Add inline wrappers for device_prep_slave_sg() and device_prep_dma_cyclic()
interfaces to hide new parameter from current users of affected interfaces.
Convert current users to use new wrappers instead of direct calls.
Suggested by Russell King [https://lkml.org/lkml/2012/2/3/269].
Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com>
Signed-off-by: Vinod Koul <vinod.koul@linux.intel.com>
cherry-picked from mainline commit
16052827d98fbc13c31ebad560af4bd53e2b4dd5
Change-Id: I929a49556539621a0546829e88b3caa498c94be2
Reviewed-on: http://git-master/r/94463
commit 772aed45b604c5ff171f0f12c12392d868333f79 upstream.
In musb_init_controller() there's a pm_runtime_put(), but there's no
pm_runtime_get(), which creates a mismatch that causes the driver to
sleep when it shouldn't.
This was introduced in 7acc619[1], but it wasn't triggered in my setup
until 18a2689[2] was merged to Linus' branch at point df0914[3]. IOW;
when PM is working as it was supposed to.
However, it seems most of the time this is used in a way that keeps the
counter above 0, so nobody noticed. Also, it seems to depend on the
configuration used in versions before 3.1, but not later (or in it).
I found the problem by loading isp1704_charger before any usb gadgets:
http://article.gmane.org/gmane.linux.kernel/1226122
All versions after 2.6.39 are affected.
[1] usb: musb: Idle path retention and offmode support for OMAP3
[2] OMAP2+: musb: hwmod adaptation for musb registration
[3] Merge branch 'omap-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6
Cc: Hema HK <hemahk@ti.com>
Signed-off-by: Felipe Contreras <felipe.contreras@gmail.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 5d193ce8f1fa7c67c7fd7be2c03ef31eed344a4f upstream.
Currently the driver tries to save context in the suspend path, but
will cause an abort if the device is already runtime suspended. This
happens, for example, if MUSB loaded/compiled-in, in host mode, but no
USB devices are attached. MUSB will be runtime suspended, but then
attempting a system suspend will crash due to the context save
being attempted while the device is disabled.
On OMAP, as of v3.1, the driver's ->runtime_suspend() callback will be
called late in the suspend path (by the PM domain layer) if the driver
is not already runtime suspended, ensuring a full shutdown.
Therefore, the context save is not needed in the ->suspend() method
since it will be called in the ->runtime_suspend() method anyways
(similarily for resume.)
NOTE: this leaves the suspend/resume methods basically empty (with
some FIXMEs and comments, but I'll leave it to the maintainers
to decide whether to remove them.
Signed-off-by: Kevin Hilman <khilman@ti.com>
In case one "forgot" to load the receiver i.e. doing
|modprobe omap2430
|modprobe musb_hdrc
he ends up with:
|musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
|HS USB OTG: no transceiver configured
|musb-hdrc musb-hdrc: musb_init_controller failed with status -19
|(NULL device *): gadget not registered.
|Unable to handle kernel NULL pointer dereference at virtual address 0000001c
|Internal error: Oops: 17 [#1] SMP
|[<c011383c>] (sysfs_find_dirent+0x4/0x60) from [<c01138c0>] (sysfs_get_dirent+0x28/0x78)
|[<c01138c0>] (sysfs_get_dirent+0x28/0x78) from [<c0115b78>] (sysfs_unmerge_group+0x1c/0x90)
|[<c0115b78>] (sysfs_unmerge_group+0x1c/0x90) from [<c0179ba4>] (dpm_sysfs_remove+0x14/0x3c)
|[<c0179ba4>] (dpm_sysfs_remove+0x14/0x3c) from [<c01742f8>] (device_del+0x40/0x1b4)
|[<c01742f8>] (device_del+0x40/0x1b4) from [<c0174478>] (device_unregister+0xc/0x18)
|[<c0174478>] (device_unregister+0xc/0x18) from [<bf0489b4>] (musb_free+0x24/0x88 [musb_hdrc])
|[<bf0489b4>] (musb_free+0x24/0x88 [musb_hdrc]) from [<bf057d18>] (musb_probe+0xb50/0xe3c [musb_hdrc])
|[<bf057d18>] (musb_probe+0xb50/0xe3c [musb_hdrc]) from [<c01779c4>] (platform_drv_probe+0x1c/0x24)
The problem is that musb_free() tries to figure out what was
initializued and what wasn't and clean up only the initialized part.
This works well for usb_del_gadget_udc() but device_unregister() can't
deal with it. Therefore we rely on the fact the we always have a parent
device and only then remove the device.
I broke this in 0f91349 ("usb: gadget: convert all users to the new udc
infrastructure")
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
After the prefetch/list.h restructure, drivers need to explicitly include
linux/prefetch.h in order to use the prefetch() function. Otherwise, the
current driver fails to build:
drivers/usb/musb/blackfin.c: In function 'musb_write_fifo':
drivers/usb/musb/blackfin.c:43: error: implicit declaration of function
'prefetch'
Signed-off-by: Bob Liu <lliubbo@gmail.com>
earlier commits have broken compilation of
tusb6010 glue layer, fix it.
Replace DBG with dev_dbg and fix invalid access of musb->controller.
With this patch cppi_dma builds successfully.
Cc: <stable@kernel.org>
Signed-off-by: Per Forlin <per.forlin@linaro.org>
ux500_dma.c fail to compile becase DBG has been removed from musb_debug.
Use dev_dbg for all prints.
Cc: stable@vger.kernel.org
Acked-by: Mian Yousaf Kaukab<mian.yousaf.kaukab@stericsson.com>
The dma driver requires both src and dst to be set.
This fix is needed in order to run gadget mass storage.
Patch is verified on snowball.
Acked-by: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com>
an 'unhandled fault' is causes when a gadget driver calls
usb_gadget_connect() while the USB cable isn't plugged into
the OTG port.
the fault is caused by an access to MUSB's memory space
while its clock is turned off due to pm_runtime kicking
in.
in order to fix the fault, we enclose musb_gadget_pullup()
with pm_runtime_get_sync() ... pm_runtime_put() calls to
be sure we will always reach that path with clock turned on.
[ balbi@ti.com : simplified commit log; removed few things
which didn't belong there ]
Cc: stable@kernel.org
Reported-by: Zach Pfeffer <zach.pfeffer@linaro.org>
Signed-off-by: John Stultz <john.stultz@linaro.org>
After 622859634 (usb: musb: drop a gigantic amount of ifdeferry):
- USB_GADGET_MUSB_HDRC is no longer selectable because it
depends on the removed USB_MUSB_PERIPHERAL and USB_MUSB_OTG
options
- The Kconfig comment still says "Enable Host or Gadget support
to see Inventra options", even though you now need to enable
both of them to see Inventra options.
Fix the dependency and drop the anyway unnecessary comment.
Signed-off-by: Rabin Vincent <rabin@rab.in>
CC drivers/usb/musb/tusb6010_omap.o
drivers/usb/musb/tusb6010_omap.c: In function 'tusb_omap_use_shared_dmareq':
drivers/usb/musb/tusb6010_omap.c:92: error: 'musb' undeclared (first use in this function)
drivers/usb/musb/tusb6010_omap.c:92: error: (Each undeclared identifier is reported only once
drivers/usb/musb/tusb6010_omap.c:92: error: for each function it appears in.)
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (115 commits)
EHCI: fix direction handling for interrupt data toggles
USB: serial: add IDs for WinChipHead USB->RS232 adapter
USB: OHCI: fix another regression for NVIDIA controllers
usb: gadget: m66592-udc: add pullup function
usb: gadget: m66592-udc: add function for external controller
usb: gadget: r8a66597-udc: add pullup function
usb: renesas_usbhs: support multi driver
usb: renesas_usbhs: inaccessible pipe is not an error
usb: renesas_usbhs: care buff alignment when dma handler
USB: PL2303: correctly handle baudrates above 115200
usb: r8a66597-hcd: fixup USB_PORT_STAT_C_SUSPEND shift
usb: renesas_usbhs: compile/config are rescued
usb: renesas_usbhs: fixup comment-out
usb: update email address in ohci-sh and r8a66597-hcd
usb: r8a66597-hcd: add function for external controller
EHCI: only power off port if over-current is active
USB: mon: Allow to use usbmon without debugfs
USB: EHCI: go back to using the system clock for QH unlinks
ehci: add pci quirk for Ordissimo and RM Slate 100 too
ehci: refactor pci quirk to use standard dmi_check_system method
Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
Sync with Linus' tree to be able to apply pending patches that
are based on newer code already present upstream.
Restoring the missing INDEX register value in musb_restore_context().
Without this suspend resume functionality is broken with offmode
enabled.
Acked-by: Anand Gadiyar <gadiyar@ti.com>
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
dev_get_drvdata() is exactly the same as
platform_get_drvdata(). Drop that useless
access to the platform device.
udc-core checks for valid callbacks so there is no need for the driver
to do so. Also "can-be-bound-once" is verified by udc-core. The pull-up
callback is called by udc-core afterwords.
[ balbi@ti.com : keep holding gadget_driver pointer for now
remove the stupid check for gadget_driver otherwise
we don't handle IRQs ]
When we start building glue layers as modules,
we need to be careful with the fifo_mode changes
otherwise that weird ifdeferry won't evaluate
correctly. Add the missing _MODULE variants for
all glue layers to prevent everybody from using
fifo_mode 2.
the MUSB IP is always OTG, so there's no point
in adding so many ifdefs on the code. Drop those
and always compile the driver for OTG support.
This also allows us to drop the useless "driver
mode" choice. For doing that, we need to make
musb depend on both Host and Peripheral side.
if we have more endpoints configured than
enabled on fifo_mode, then we need to be
careful on save/restore context operations,
otherwise we will try to access uninitialized
__iomem pointer.
The "channel_program" member was renamed to "adjust_channel_params",
but the documentation wasn't updated.
Reported-by: Sergei Shtylyov <sshtylyov@mvista.com>
peripheral drivers are using usb_add_gadget()/usb_del_gadget() to
register/unregister to the udc-core.
The udc-core will take the first available gadget driver and attach
function driver which is calling usb_gadget_register_driver(). This is
the same behaviour we have right now.
Only dummy_hcd was tested, the others were compiled tested.
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Anton Tikhomirov <av.tikhomirov@samsung.com>
Cc: Ben Dooks <ben-linux@fluff.org>
Cc: Dan Carpenter <error27@gmail.com>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Eric Miao <eric.y.miao@gmail.com>
Cc: Jingoo Han <jg1.han@samsung.com>
Cc: Kukjin Kim <kgene.kim@samsung.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Michael Hennerich <michael.hennerich@analog.com>
Cc: Nicolas Ferre <nicolas.ferre@atmel.com>
Cc: Pavankumar Kondeti <pkondeti@codeaurora.org>
Cc: Roy Huang <roy.huang@analog.com>
Cc: Toshiharu Okada <toshiharu-linux@dsn.okisemi.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Cc: Yoshihiro Shimoda <shimoda.yoshihiro@renesas.com>
Cc: Yuan-Hsin Chen <yhchen@faraday-tech.com>
Cc: cxie4 <cxie4@marvell.com>
Cc: linux-geode@lists.infradead.org
Just tyops.
Fixes mis-use of MUSB's hardware feature where it won't
flush FIFOs when TXPKTRDY flag was set before and we are
flushing setting both FLUSHFIFO and TXPKTRDY.
In other words, we need to ensure that when we try to
flush FIFOs, we don't accidentaly set TXPKTRDY bit too
due to a read-back of the register.
The MUSB Programming Guide says "May be set simultaneously
with TxPktRdy to abort the packet that is currently being
loaded into the FIFO". This is a situation where TXPKTRDY
hasn't been set yet, but some data already loaded into the
fifo. It looks, that if TXPKTRDY has been set before, and
there is no loading in progress, but we set FLUSHFIFO with
the TXPKTRDY, controller tries to use the same logic to
abort loading and as the result just does nothing (because
there is no packet been loaded currently)
Signed-off-by: Yauheni Kaliuta <yauheni.kaliuta@nokia.com>
[ balbi@ti.com : fixed one whitespace git complained about
improved the commit log slightly ]
Variable d is a struct usb_iso_packet_descriptor. The status filed is usually
negative when an error happens.
Signed-off-by: Márton Németh <nm127@freemail.hu>
drivers/usb/musb/musb_core.c: In function 'musb_write_fifo':
drivers/usb/musb/musb_core.c:219: error: implicit declaration of function 'prefetch'
make[3]: *** [drivers/usb/musb/musb_core.o] Error 1
Signed-off-by: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com>
Unaligned sizes and buffers are not supported and they will be filtered
out by is_compatible().
Although U8500 and U5500 platforms use paltform dma, Inventra dma specific code
can work for them for the most part. Only difference is for the Rx path where
this patch is making use of request->short_not_ok to select dma mode.
commit 35a83365da6aa10095c6138cc428c15853409c32
(usb: musb: drop unneeded musb_debug trickery)
introduced a compile error for blackfin and
tusb6010 glue layers. Fix it.
Reported-by: Mike Frysinger <vapier.adi@gmail.com>
Call VBUS pulsing API when there is SRP initiation from user space.
Signed-off-by: Hema HK <hemahk@ti.com>
musb_ep_program() contains obviously duplicate check for 'dma_channel' in its
IN/receive path -- removing it allows to save one level of indentation. While
at it, improve the comment style...
currently that's used by another module
(am35x) which, granted, it shouldn't be
using that, but in order to avoid compile
errors, let's export that symbol temporarily
until re-factoring work is done on that
driver.
This in part reverts commit 7a180e70cfc56e131bfe4796773df2acfc7d4180.
(usb: musb: temporarily make it bool) and while
at that we also allow glue layers to be compiled
as modules.
There are still some other changes needed
until we can have a fully functional build
with this setup, but we're getting there.
We have a generic way of enabling/disabling
different debug messages on a driver called
DYNAMIC_PRINTK. Anyone interested in enabling
just part of the debug messages, please read
the documentation under:
Documentation/dynamic-debug-howto.txt
for information on how to use that great
infrastructure.
This was needed to resolve a conflict in:
drivers/usb/host/isp1760-hcd.c
Commit 3dacdf11 "usb: factor out state_string() on otg drivers"
broke building musb drivers since there is already another
otg_state_string() function in musb drivers, but with different
prototype. Fix musb drivers to use common otg_state_string(), too.
Also provide a nop for otg_state_string() if CONFIG_USB_OTG_UTILS
is not defined.
If cable is not connected to peripheral only board when initializing the
gadget driver, then runtime pm calls are out-of-sync and the musb cannot
idle with omap2430.c. This was noted on Nokia N900 where musb prevented the
CPU to be able to enter deeper retention idle state.
This was working in 2.6.38 before runtime pm conversions but there musb
smart standby/idle modes were configured statically where they are now
updated runtime depending on use and cable status.
Reason for out-of-sync is that runtime pm is activated in function
musb_gadget.c: usb_gadget_probe_driver but suspended only in OTG mode if
cable is not connected when initializing. In peripheral only mode this leads
to out-of-sync runtime pm since runtime pm remain active and is activated
another time in omap2430.c: musb_otg_notifications for VBUS Connect event
and thus cannot suspend for VBUS Disconnect event since the use count remains
active.
Fix this by moving cable status check and pm_runtime_put call in
usb_gadget_probe_driver out of is_otg_enabled block.
Signed-off-by: Jarkko Nikula <jhnikula@gmail.com>
Recent runtime pm and hwmod conversions for 2.6.39 broke the musb peripheral
mode OMAP retention idle on boards where the board mode in struct
musb_hdrc_platform_data is set to MUSB_PERIPHERAL.
These conversions changed the way how the OTG_SYSCONFIG register is
configured and used in runtime. Before 2.6.39 smart standby/idle modes were
activated statically in OTG_SYSCONFIG. Those modes allow that the musb is
able to idle when peripheral device is not connected to host.
In 2.6.39 the OTG_SYSCONFIG is updated runtime depending on VBUS status.
No standby/idle modes are used when device is connected and force
standby/idle when disconnected.
Unfortunately VBUS disconnect event that handles the disconnect case lets
the peripheral musb to idle only when board mode is MUSB_OTG. Fix this by
checking the peripheral mode also.
Fix build failure introduced by commit
7acc6197b76edd0b932a7cbcc6cfad0a8a87f026 (usb: musb: Idle path retention
and offmode support for OMAP3) when building without gadget
support.
CC drivers/usb/musb/omap2430.o
drivers/usb/musb/omap2430.c: In function ‘musb_otg_notifications’:
drivers/usb/musb/omap2430.c:262: error: ‘struct musb’ has no member named ‘gadget_driver’
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Cc: Felipe Balbi <balbi@ti.com>
DMA mode 1 data corruption anomaly on Blackfin systems. This issue is
specific to the Blackfin silicon as the bug appears to be related to the
connection of the musb ip to the bus/dma fabric.
Data corruption when using USB DMA mode 1. (Issue manager 17-01-0105)
DMA mode 1 allows large size transfers to generate a single interrupt
at the end of the entire transfer. The transfer is split up in packets
of length specified in the Maximum Packet Size field for that endpoint.
If the transfer size is not an integer multiple of the Maximum Packet
Size, a short packet will be present at the end of the transfer.
Under certain conditions this packet may be corrupted in the USB FIFO.
Workaround:
Use DMA mode 1 to transfer (n* Maximum Packet Size) and schedule DMA
mode 0 to transfer the short packet.
As an example if your transfer size is 33168 bytes and Maximum Packet
Size equals 512, schedule [33168 - (33168 mod 512)] in DMA mode 1 and
the remainder (33168 mod 512) in DMA mode 0.
Below crash observed with commit 7acc6197b76edd0b932a7cbcc6cfad0a8a87f026
(usb: musb: Idle path retention and offmode support for OMAP3)
during board reboot.
The musb clock was disabled when musb_shutdown() was called by
platform_drv_shutdown in which there are register accesses.
call pm_runtime_get_sync() and pm_runtime_put_sync() in the
musb_shutdown function.
/ # [ 172.368774] Unhandled fault: imprecise external abort (0x1406) at 0x400f0000
[ 172.376190] Internal error: : 1406 [#1] SMP
[ 172.380554] last sysfs file: /sys/devices/platform/omap/omap_i2c.4/i2c-4/i2c-dev/i2c-4/dev
[ 172.389221] Modules linked in:
[ 172.392456] CPU: 0 Tainted: G W (2.6.38-06671-geddecbb #33)
[ 172.399475] PC is at do_raw_spin_unlock+0x50/0xc0
[ 172.404418] LR is at _raw_spin_unlock_irqrestore+0x24/0x44
[ 172.410186] pc : [<c069bfdc>] lr : [<c085a7f8>] psr: 60000093
[ 172.410186] sp : ee993e40 ip : c0d00240 fp : bea9cf14
[ 172.422241] r10: 00000000 r9 : ee992000 r8 : c04b2fa8
[ 172.427703] r7 : 00000000 r6 : c0fa46c0 r5 : ef966124 r4 : ef966124
[ 172.434539] r3 : ef92cbc0 r2 : ef92cbc0 r1 : 00000000 r0 : ef966124
[ 172.441406] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
[ 172.448974] Control: 10c5387d Table: ae8d804a DAC: 00000015
[ 172.454986] Process init (pid: 1094, stack limit = 0xee9922f8)
[ 172.461120] Stack: (0xee993e40 to 0xee994000)
[ 172.465667] 3e40: a0000013 c085a7f8 ef966124 a0000013 c0fa46c0 c0761ab4 c0761a70 ef95c008
[ 172.474273] 3e60: ef95c014 c06e2fd0 c06e2fbc c06dea90 00000000 01234567 28121969 c04fccb4
[ 172.482849] 3e80: 00000000 c04fcd04 c0a302bc c04fce44 c0a02600 00000001 00000000 c085cd04
[ 172.491424] 3ea0: 00000000 00000002 c09ea000 c085afc0 ee993f24 00000000 00040001 00000445
[ 172.499999] 3ec0: a8eb9d34 00000027 00000000 00000000 00000000 c0a56a4c 00000000 00000000
[ 172.508575] 3ee0: 00000002 60000093 00000000 c0519aac 00000002 00000080 00000000 c0550420
[ 172.517150] 3f00: 00000000 00000002 ee970000 c0a56a3c c0a56a20 00000002 c0a56a3c 00000000
[ 172.525726] 3f20: c0a56a3c 0000000a c1580e00 c0a56a20 00000002 c0a56a3c c1580e00 c0a56a20
[ 172.534301] 3f40: ef92cbc0 c05173a0 00000001 ef92cbc0 c0576190 c04e3174 20000013 c0517324
[ 172.542877] 3f60: ef815c00 ee90b720 c04e3174 c0576190 00000001 ef92cbc0 c04b2f00 ffffffff
[ 172.551483] 3f80: 00000058 c0517324 00000000 00000000 ffffffff 00000000 00000000 ffffffff
[ 172.560058] 3fa0: 00000058 c04b2de0 00000000 00000000 fee1dead 28121969 01234567 00000000
[ 172.568634] 3fc0: 00000000 00000000 ffffffff 00000058 00000000 00000001 400aa000 bea9cf14
[ 172.577209] 3fe0: 000ea148 bea9c958 000aa750 40225728 60000010 fee1dead 00000000 00000000
[ 172.585784] [<c069bfdc>] (do_raw_spin_unlock+0x50/0xc0) from [<c085a7f8>] (_raw_spin_unlock_irqrestore+0x24/0x44)
[ 172.596588] [<c085a7f8>] (_raw_spin_unlock_irqrestore+0x24/0x44) from [<c0761ab4>] (musb_shutdown+0x44/0x88)
[ 172.606933] [<c0761ab4>] (musb_shutdown+0x44/0x88) from [<c06e2fd0>] (platform_drv_shutdown+0x14/0x18)
[ 172.616699] [<c06e2fd0>] (platform_drv_shutdown+0x14/0x18) from [<c06dea90>] (device_shutdown+0x74/0xb4)
[ 172.626647] [<c06dea90>] (device_shutdown+0x74/0xb4) from [<c04fccb4>] (kernel_restart_prepare+0x24/0x38)
[ 172.636688] [<c04fccb4>] (kernel_restart_prepare+0x24/0x38) from [<c04fcd04>] (kernel_restart+0xc/0x48)
[ 172.646545] [<c04fcd04>] (kernel_restart+0xc/0x48) from [<c04fce44>] (sys_reboot+0xfc/0x1d8)
[ 172.655426] [<c04fce44>] (sys_reboot+0xfc/0x1d8) from [<c04b2de0>] (ret_fast_syscall+0x0/0x3c)
[ 172.664459] Code: e3c3303f e594200c e593300c e1520003 (0a000002)
[ 172.670867] ------------[ cut here ]------------
We are now using our own list_head, so we should
be checking against that, not the gadget driver's
list_head.
Due to the recent changes to musb's glue layers,
we can't compile musb-hdrc as a module - compilation
will break due to undefined symbol musb_debug. In
order to fix that, we need a big re-work of the
debug support on the MUSB driver.
Because that would mean a lot of new code coming
into the -rc series, it's best to defer that to
next merge window and for now just disable module
support for MUSB.
Once we get the refactor of the debugging support
done, we can simply revert this patch and things
will go back to normal again.
Cc: stable@kernel.org # v2.6.38
"tx_ram" points to io memory. We can't dereference it directly. Sparse
complains about this: "drivers/usb/musb/cppi_dma.c:1205:25: warning:
dereference of noderef expression"
Gcc gives the following warnings:
drivers/usb/musb/cppi_dma.c: In function ‘cppi_next_tx_segment’:
drivers/usb/musb/cppi_dma.c:600: warning: format ‘%x’ expects type ‘unsigned int’, but argument 8 has type ‘dma_addr_t’
drivers/usb/musb/cppi_dma.c: In function ‘cppi_next_rx_segment’:
drivers/usb/musb/cppi_dma.c:822: warning: format ‘%x’ expects type ‘unsigned int’, but argument 9 has type ‘dma_addr_t’
drivers/usb/musb/cppi_dma.c: In function ‘cppi_rx_scan’:
drivers/usb/musb/cppi_dma.c:1042: warning: format ‘%08x’ expects type ‘unsigned int’, but argument 4 has type ‘dma_addr_t’
drivers/usb/musb/cppi_dma.c:1114: warning: format ‘%08x’ expects type ‘unsigned int’, but argument 7 has type ‘dma_addr_t’
dma_addr_t is sometimes 32 bit and sometimes 64. We normally cast them
to unsigned long long for printk().
Sparse complains (and rightly so):
drivers/usb/musb/cppi_dma.c:1458:33:
warning: Using plain integer as NULL pointer
We should unlock before returning here.
musb code checks dma mask before calling dma hooks.
