^C2155 packets captured
2155 packets received by filter
1019 packets dropped by kernel
Signed-off-by: Johannes Stezenbach <js@sig21.net>
Do not bail out with an error in mon_text_init() if debugfs is not
available, instead just return 0 and let mon_init() go ahead with
loading the binary API. Return -ENOMEM in case debugfs_create_dir()
fails for other reasons. Later, it is enough to check for mon_dir
not set.
Signed-off-by: Tobias Klauser <tklauser@distanz.ch>
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
This is based on a patch that Alan Stern wrote. It did the same simple
thing in both text and binary cases. In the same time, Marton and I
fixed the binary side properly, but this leaves the text to be fixed.
It is not very important due to low maxium data size of text, but
let's add it just for extra correctness.
The pseudocode is too much to keep fixed up, and we have real code
to be used as examples now, so let's drop it too.
* usb-next: (132 commits)
USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path
USB: uas: Ensure we only bind to a UAS interface
USB: uas: Rename sense pipe and sense urb to status pipe and status urb
USB: uas: Use kzalloc instead of kmalloc
USB: uas: Fix up the Sense IU
usb: musb: core: kill unneeded #include's
DA8xx: assign name to MUSB IRQ resource
usb: gadget: g_ncm added
usb: gadget: f_ncm.c added
usb: gadget: u_ether: prepare for NCM
usb: pch_udc: Fix setup transfers with data out
usb: pch_udc: Fix compile error, warnings and checkpatch warnings
usb: add ab8500 usb transceiver driver
USB: gadget: Implement runtime PM for MSM bus glue driver
USB: gadget: Implement runtime PM for ci13xxx gadget
USB: gadget: Add USB controller driver for MSM SoC
USB: gadget: Introduce ci13xxx_udc_driver struct
USB: gadget: Initialize ci13xxx gadget device's coherent DMA mask
USB: gadget: Fix "scheduling while atomic" bugs in ci13xxx_udc
USB: gadget: Separate out PCI bus code from ci13xxx_udc
Usually the usbmon returns the amount of data specified in
urb->transfer_buffer_length for output submissions and urb->actual_length
for input callbacks. However, for Isochronous input transfers, this is
not enough, since the returned data buffer may contain "holes".
One easy way to fix this is to use urb->transfer_buffer_length,
but this often transfers a whole lot of unused data, so we find
how much was actually used instead.
Original patch by Márton Németh. See also kernel bug 22182.
Signed-off-by: Márton Németh <nm127@freemail.hu>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
For all modules, change <module>-objs to <module>-y; remove
if-statements and replace with lists using the kbuild idiom; move
flags to the top of the file; and fix alignment while trying to
maintain the original scheme in each file.
None of the dependencies are modified.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: Sam Ravnborg <sam@ravnborg.org>
Acked-by: Felipe Balbi <balbi@ti.com>
fs/exofs/inode.c
Enlarging the buffer size via the MON_IOCT_RING_SIZE ioctl causes
general protection faults. It appears the culprit is an incorrect
argument to mon_free_buff: instead of passing the size of the current
buffer being freed, the size of the new buffer is passed.
Use the correct size argument to mon_free_buff when changing the size of
the buffer.
Signed-off-by: Steven Robertson <steven@strobe.cc>
Acked-by: Pete Zaitcev <zaitcev@redhat.com>
Cc: stable <stable@kernel.org>
compat_ioctl does not use the BKL, so I assume that
the native function does not need it either.
The open function is already protected by the
driver's mutex, the BKL is probably not needed
here either.
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Pete Zaitcev <zaitcev@redhat.com>
Greg prefers this to go through the trivial tree.
http://lkml.org/lkml/2010/6/24/1
There are about 2500 void functions in drivers/usb
Only a few used return; at end of function.
Standardize them a bit.
Moved a statement down a line in drivers/usb/host/u132-hcd.c
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing
* 'bkl/ioctl' of git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing:
uml: Pushdown the bkl from harddog_kern ioctl
sunrpc: Pushdown the bkl from sunrpc cache ioctl
sunrpc: Pushdown the bkl from ioctl
autofs4: Pushdown the bkl from ioctl
uml: Convert to unlocked_ioctls to remove implicit BKL
ncpfs: BKL ioctl pushdown
coda: Clean-up whitespace problems in pioctl.c
coda: BKL ioctl pushdown
drivers: Push down BKL into various drivers
isdn: Push down BKL into ioctl functions
scsi: Push down BKL into ioctl functions
dvb: Push down BKL into ioctl functions
smbfs: Push down BKL into ioctl function
coda/psdev: Remove BKL from ioctl function
um/mmapper: Remove BKL usage
sn_hwperf: Kill BKL usage
hfsplus: Push down BKL into ioctl function
Change the type of the URB's 'sg' pointer from a usb_sg_request to
a scatterlist. This allows drivers to submit scatter-gather lists
without using the usb_sg_wait() interface. It has the added benefit
of removing the typecasts that were added as part of patch as1368 (and
slightly decreasing the number of pointer dereferences).
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1368) fixes a rather obscure bug in usbmon: When tracing
URBs sent by the scatter-gather library, it accesses the data buffers
while they are still mapped for DMA.
The solution is to move the mapping and unmapping out of the s-g
library and into the usual place in hcd.c. This requires the addition
of new URB flag bits to describe the kind of mapping needed, since we
have to call dma_map_sg() if the HCD supports native scatter-gather
operation and dma_map_page() if it doesn't. The nice thing about
having the new flags is that they simplify the testing for unmapping.
The patch removes the only caller of usb_buffer_[un]map_sg(), so those
functions are #if'ed out. A later patch will remove them entirely.
As a result of this change, urb->sg will be set in situations where
it wasn't set previously. Hence the xhci and whci drivers are
adjusted to test urb->num_sgs instead, which retains its original
meaning and is nonzero only when the HCD has to handle a scatterlist.
Finally, even when a submission error occurs we don't want to hand
URBs to usbmon before they are unmapped. The submission path is
rearranged so that map_urb_for_dma() is called only for non-root-hub
URBs and unmap_urb_for_dma() is called immediately after a submission
error. This simplifies the error handling.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: <stable@kernel.org>
The usbcore headers: hcd.h and hub.h are shared between usbcore,
HCDs and a couple of other drivers (e.g. USBIP modules).
So, it makes sense to move them into a more public location and
to cleanup dependency of those modules on kernel internal headers.
This patch moves hcd.h from drivers/usb/core into include/linux/usb/
Signed-of-by: Eric Lescouet <eric@lescouet.org>
These are the last remaining device drivers using
the ->ioctl file operation in the drivers directory
(except from v4l drivers).
[fweisbec: drop i8k pushdown as it has been done from
procfs pushdown branch already]
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
The code does not implement the comment, so timestamps for long traces
become confusing instead of wrapping neatly as expected. This was actually
observed. Fortunately for API being in debugfs, we can just fix this instead
of staying bug-for-bug compatible. Double fortunately, the stable binary
API is not affected.
Due to a simple oversight when bus zero was added, the text API fails to
deliver the bus number in 'E' messages (which are equivalent of 'C'
messages, only for error case). This makes it harder, for instance,
use a search-and-highlight in a text editor. So fix it.
Also, Alan Stern requested adding timestamps to 'E' messages. This is
purely cosmetic, but makes it easier to read the trace. This is done
for both text and binary APIs.
This patch (as1301) adds support to usbmon for scatter-gather URBs.
The text interface looks at only the first scatterlist element, since
it never copies more than 32 bytes of data anyway. The binary
interface copies as much data as possible up to the first
non-addressable buffer.
CC: Pete Zaitcev <zaitcev@redhat.com>
This patch (as1299b) fixes a bug in an error-handling path of usbmon's
binary interface. The storage area for URB data is divided into
fixed-size blocks. If an URB's data can't be copied, the area
reserved for it should be decreased to the size of the truncated
information (rounded up to a block boundary). Rounding up the amount
to be removed and subtracting it from the reserved size is definitely
the wrong thing to do.
Also, when the data for an isochronous URB can't be copied, we can
still copy the isoc packet descriptors. In fact the current code does
copy the descriptors, but then sets the capture length to 0 so they
remain inaccessible. The capture length should be reduced to the
length of the descriptors, not set to 0.
CC: stable <stable@kernel.org>
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
This patch fixes crashes when usbmon attempts to access GART aperture.
The old code attempted to take a bus address and convert it into a
virtual address, which clearly was impossible on systems with actual
IOMMUs. Let us not persist in this foolishness, and use transfer_buffer
in all cases instead.
I think downsides are negligible. The ones I see are:
- A driver may pass an address of one buffer down as transfer_buffer,
and entirely different entity mapped for DMA, resulting in misleading
output of usbmon. Note, however, that PIO based controllers would
do transfer the same data that usbmon sees here.
- Out of tree drivers may crash usbmon if they store garbage in
transfer_buffer. I inspected the in-tree drivers, and clarified
the documentation in comments.
- Drivers that use get_user_pages will not be possible to monitor.
I only found one driver with this problem (drivers/staging/rspiusb).
- Same happens with with usb_storage transferring from highmem, but
it works fine on 64-bit systems, so I think it's not a concern.
At least we don't crash anymore.
Why didn't we do this in 2.6.10? That's because back in those days
it was popular not to fill in transfer_buffer, so almost all
traffic would be invisible (e.g. all of HID was like that).
But now, the tree is almost 100% PIO friendly, so we can do the
right thing at last.
These statements seem to be unnecessary. No idea why, but I built all
possible configurations and everything gets built just as before.
It's an old patch that popped from discussion with Paul in November 2008.
Obviously not a very high priority but better late than never.
These warnings were observed on MIPS32 using 2.6.31-rc1 and gcc-4.2.0:
mm/page_alloc.c: In function 'alloc_pages_exact':
mm/page_alloc.c:1986: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast
drivers/usb/mon/mon_bin.c: In function 'mon_alloc_buff':
drivers/usb/mon/mon_bin.c:1264: warning: passing argument 1 of 'virt_to_phys' makes pointer from integer without a cast
[akpm@linux-foundation.org: fix kernel/perf_counter.c too]
Signed-off-by: Kevin Cernekee <cernekee@gmail.com>
All usb debugfs files should be behind the usb directory, not at the
root of debugfs.
This patch adds an extension to the binary API so it reaches parity with
existing text API (so-called "1u"). The extension delivers additional data,
such as ISO descriptors and the interrupt interval.
Signed-Off-By: Pete Zaitcev <zaitcev@redhat.com>
Running a 32-bit usbmon(8) on 2.6.28-rc9 produces the following:
ioctl32(usbmon:28563): Unknown cmd fd(3) cmd(400c9206){t:ffffff92;sz:12} arg(ffd3f458) on /dev/usbmon0
It happens because the compatibility mode was implemented for 2.6.18
and not updated for the fsops.compat_ioctl API.
This patch relocates the pieces from under #ifdef CONFIG_COMPAT into
compat_ioctl with no other changes except one new whitespace.
usbmon can only be built as a module if usbcore is a module too. Trivial
changes to the relevant Kconfig and Makefile (and a few trivial changes
elsewhere) allow usbmon to be built as a module even if usbcore is
builtin.
This is verified to work in all 9 permutations (3 correctly prohibited
by Kconfig, 6 build a suitable result).
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
There's a bug in the usbmon binary reader: When using read() to fetch
the packets and a packet's data is partially read, the next read call
will once again return up to len_cap bytes of data. The b_read counter
is not regarded when determining the remaining chunk size.
So, when dumping USB data with "cat /dev/usbmon0 > usbmon.trace" while
reading from a USB storage device and analyzing the dump file
afterwards it will get out of sync after a couple of packets.
Signed-off-by: Ingo van Lil <inguin@gmx.de>
usbmon registers the notifier chain, takes the bus lock and then goes to
scan the existing devices for hooking up.
Unfortunately, if usb_mon gets initialized while USB bus discovery is
going on, it's possible that usbmon gets a notifier on one cpu (which runs
without USB locks), and the scan is going on and also finds the new bus,
resulting in a double sysfs registration, which then produces a WARNING.
Pete Zaitcev did the bug diagnostics on this one
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Now that device_create() has been audited, rename things back to the
original call to be sane.
Kmem cache passed to constructor is only needed for constructors that are
themselves multiplexeres. Nobody uses this "feature", nor does anybody uses
passed kmem cache in non-trivial way, so pass only pointer to object.
Non-trivial places are:
arch/powerpc/mm/init_64.c
arch/powerpc/mm/hugetlbpage.c
This is flag day, yes.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jon Tollefson <kniht@linux.vnet.ibm.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Matt Mackall <mpm@selenic.com>
[akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c]
[akpm@linux-foundation.org: fix mm/slab.c]
[akpm@linux-foundation.org: fix ubifs]
device_create() is race-prone, so use the race-free
device_create_drvdata() instead as device_create() is going away.
Add explicit lock_kernel() calls to mon_bin_open()
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Paolo asked to enable the mmap. I kept it off because I'm do not
entirely understand how it workse these days after ->nopage etc.
But it seems like working somewhat at least.
Signed-Off-By: Pete Zaitcev <zaitcev@gmail.com>
Cc: Paolo Abeni <paolo.abeni@email.it>
Fix the leak of the snap structure allocated in mon_stat_open().
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Convert USB mon driver from nopage to fault.
Signed-off-by: Nick Piggin <npiggin@suse.de>
- make the needlessly global struct mon_fops_binary static
- #if 0 the unused mon_bin_mmap() and related code
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Cc: Greg KH <greg@kroah.com>
Slab constructors currently have a flags parameter that is never used. And
the order of the arguments is opposite to other slab functions. The object
pointer is placed before the kmem_cache pointer.
Convert
ctor(void *object, struct kmem_cache *s, unsigned long flags)
to
ctor(struct kmem_cache *s, void *object)
throughout the kernel
[akpm@linux-foundation.org: coupla fixes]
Signed-off-by: Christoph Lameter <clameter@sgi.com>
This patch (as978) reorganizes the way usbmon uses urb->status. It
now accepts the status value as an argument.
Two things:
- mbus can be NULL (in case of bus removal while reader is reading)
- Remove a useless assignment
Setup packet must be visible in virtual space. There's absolutely no
good reason to implement any kind of zero-copy transfer of 8 bytes, and
the documentation in usb.h is explicit about it. So, drop DMA remapping.
This is a set of small updates to Alan's work to make the code more to
my liking. Mostly premature optimizations, but also direction of control
transfers in the binary interface was always out.
This patch (as949) changes the usbmon driver to use the new urb->ep
field rather than urb->pipe.
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
