Now ${LINUX}/drivers/usb/* can use usb_endpoint_maxp(desc) to get maximum packet size
instead of le16_to_cpu(desc->wMaxPacketSize).
This patch fix it up
Cc: Armin Fuerst <fuerst@in.tum.de>
Cc: Pavel Machek <pavel@ucw.cz>
Cc: Johannes Erdfelt <johannes@erdfelt.com>
Cc: Vojtech Pavlik <vojtech@suse.cz>
Cc: Oliver Neukum <oliver@neukum.name>
Cc: David Kubicek <dave@awk.cz>
Cc: Johan Hovold <jhovold@gmail.com>
Cc: Brad Hards <bhards@bigpond.net.au>
Acked-by: Felipe Balbi <balbi@ti.com>
Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Cc: Thomas Dahlmann <dahlmann.thomas@arcor.de>
Cc: David Brownell <david-b@pacbell.net>
Cc: David Lopo <dlopo@chipidea.mips.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Michal Nazarewicz <m.nazarewicz@samsung.com>
Cc: Xie Xiaobo <X.Xie@freescale.com>
Cc: Li Yang <leoli@freescale.com>
Cc: Jiang Bo <tanya.jiang@freescale.com>
Cc: Yuan-hsin Chen <yhchen@faraday-tech.com>
Cc: Darius Augulis <augulis.darius@gmail.com>
Cc: Xiaochen Shen <xiaochen.shen@intel.com>
Cc: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Cc: OKI SEMICONDUCTOR, <toshiharu-linux@dsn.okisemi.com>
Cc: Robert Jarzmik <robert.jarzmik@free.fr>
Cc: Ben Dooks <ben@simtec.co.uk>
Cc: Thomas Abraham <thomas.ab@samsung.com>
Cc: Herbert Pötzl <herbert@13thfloor.at>
Cc: Arnaud Patard <arnaud.patard@rtp-net.org>
Cc: Roman Weissgaerber <weissg@vienna.at>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Cc: Tony Olech <tony.olech@elandigitalsystems.com>
Cc: Florian Floe Echtler <echtler@fs.tum.de>
Cc: Christian Lucht <lucht@codemercs.com>
Cc: Juergen Stuber <starblue@sourceforge.net>
Cc: Georges Toth <g.toth@e-biz.lu>
Cc: Bill Ryder <bryder@sgi.com>
Cc: Kuba Ober <kuba@mareimbrium.org>
Cc: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Several resources have been allocated before this kmalloc failure, and thus
they should be released in this error handling code, as done in nearby
error handling code.
The semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
local idexpression urb;
statement S;
position p1,p2;
urb = usb_alloc_urb@p1(...);
... when != urb
if (urb == NULL) S
... when != urb
return <+...urb...+>;
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
cocci.print_main("",p1)
cocci.print_secs("",p2)
// </smpl>
* 'for-linus2' of git://git.profusion.mobi/users/lucas/linux-2.6:
Fix common misspellings
Fix build warnings caused by removal of *filp arg in struct
usb_serial_driver.
These changes were missed somehow in commits 00a0d0d65b61 ("tty: remove
filp from the USB tty ioctls") and 60b33c133ca0b ("tiocmget: kill off
the passing of the struct file")
drivers/usb/serial/mct_u232.c:159: warning: initialization from incompatible pointer type
drivers/usb/serial/opticon.c:627: warning: initialization from incompatible pointer type
Cc: Alan Cox <alan@linux.intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6
* 'tty-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (76 commits)
pch_uart: reference clock on CM-iTC
pch_phub: add new device ML7213
n_gsm: fix UIH control byte : P bit should be 0
n_gsm: add a documentation
serial: msm_serial_hs: Add MSM high speed UART driver
tty_audit: fix tty_audit_add_data live lock on audit disabled
tty: move cd1865.h to drivers/staging/tty/
Staging: tty: fix build with epca.c driver
pcmcia: synclink_cs: fix prototype for mgslpc_ioctl()
Staging: generic_serial: fix double locking bug
nozomi: don't use flush_scheduled_work()
tty/serial: Relax the device_type restriction from of_serial
MAINTAINERS: Update HVC file patterns
tty: phase out of ioctl file pointer for tty3270 as well
tty: forgot to remove ipwireless from drivers/char/pcmcia/Makefile
pch_uart: Fix DMA channel miss-setting issue.
pch_uart: fix exclusive access issue
pch_uart: fix auto flow control miss-setting issue
pch_uart: fix uart clock setting issue
pch_uart : Use dev_xxx not pr_xxx
Fix up trivial conflicts in drivers/misc/pch_phub.c (same patch applied
twice, then changes to the same area in one branch)
Add support for RTS and CTS line status
Signed-off-by: Martin Jansen <martin.jansen@opticon.com>
We don't use it so we can trim it from here as we try and stamp the file
object dependencies out of the serial code.
Signed-off-by: Alan Cox <alan@linux.intel.com>
We don't actually need this and it causes problems for internal use of
this functionality. Currently there is a single use of the FILE * pointer.
That is the serial core which uses it to check tty_hung_up_p. However if
that is true then IO_ERROR is also already set so the check may be removed.
Signed-off-by: Alon Ziv <alon-git@nolaviz.org>
OPN2001 expects write operations to arrive as a vendor-specific command
through the control pipe (instead of using a separate bulk-out pipe).
The bulk-read callback had two bugs:
a) The bulk-in packet's leading two zeros were returned (and the two last
bytes truncated)
b) The wrong URB was transmitted for the second (and later) read requests,
causing further reads to return the entire packet (including leading
zeros)
Cc: stable <stable@kernel.org>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
We have lots of callers that do not need to do this in the first place.
Remove the calls as they both cost CPU and for big buffers can mess up the
multi-page allocation avoidance.
#define dbg adds the newline, messages shouldn't.
Converted dbg("%s", "some string") to dbg("some string")
The id_table field of the struct usb_device_id is constant in <linux/usb.h>
so it is worth to make the initialization data also constant.
The semantic match that finds this kind of pattern is as follows:
// <smpl>
@r@
disable decl_init,const_decl_init;
identifier I1, I2, x;
struct I1 {
const struct I2 *x;
@s@
identifier r.I1, y;
identifier r.x, E;
struct I1 y = {
.x = E,
@c@
identifier r.I2;
identifier s.E;
const struct I2 E[] = ... ;
@depends on !c@
identifier r.I2;
identifier s.E;
+ const
struct I2 E[] = ...;
// </smpl>
Signed-off-by: Németh Márton <nm127@freemail.hu>
Cc: Julia Lawall <julia@diku.dk>
Cc: cocci@diku.dk
Opticon now takes the right mutex to check the port status but the status
check is done wrongly for the modern serial code, so fix it.
Cc: Oliver Neukum <oliver@neukum.org>
The tty port has a port mutex used for all the port related locking so we
don't need the one in the USB serial layer any more.
usb:usbserial:opticon: fix race between unthrottle and completion handler
opticon_unthrottle() mustn't resubmit the URB unconditionally
as the URB may still be running.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
And indeed none of them use it. Clean this up as it will make moving to a
standard open method rather easier.
This patch (as1254) splits up the shutdown method of usb_serial_driver
into a disconnect and a release method.
The problem is that the usb-serial core was calling shutdown during
disconnect handling, but drivers didn't expect it to be called until
after all the open file references had been closed. The result was an
oops when the close method tried to use memory that had been
deallocated by shutdown.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This allows us to clean stuff up, but is probably also going to cause
some app breakage with buggy apps as we now implement proper POSIX behaviour
for USB ports matching all the other ports. This does also mean other apps
that break on USB will now work properly.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
This removes tty->low_latency from all USB serial drivers that push
data into the tty layer at hard interrupt context. It's no longer needed
and actually harmful.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
This lets userspace determine what the state of the RTS line is, which
is what is needed to properly handle data flow for this device (it
raises RTS when there is data to be sent from it.)
Cc: Kees Stoop <kees.stoop@opticon.com>
This patch allows data to be sent to the scanner.
this does the standard support for suspend/resume for the opticon
driver.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
This is for the serial mode of the Opticon barcode scanner.
