path: root/drivers/usb/serial/option.c
2007-09-11USB: option: Add Dell HSDPA 5520 to driverGreg Kroah-Hartman
This is based on information sent in by Christian Gothe. Cc: Christian Gothe <christian.gothe@kapelan.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-09-11USB: option: Add a new device ID for the HUAWEI E220 HSDPA modem.Jaime Velasco Juan
Signed-off-by: Jaime Velasco Juan <jaime@singular.local> CC: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-08-22USB: fix support for Dell Wireless Broadband (aka WWAN)Faidon Liambotis
Dell Wireless Broadband ExpressCards are rebrands of Novatel's cards. Add all of their known PCI IDs to date along with their mapping to the exact Novatel model to the Option driver which already claims to support them. Signed-off-by: Faidon Liambotis <paravoid@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: serial: option: clean up urb->status usageGreg Kroah-Hartman
This done in anticipation of removal of urb->status, which will make that patch easier to review and apply in the future. Cc: <linux-usb-devel@lists.sourceforge.net> Cc: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: option: fix usage of urb->status abuseAlan Stern
Might fix bug 8561 On Mon, 4 Jun 2007, Paulo Pereira wrote: > The patch that you send is not resolving the problem... :( > I stil have Kernel panic after 45/60 min of work with Ktorrent/Amule... > > The Drump is: > > Call Trace: > [<c055fb36>] usb_hcd_submit+0xb1/0x763 > [<f9276488>] ipt_do_table+0x2c7/0x2ef [ip_tables] > [<f929a6d7>] nf_ct_deliver_cached_events+0x41/0x96 [nf_conntrak] > [<f9288254>] ipv4_confirm+0x36/0c3b [nf_conntrack_ipv4] > [<c05ce7c2>] tcp_v4_rcv+0x827/0x899 > [<c05afcc0>] nf_hook_slow+0x4d/0xb5 > [<c042826f>] irq_enter+0x19/0x23 > [<c042826f>] irq_enter+0x19/0x23 > [<c040794c>] do_IRQ+0xbd/0xd1 > [<f90893c9>] option_write+0xa7/0xef [option] Okay, from this it looks like there's a problem in the option.c serial driver. Glancing at the code, it's obvious why: The thing totally abuses the USB API. Try applying this patch; it should help. From: Alan Stern <stern@rowland.harvard.edu> Cc: Paulo Pereira <pfmp.404@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-25USB: add new device id to option driverAlexander Gattin
2007-05-22USB: Remove duplicate IDs from option card driverBen Collins
Cc: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: dell device id for option.cHans Engelen
2007-04-27USB: BandRich BandLuxe HSDPA Data Card DriverLeon Leong
Add the detection for the BandRich BandLuxe C100/C100S/C120 HSDPA Data Card. With the vendor and product IDs are set properly, the data card can be detected and works fine. Signed-off-by: Leon Leong <upleong@bandrich.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-04-27USB: option close raceOliver Neukum
the option driver does not directly use usb_kill_urb(). It uses a wrapper. This wrapper means that callbacks which are running are not killed during close, resubmitting and illicitly pushing data into the tty layer. The whole purpose of usb_kill_urb() is subverted. The wrapper must be removed. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-03-19USB: new Novatel device ids for option driverGreg Kroah-Hartman
This moves all of the Novatel device ids to the option driver, where they belong. Thanks to Novatel for providing a list of all supported devices. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23USB: option: add a bunch of new device idsGreg Kroah-Hartman
This adds all of the known Option device ids to the driver. Many thanks to some Option engineers for getting me this list. Cc: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-23USB: option: remove duplicate device id tableGreg Kroah-Hartman
There is no need to have two tables with the same device ids in it. Cc: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-16usb: Remove Airprime device from option.cKevin Lloyd
from: Kevin Lloyd <linux@sierrawireless.com> This patch removes the Airprime 5220 device (branded as Audiovox) from the option.c driver. This device is already supported by the sierra.c driver. This was based off of the option.c driver found in kernel 2.6.20-git11. Signed-off-by: Kevin Lloyd <linux@sierrawireless.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB serial: add driver pointer to all usb-serial driversJohannes Hölzl
Every usb serial driver should have a pointer to the corresponding usb driver. So the usb serial core can add a new id not only to the usb serial driver, but also to the usb driver. Also the usb drivers of ark3116, mos7720 and mos7840 missed the flag no_dynamic_id=1. This is added now. Signed-off-by: Johannes Hölzl <johannes.hoelzl@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-01-22USB: add vendor/device id for Option GT Max 3.6 cardsgarrett_damore@tadpole.com
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=7814 Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-01-05USB: fix interaction between different interfaces in an "Option" usb deviceMiguel Angel Alvarez
Just the serial port in the first interface should control DTR and RTS lines. This way, the closing of the rest of the ports does not produce a= hangup in the communication. Signed-off-by: Miguel Angel Alvarez <ma.alvarez@ziv.es> Signed-off-by: Matthias Urlichs <matthias@urlichs.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-20usb-gsm-driver: Added VendorId and ProductId for Huawei E220 USB ModemJohann Wilhelm
Added VendorId and ProductId for Huawei E220 USB Modem Signed-off-by: Johann Wilhelm <johann.wilhelm@student.tugraz.at> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-12-08[PATCH] tty: switch to ktermiosAlan Cox
This is the grungy swap all the occurrences in the right places patch that goes with the updates. At this point we have the same functionality as before (except that sgttyb() returns speeds not zero) and are ready to begin turning new stuff on providing nobody reports lots of bugs If you are a tty driver author converting an out of tree driver the only impact should be termios->ktermios name changes for the speed/property setting functions from your upper layers. If you are implementing your own TCGETS function before then your driver was broken already and its about to get a whole lot more painful for you so please fix it 8) Also fill in c_ispeed/ospeed on init for most devices, although the current code will do this for you anyway but I'd like eventually to lose that extra paranoia [akpm@osdl.org: bluetooth fix] [mp3@de.ibm.com: sclp fix] [mp3@de.ibm.com: warning fix for tty3270] [hugh@veritas.com: fix tty_ioctl powerpc build] [jdike@addtoit.com: uml: fix ->set_termios declaration] Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Martin Peschke <mp3@de.ibm.com> Acked-by: Peter Oberparleiter <oberpar@de.ibm.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-08-02USB: Removed 3-port device handler from Option driverMatthias Urlichs
Dead code. From: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02USB: Drop Sierra Wireless MC8755 from the Option driverMatthias Urlichs
This device is now supported by sierra.c. From: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02USB: Let option driver handle Anydata CDMA modems. Remove anydata driver.Matthias Urlichs
Signed-off-by: Jon K Hellan <hellan@acm.org> Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02USB: Option driver: Short driver names were identicalMatthias Urlichs
The short driver names were not unique, which prevented the driver from actually loading. Also, one of the ioctl pointers was missing. Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02USB: Option driver: removed change history and linux/version.h includeMatthias Urlichs
2006-07-12[PATCH] USB: move usb-serial.h to include/linux/usb/Greg Kroah-Hartman
USB serial outside of the kernel tree can not build properly due to usb-serial.h being buried down in the source tree. This patch moves the location of the file to include/linux/usb and fixes up all of the usb serial drivers to handle the move properly. Cc: Sergei Organov <osv@javad.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-12[PATCH] USB: Option driver: new product IDMatthias Urlichs
Yet another "same name, somewhat different hardware" product. Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: new devices for the Option driverMatthias Urlichs
This patch extends the "option" driver with a few more devices, some of which are actually connected to USB the "right" way -- as opposed to doing it via PCMCIA and OHCI. Signed-Off-By: Matthias Urlichs <smurf@debian.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB serial: encapsulate schedule_work, remove double-callingPete Zaitcev
I'm going to throw schedule_work away, it's retarded. But for starters, let's have it encapsulated. Also, generic and whiteheat were both calling usb_serial_port_softint and scheduled work. Only one was necessary. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-11[PATCH] Overrun in option-card USB driverMatthias Urlichs
Since the arrays are declared as in_urbs[N_IN_URB] and out_urbs[N_OUT_URB], both for loops go one over the end of the array. This fixes coverity id #555. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-Off-By: Linus Torvalds <torvalds@osdl.org>
2006-03-24fix typos "wich" -> "which"Uwe Zeisberger
Signed-off-by: Uwe Zeisberger <zeisberg@informatik.uni-freiburg.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-20[PATCH] USB: kzalloc() conversion for rest of drivers/usbEric Sesterhenn
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-10[PATCH] TTY layer buffering revampAlan Cox
The API and code have been through various bits of initial review by serial driver people but they definitely need to live somewhere for a while so the unconverted drivers can get knocked into shape, existing drivers that have been updated can be better tuned and bugs whacked out. This replaces the tty flip buffers with kmalloc objects in rings. In the normal situation for an IRQ driven serial port at typical speeds the behaviour is pretty much the same, two buffers end up allocated and the kernel cycles between them as before. When there are delays or at high speed we now behave far better as the buffer pool can grow a bit rather than lose characters. This also means that we can operate at higher speeds reliably. For drivers that receive characters in blocks (DMA based, USB and especially virtualisation) the layer allows a lot of driver specific code that works around the tty layer with private secondary queues to be removed. The IBM folks need this sort of layer, the smart serial port people do, the virtualisers do (because a virtualised tty typically operates at infinite speed rather than emulating 9600 baud). Finally many drivers had invalid and unsafe attempts to avoid buffer overflows by directly invoking tty methods extracted out of the innards of work queue structs. These are no longer needed and all go away. That fixes various random hangs with serial ports on overflow. The other change in here is to optimise the receive_room path that is used by some callers. It turns out that only one ldisc uses receive room except asa constant and it updates it far far less than the value is read. We thus make it a variable not a function call. I expect the code to contain bugs due to the size alone but I'll be watching and squashing them and feeding out new patches as it goes. Because the buffers now dynamically expand you should only run out of buffering when the kernel runs out of memory for real. That means a lot of the horrible hacks high performance drivers used to do just aren't needed any more. Description: tty_insert_flip_char is an old API and continues to work as before, as does tty_flip_buffer_push() [this is why many drivers dont need modification]. It does now also return the number of chars inserted There are also tty_buffer_request_room(tty, len) which asks for a buffer block of the length requested and returns the space found. This improves efficiency with hardware that knows how much to transfer. and tty_insert_flip_string_flags(tty, str, flags, len) to insert a string of characters and flags For a smart interface the usual code is len = tty_request_buffer_room(tty, amount_hardware_says); tty_insert_flip_string(tty, buffer_from_card, len); More description! At the moment tty buffers are attached directly to the tty. This is causing a lot of the problems related to tty layer locking, also problems at high speed and also with bursty data (such as occurs in virtualised environments) I'm working on ripping out the flip buffers and replacing them with a pool of dynamically allocated buffers. This allows both for old style "byte I/O" devices and also helps virtualisation and smart devices where large blocks of data suddenely materialise and need storing. So far so good. Lots of drivers reference tty->flip.*. Several of them also call directly and unsafely into function pointers it provides. This will all break. Most drivers can use tty_insert_flip_char which can be kept as an API but others need more. At the moment I've added the following interfaces, if people think more will be needed now is a good time to say int tty_buffer_request_room(tty, size) Try and ensure at least size bytes are available, returns actual room (may be zero). At the moment it just uses the flipbuf space but that will change. Repeated calls without characters being added are not cumulative. (ie if you call it with 1, 1, 1, and then 4 you'll have four characters of space. The other functions will also try and grow buffers in future but this will be a more efficient way when you know block sizes. int tty_insert_flip_char(tty, ch, flag) As before insert a character if there is room. Now returns 1 for success, 0 for failure. int tty_insert_flip_string(tty, str, len) Insert a block of non error characters. Returns the number inserted. int tty_prepare_flip_string(tty, strptr, len) Adjust the buffer to allow len characters to be added. Returns a buffer pointer in strptr and the length available. This allows for hardware that needs to use functions like insl or mencpy_fromio. Signed-off-by: Alan Cox <alan@redhat.com> Cc: Paul Fulghum <paulkf@microgate.com> Signed-off-by: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: John Hawkes <hawkes@sgi.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-04[PATCH] USB: remove .owner field from struct usb_driverGreg Kroah-Hartman
It is no longer needed, so let's remove it, saving a bit of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-04[PATCH] USB: allow usb drivers to disable dynamic idsGreg Kroah-Hartman
This lets drivers, like the usb-serial ones, disable the ability to add ids from sysfs. The usb-serial drivers are "odd" in that they are really usb-serial bus drivers, not usb bus drivers, so the dynamic id logic will have to go into the usb-serial bus core for those drivers to get that ability. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB Serial: move name to driver structureGreg Kroah-Hartman
This fixes up a lot of problems in sysfs with some of the usb serial drivers, they had incorrect driver names. Also saves a tiny ammount of memory. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB Serial: get rid of the .owner field in usb_serial_driverGreg Kroah-Hartman
Don't duplicate something that's already in struct driver. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] USB Serial: rename usb_serial_device_type to usb_serial_driverGreg Kroah-Hartman
I'm tired of trying to explain why a "device_type" is really a driver. This better describes exactly what this structure is. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-22[PATCH] usb/serial/option.c: Increase input buffer sizeMatthias Urlichs
The card sometimes sends >2000 bytes in one single chunk. Ouch. Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-22[PATCH] USB: more device IDs for Option card driverMatthias Urlichs
Added support for HUAWEI E600 and Audiovox AirCard User reports say that these devices work without driver modification. Signed-off-by: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-08[PATCH] USB: fix up URB_ASYNC_UNLINK usages from the usb-serial driversGreg Kroah-Hartman
2005-09-08[PATCH] USB: option card driver coding style tweaksAndrew Morton
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-07-14[PATCH] Option Card driver update, Maintainer entryMatthias Urlichs
This patch updates the Option Card driver: - remove a deadlock - add sponsor notice - add new card - renamed the device to what's usually printed on it - removed some dead code - clean up a bunch of irregular whitespace (end-of-line, tabs) Also add a MAINTAINERS entry for the Option Card driver. Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-03[PATCH] USB: add Option Card driverMatthias Urlichs
This patch adds a new driver for "Option" cards. This is a GSM data card, controlled by three "serial ports" which are connected via an OHCI adapter, all located on an oversized PC-Card. It's sold by several GSM service providers. Traditionally, this card has been accessed via the standard serial driver and appropriate vendor= and product= options. However, testing has revealed several problems with this approach, including hung data transfers and lost data blocks when receiving. Therefore, I've written a separate driver. Signed-off-by: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
