path: root/drivers/usb/serial/ftdi_sio.h
2009-08-07USB: ftdi_sio: add product_id for Marvell OpenRD Base, ClientDhaval Vasa
reference: http://www.open-rd.org Signed-off-by: Dhaval Vasa <dhaval.vasa@einfochips.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-08-07USB: ftdi_sio: add vendor and product id for Bayer glucose meter serial ↵Marko Hänninen
converter cable Attached patch adds USB vendor and product IDs for Bayer's USB to serial converter cable used by Bayer blood glucose meters. It seems to be a FT232RL based device and works without any problem with ftdi_sio driver when this patch is applied. See: http://winglucofacts.com/cables/ Signed-off-by: Marko Hänninen <bugitus@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-28USB: ftdi_sio: Add support for GN Otometrics Aurical USB AudiometerVille Sundberg
The patch adds support for the GN Otometrics Aurical USB Audiometer (FT232BM-based). A new VID and a new PID is added. Signed-off-by: Ville Sundberg <vsundber@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB serial: Add ID for Turtelizer, an FT2232L-based JTAG/RS-232 adapter.Krzysztof Halasa
Adds USB ID for Turtelizer, an FT2232L-based JTAG/RS-232 adapter. Signed-off-by: Krzysztof Ha³asa <khc@pm.waw.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: ftdi: support NDI devicesMartin Geleynse
It enhances the driver for FTDI-based USB serial adapters to recognize and support Northern Digital Inc (NDI) measurement equipment. NDI has been providing this patch for various kernel flavors for several years and we would like to see these changes built in to the driver so that our equipement works without the need for customers to patch the kernel themselves. The patch makes small modifications to 2 files: ./drivers/usb/serial/ftdi_sio.c and ./drivers/usb/serial/ftdi_sio.h. It accomplishes 3 things: 1. Define the VID and PIDs to allow the driver to recognize the NDI devices. 2. Map the 19200 baud rate setting to our higher baud rate of 1.2Mb We would have chosen to map 38400 to the higher rate, similar to what several other vendors have done, but some of our legacy customers actually use 38400, therefore we remap 19200 to the higher rate. 3. We set the default transmit latency in the FTDI chip to 1ms for our devices. Our devices are typically polled at 60Hz and the default ftdi latency seriously affects turn-around time and results in missed data frames. We have created a modprobe option that allows this setting to be increased. This has proven necessary particularly in some virtualized environments. Signed-off-by: Martin P. Geleynse <mgeleyns@ndigital.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: serial: FTDI with product code FB80 and vendor id 0403Folkert van Heusden
It seems an USB device with vendor id 0403 and product code FB80 has an FTDI serial io chip as well: http://ftdichip.com/Drivers/D2XX.htm This device in fact is a true random generantor by comsci: http://comscire.com/Products/R2000KU/ So the following patch should add support for this device if I am correct. Not tested as I do not own this device (I would like support in the kernel so that my entropybroker application (which distributes entrop data (random values) between servers and clients)). From: Folkert van Heusden <folkert@vanheusden.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-12USB: ftdi_sio - product ID's for CCS PIC programmersJan Capek
The product ID's for the following devices have been added: - LOAD-n-GO - ICD-U64 - PRIME-8 Signed-off-by: Jan Capek <jan@ccsinfo.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: serial: FTDI: add high speed device supportMark Adamson
Added support for FTDI's USB 2.0 hi-speed devices - FT2232H (2 interfaces) and FT4232H (4 interfaces), including a new baud rate calculation for these devices which can now achieve up to 12Mbaud by turning off a divide by 2.5 in the baud rate generator of the chips. In order to achieve baud rates of <1200 baud, the divide by 2.5 must be active. The default product ID of the FT2232H is 0x6010 (same as the FT2232C IC). The default PID of the FT4232H is 0x6011. Signed-off-by: Mark J. Adamson <mark.adamson@ftdichip.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-15USB: FTDI-SIO new device idsDaniel Suchy
I would like to have added new device to usbserial/ftdi_sio driver. These ids used USB track device (http://www.l-and-b.dk/access_alt.html). They use differend device IDs, but it works as standard usb-serial conventer. From: Daniel Suchy <danny@danysek.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-08USB: ftdi_sio: add vendor/product id for the Marvell SheevaPlugNicolas Pitre
For reference: http://www.marvell.com/products/embedded_processors/developer/kirkwood/sheevaplug.jsp Signed-off-by: Nicolas Pitre <nico@marvell.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-17USB: ftdi_sio: add vendor/project id for JETI specbos 1201 spectrometerPeter Korsgaard
Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-17USB: serial: ftdi: enable UART detection on gnICE JTAG adaptors blacklist ↵Michael Hennerich
interface0 Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-17USB: serial: add FTDI USB/Serial converter devicesAxel Wachtler
Add the following devices to the USB FTDI SIO device table: Bus 001 Device 009: ID 03eb:2109 Atmel Corp. http://www.atmel.com/dyn/products/tools_card.asp?tool_id=4187 Bus 001 Device 008: ID 1cf1:0001 http://www.dresden-elektronik.de/shop/prod75.html Bus 001 Device 007: ID 1c1f:0004 http://www.dresden-elektronik.de/shop/prod64.html Signed-off-by: Axel Wachtler <axel.wachtler@atmel.com> Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-02-09USB: ftdi_sio: add support for the NDI Polaris systemStephane Clerambault
Add support for the NDI Polaris system *http://www.ndigital.com/). Cc: Ian Abbott <abbotti@mev.co.uk> Cc: Oliver Neukum <oneukum@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: ftdi_sio driver support of bar code scanner from DieboldMhayk Whandson
Added the product id of bcs(bar code scanner) from Diebold Procomp Brazil. Signed-off-by: Mhayk Whandson <eu@mhayk.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-27USB: ftdi_sio: added Alti-2 VID and Neptune 3 PIDRobie Basak
This patch adds the vendor and product ID for the Alti-2 Neptune 3 (http://www.alti-2.com) which uses the FTDI chip. Signed-off-by: Robie Basak <rb-oss-1@justgohome.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-17USB: ftdi_sio: Adding Ewert Energy System's CANdapter PIDAndrew Ewert
The following patch adds in the USB PID for Ewert Energy System's CANdapter device (CANBUS to USB-Serial which uses the FTDI 245R chipset) to the ftdi_sio device driver. The patch was tested successfully on Linux kernel 2.6.27 under Ubuntu. Relevant output from /proc/bus/usb/devices (With patch installed): T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1 P: Vendor=0403 ProdID=9f80 Rev= 6.00 S: Manufacturer=Ewert Energy Systems S: Product=CANdapter S: SerialNumber=A6RGB3Z3 C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr= 90mA I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms Signed-off-by: Andrew Ewert <andrew@ewertenergy.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-17USB: tty: SprogII DCC controller identifiersAlan Cox
Someone on rmweb reminded me this had been overlooked from ages ago.. Add the identifiers for the Sprog II USB. This is a DCC control interface using the FTDI-SIO hardware: http://www.sprog-dcc.co.uk/. People have been using it with insmod options for ages, this just puts it into the driver data. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: Add Oceanic product ID to ftdi_sioVladimir Vukicevic
Add Oceanic PID to ftdi_sio driver Oceanic dive computers (such as the VT3 -- http://www.oceanicworldwide.com/p_computers_vt3.html) all use an onboard FTDI serial converter, with the FTDI vid and a PID of 0xf460. The attached patch adds that pid to ftdi_sio; driver connects to my VT3 after that. Signed-off-by: Vladimir Vukicevic <vladimir@pobox.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23usb: ftdi_sio: add support for Domintell devicesGaetan Carlier
Support for Domintell devices (FTDI FT232BM based) : DGQG and DUSB01 module. PIDs were missing. Signed-off-by: Gaetan Carlier <gcpatch@gmail.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Ian Abbott <abbotti@mev.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-23USB: ftdi_sio: Add 0x5050/0x0900 USB IDs (Papouch Quido USB 4/4)Jaroslav Kysela
USB: ftdi_sio: Add 0x5050/0x0900 USB IDs (Papouch Quido USB 4/4) Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB: ftdi_sio: add support for PHI Fisco data cable (FT232BM based, VID/PID ↵Lex Ross
0403:e40b) Support for PHI Fisco USB to Serial data cable (FTDI FT232BM based). PHI Fisco cable is supplied for connecting Philips Xenium 9@9++ mobile phones. PIDs were missing. Tested successfully with PHI Fisco Data Cable (VID/PID 0403:e40b) Signed-off-by: Lex V. Ross <lross@mail.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB: ftdi_sio: add support for Luminance Stellaris Evaluation/Development KitsFrederik Kriewitz
The Patch adds support for Luminance Stellaris Evaluation/Development Kits (FTDI 2232C based). The PIDs were missing. Successfully tested with a Stellaris LM3S8962 Evaluation kit. Signed-off-by: Frederik Kriewitz <frederik@kriewitz.eu> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB: ftdi_sio: Add USB Product Id for ELV HS485André Schenk
USB product id registration for the ELV HS485 USB adapter (www.elv.de) to their home automation bus system. Applies to 2.6.26. Signed-off-by: Andre Schenk <andre@melior.s.bawue.de> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-22ftdi_sio: Coding styleAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-03USB: New device ID for ftdi_sio driverJon K Hellan
Here's a new device ID for the ftdio_sio driver. The diff is with linus's tree as of this morning. The device is the RigExpert Tiny USB Soundcard Transceiver Interface for ham radio. (I didn't actually test this. A fellow ham couldn't get the device to work, and I suggested binding the device ID using sysfs - see "http://jk.ufisa.uninett.no/usb/". However, he had had moved on to other things by then. I guess adding the device ID to the kernel "on spec" won't hurt. The relevant part of cat /proc/bus/usb/devices shows: T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1 P: Vendor=0403 ProdID=ed22 Rev= 5.00 S: Manufacturer=FTDI S: Product=MixW RigExpert Tiny S: SerialNumber=00000000 C:* #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=100mA I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none) E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms E: Ad=04(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms ) From: Jon K Hellan <hellan@acm.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-29USB: FTDI_SIO : Add support for Matrix Orbital PID RangeRay Molenkamp
This patch adds support for the range of PIDs that have been allocated for FTDI based devices at Matrix Orbital. A small number of units have been shipped early 2008 with a faulty USB Descriptor. Products that may have this issue have been marked with the existing quirk to work around the problem. Signed-off-by: R. Molenkamp <rmolenkamp@matrixorbital.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-20usb-serial: Use ftdi_sio driver for RATOC REX-USB60FAtsushi Nemoto
This patch reverts 57833ea6b95a3995149f1f6d1a8d8862ab7a0ba2 ("usb-serial: pl2303: add support for RATOC REX-USB60F") and adds support for the device to ftdi_sio driver. Cc: Akira Tsukamoto <akirat@rd.scei.sony.co.jp> Cc: stable <stable@kernel.org> Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-05-02USB: add more FTDI device idsPeter Mack
Add more usb device ids to the ftdi driver. From: Peter Mack <Peter.Mack@scs-ptc.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10USB: new ftdi_sio device idMirko Bordignon
Here is a patch that adds support for the propox jtagcable II dongle (http://www.propox.com/products/t_117.html): their PID was missing, therefore we were not able to have the device recognized though it uses a standard FTDI chip. Signed-off-by: Mirko Bordignon <mirko.bordignon@ieee.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-04USB: ftdi_sio: Workaround for broken Matrix Orbital serial portKevin Vance
Workaround for the FT232RL-based, Matrix Orbital VK204-25-USB serial port added to the ftdi_sio driver. The device has an invalid endpoint descriptor, which must be modified before it can be used. Signed-off-by: Kevin Vance <kvance@kvance.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: ftdi_sio: Support for more JTAG adaptorsHarald Welte
[PATCH] ftdi_sio: add support for more FTDI based JTAG adaptors There are more devices similar to the Olimex JTAG adaptor, in that the first port of the FT2232C is used for JTAG, and only the second port is available as UART. I have thus renamed ftdi_olimex_{probe,quirk} to ftdi_jtag_{probe,quirk} and added vendor/product ID's for the OpenMoko Neo1973 Debug Board as well as the OOCDlink device. I've also updated the KERN_INFO message sent to userspace to remove the word 'olimex' and an extra '\n' that was causing an empty line in dmesg. Signed-off-by: Harald Welte <laforge@openmoko.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: ftdi driver - add support for optical probe deviceEd Beroset
Added support for the Elster Unicom III Optical Probe. The device ID has already been added to the usb.ids file. Cc: stable <stable@kernel.org> Signed-off-by: Ed Beroset <beroset@mindspring.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: ftdi-sio: Patch to add vendor/device id for ATK_16IC CCDFranco Lanza
little patches only to add vendor/device id of ATK_16IC CCD cam for astronomy. From: Franco Lanza <nextime@nexlab.it> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: ftdi_sio - enabling multiple ELV devices, adding EM1010PCPeter Stark
I work with a group of people on a free home automation tool called FHEM. Some of the users own more than one USB-serial device by ELV. The ftdi_sio driver has most of the ELV devices disabled by default and needs to be re-enabled every time you get a new kernel. Additionally a new device (EM 1010 PC - enegry monitor) is missing in the list. Currently our users have to follow the instructions we provide at http://www.koeniglich.de/fhem/linux.html ... However, to some users it is too complicated to compile their own kernel module. We are aware that you can specify one additional device using the vendor/product option of the module. But lot's of users own more than one device. Cc: stable <stable@kernel.org> Signed-off-by: Peter Stark <peter.stark@t-online.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-09-11USB: ftdi_sio: add of a new product/manufacturer, TMLPierre Castella
I have added to a new product based on the FTDI 232R USB/Serial transceiver, which is commercialized by The Mobility Lab. Here is a trivial patch enclosed, against 2.6.22.6 kernel. Signed-off-by: Pierre Castella <pp.castella@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22USB: Support for the Evolution Scorpion robotsSøren Hauberg
The attached (mostly trivial) patches adds support for the Evolution Scorpion Robots. Evolution Robotics supplies a patch against 2.6.8 with their software. My patch is based on their work, so I don't know if I can sign it off, or if you need some Evolution people to do this (which might be hard). The patch adds device ID's for some robots which is trivial. From: Søren Hauberg <hauberg@gmail.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Søren
2007-06-25USB: ftdio_sio: New IPlus device IDLuiz Fernando N. Capitulino
Reported by Grzegorz Chimosz <gchimi@gmail.com> Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-22USB: Add support for Olimex arm-usb-ocd JTAG interface serial portTony Lindgren
This patch adds support for the serial port on Olimex arm-usb-ocd JTAG interface. The device appears as two serial ports, but the first one is reserved for the JTAG interface. The JTAG interface can be used with OpenOCD from userspace. For more information, please see: http://openocd.berlios.de/web/ http://www.olimex.com/dev/arm-usb-ocd.html Signed-off-by: Tony Lindgren <tony@atomide.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-22USB: ftdi_sio: Add USB Product Id for OpenDCCGuido Scholz
USB product id registration for the OpenDCC (www.opendcc.de) model railway central unit. Applies to 2.6.21.1. Signed-off-by: Guido Scholz <guido.scholz@bayernline.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-22USB: New device PID for ftdi_sio driverNeil \"Superna\" ARMSTRONG
Hello, I need to use MaxStream's PKG-U modules which includes a ftdi sio chipset for usb2serial communication, here are the patches for handling Maxstream's modules. The VID & PID to use with the open-source driver are provided on the CD-ROM bundled with the modules. From: Neil Superna ARMSTRONG <superna@na-prod.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: ftdi_sio: Add USB ID of ADSTech USBX-707Jelle Foks
This patch adds the USB ID of the ADS Tech USBX-707 USB IR blaster (that comes with the ADS Tech PTV-305 grabber card), which has a ftdi232bm inside hooked up to a pic. With this it should be fairly straightforward to make at least lirc receiving work with this device. I will submit a patch to lirc for that as soon as I have one ready, I'm getting data with minicom with this patch, but need to figure out some more details such as best/correct baudrate. Signed-off-by: Jelle Foks <jelle@foks.8m.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09USB: Product ID for FT232RL in ftdi_sioGard Spreemann
Here is a patch adding the PID for the FT232RL to ftdi_sio. The patch generates a warning during compilation because get_ftdi_divisor doesn't explicitly handle the FT232RL with this patch, so I guess you don't want to use it in its current state. It is all I could come up with with the knowledge I have of the drivers at the moment, though, and I hope you can have some use for it at least. It works fine with my DLP-TILT with an FT232RL. From: Gard Spreemann <spreeman@stud.ntnu.no> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09USB: add Additional PIDs in ftdi_sioThomas Schleusener
I've developed some devices with FTDI chips (FT232xx). FTDI was so kind to give some own PID's which I can use together with their VID. Some of the devices are already very popular here and I have customers from universities, institutes ..... I use the FTDI VID 0x0403. My PID's are: 0xff38 - IBS US485 (USB<-->RS422/485 interface) 0xff39 - IBS PIC-Programmer 0xff3a - IBS Card reader for PCMCIA SRAM-cards 0xff3b - IBS PK1 - Particel counter 0xff3c - IBS RS232 - Monitor 0xff3d - APP 70 (dust monitoring system) 0xff3e - IBS PEDO-Modem (RF modem 868.35 MHz) 0xff3f - future device The company is "IBS Ing.-Buero Schleusener". From: Thomas Schleusener <thomas@be-schl.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-09USB: add QL355P power supply ids to fdti_sioMichael Olberg
2007-02-23USB: ftdi_sio: Adding VID and PID for TellstickMicke Prag
I would like to add the VID and PID for Telldus Technologies Homeautomation usb-dongle to the ftdi_sio driver. From: Micke Prag <micke.prag@telldus.se> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: remove duplicate device id from ftdi_sioGreg Kroah-Hartman
As pointed out by Kay Sievers <kay.sievers@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20USB: ftdi_sio - MachX product ID addedJan Capek
below is a patch for the ftdi_sio driver to include a new device ID for CCS MachX PIC programmer. From: Jan Capek <jan@ccsinfo.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-16USB: ftdi driver pid for dmx-interfacesFrank Sievertsen
Please add a usb pid to the ftdi_sio driver. The pid is used by dmx4all dmx-interfaces (for stage lighting). The interfaces are using the usb-id 0403:c850. I added the id to the driver and it works perfectly. I added a patch for linux 2.6.18.1, too. From: Frank Sievertsen <frank@sievertsen.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
