commit 3c0e25d883d06a1fbd1ad35257e8abaa57befb37 upstream.
Make sure to detect short control-message transfers and log an error
when reading incomplete manufacturer and boot descriptors.
Note that the default all-zero descriptors will now be used after a
short transfer is detected instead of partially initialised ones.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit e4457d9798adb96272468e93da663de9bd0a4198 upstream.
Use a dedicated buffer for the DMA transfer and make sure to detect
short transfers to avoid parsing a corrupt descriptor.
Fixes: 6e8cf7751f9f ("USB: add EPIC support to the io_edgeport driver")
commit 0dd408425eb21ddf26a692b3c8044c9e7d1a7948 upstream.
Fix NULL-pointer dereference when initialising URBs at open should a
non-EPIC device lack a bulk-in or interrupt-in endpoint.
Unable to handle kernel NULL pointer dereference at virtual address 00000028
PC is at edge_open+0x24c/0x3e8 [io_edgeport]
Note that the EPIC-device probe path has the required sanity checks so
this makes those checks partially redundant.
commit c8d62957d450cc1a22ce3242908709fe367ddc8e upstream.
URBs and buffers allocated in attach for Epic devices would never be
deallocated in case of a later probe error (e.g. failure to allocate
minor numbers) as disconnect is then never called.
Fix by moving deallocation to release and making sure that the
URBs are first unlinked.
Fixes: f9c99bb8b3a1 ("USB: usb-serial: replace shutdown with disconnect,
release")
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit c5c0c55598cefc826d6cfb0a417eeaee3631715c upstream.
Private data, URBs and buffers allocated for Epic devices during
attach were never released on errors (e.g. missing endpoints).
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
Remove redundant error messages on allocation failures, which have
already been logged.
Cc: Joe Perches <joe@perches.com>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
Remove redundant ioctl debugging from subdrivers. The ioctl request code
has already been logged by usb-serial core.
Remove unused timeout defines.
This moves the allocation of minor device numbers from a static array to
be dynamic, using the idr interface. This means that you could
potentially get "gaps" in a minor number range for a single USB serial
device with multiple ports, but all should still work properly.
We remove the 'minor' field from the usb_serial structure, as it no
longer makes any sense for it (use the field in the usb_serial_port
structure if you really want to know this number), and take the fact
that we were overloading a number in this field to determine if we had
initialized the minor numbers or not, and just use a flag variable
instead.
Note, we still have the limitation of 255 USB to serial devices in the
system, as that is all we are registering with the TTY layer at this
point in time.
Tested-by: Tobias Winter <tobias@linuxdingsda.de>
Reviewed-by: Johan Hovold <jhovold@gmail.com>
The usb_serial_port structure had the number field, which was the minor
number for the port, which almost no one really cared about. They
really wanted the number of the port within the device, which you had to
subtract from the minor of the parent usb_serial_device structure. To
clean this up, provide the real minor number of the port, and the number
of the port within the serial device separately, as these numbers might
not be related in the future.
Bonus is that this cleans up a lot of logic in the drivers, and saves
lines overall.
drivers/staging/serqt_usb2/serqt_usb2.c | 21 +++--------
drivers/usb/serial/ark3116.c | 2 -
drivers/usb/serial/bus.c | 6 +--
drivers/usb/serial/console.c | 2 -
drivers/usb/serial/cp210x.c | 2 -
drivers/usb/serial/cypress_m8.c | 4 +-
drivers/usb/serial/digi_acceleport.c | 6 ---
drivers/usb/serial/f81232.c | 5 +-
drivers/usb/serial/garmin_gps.c | 6 +--
drivers/usb/serial/io_edgeport.c | 58 ++++++++++++--------------------
drivers/usb/serial/io_ti.c | 21 ++++-------
drivers/usb/serial/keyspan.c | 29 +++++++---------
drivers/usb/serial/metro-usb.c | 4 +-
drivers/usb/serial/mos7720.c | 37 +++++++++-----------
drivers/usb/serial/mos7840.c | 52 +++++++++-------------------
drivers/usb/serial/opticon.c | 2 -
drivers/usb/serial/pl2303.c | 2 -
drivers/usb/serial/quatech2.c | 7 +--
drivers/usb/serial/sierra.c | 2 -
drivers/usb/serial/ti_usb_3410_5052.c | 10 ++---
drivers/usb/serial/usb-serial.c | 7 ++-
drivers/usb/serial/usb_wwan.c | 2 -
drivers/usb/serial/whiteheat.c | 20 +++++------
include/linux/usb/serial.h | 6 ++-
24 files changed, 133 insertions(+), 180 deletions(-)
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB patches from Greg Kroah-Hartman:
"Here's the big USB pull request for 3.10-rc1.
Lots of USB patches here, the majority being USB gadget changes and
USB-serial driver cleanups, the rest being ARM build fixes / cleanups,
and individual driver updates. We also finally got some chipidea
fixes, which have been delayed for a number of kernel releases, as the
maintainer has now reappeared.
All of these have been in linux-next for a while"
* tag 'usb-3.10-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (568 commits)
USB: ehci-msm: USB_MSM_OTG needs USB_PHY
USB: OHCI: avoid conflicting platform drivers
USB: OMAP: ISP1301 needs USB_PHY
USB: lpc32xx: ISP1301 needs USB_PHY
USB: ftdi_sio: enable two UART ports on ST Microconnect Lite
usb: phy: tegra: don't call into tegra-ehci directly
usb: phy: phy core cannot yet be a module
USB: Fix initconst in ehci driver
usb-storage: CY7C68300A chips do not support Cypress ATACB
USB: serial: option: Added support Olivetti Olicard 145
USB: ftdi_sio: correct ST Micro Connect Lite PIDs
ARM: mxs_defconfig: add CONFIG_USB_PHY
ARM: imx_v6_v7_defconfig: add CONFIG_USB_PHY
usb: phy: remove exported function from __init section
usb: gadget: zero: put function instances on unbind
usb: gadget: f_sourcesink.c: correct a copy-paste misnomer
usb: gadget: cdc2: fix error return code in cdc_do_config()
usb: gadget: multi: fix error return code in rndis_do_config()
usb: gadget: f_obex: fix error return code in obex_bind()
USB: storage: convert to use module_usb_driver()
We need the fixes here as well.
Switch to the generic TIOCMIWAIT implementation.
This also fixes the issue with processes waiting for
modem-status-changes not being woken up at disconnect.
Switch to the generic get_icount implementation.
Note that the interrupt counters will no longer be reset at open which
is in accordance with which how the other drivers work.
Use the port wait queue and make sure to check the serial disconnected
flag before accessing private port data after waking up.
This is is needed as the private port data (including the wait queue
itself) can be gone when waking up after a disconnect.
Cc: stable <stable@vger.kernel.org>
It allows for cleaning up on a considerable amount of places. They did
port_get, wakeup, kref_put. Now the only thing needed is to call
tty_port_tty_wakeup which does exactly that.
One exception is ifx6x60 where tty_wakeup was open-coded. We now call
tty_wakeup properly there.
Now, we start converting tty buffer functions to actually use
tty_port. This will allow us to get rid of the need of tty in many
call sites. Only tty_port will needed and hence no more
tty_port_tty_get in those paths.
Now, the one where most of tty_port_tty_get gets removed:
tty_flip_buffer_push.
IOW we also closed all the races in drivers not using tty_port_tty_get
at all yet.
Also we move tty_flip_buffer_push declaration from include/linux/tty.h
to include/linux/tty_flip.h to all others while we are changing it
anyway.
tty_insert_flip_string this time.
Remove all MODULE_VERSION macros and driver-version information (except
for garmin_gps which uses it in a status reply).
It is the kernel version that matters and not some private version
scheme which rarely even gets updated.
Fix port-data memory leak by moving port data allocation and
deallocation to port_probe and port_remove.
Since commit 0998d0631001288 (device-core: Ensure drvdata = NULL when no
driver is bound) the port private data is no longer freed at release as
it is no longer accessible.
Compile-only tested.
Cc: <stable@vger.kernel.org>
Pull USB changes from Greg Kroah-Hartman:
"Here is the big USB pull request for 3.7-rc1
There are lots of gadget driver changes (including copying a bunch of
files into the drivers/staging/ccg/ directory so that the other gadget
drivers can be fixed up properly without breaking that driver), and we
remove the old obsolete ub.c driver from the tree.
There are also the usual XHCI set of updates, and other various driver
changes and updates. We also are trying hard to remove the old dbg()
macro, but the final bits of that removal will be coming in through
the networking tree before we can delete it for good.
All of these patches have been in the linux-next tree.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
Fix up several annoying - but fairly mindless - conflicts due to the
termios structure having moved into the tty device, and often clashing
with dbg -> dev_dbg conversion.
* tag 'usb-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (339 commits)
USB: ezusb: move ezusb.c from drivers/usb/serial to drivers/usb/misc
USB: uas: fix gcc warning
USB: uas: fix locking
USB: Fix race condition when removing host controllers
USB: uas: add locking
USB: uas: fix abort
USB: uas: remove aborted field, replace with status bit.
USB: uas: fix task management
USB: uas: keep track of command urbs
xhci: Intel Panther Point BEI quirk.
powerpc/usb: remove checking PHY_CLK_VALID for UTMI PHY
USB: ftdi_sio: add TIAO USB Multi-Protocol Adapter (TUMPA) support
Revert "usb : Add sysfs files to control port power."
USB: serial: remove vizzini driver
usb: host: xhci: Fix Null pointer dereferencing with 71c731a for non-x86 systems
Increase XHCI suspend timeout to 16ms
USB: ohci-at91: fix null pointer in ohci_hcd_at91_overcurrent_irq
USB: sierra_ms: don't keep unused variable
fsl/usb: Add support for USB controller version 2.4
USB: qcaux: add Pantech vendor class match
Now that all usb-serial modules are only using dev_dbg()
the debug module parameter does not do anything at all, so
remove it to reduce any confusion if someone were to try to
use it.
CC: Johan Hovold <jhovold@gmail.com>
CC: Rusty Russell <rusty@rustcorp.com.au>
CC: Alan Stern <stern@rowland.harvard.edu>
CC: Mauro Carvalho Chehab <mchehab@redhat.com>
We should use dev_dbg() for usb_serial_debug_data() like all of the rest
of the usb-serial drivers use, so remove the debug parameter as it's not
needed.
dbg() was a very old USB-serial-specific macro.
This patch removes it from being used in the
driver and uses dev_dbg() instead.
Cc: Johan Hovold <jhovold@gmail.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
This will let us sort out a whole pile of tty related races. The
alternative would be to keep points and refcount the termios objects.
However
1. They are tiny anyway
2. Many devices don't use the stored copies
3. We can remove a pty special case
Signed-off-by: Alan Cox <alan@linux.intel.com>
This reworks the usb_serial_register_drivers() and
usb_serial_deregister_drivers() to not need a pointer to a struct
usb_driver anymore. The usb_driver structure is now created dynamically
and registered and unregistered as needed.
This saves lines of code in each usb-serial driver. All in-kernel users
of these functions were also fixed up at this time. The pl2303 driver
was tested that everything worked properly.
Thanks for the idea to do this from Alan Stern.
Cc: Adhir Ramjiawan <adhirramjiawan0@gmail.com>
Cc: Al Borchers <alborchers@steinerpoint.com>
Cc: Aleksey Babahin <tamerlan311@gmail.com>
Cc: Andrew Worsley <amworsley@gmail.com>
Cc: Bart Hartgers <bart.hartgers@gmail.com>
Cc: Bill Pemberton <wfp5p@virginia.edu>
Cc: Dan Carpenter <error27@gmail.com>
Cc: Dan Williams <dcbw@redhat.com>
Cc: Donald Lee <donald@asix.com.tw>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Gary Brubaker <xavyer@ix.netcom.com>
Cc: Jesper Juhl <jj@chaosbits.net>
Cc: Jiri Kosina <jkosina@suse.cz>
Cc: Julia Lawall <julia@diku.dk>
Cc: Kautuk Consul <consul.kautuk@gmail.com>
Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Cc: Lonnie Mendez <dignome@gmail.com>
Cc: Matthias Bruestle and Harald Welte <support@reiner-sct.com>
Cc: Matthias Urlichs <smurf@smurf.noris.de>
Cc: Mauro Carvalho Chehab <mchehab@redhat.com>
Cc: Michal Sroczynski <msroczyn@gmail.com>
Cc: "Michał Wróbel" <michal.wrobel@flytronic.pl>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: Paul Gortmaker <paul.gortmaker@windriver.com>
Cc: Peter Berger <pberger@brimson.com>
Cc: Preston Fick <preston.fick@silabs.com>
Cc: "Rafael J. Wysocki" <rjw@sisk.pl>
Cc: Rigbert Hamisch <rigbert@gmx.de>
Cc: Simon Arlott <simon@fire.lp0.eu>
Cc: Support Department <support@connecttech.com>
Cc: Thomas Tuttle <ttuttle@chromium.org>
Cc: Uwe Bonnes <bon@elektron.ikp.physik.tu-darmstadt.de>
Cc: Wang YanQing <Udknight@gmail.com>
Cc: William Greathouse <wgreathouse@smva.com>
This converts the io_edgeport.c driver to use the module_usb_serial_driver() call
instead of having to have a module_init/module_exit function, saving a lot
of duplicated code.
CC: Huzaifa Sidhpurwala <huzaifas@redhat.com>
CC: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
This patch (as1525) modifies the following usb-serial drivers to
utilize the new usb_serial_{de}register_drivers() routines:
io_edgeport, io_ti, ipaq, ipw, ir-usb, and iuu_phoenix.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Use dev_err_console in write paths for devices which can be used as a
console but do not use the generic write implementation.
module_param(bool) used to counter-intuitively take an int. In
fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy
trick.
It's time to remove the int/unsigned int option. For this version
it'll simply give a warning, but it'll break next kernel version.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Remove unnecessary reinitialisations of urb->dev before each submission,
which were based on the (no longer valid) assumption that serial->dev
will be set to NULL on close.
Now ${LINUX}/drivers/usb/* can use usb_endpoint_maxp(desc) to get maximum packet size
instead of le16_to_cpu(desc->wMaxPacketSize).
This patch fix it up
Cc: Armin Fuerst <fuerst@in.tum.de>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Johannes Erdfelt <johannes@erdfelt.com>
Cc: Vojtech Pavlik <vojtech@suse.cz>
Cc: David Kubicek <dave@awk.cz>
Cc: Brad Hards <bhards@bigpond.net.au>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Thomas Dahlmann <dahlmann.thomas@arcor.de>
Cc: David Brownell <david-b@pacbell.net>
Cc: David Lopo <dlopo@chipidea.mips.com>
Cc: Michal Nazarewicz <m.nazarewicz@samsung.com>
Cc: Xie Xiaobo <X.Xie@freescale.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Jiang Bo <tanya.jiang@freescale.com>
Cc: Yuan-hsin Chen <yhchen@faraday-tech.com>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: OKI SEMICONDUCTOR, <toshiharu-linux@dsn.okisemi.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Ben Dooks <ben@simtec.co.uk>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Herbert Pötzl <herbert@13thfloor.at>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Roman Weissgaerber <weissg@vienna.at>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: Florian Floe Echtler <echtler@fs.tum.de>
Cc: Christian Lucht <lucht@codemercs.com>
Cc: Juergen Stuber <starblue@sourceforge.net>
Cc: Georges Toth <g.toth@e-biz.lu>
Cc: Bill Ryder <bryder@sgi.com>
Cc: Kuba Ober <kuba@mareimbrium.org>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits)
pch_uart: reference clock on CM-iTC
pch_phub: add new device ML7213
n_gsm: fix UIH control byte : P bit should be 0
n_gsm: add a documentation
serial: msm_serial_hs: Add MSM high speed UART driver
tty_audit: fix tty_audit_add_data live lock on audit disabled
tty: move cd1865.h to drivers/staging/tty/
Staging: tty: fix build with epca.c driver
pcmcia: synclink_cs: fix prototype for mgslpc_ioctl()
Staging: generic_serial: fix double locking bug
nozomi: don't use flush_scheduled_work()
tty/serial: Relax the device_type restriction from of_serial
MAINTAINERS: Update HVC file patterns
tty: phase out of ioctl file pointer for tty3270 as well
tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile
pch_uart: Fix DMA channel miss-setting issue.
pch_uart: fix exclusive access issue
pch_uart: fix auto flow control miss-setting issue
pch_uart: fix uart clock setting issue
pch_uart : Use dev_xxx not pr_xxx
Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied
twice, then changes to the same area in one branch)
timeout variable is not used anywhere in int write_cmd_usb, remove it
Signed-off-by: Huzaifa Sidhpurwala <huzaifas@redhat.com>
This was to resolve a merge issue with drivers/char/Makefile and
drivers/tty/serial/68328serial.c
We don't use it so we can trim it from here as we try and stamp the file
object dependencies out of the serial code.
Doing tiocmget was such fun we should do tiocmset as well for the same
reasons
We don't actually need this and it causes problems for internal use of
this functionality. Currently there is a single use of the FILE * pointer.
That is the serial core which uses it to check tty_hung_up_p. However if
that is true then IO_ERROR is also already set so the check may be removed.
The major and minor number saved in the product_info structure
were copied from the address instead of the data, causing an
inconsistency in the reported versions during firmware loading:
usb 4-1: firmware: requesting edgeport/down.fw
/usr/src/linux/drivers/usb/serial/io_edgeport.c: downloading firmware version (930) 1.16.4
/usr/src/linux/drivers/usb/serial/io_edgeport.c: edge_startup - time 3 4328191260
/usr/src/linux/drivers/usb/serial/io_edgeport.c: FirmwareMajorVersion 0.0.4
This can cause some confusion whether firmware loaded successfully
or not.
Cc: stable@kernel.org
Signed-off-by: Bjørn Mork <bjorn@mork.no>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
Update broken web addresses in arch directory.
Update broken web addresses in the kernel.
Revert "drivers/usb: Remove unnecessary return's from void functions" for musb gadget
Revert "Fix typo: configuation => configuration" partially
ida: document IDA_BITMAP_LONGS calculation
ext2: fix a typo on comment in ext2/inode.c
drivers/scsi: Remove unnecessary casts of private_data
drivers/s390: Remove unnecessary casts of private_data
net/sunrpc/rpc_pipe.c: Remove unnecessary casts of private_data
drivers/infiniband: Remove unnecessary casts of private_data
drivers/gpu/drm: Remove unnecessary casts of private_data
kernel/pm_qos_params.c: Remove unnecessary casts of private_data
fs/ecryptfs: Remove unnecessary casts of private_data
fs/seq_file.c: Remove unnecessary casts of private_data
arm: uengine.c: remove C99 comments
arm: scoop.c: remove C99 comments
Fix typo configue => configure in comments
Fix typo interrest[ing|ed] => interest[ing|ed]
Fix various typos of valid in comments
Fix up trivial conflicts in:
drivers/char/ipmi/ipmi_si_intf.c
drivers/usb/gadget/rndis.c
net/irda/irnet/irnet_ppp.c
Simple pasting job using the new ops function. Also fix a couple of devices
directly returning the internal struct (which happens at this point to match
for the fields that matter but isn't correct or futureproof)
Greg prefers this to go through the trivial tree.
http://lkml.org/lkml/2010/6/24/1
There are about 2500 void functions in drivers/usb
Only a few used return; at end of function.
Standardize them a bit.
Moved a statement down a line in drivers/usb/host/u132-hcd.c
Use kzalloc rather than the combination of kmalloc and memset.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression x,size,flags;
statement S;
-x = kmalloc(size,flags);
+x = kzalloc(size,flags);
if (x == NULL) S
-memset(x, 0, size);
// </smpl>
We have lots of callers that do not need to do this in the first place.
Remove the calls as they both cost CPU and for big buffers can mess up the
multi-page allocation avoidance.
#define dbg adds the newline, messages shouldn't.
Converted dbg("%s", "some string") to dbg("some string")
Johan Hovold points out that get_string() is basically just a
re-implimentation of usb_string(). It is also buggy. It does DMA on
the stack and it doesn't handle negative returns from
usb_get_descriptor(). Plus unicode_to_ascii() is a rubbish function and
moving to usb_string() avoids using it.
Let's eliminate get_string() entirely.
Reported-by: Johan Hovold <jhovold@gmail.com>
Acked-by: Johan Hovold <jhovold@gmail.com>
The original code was passing a stack variable as a dma buffer, so I
made it an allocated variable. Instead of adding a bunch of kfree()
calls, I changed all the error return paths to gotos.
Also I noticed that the error checking wasn't correct because
usb_get_descriptor() can return negative values.
While I was at it, I made an unrelated white space change by moving
the unicode_to_ascii() on to one line.
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
