Add device ids to pl2303 for the Hewlett-Packard HP POS pole displays:
LD960: 03f0:0B39
LCM220: 03f0:3139
LCM960: 03f0:3239
[ Johan: fix indentation and sort PIDs numerically ]
Signed-off-by: Aaron Sanders <aaron.sanders@hp.com>
Cc: stable@vger.kernel.org
Signed-off-by: Johan Hovold <jhovold@gmail.com>
I get report from customer that his usb-serial
converter doesn't work well,it sometimes work,
but sometimes it doesn't.
The usb-serial converter's id:
vendor_id product_id
0x4348 0x5523
Then I search the usb-serial codes, and there are
two drivers announce support this device, pl2303
and ch341, commit 026dfaf1 cause it. Through many
times to test, ch341 works well with this device,
and pl2303 doesn't work quite often(it just work quite little).
ch341 works well with this device, so we doesn't
need pl2303 to support.I try to revert 026dfaf1 first,
but it failed. So I prepare this patch by hand to revert it.
Signed-off-by: Wang YanQing <Udknight@gmail.com>
Cc: stable <stable@vger.kernel.org>
Add vendor and product ID for the SMART USB to serial adapter. These
were meant to be used with their SMART Board whiteboards, but can be
re-purposed for other tasks. Tested and working (at at least 9600 bps).
Signed-off-by: Eric Benoit <eric@ecks.ca>
Cc: stable <stable@kernel.org>
Add ID 4348:5523 for WinChipHead USB->RS 232 adapter with
Prolifec PL2303 chipset
Added 0x0307 device id to support Motorola cables to the pl2303 usb
serial driver. This cable has a modified chip that is a pl2303, but
declares itself as 0307. Fixed by adding the right device id to the
supported devices list, assigning it the code labeled
PL2303_PRODUCT_ID_MOTOROLA.
Signed-off-by: Dario Lombardo <dario.lombardo@libero.it>
Add support for the Zeagle N2iTiON3 dive computer interface. Since
Zeagle devices are actually manufactured by Seiko, this patch will
support other Seiko based models as well.
Signed-off-by: Jef Driesen <jefdriesen@telenet.be>
Minor whitespace cleanups to make checkpatch happy.
I tried a magnetic stripe reader
(http://www.kimaldi.com/kimaldi_eng/productos/lectores_de_tarjetas/lectores_tarjeta_chip_y_dni/lector_hibrido_uniform_hcr_331)
and I see that it is interfaced with a PL2303. I wrote a patch to use
your driver which simply adds the product ID for the device and it
seems working fine.
I read a rumor that the AdLink ND6530 USB RS232, RS422 and RS485
isolated adapter is actually a PL2303 based usb serial adapter. I
tried it out, and as far as I can tell it works.
Signed-off-by: Manuel Jander <manuel.jander@gmail.com>
I'd like to present my small patch enabling to use Sanwa PC5000
mulitimeter with linux.
Signed-off-by: Pawel Ludwikow <pludwiko@rab.ict.pwr.wroc.pl>
I am submitting a patch for the pl2303 driver. This patch adds support
for the "Sony QN-3USB" cable (vendor=0x054c, product=0x0437). This USB
cable is a so-called data cable used to connect a Sony mobile phone to a
computer. Supported models are Sony CMD-J5, J6, J7, J16, J26, J70 and
Z7.
I have used this patch with my Sony CMD-J70 for several days and I
haven't encountered any kernel/hardware issue.
I recently bought a PC interface for the Cressi Edy dive computer
(www.cressi.it) and discovered that it uses the pl2303 chip, albeit
with ad-hoc vendor and product ids (04b8, 0521 respectively). Being in
the process of writing a linux software for such device (cressi only
provides a windows software), I patched the pl2303 linux driver to
have the interface recognized. I am submitting you the patch (very
basic) for inclusion in next kernel version.
Closes bug 9065
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Add id for the Hewlett-Packard LD220-HP POS pole display.
Bus 002 Device 002: ID 03f0:3524 Hewlett-Packard
Signed-off-by: Mike Provencher <mike.provencher@hp.com>
This patch adds the "Superial" USB-Serial converter to pl2303 so that it
is detected, by the correct driver. Adds the relevant vendor:product
(5372:2303) to the device tables in pl2303.c & pl2303.h. The patch has
been tested against 2.6.24-22-generic.
Signed-off-by: Matthew D Arnold <matthew.arnold-1@uts.edu.au>
USB ID 4348:5523 is handled by the ch341 driver. Remove it from the
pl2023 driver.
Reverts 002e8f2c80c6be76bb312940bc278fc10b2b2487.
Signed-off-by: Tollef Fog Heen <tfheen@err.no>
As reported by Ken A Scott <kscott9@sent.com>
Cc: Ken A Scott <kscott9@sent.com>
I've just got a USB GPRS/EDGE modem branded Manufacturer Micromax Model
MMX610U (see http://www.airtel.in/level2_t3data.aspx?path=1/106/179)
working by adding another product ID to pl2303. Modem info reports same
module as Max Arnold's i.e.SIMCOM SIM600 but with product ID 0x0612
(cf Ox0611).
This patch reverts 57833ea6b95a3995149f1f6d1a8d8862ab7a0ba2
("usb-serial: pl2303: add support for RATOC REX-USB60F") and adds
support for the device to ftdi_sio driver.
Cc: Akira Tsukamoto <akirat@rd.scei.sony.co.jp>
Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp>
Device like this http://aldiga.com/english/A-100-USB-EDGE10.htm
contains Prolific 2303 chip.
Actually their site a bit outdated - I have AlDiga AL-11U
GSM/GPRS/EDGE modem and it works with pl2303 module after adding
corresponding product ID.
By default modem uses baud rate 460800. GSM chipset - SIMCom SIM600,
quad band 850/900/1800/1900 MHz
Device info:
T: Bus=04 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 5 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=067b ProdID=0611 Rev= 0.00
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=pl2303
E: Ad=81(I) Atr=03(Int.) MxPS= 10 Ivl=1ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
This patch adds support for RATOC REX-USB60F Serial Adapters,
which is widely used in Japan recently.
Signed-off-by: Akira Tsukamoto <akirat@rd.scei.sony.co.jp>
Remove entry for Huawei E620 UMTS/HSDPA card (ID: 12d1:1001) in pl2303 driver
Option driver is use instead
Signed-off-by: Daniel Kozák <kozzi11@gmail.com>
This simply adds the "YC Cable" as a vendor and its pl2303-based
USB<->Serial adapter as a product. This particular adapter is sold by
Radio Shack. I've done limited testing on a few different systems with
no issues.
add support for:
4348:5523 WinChipHead USB->RS 232 adapter with Prolifec PL 2303 chipset
[ mingo@elte.hu: merged it and nursed it upstream ]
pl2303: add support for Corega CG-USBRS232R
This patch adds support for Corega CG-USBRS232R Serial Adapters.
Signed-off-by: Magnus Damm <damm@igel.co.jp>
This patch adds support for the IO Data Device USB-RSAQ5, PL2303 based
USB-serial converter, to pl2303 driver
Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp>
This patch adds support for the BenQ Mobile Phone EF81 to pl2303
Signed-off-by: Andreas Loibl <andreas@andreas-loibl.de>
Signed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Patch to add support for Alcor Micro Corp. USB 2.0 TO RS-232 converter.
This patch adds VID and PID to pl2303.[ch], adds it to the "HORRIBLE
HACK FOR PL2303" in usb-serial.c and also prevents cdc-acm to claim
driving this device by blacklisting it in hid-core.
Signed-off-by: Johannes Steingraeber <Jo_Stein@web.de>
This patch removes support for a clone of Nokia DKU-5 cable made by Ours
Technology Inc, as it turned out that the cable does not use the pl2303
chip, but OTI-6858 chip which is not compatible with the pl2303.
Signed-off-by: Tomasz Kazmierczak <tomek.fizyk@op.pl>
Can you add the USB IDs for the Belkin USB Serial adapter (P/N F5U257)
to the pl2303 driver in the Linux Kernel? Are you the appropriate person
to approach for this?
I recently purchased a Belkin USB Serial adapter (P/N F5U257) and found
that it didn't work. After a bit of experimentation I found that it
works with the pl2303 driver once the ID has been added. See attached
patch to fix this. Also attached is the output from lsusb -v just in
case you require any information from there.
The Susteen Datapilot cable
(http://www.susteen.com/productdetail/71/producthl/Notempty) has an
internal pl2303 to communicate with a set of dummy connector-ends that
connect to a variety of cell phones. I've found that it works right out
of the box by simply adding the product/vendor id to the pl2303 driver.
Signed-off-by: Matt Meno <mmeno@idealcorp.com>
Text from the back of the box, for your information/amusement:
USB DATA CABLE
FOR K700 Series
The USB Cable is an ideal link between your mobile phone and PC. Employing
the user-friendiy [sic] USB standard,its capacity for rapid data transfer enables functions
such as synchronization of phone book and calendar,as well as Internet browsing via
a modem-enabled phone.Autual [sic] connection speed is dependent on phone capacity.
MADE IN CHINA
From: Peter Moulder <Peter.Moulder@infotech.monash.edu.au>
Add new iTegno usb CDMA 1x card (usbid '0eba:2080') support to pl2303 driver
Signed-off-by: Wang Jun <wangjun1974@gmail.com>
This patch adds support for a clone of Nokia DKU-5 cable made by
Ours Technology Inc for Nokia phones with PopPort (Nokia 3100 and others).
The cable uses PL2303 USB-to-serial converter from Prolific Technology Inc.
The USB data cable for my Samsung GSM phone contains the USB-to-serial
converter chip MS3303H from Speed Dragon Multimedia, Inc. that appears to
be compatible with the PL2303 chip. The following patch adds support for
this chip to the pl2303 driver.
Signed-off-by: Dick Streefland <dick@streefland.net>
The patch adds the USB ID (0413:2101) for the Leadtek GPS-Mouse 9531 to
the driver pl2303.
Signed-off-by: Christian Lindner <christian.lindner@gmx.net>
Signed-off-by: FALIPOU F Developer <fred.falipou@free.fr>
Added support for CA-42 clone cable (www.ca-42.com)
Signed-off-by: Martin Gingras <martin.gingras@gmail.com>
This patch adds two new Siemens mobiles IDs for the pl2303 driver.
Signed-off-by: Luiz Capitulino <lcapitulino@mandriva.com.br>
This patch adds the product ID and vendor ID for a Nokia CA-42 USB cable
to the list of devices handled by the pl2303 driver. The patch is
against 2.6.13.
Signed-off-by: Robert Spanton <rds204@zepler.net>
Please accept the attached patch which adds the vendorid 0x0745 and
modelid 0x0001 (ID 0745:0001) "Syntech Information Co., Ltd."
The device is an USB IR cradle for a barcode scanner (CPT-8001C) from
Cipherlab.
diff -u kernel-source-2.6.11/drivers/usb/serial/pl2303.c ../kernel-source-2.6.11/drivers/usb/serial/pl2303.c
infrastructure for it.
Let it rip!
