path: root/drivers/usb/serial/opticon.c
2013-03-25USB: opticon: remove disconnect test from tiocmsetJohan Hovold
Remove unnecessary disconnect test in tiocmset. No ioctls will be made after disconnect returns. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-25USB: opticon: fix return value of tiocmsetJohan Hovold
Make sure we return 0 or a negative error number appropriate for userspace on errors. Currently 1 rather than 0 is returned on successful operation. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_flip_buffer_pushJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. Now, the one where most of tty_port_tty_get gets removed: tty_flip_buffer_push. IOW we also closed all the races in drivers not using tty_port_tty_get at all yet. Also we move tty_flip_buffer_push declaration from include/linux/tty.h to include/linux/tty_flip.h to all others while we are changing it anyway. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15TTY: switch tty_insert_flip_stringJiri Slaby
Now, we start converting tty buffer functions to actually use tty_port. This will allow us to get rid of the need of tty in many call sites. Only tty_port will needed and hence no more tty_port_tty_get in those paths. tty_insert_flip_string this time. Signed-off-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: switch to generic read implementationJohan Hovold
Switch to the more efficient generic read implementation. Note that the generic implementation is not required to hold the tty port mutex during resume due to the read-urb free mask and write start flag. Note also that the generic resume implementation will call generic write start if there is a bulk-out end-point, but that nothing will be submitted as the write fifo is not used and is empty. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: refactor reab-urb processingJohan Hovold
Refactor and clean up read-urb processing. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: use usb-serial bulk-in urbJohan Hovold
Use the bulk-in urb provided by usb-serial core rather than allocating a private one. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: increase bulk-in sizeJohan Hovold
Use 256 byte bulk-in buffers rather than double end-point sized ones. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: use port as urb contextJohan Hovold
Use port rather than private data as urb context, as the latter may be accessed as port data, and remove the port field from the private data. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: pass port to get_serial_infoJohan Hovold
Pass port rather then private data to get_serial_info, which only used the private data to access the port. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: make private data port specificJohan Hovold
Make private data port specific and move allocation and deallocation to port_probe and port_remove. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: remove disconnectJohan Hovold
Remove disconnect and its redundant read-urb kill which is already taken care of in close. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: move read-urb deallocation to releaseJohan Hovold
Move read-urb deallocation from disconnect to release. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: simplify bulk-in discovery in attachJohan Hovold
Remove custom end-point iteration which has already been taken care of by usb-serial core. The first bulk-in endpoint found will be associated with the first port. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: remove private usb-serial dataJohan Hovold
Remove redundant usb-serial field from private data. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: remove redundant initialisationJohan Hovold
Remove redundant zero-initialisation of outstanding-urbs field in kzalloced struct. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: remove private serial-device dataJohan Hovold
Remove usb-serial-device field from private data as it can be accessed from the usb-serial-port structure. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: use port device for error and debugJohan Hovold
Use port rather than interface device to report port related errors and debug information. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: move private urb initialisation to attachJohan Hovold
There no need to reinitialise the private urb at every open. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21USB: opticon: remove redundant bulk urb fillJohan Hovold
The private bulk in urb is set up at open and does not need to be reinitialised at every resubmit. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-25USB: opticon: fix memory leak in error pathJohan Hovold
Fix memory leak in write error path. Cc: <stable@vger.kernel.org> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-25USB: opticon: fix DMA from stackJohan Hovold
Make sure to allocate the control-message buffer dynamically as some platforms cannot do DMA from stack. Note that only the first byte of the old buffer was used. Cc: <stable@vger.kernel.org> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-18USB: Serial: opticon.c: remove debug module parameterGreg Kroah-Hartman
Now that all usb-serial modules are only using dev_dbg() the debug module parameter does not do anything at all, so remove it to reduce any confusion if someone were to try to use it. CC: Johan Hovold <jhovold@gmail.com> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Alan Stern <stern@rowland.harvard.edu> CC: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-18USB: serial: remove debug parameter from usb_serial_debug_data()Greg Kroah-Hartman
We should use dev_dbg() for usb_serial_debug_data() like all of the rest of the usb-serial drivers use, so remove the debug parameter as it's not needed. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-09-13USB: serial: opticon.c: remove dbg() usageGreg Kroah-Hartman
dbg() was a very old USB-serial-specific macro. This patch removes it from being used in the driver and uses dev_dbg() instead. CC: Johan Hovold <jhovold@gmail.com> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Alan Stern <stern@rowland.harvard.edu> CC: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-10USB: serial: opticon: hook up suspend/resume callbacksGreg Kroah-Hartman
With a previous patch, the usb_driver suspend/resume callbacks got overridden and were never called if a usb_serial driver defined them. This patch fixes the opticon driver to move the suspend/resume callbacks into the usb_serial_driver structure where they will be properly called. It then removes the unused usb_driver structure. Cc: Johan Hovold <jhovold@gmail.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Cc: Julia Lawall <julia@diku.dk> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-08USB: serial: rework usb_serial_register/deregister_drivers()Greg Kroah-Hartman
This reworks the usb_serial_register_drivers() and usb_serial_deregister_drivers() to not need a pointer to a struct usb_driver anymore. The usb_driver structure is now created dynamically and registered and unregistered as needed. This saves lines of code in each usb-serial driver. All in-kernel users of these functions were also fixed up at this time. The pl2303 driver was tested that everything worked properly. Thanks for the idea to do this from Alan Stern. Cc: Adhir Ramjiawan <adhirramjiawan0@gmail.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Al Borchers <alborchers@steinerpoint.com> Cc: Aleksey Babahin <tamerlan311@gmail.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andrew Worsley <amworsley@gmail.com> Cc: Bart Hartgers <bart.hartgers@gmail.com> Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Dan Carpenter <error27@gmail.com> Cc: Dan Williams <dcbw@redhat.com> Cc: Donald Lee <donald@asix.com.tw> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Gary Brubaker <xavyer@ix.netcom.com> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Johan Hovold <jhovold@gmail.com> Cc: Julia Lawall <julia@diku.dk> Cc: Kautuk Consul <consul.kautuk@gmail.com> Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Cc: Lonnie Mendez <dignome@gmail.com> Cc: Matthias Bruestle and Harald Welte <support@reiner-sct.com> Cc: Matthias Urlichs <smurf@smurf.noris.de> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Michal Sroczynski <msroczyn@gmail.com> Cc: "Michał Wróbel" <michal.wrobel@flytronic.pl> Cc: Oliver Neukum <oliver@neukum.name> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Berger <pberger@brimson.com> Cc: Preston Fick <preston.fick@silabs.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Rigbert Hamisch <rigbert@gmx.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Simon Arlott <simon@fire.lp0.eu> Cc: Support Department <support@connecttech.com> Cc: Thomas Tuttle <ttuttle@chromium.org> Cc: Uwe Bonnes <bon@elektron.ikp.physik.tu-darmstadt.de> Cc: Wang YanQing <Udknight@gmail.com> Cc: William Greathouse <wgreathouse@smva.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-07USB: serial: remove usb_serial_disconnect call in all driversGreg Kroah-Hartman
This is now set by the usb-serial core, no need for the driver to individually set it. Thanks to Alan Stern for the idea to get rid of it. Cc: William Greathouse <wgreathouse@smva.com> Cc: Matthias Bruestle and Harald Welte <support@reiner-sct.com> Cc: Lonnie Mendez <dignome@gmail.com> Cc: Peter Berger <pberger@brimson.com> Cc: Al Borchers <alborchers@steinerpoint.com> Cc: Gary Brubaker <xavyer@ix.netcom.com> Cc: Oliver Neukum <oliver@neukum.name> Cc: Matthias Urlichs <smurf@smurf.noris.de> Cc: Support Department <support@connecttech.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: Kautuk Consul <consul.kautuk@gmail.com> Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Bart Hartgers <bart.hartgers@gmail.com> Cc: Johan Hovold <jhovold@gmail.com> Cc: Preston Fick <preston.fick@silabs.com> Cc: Uwe Bonnes <bon@elektron.ikp.physik.tu-darmstadt.de> Cc: Simon Arlott <simon@fire.lp0.eu> Cc: Andrew Worsley <amworsley@gmail.com> Cc: "Michał Wróbel" <michal.wrobel@flytronic.pl> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Eric Dumazet <eric.dumazet@gmail.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Felipe Balbi <balbi@ti.com> Cc: Aleksey Babahin <tamerlan311@gmail.com> Cc: Dan Carpenter <error27@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Donald Lee <donald@asix.com.tw> Cc: Julia Lawall <julia@diku.dk> Cc: Michal Sroczynski <msroczyn@gmail.com> Cc: Wang YanQing <Udknight@gmail.com> Cc: Dan Williams <dcbw@redhat.com> Cc: Thomas Tuttle <ttuttle@chromium.org> Cc: Rigbert Hamisch <rigbert@gmx.de> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Adhir Ramjiawan <adhirramjiawan0@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-07USB: serial: remove usb_serial_probe call in all driversGreg Kroah-Hartman
2012-05-03USB: opticon.c: remove dbg() tracing callsGreg Kroah-Hartman
dbg() was used a lot a long time ago to trace code flow. Now that we have ftrace, this isn't needed at all, so remove these calls. CC: Johan Hovold <jhovold@gmail.com> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> CC: Julia Lawall <julia@diku.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-25USB: opticon: fix abuse of interface dataJohan Hovold
Fix abuse of interface data which was used to signal device disconnect. Use the usb_serial disconnect flag and mutex where appropriate. Note that tiocmget does not need to check for disconnect as it does not access the device. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-28USB: serial: opticon.c: use module_usb_serial_driverGreg Kroah-Hartman
This converts the opticon.c driver to use the module_usb_serial_driver() call instead of having to have a module_init/module_exit function, saving a lot of duplicated code. CC: Rusty Russell <rusty@rustcorp.com.au> CC: Johan Hovold <jhovold@gmail.com> CC: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> CC: Julia Lawall <julia@diku.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-02-24usb-serial: use new registration API in [n-p]* driversAlan Stern
This patch (as1527) modifies the following usb-serial drivers to utilize the new usb_serial_{de}register_drivers() routines: navman, omninet, opticon, option, oti6858, and pl2303. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-13module_param: make bool parameters really bool (drivers & misc)Rusty Russell
module_param(bool) used to counter-intuitively take an int. In fddd5201 (mid-2009) we allowed bool or int/unsigned int using a messy trick. It's time to remove the int/unsigned int option. For this version it'll simply give a warning, but it'll break next kernel version. Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2011-11-15USB: serial: remove unnecessary reinitialisations of urb->devJohan Hovold
Remove unnecessary reinitialisations of urb->dev before each submission, which were based on the (no longer valid) assumption that serial->dev will be set to NULL on close. Compile-only tested. Cc: Matthias Bruestle and Harald Welte <support@reiner-sct.com> Cc: Lonnie Mendez <dignome@gmail.com> Cc: Peter Berger <pberger@brimson.com> Cc: Al Borchers <alborchers@steinerpoint.com> Cc: Support Department <support@connecttech.com> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-23USB: use usb_endpoint_maxp() instead of le16_to_cpu()Kuninori Morimoto
Now ${LINUX}/drivers/usb/* can use usb_endpoint_maxp(desc) to get maximum packet size instead of le16_to_cpu(desc->wMaxPacketSize). This patch fix it up Cc: Armin Fuerst <fuerst@in.tum.de> Cc: Pavel Machek <pavel@ucw.cz> Cc: Johannes Erdfelt <johannes@erdfelt.com> Cc: Vojtech Pavlik <vojtech@suse.cz> Cc: Oliver Neukum <oliver@neukum.name> Cc: David Kubicek <dave@awk.cz> Cc: Johan Hovold <jhovold@gmail.com> Cc: Brad Hards <bhards@bigpond.net.au> Acked-by: Felipe Balbi <balbi@ti.com> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Thomas Dahlmann <dahlmann.thomas@arcor.de> Cc: David Brownell <david-b@pacbell.net> Cc: David Lopo <dlopo@chipidea.mips.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Michal Nazarewicz <m.nazarewicz@samsung.com> Cc: Xie Xiaobo <X.Xie@freescale.com> Cc: Li Yang <leoli@freescale.com> Cc: Jiang Bo <tanya.jiang@freescale.com> Cc: Yuan-hsin Chen <yhchen@faraday-tech.com> Cc: Darius Augulis <augulis.darius@gmail.com> Cc: Xiaochen Shen <xiaochen.shen@intel.com> Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com> Cc: OKI SEMICONDUCTOR, <toshiharu-linux@dsn.okisemi.com> Cc: Robert Jarzmik <robert.jarzmik@free.fr> Cc: Ben Dooks <ben@simtec.co.uk> Cc: Thomas Abraham <thomas.ab@samsung.com> Cc: Herbert Pötzl <herbert@13thfloor.at> Cc: Arnaud Patard <arnaud.patard@rtp-net.org> Cc: Roman Weissgaerber <weissg@vienna.at> Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Tony Olech <tony.olech@elandigitalsystems.com> Cc: Florian Floe Echtler <echtler@fs.tum.de> Cc: Christian Lucht <lucht@codemercs.com> Cc: Juergen Stuber <starblue@sourceforge.net> Cc: Georges Toth <g.toth@e-biz.lu> Cc: Bill Ryder <bryder@sgi.com> Cc: Kuba Ober <kuba@mareimbrium.org> Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-05-13drivers/usb/serial/opticon.c: Release resources on kmalloc failureJulia Lawall
Several resources have been allocated before this kmalloc failure, and thus they should be released in this error handling code, as done in nearby error handling code. The semantic match that finds this problem is: (http://coccinelle.lip6.fr/) // <smpl> @r exists@ local idexpression urb; statement S; position p1,p2; @@ urb = usb_alloc_urb@p1(...); ... when != urb if (urb == NULL) S ... when != urb ( return <+...urb...+>; | return@p2 ...; ) @script:python@ p1 << r.p1; p2 << r.p2; @@ cocci.print_main("",p1) cocci.print_secs("",p2) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-04-07Merge branch 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6: Fix common misspellings
2011-04-04usb/serial: fix function args warnings, dropping *filpRandy Dunlap
Fix build warnings caused by removal of *filp arg in struct usb_serial_driver. These changes were missed somehow in commits 00a0d0d65b61 ("tty: remove filp from the USB tty ioctls") and 60b33c133ca0b ("tiocmget: kill off the passing of the struct file") drivers/usb/serial/mct_u232.c:159: warning: initialization from incompatible pointer type drivers/usb/serial/opticon.c:627: warning: initialization from incompatible pointer type Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alan Cox <alan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-16Merge branch 'tty-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6 * 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits) pch_uart: reference clock on CM-iTC pch_phub: add new device ML7213 n_gsm: fix UIH control byte : P bit should be 0 n_gsm: add a documentation serial: msm_serial_hs: Add MSM high speed UART driver tty_audit: fix tty_audit_add_data live lock on audit disabled tty: move cd1865.h to drivers/staging/tty/ Staging: tty: fix build with epca.c driver pcmcia: synclink_cs: fix prototype for mgslpc_ioctl() Staging: generic_serial: fix double locking bug nozomi: don't use flush_scheduled_work() tty/serial: Relax the device_type restriction from of_serial MAINTAINERS: Update HVC file patterns tty: phase out of ioctl file pointer for tty3270 as well tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile pch_uart: Fix DMA channel miss-setting issue. pch_uart: fix exclusive access issue pch_uart: fix auto flow control miss-setting issue pch_uart: fix uart clock setting issue pch_uart : Use dev_xxx not pr_xxx ... Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied twice, then changes to the same area in one branch)
2011-02-25USB: opticon: add rts and cts supportMartin Jansen
Add support for RTS and CTS line status Signed-off-by: Martin Jansen <martin.jansen@opticon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tty: remove filp from the USB tty ioctlsAlan Cox
We don't use it so we can trim it from here as we try and stamp the file object dependencies out of the serial code. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17tiocmget: kill off the passing of the struct fileAlan Cox
We don't actually need this and it causes problems for internal use of this functionality. Currently there is a single use of the FILE * pointer. That is the serial core which uses it to check tty_hung_up_p. However if that is true then IO_ERROR is also already set so the check may be removed. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: opticon: Whitespace fixes in opticon driverAlon Ziv
Signed-off-by: Alon Ziv <alon-git@nolaviz.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: opticon: Add Opticon OPN2001 write supportAlon Ziv
OPN2001 expects write operations to arrive as a vendor-specific command through the control pipe (instead of using a separate bulk-out pipe). Signed-off-by: Alon Ziv <alon-git@nolaviz.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-22USB: opticon: Fix long-standing bugs in opticon driverAlon Ziv
The bulk-read callback had two bugs: a) The bulk-in packet's leading two zeros were returned (and the two last bytes truncated) b) The wrong URB was transmitted for the second (and later) read requests, causing further reads to return the entire packet (including leading zeros) Signed-off-by: Alon Ziv <alon-git@nolaviz.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-02USB: tty: Prune uses of tty_request_room in the USB layerAlan Cox
We have lots of callers that do not need to do this in the first place. Remove the calls as they both cost CPU and for big buffers can mess up the multi-page allocation avoidance. Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
