This patch adds new PIDs for ZTE 3G modem, after we confirm it and tested.
Thanks for Dan's work at kernel option devier.
Signed-off-by: Alvin.Zheng <zheng.zhijian@zte.com.cn>
Signed-off-by: wsalvin <wsalvin@yahoo.com.cn>
Cc: stable <stable@vger.kernel.org>
Add VendorID/ProductID for USB 3G dongle Model VT1000 of Viettel.
Signed-off-by: VU Tuan Duc <ducvt@viettel.com.vn>
IDs found in the Windows driver's ZTEusbnet.inf file from the
ZTE MF100 drivers (O2 UK). Also fixes the ZTE MF626 device
since it really is distinct from the 4G Systems stick and
apparently needs the net interface blacklisted too, while
there's no indication (yet) that the 4G Systems stick does.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Cc: stable <stable@kernel.org>
blacklist
That's what the blacklist is for...
It's cleaner than the array stuff, and we're about to add a bunch
more blacklist entries. Second, there are devices that need both
the sendsetup and the reserved interface blacklists, which the
current code can't accommodate.
Currently the Option driver avoids binding interface 1 on Huawei K3765
and K4505 broadband modems as it should be handled by the cdc_ether
driver instead. This patch ensures we don't bind the interface 2
on those devices as that is CDC_DATA.
Signed-off-by: Andrew Bird <ajb@spheresystems.co.uk>
Signed-off-by: Gavin.zhu <gavin.kx@qq.com>
This patch adds the product ID of Huawei's Vodafone K4605 mobile broadband
modem to option.c. This is necessary so that the driver gets loaded on
demand without the intervention of usb_modeswitch. This has the benefit of
it becoming available faster and also ensures that the option driver is not
bound to a network interface that should be claimed by suitable network
driver.
Signed-off-by: Alex Chiang <achiang@canonical.com>
This patch adds the product ID of Huawei's Vodafone K3806 mobile broadband
bound to a network interface that should be claimed by cdc_ether.
This patch adds the product ID of Huawei's Vodafone K4511 mobile broadband
modem to option.c. This is necessary so that the driver gets loaded on demand
without the intervention of usb_modeswitch. This has the benefit of it becoming
available faster and also ensures that the option driver is not bound to a
This patch adds the product ID of Huawei's Vodafone K4510 mobile broadband
This patch adds the product ID of Huawei's Vodafone K3771 mobile broadband
This patch adds the product ID of Huawei's Vodafone K3770 mobile broadband
This reverts commit a559d2c8c1bf652ea2d0ecd6ab4a250fcdb37db8.
Turns out that device id 0x1d6b:0x0002 is a USB hub, which causes havoc
when the option driver tries to bind to it.
So revert this as it doesn't seem to be needed at all.
Thanks to Michael Tokarev and Paweł Drobek for working on resolving this
issue.
Cc: Paweł Drobek <pawel.drobek@gmail.com>
Cc: Michael Tokarev <mjt@tls.msk.ru>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
The funtion option_send_status times out when sending USB messages
to the interfaces 0, 1, and 2 of this UMTS stick. This results in a
5s timeout in the function causing other tty operations to feel very
sluggish.
This patch adds a blacklist entry for these 3 interfaces on the ZTE
K3765-Z device.
I was also able to reproduce the problem with v2.6.38 and v2.6.39.
This is very similar to a problem fixed in
commit 7a89e4cb9cdaba92f5fbc509945cf4e3c48db4e2
Author: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
Date: Wed Mar 9 09:19:48 2011 +0000
USB: serial: option: Apply OPTION_BLACKLIST_SENDSETUP also for ZTE MF626
Signed-off-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Simple ID addition.
Cc: stable@kernel.org
This modem really wants sendsetup blacklisted for interfaces 0 and 1,
otherwise the kernel hardlocks for about 10 seconds while waiting for
the modem's firmware to respond, which it of course doesn't do.
A slight complication here is that TCT (who owns the Alcatel brand) used
the same USB IDs for the X200 as the X060s despite the devices having
completely different firmware and AT command sets, so we end up adding
the X060s to the blacklist at the same time. PSA to OEMs: don't use the
same USB IDs for different devices. Really. It makes your kittens cry.
Uses Longcheer-based firmware and AT command set.
I am sharing patch to the devices/usb/serial/option.c. This allows
operation of Huawei E353 broadband modem using the “option” driver. The
patch simply adds new constant with proper product ID and an entry to
usb_device_id. I worked on the 2.6.38.6 sources. Tested on Dell inspiron
1764 (i3 core cpu) and brand new Huawei E353 modem, Fedora 15 beta.
Looking at the type of change, i doubt it has potential to introduce
problems in other parts of kernel or the driver itself.
Signed-off-by: Marcin Galczynski <marcin@galczynski.pl>
Network interface is handled by upcoming gt_b3730 module.
Removed "GT-B3710" from comment, it is another modem with another USB ID.
Signed-off-by: Marius B. Kotsbak <marius@kotsbak.com>
Bind only modem AT command endpoint to option.
On https://bugs.launchpad.net/ubuntu/+source/linux/+bug/636091, one of
the cases reported is a big timeout on option_send_setup, which causes
some side effects as tty_lock is held. Looks like some of ZTE MF626
devices also don't like the RTS/DTR setting in option_send_setup, like
with 4G XS Stick W14. The reporter confirms which this it solves the
long freezes in his system.
Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com>
/drivers/usb/serial/option.c: Adding support for Cinterion's HC25, HC28,
HC28J, EU3-E, EU3-P and PH8 by correcting/adding Cinterion's and
Siemens' Vendor IDs as well as Product IDs and USB_DEVICE tuples
Signed-off-by: Nicolaus Colberg <nicolaus.colberg@cinterion.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6
* 'staging-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (510 commits)
staging: speakup: fix failure handling
staging: usbip: remove double giveback of URB
Staging: batman-adv: Remove batman-adv from staging
Staging: hv: Use only one txf buffer per channel and kmalloc/GFP_KERNEL on initialize
staging: hv: remove unneeded osd_schedule_callback
staging: hv: convert channel_mgmt.c to not call osd_schedule_callback
staging: hv: convert vmbus_on_msg_dpc to not call osd_schedule_callback
staging: brcm80211: Fix WL_<type> logging macros
Staging: IIO: DDS: AD9833 / AD9834 driver
Staging: IIO: dds.h convenience macros
Staging: IIO: Direct digital synthesis abi documentation
staging: brcm80211: Convert ETHER_TYPE_802_1X to ETH_P_PAE
staging: brcm80211: Remove unused ETHER_TYPE_<foo> #defines
staging: brcm80211: Remove ETHER_HDR_LEN, use ETH_HLEN
staging: brcm80211: Convert ETHER_ADDR_LEN to ETH_ALEN
staging: brcm80211: Convert ETHER_IS<FOO> to is_<foo>_ether_addr
staging: brcm80211: Remove unused ether_<foo> #defines and struct
staging: brcm80211: Convert ETHER_IS_MULTI to is_multicast_ether_addr
staging: brcm80211: Remove unused #defines ETHER_<foo>_LOCALADDR
Staging: comedi: Fix checkpatch.pl issues in file s526.c
Fix up trivial conflict in drivers/video/udlfb.c
* usb-next: (132 commits)
USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path
USB: uas: Ensure we only bind to a UAS interface
USB: uas: Rename sense pipe and sense urb to status pipe and status urb
USB: uas: Use kzalloc instead of kmalloc
USB: uas: Fix up the Sense IU
usb: musb: core: kill unneeded #include's
DA8xx: assign name to MUSB IRQ resource
usb: gadget: g_ncm added
usb: gadget: f_ncm.c added
usb: gadget: u_ether: prepare for NCM
usb: pch_udc: Fix setup transfers with data out
usb: pch_udc: Fix compile error, warnings and checkpatch warnings
usb: add ab8500 usb transceiver driver
USB: gadget: Implement runtime PM for MSM bus glue driver
USB: gadget: Implement runtime PM for ci13xxx gadget
USB: gadget: Add USB controller driver for MSM SoC
USB: gadget: Introduce ci13xxx_udc_driver struct
USB: gadget: Initialize ci13xxx gadget device's coherent DMA mask
USB: gadget: Fix "scheduling while atomic" bugs in ci13xxx_udc
USB: gadget: Separate out PCI bus code from ci13xxx_udc
Some devices (ex ZTE 2726) simply don't respond at all when data is sent
to some of their USB interfaces. The data gets stuck in the TTYs queue
and sits there until close(2), which them blocks because closing_wait
defaults to 30 seconds (even though the fd is O_NONBLOCK). This is
rarely desired. Implement the standard mechanism to adjust closing_wait
and let applications handle it how they want to.
This was necessary in order to resolve some conflicts that happened
between -rc1 and -rc2 with the following files:
drivers/staging/bcm/Bcmchar.c
drivers/staging/intel_sst/intel_sst_app_interface.c
All should be resolved now.
When huawei datacard with PID 0x14AC is insterted into Linux system, the
present kernel will load the "option" driver to all the interfaces. But
actually, some interfaces run as other function and do not need "option"
driver.
In this path, we modify the id_tables, when the PID is 0x14ac ,VID is
0x12d1, Only when the interface's Class is 0xff,Subclass is 0xff, Pro is
0xff, it does need "option" driver.
Signed-off-by: ma rui <m00150988@huawei.com>
Signed-off-by: Alejandro R. Sedeño <asedeno@mit.edu>
This patch, adds to the option driver the Onda Communication
(http://www.ondacommunication.com) vendor id, and the MT825UP modem
device id.
Note that many variants of this same device are being release here in
Italy (at least one or two per telephony operator).
These devices are perfectly equivalent except for some predefined
settings (which can be changed of course).
It should be noted that most ONDA devices are allready supported (they
used other vendor's ids in the past). The patch seems working fine here,
and the rest of the driver seems uninfluenced.
Signed-off-by: Enrico Mioso <mrkiko.rs@gmail.com>
There are lots of ZTE USB id's currently not covered by usb/serial. Adds them,
to allow those devices to work properly on Linux.
While here, put the USB ID's for 0x2002/0x2003 at the sorted order.
This patch is based on zte.c file found on MF645.
PS.: The ZTE driver is commenting the USB ID for 0x0053. It also adds, commented,
an USB ID for 0x0026.
Not sure why, but I think that 0053 is used by their devices in storage mode only.
So, I opted to keep the comment on this patch.
Unfortunately some of the hardware PID belonging to auto-install CDROM
(AICD) of Novatel modems found their way into the option module. This
causes the AICD to be treated as a modem in stead of a disk. Since the
modem ports do not appear until after the AICD is ejected, this
essentially disables the modem. After a couple of minutes the AICD
should auto-eject, but it is just too long a wait. The frequency of the
failure seems to depend on both the hardware and the linux distribution.
Here is a patch that fixes this up, and also adds a couple of new PID,
offering some explanations and removing some incomplete and unnecessary
comments.
Signed-off-by: Dirk De Schepper <ddeschepper@nvtl.com>
Signed-off-by: Michael Tokarev <mjt@tls.msk.ru>
This patch adds the product IDs of Huawei's K3765 and K4505 mobile
broadband usb modems to option.c. It also adds a quirk to the option
probe function so that binding to the device's network interface(class
0xff) is avoided. This is necessary to allow another driver to bind to
that, and to avoid programs like wvdial opening a nonfunctioning tty
during modem discovery.
The patch adds Huawei ETS 1220 product id into the list of supported
devices in 'option' usb serial driver.
Signed-off-by: Pavel Kazlou <p.i.kazlou@gmail.com>
AMOI_VENDOR_ID is defined twice. Remove the duplicate entry and move
the AMOI_PRODUCT_9508 definition to be grouped with the other AMOI
product definitions.
Originally-by: Ben Collins <ben.collins@ubuntu.com>
Signed-off-by: Leann Ogasawara <leann.ogasawara@canonical.com>
usbserial: Add AMOI Skypephone S2 support.
This patch adds support for the AMOI Skypephone S2 to the usbserial module.
Tested-by: Dennis Jansen <Dennis.Jansen@web.de>
Signed-off-by: Dennis Jansen <Dennis.Jansen@web.de>
Signed-off-by: Omer Sezgin Ugurlu <omer.ugurlu@a-kent.com>
This patch adds support for an olivetti olicard100 HЅDPA usb-stick.
This device is a zeroCD one with ID 0b3c:c700 that needs switching via
eject or usb-modeswitch with
MessageContent="5553424312345678000000000000061b000000030000000000000000000000".
After switching it has ID 0b3c:c000 and provides 5 serial ports ttyUSB[0-4].
Port 0 (modem) and 4 are interrupt ports.
Signed-off-by: Nils Radtke <lkml@Think-Future.de>
this patch adds ZTE modem devices
Signed-off-by: Joey <zhao.ming9@zte.com.cn>
As this code was simply factored out of option, this is a simple
conversion.
All unsuccessful (non-zero status) URBs were being dropped. After N_IN_URBs are
dropped you will no longer be able to receive data.
This patch resubmits unsuccessful URBs unless the status indicates that it should
be terminated. The statuses that indicate the URB should be terminated was
gathered from other similar drivers.
Signed-off-by: James Maki <jamescmaki@gmail.com>
This adds a device id for a Cinterion device.
Reported-by: John Race <John.Race@roscom.co.uk>
PATCH TO EXTEND SUPPORT TO AC8710 WITH 0xFFFF Product ID.
Signed-off-by: Mahesh Kuruganti <maheshkuruganti@gmail.com>
Based on the information provided for by Paweł Drobek, add
a second vendor ID and the correct product ID for ZTE MF 330.
Reported-by: Paweł Drobek <pawel.drobek@gmail.com>
Signed-off: Dominik Brodowski <linux@dominikbrodowski.net>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
0xff
Signed-off-by: spark <spark@bandrich.com>
Signed-off-by: Nathaniel McCallum <nathaniel@natemccallum.com>
