commit 28fe2eb0162a1d23370dd99ff7d0e35632b1ee91 upstream.
Add the USB Vendor ID and Product ID for a Acton Research Corp.
spectrograph device with a FTDI chip for serial I/O.
Signed-off-by: Michael H Williamson <michael.h.williamson@gmail.com>
commit 6ec2f46c4b4abf48c88c0ae7c476f347b97e1105 upstream.
on ST Micro Connect Lite we have 4 port
Part A and B for the JTAG
Port C Uart
Port D for PIO
commit a9d61bc49188e32d2ae9cf0f683cde3e1744feef upstream.
I found the original patch on the db0fhn repeater wiki (couldn't find the email
of the origial author) I guess it was never commited.
I updated and added some Icom HAM-radio devices to the ftdi driver.
Added extra comments to make clear what devices it are.
Signed-off-by: Pieter Maes <maescool@gmail.com>
commit 5363cdc3c5da9bd431552cf5989ab481596f0c6d upstream.
Add FTDI PID to identify D.O.Tec devices correctly.
Signed-off-by: Florian Faber <faberman@linuxproaudio.org>
commit 6fdbad8021151a9e93af8159a6232c8f26415c09 upstream.
Add the PID for the Vardaan Enterprises VEUSB422R3 USB to RS422/485
converter. It uses the same chip as the FTDI_8U232AM_PID 0x6001.
This should also work with the stable branches for:
2.6.31, 2.6.32, 2.6.33, 2.6.34, 2.6.35, 2.6.36
Signed-off-by: Jacques Viviers <jacques.viviers@gmail.com>
commit 28942bb6a9dd4e2ed793675e515cfb8297ed355b upstream.
Another variant of the RT Systems programming cable for ham radios.
Signed-off-by: Michael Stuermer <ms@mallorn.de>
commit 7fea0f714ffb3f303d4b66933af2df2f5584c9bf upstream.
Add the USB IDs for the Milkymist One FTDI-based JTAG/serial adapter
(http://projects.qi-hardware.com/index.php/p/mmone-jtag-serial-cable/)
to the ftdi_sio driver and disable the first serial channel (used as
JTAG from userspace).
Signed-off-by: Sebastien Bourdeauducq <sebastien@milkymist.org>
commit 0f266abd70cd83571eca019f764b5f1992da7361 upstream.
This adds the requested device ids to the ftdi_sio driver.
Reported-by: Ewan Bingham <ewan@auc.co.uk>
Cc: Kuba Ober <kuba@mareimbrium.org>
commit 59c6ccd9f9aecfa59c99ceba6d4d34b180547a05 upstream.
This patch for FTDI USB serial driver ads new VID/PIDs used on various
devices manufactured by Papouch (http://www.papouch.com). These devices
have their own VID/PID, although they're using standard FTDI chip. In
ftdi_sio.c, I also made small cleanup to have declarations for all
Papouch devices together.
Signed-off-by: Daniel Suchy <danny@danysek.cz>
commit 99c1e4f89d1033444ce4d0c064bd2826e81c3775 upstream.
The OpenDCC project is developing a new hardware. This patch adds its
PID to the list of known FTDI devices. The PID can be found at
http://www.opendcc.de/elektronik/usb/opendcc_usb.html
Signed-off-by: Rainer Keller <mail@rainerkeller.de>
commit 3126d8236ca6f68eb8292c6af22c2e59afbeef24 upstream.
Adds support for Accesio USB to Serial adapters, which are built around
FTDI FT232 UARTs. Tested with the Accesio USB-COM-4SM.
Signed-off-by: Rich Mattes <richmattes@gmail.com>
commit 657373883417b2618023fd4135d251ba06a2c30a upstream.
Added the 0xDAF8 to 0xDAFF PID range for ChamSys limited USB interface/wing products
Signed-off-by: Luke Lowrey <luke@chamsys.co.uk>
commit ea233f805537f5da16c2b34d85b6c5cf88a0f9aa upstream.
Add ftdi product ID for Lenz LI-USB, a model train interface. This
was NOT tested against 2.6.35, but a similar patch was tested with the
CentOS 2.6.18-194.11.1.el5 kernel. It wasn't clear to me what
ordering is being used in ftdi_sio.c, so I inserted the ID after another
model train entry(SPROG_II).
Signed-off-by: Galen Seitz <galens@seitzassoc.com>
commit 666cc076d284e32d11bfc5ea2fbfc50434cff051 upstream.
Add the ID for the Ionics PlugComputer (<http://ionicsplug.com/>).
Signed-off-by: Martin Michlmayr <tbm@cyrius.com>
commit b6180ef7c99574c3350bbffa2a3a9d675321543d upstream.
This patch is to add a US Interface, Inc. "Navigator" USB device.
Specifically, it's a HAM Radio USB sound modem that also
incorporates three pairs of unique FTDI serial ports. The standard
Linux FTDI serial driver will only recognize the first two serial
ports of an unknown FDTI derived device and this patch adds in
recognition to these specific new IDs.
Signed-off-by: David A. Ranch <dranch@trinnet.net>
commit afad19648f70c6493193e0a774bd754b7790b4a0 upstream.
I have added the ProductID=0xe729 VendorID=FTDI_VID=0x0403 which will
enable support for the Segway Robotic Mobility Platform (RMP200) in the
ftdi_sio kernel module. Currently, users of the Segway RMP200 must use
a RUN+="/sbin/modprobe -q ftdi-sio product=0xe729 vendor=0x0403 in a
udev rule to get the ftdi_sio module to handle the usb interface and
mount it on /dev/ttyXXX. This is not a good solution because some users
will have multiple USB to Serial converters which will use the ftdi_sio
module.
Signed-off-by: John Rogers <jgrogers@gmail.com>
commit fcc6cb789c77ffee31710eec64efeb25f2124f7a upstream.
RT Systems has put out bunch of ham radio cables based on the FT232RL
chip. Each cable type has a unique PID, this adds one for the Yaesu VX-7
radios.
Signed-off-by: Corey Minyard <minyard@acm.org>
commit 77dbd74e16b566e9d5eeb4be18ae3ee7d5902bd3 upstream.
ftdi_sio: support for Signalyzer tools based on FTDI chips
This patch adds support for the Xverve Signalyzers.
Signed-off-by: Colin Leitner <colin.leitner@googlemail.com>
commit dee5658b482e9e2ac7d6205dc876fc11d4008138 upstream.
This is a patch to ftdi_sio_ids.h and ftdi_sio.c that adds identifiers for
CONTEC USB serial converter. I tested it with the device COM-1(USB)H
[akpm@linux-foundation.org: keep the VIDs sorted a bit]
Signed-off-by: Daniel Sangorrin <daniel.sangorrin@gmail.com>
Cc: Andreas Mohr <andi@lisas.de>
Cc: Radek Liboska <liboska@uochb.cas.cz>
commit 46b72d78cb022714c89a9ebc00b9581b550cfca7 upstream.
identifiers for CONTEC USB serial converter. I tested it
commit 9714080d20f2ec4b671a06ce69367d91fa9e227e upstream.
PID patch for my products
Signed-off-by: Mitchell Solomon <mitchjs@rush2112.net>
commit 65e1ec6751b3eefee6d94161185e78736366126f upstream.
- add FTDI device IDs for several ELV devices and NXTCam of Lego Mindstorms NXT
- add hopefully helpful new_id comment
- remove less helpful "Due to many user requests for multiple ELV devices we enable
them by default." comment (we simply add _all_ known devices - an
enduser shouldn't have to fiddle with obscure module parameters...).
- add myself to DRIVER_AUTHOR
The missing NXTCam ID has been found at
http://www.unixboard.de/vb3/showthread.php?t=44155
, ELV devices taken from ELV Windows .inf file.
Signed-off-by: Andreas Mohr <andi@lisas.de>
commit a7787e508acb4378d62f4584bae3dd1cd0ba3eac upstream.
added new device pid (PAPOUCH_AD4USB_PID) to ftdi_sio.h and ftdi_sio.c
AD4USB measuring converter is a 4-input A/D converter which enables the
user to measure to four current inputs ranging from 0(4) to 20 mA or
voltage between 0 and 10 V. The measured values are then transferred to
a superior system in digital form. The AD4USB communicates via USB.
Powered is also via USB. datasheet in english is here:
http://www.papouch.com/shop/scripts/pdf/ad4usb_en.pdf
Signed-off-by: Radek Liboska <liboska@uochb.cas.cz>
commit 4e092d110fe931db3878865db185be1c9df3e182 upstream.
This is a (almost) sort-only patch to sort FTDI device
product ID definitions in new ftdi_sio_ids.h header.
Advantage is that new device ID submissions will now have a specific (sorted)
position - less future merge conflicts.
Compile-tested, based on _current_ mainline git.
Minor checkpatch.pl warnings were eliminated whereever it made sense,
very minor text changes.
commit 31844d55800e1b93fe75c4d6188a4a44db2e1bbe upstream.
This is a strictly move-only patch to relocate all FTDI device
product ID definitions to their own ftdi_sio_ids.h header
(following the usual *_ids.h kernel tree convention, too),
thus correcting the slightly too messy appearance
(crucial driver defines were stuck somewhere in the decaying middle swamp
of the huge existing header).
Compile-tested, based on latest mainline git.
