path: root/drivers/usb/serial/bus.c
2015-02-26USB: serial: clean up bus probe error handlingJohan Hovold
Clean up bus probe error handling by separating success and error paths. Signed-off-by: Johan Hovold <johan@kernel.org>
2015-02-26USB: serial: fix port attribute-creation raceJohan Hovold
Fix attribute-creation race with userspace by using the port device groups field to create the port attributes. Also use %u when printing the port number, which is unsigned, even though we do not currently support more than 128 ports per device. Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Johan Hovold <johan@kernel.org> Acked-by: Greg Kroah-Hartman <greg@kroah.com>
2015-02-26USB: serial: fix tty-device error handling at probeJohan Hovold
Add missing error handling when registering the tty device at port probe. This avoids trying to remove an uninitialised character device when the port device is removed. Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2") Reported-by: Takashi Iwai <tiwai@suse.de> Cc: stable <stable@vger.kernel.org> # v2.6.12 Signed-off-by: Johan Hovold <johan@kernel.org> Acked-by: Greg Kroah-Hartman <greg@kroah.com>
2015-02-26USB: serial: fix potential use-after-free after failed probeJohan Hovold
Fix return value in probe error path, which could end up returning success (0) on errors. This could in turn lead to use-after-free or double free (e.g. in port_remove) when the port device is removed. Fixes: c706ebdfc895 ("USB: usb-serial: call port_probe and port_remove at the right times") Cc: stable <stable@vger.kernel.org> # v2.6.31 Signed-off-by: Johan Hovold <johan@kernel.org> Acked-by: Greg Kroah-Hartman <greg@kroah.com>
2014-05-27USB: serial: fix potential runtime pm imbalance at device removeJohan Hovold
Only call usb_autopm_put_interface() if the corresponding usb_autopm_get_interface() was successful. This prevents a potential runtime PM counter imbalance should usb_autopm_get_interface() fail. Note that the USB PM usage counter is reset when the interface is unbound, but that the runtime PM counter may be left unbalanced. Also add comment on why we don't need to worry about racing resume/suspend on autopm_get failures. Fixes: d5fd650cfc7f ("usb: serial: prevent suspend/resume from racing against probe/remove") Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-01-10usb: core: allow a reference device for new_idWolfram Sang
Often, usb drivers need some driver_info to get a device to work. To have access to driver_info when using new_id, allow to pass a reference vendor:product tuple from which new_id will inherit driver_info. Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-09-03Merge tag 'driver-core-3.12-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core patches from Greg KH: "Here's the big driver core pull request for 3.12-rc1. Lots of tiny changes here fixing up the way sysfs attributes are created, to try to make drivers simpler, and fix a whole class race conditions with creations of device attributes after the device was announced to userspace. All the various pieces are acked by the different subsystem maintainers" * tag 'driver-core-3.12-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (119 commits) firmware loader: fix pending_fw_head list corruption drivers/base/memory.c: introduce help macro to_memory_block dynamic debug: line queries failing due to uninitialized local variable sysfs: sysfs_create_groups returns a value. debugfs: provide debugfs_create_x64() when disabled rbd: convert bus code to use bus_groups firmware: dcdbas: use binary attribute groups sysfs: add sysfs_create/remove_groups for when SYSFS is not enabled driver core: add #include <linux/sysfs.h> to core files. HID: convert bus code to use dev_groups Input: serio: convert bus code to use drv_groups Input: gameport: convert bus code to use drv_groups driver core: firmware: use __ATTR_RW() driver core: core: use DEVICE_ATTR_RO driver core: bus: use DRIVER_ATTR_WO() driver core: create write-only attribute macros for devices and drivers sysfs: create __ATTR_WO() driver-core: platform: convert bus code to use dev_groups workqueue: convert bus code to use dev_groups MEI: convert bus code to use dev_groups ...
2013-08-25USB: serial: clean up attribute permissionsGreg Kroah-Hartman
Clean up the DEVICE_ATTR usage in the USB serial drivers, making them more obvious as to the permissions that the sysfs files should be. Note: ftdi_sio.c still has a DEVICE_ATTR() used, that will have to wait until after 3.12-rc1 comes out when DEVICE_ATTR_WO() shows up in Linus's tree. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-08-23USB: serial: convert bus code to use drv_groupsGreg Kroah-Hartman
The drv_attrs field of struct bus_type is going away soon, drv_groups should be used instead. This converts the USB serial bus code to use the correct field. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-10USB: serial: ports: add minor and port numberGreg Kroah-Hartman
The usb_serial_port structure had the number field, which was the minor number for the port, which almost no one really cared about. They really wanted the number of the port within the device, which you had to subtract from the minor of the parent usb_serial_device structure. To clean this up, provide the real minor number of the port, and the number of the port within the serial device separately, as these numbers might not be related in the future. Bonus is that this cleans up a lot of logic in the drivers, and saves lines overall. Tested-by: Tobias Winter <tobias@linuxdingsda.de> Reviewed-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> -- drivers/staging/serqt_usb2/serqt_usb2.c | 21 +++-------- drivers/usb/serial/ark3116.c | 2 - drivers/usb/serial/bus.c | 6 +-- drivers/usb/serial/console.c | 2 - drivers/usb/serial/cp210x.c | 2 - drivers/usb/serial/cypress_m8.c | 4 +- drivers/usb/serial/digi_acceleport.c | 6 --- drivers/usb/serial/f81232.c | 5 +- drivers/usb/serial/garmin_gps.c | 6 +-- drivers/usb/serial/io_edgeport.c | 58 ++++++++++++-------------------- drivers/usb/serial/io_ti.c | 21 ++++------- drivers/usb/serial/keyspan.c | 29 +++++++--------- drivers/usb/serial/metro-usb.c | 4 +- drivers/usb/serial/mos7720.c | 37 +++++++++----------- drivers/usb/serial/mos7840.c | 52 +++++++++------------------- drivers/usb/serial/opticon.c | 2 - drivers/usb/serial/pl2303.c | 2 - drivers/usb/serial/quatech2.c | 7 +-- drivers/usb/serial/sierra.c | 2 - drivers/usb/serial/ti_usb_3410_5052.c | 10 ++--- drivers/usb/serial/usb-serial.c | 7 ++- drivers/usb/serial/usb_wwan.c | 2 - drivers/usb/serial/whiteheat.c | 20 +++++------ include/linux/usb/serial.h | 6 ++- 24 files changed, 133 insertions(+), 180 deletions(-)
2013-03-25USB: serial: clean up usb-serial bus device removalJohan Hovold
Make sure to unregister the tty-device before calling subdriver port_remove. This way remove will reverse probe, and specifically any port data released in port_remove will be available throughout tty unregister. Note that the order currently does not matter as the tty-layer can make callbacks also after the device has been unregistered. This is handled in usb-serial core using the disconnected flag, which is already set when usb-serial bus device remove is called. Cc: Peter Hurley <peter@hurleysoftware.com> Reported-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21usb-core: remove CONFIG_HOTPLUG ifdefsBill Pemberton
Remove conditional code based on CONFIG_HOTPLUG being false. It's always on now in preparation of it going away as an option. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-10usb: serial: prevent suspend/resume from racing against probe/removeBjørn Mork
Some usb-serial drivers may access port data in their suspend/ resume functions. Such drivers must always verify the validity of the data as both suspend and resume can be called both before usb_serial_device_probe and after usb_serial_device_remove. But the port data may be invalidated during port_probe and port_remove. This patch prevents the race against suspend and resume by disabling suspend while port_probe or port_remove is running. Suggested-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-14USB: add read support to usb-serial/../new_idBjørn Mork
Keep the usb-serial support for dynamic IDs in sync with the usb support. This enables readout of dynamic device IDs for usb-serial drivers. Common code is exported from the usb core system and reused by the usb-serial bus driver. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-09USB: fix bug in serial driver unregistrationAlan Stern
This patch (as1536) fixes a bug in the USB serial core. Unloading and reloading a serial driver while a serial device is plugged in causes errors because of the code in usb_serial_disconnect() that tries to make sure the port_remove method is called. With the new order of driver registration introduced in the 3.4 kernel, this is definitely not the right thing to do (if indeed it ever was). The patch removes that whole section code, along with the mechanism for keeping track of each port's registration state, which is no longer needed. The driver core can handle all that stuff for us. Note: This has been tested only with one or two USB serial drivers. In theory, other drivers might still run into trouble. But if they do, it will be the fault of the drivers, not of this patch -- that is, the drivers will need to be fixed. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Reported-and-tested-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-06-15USB: usb-serial: call port_probe and port_remove at the right timesAlan Stern
This patch (as1253) prevents the usb-serial core from calling a driver's port_probe and port_remove methods more than once per port. It also removes some unnecessary try_module_get() calls and adds a missing port_remove method call in a failure path. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-22usb-serial-bus: tidy coding styleAlan Cox
Tidy up Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-12usb-serial: show port number in sysfsRoman Kagan
Some usb-serial devices (e.g. certain Edgeport models) have more than one serial port on the same USB device/interface. Currently the only way to distinguish these ports in userspace is by their minor device number: the driver makes them consecutive and in stable order. However, for the purpose of stable naming with udev this is insufficient: when udev handles the ADD event for one of the ports it doesn't know what minor number the other one has. To make stable naming easier, export the port number via sysfs. Signed-off-by: Roman Kagan <rkagan@sw.ru> Signed-off-by: Dmitry Guryanov <dimak@dgap.mipt.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11USB: drivers/usb/serial/bus.c: Fix incompatible pointer type warningSatyam Sharma
drivers/usb/serial/bus.c: In function usb_serial_bus_deregister: drivers/usb/serial/bus.c:185: warning: passing argument 1 of free_dynids from incompatible pointer type Above build warning comes when CONFIG_HOTPLUG=n because argument of free_dynids() in serial/bus.c is a struct usb_serial_driver, not a struct usb_driver. This is not a runtime bug, because the function is an empty stub and never dereferences the passed pointer anyway. Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB serial: add dynamic id support to usb-serial coreGreg Kroah-Hartman
Thanks to Johannes Hölzl <johannes.hoelzl@gmx.de> for fixing a few things and getting it all working properly. This adds support for dynamic usb ids to the usb serial core. The file "new_id" will show up under the usb serial driver, not the usb driver associated with the usb-serial driver (yeah, it can be a bit confusing at first glance...) This patch also modifies the USB core to allow the usb-serial core to reuse much of the dynamic id logic. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Johannes Hölzl <johannes.hoelzl@gmx.de>
2006-07-12[PATCH] USB: move usb-serial.h to include/linux/usb/Greg Kroah-Hartman
USB serial outside of the kernel tree can not build properly due to usb-serial.h being buried down in the source tree. This patch moves the location of the file to include/linux/usb and fixes up all of the usb serial drivers to handle the move properly. Cc: Sergei Organov <osv@javad.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-13[PATCH] Add usb_serial_bus_type probe and remove methodsRussell King
Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB Serial: move name to driver structureGreg Kroah-Hartman
This fixes up a lot of problems in sysfs with some of the usb serial drivers, they had incorrect driver names. Also saves a tiny ammount of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB Serial: get rid of the .owner field in usb_serial_driverGreg Kroah-Hartman
Don't duplicate something that's already in struct driver. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB Serial: rename usb_serial_device_type to usb_serial_driverGreg Kroah-Hartman
I'm tired of trying to explain why a "device_type" is really a driver. This better describes exactly what this structure is. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
