commit b14de3857227cd978f515247853fd15cc2425d3e upstream.
If usb_deregister() is called after usb_serial_deregister() when
the device is plugged in, the following Oops occurs:
[ 95.337377] BUG: unable to handle kernel NULL pointer dereference at 00000010
[ 95.338236] IP: [<c0776b2d>] klist_put+0x12/0x62
[ 95.338356] *pdpt = 000000003001a001 *pde = 0000000000000000
[ 95.338356] Oops: 0000 [#1] SMP
[ 95.340499] last sysfs file: /sys/devices/pci0000:00/0000:00:1d.2/usb8/idVendor
[ 95.340499] Modules linked in: ti_usb_3410_5052(-) usbserial cpufreq_ondemand acpi_cpufreq mperf iptable_nat nf_nat iptable_mangle ip6t_REJECT nf_conntrack_ipv6 nf_defrag_ipv6 ip6table_filter ip6_tables ipv6 uinput arc4 ecb iwlagn iwlcore mac80211 cfg80211 microcode pcspkr acer_wmi joydev wmi sky2 [last unloaded: scsi_wait_scan]
[ 95.341908]
[ 95.341908] Pid: 1532, comm: modprobe Not tainted 2.6.37-rc7+ #6 Eiger /Aspire 5930
[ 95.341908] EIP: 0060:[<c0776b2d>] EFLAGS: 00010246 CPU: 0
[ 95.341908] EIP is at klist_put+0x12/0x62
[ 95.341908] EAX: 00000000 EBX: eedc0c84 ECX: c09c21b4 EDX: 00000001
[ 95.341908] ESI: 00000000 EDI: efaa0c1c EBP: f214fe2c ESP: f214fe1c
[ 95.341908] DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068
[ 95.341908] Process modprobe (pid: 1532, ti=f214e000 task=efaaf080 task.ti=f214e000)
[ 95.341908] Stack:
[ 95.341908] f214fe24 eedc0c84 efaaf080 efaa0c1c f214fe34 c0776ba8 f214fe5c c0776c76
[ 95.341908] c09c21b4 c09c21b4 eedc0c84 efaaf080 00000000 c0634398 eafe2d1c f7b515f0
[ 95.341908] f214fe6c c0631b5c eafe2d50 eafe2d1c f214fe7c c0631ba2 eafe2d1c eafe2c00
[ 95.341908] Call Trace:
[ 95.341908] [<c0776ba8>] ? klist_del+0xd/0xf
[ 95.341908] [<c0776c76>] ? klist_remove+0x48/0x74
[ 95.341908] [<c0634398>] ? devres_release_all+0x49/0x51
[ 95.341908] [<c0631b5c>] ? __device_release_driver+0x7b/0xa4
[ 95.341908] [<c0631ba2>] ? device_release_driver+0x1d/0x28
[ 95.341908] [<c06317c4>] ? bus_remove_device+0x92/0xa1
[ 95.341908] [<c062f3d8>] ? device_del+0xf9/0x13e
[ 95.341908] [<f7b06146>] ? usb_serial_disconnect+0xd9/0x116 [usbserial]
[ 95.341908] [<c0681e3f>] ? usb_disable_interface+0x32/0x40
[ 95.341908] [<c0683972>] ? usb_unbind_interface+0x48/0xfd
[ 95.341908] [<c0631b43>] ? __device_release_driver+0x62/0xa4
[ 95.341908] [<c06320b9>] ? driver_detach+0x62/0x81
[ 95.341908] [<c0631a41>] ? bus_remove_driver+0x8f/0xae
[ 95.341908] [<c063214c>] ? driver_unregister+0x50/0x57
[ 95.341908] [<c0682f95>] ? usb_deregister+0x77/0x84
[ 95.341908] [<f7b505b6>] ? ti_exit+0x26/0x28 [ti_usb_3410_5052]
[ 95.341908] [<c046a307>] ? sys_delete_module+0x181/0x1de
[ 95.341908] [<c04e2727>] ? path_put+0x1a/0x1d
[ 95.341908] [<c047f4c5>] ? audit_syscall_entry+0x116/0x138
[ 95.341908] [<c04094df>] ? sysenter_do_call+0x12/0x28
[ 95.341908] Code: 00 83 7d f0 00 74 09 85 f6 74 05 89 f0 ff 55 f0 8b 43 04 5a 5b 5e 5f 5d c3 55 89 e5 57 56 53 89 c3 83 ec 04 8b 30 83 e6 fe 89 f0 <8b> 7e 10 88 55 f0 e8 47 26 01 00 8a 55 f0 84 d2 74 17 f6 03 01
[ 95.341908] EIP: [<c0776b2d>] klist_put+0x12/0x62 SS:ESP 0068:f214fe1c
[ 95.341908] CR2: 0000000000000010
[ 95.342357] ---[ end trace 8124d00ad871ad18 ]---
Signed-off-by: Ionut Nicu <ionut.nicu@mindbit.ro>
And indeed none of them use it. Clean this up as it will make moving to a
standard open method rather easier.
Signed-off-by: Alan Cox <alan@linux.intel.com>
This function does not have an error return and returning an error is
instead interpreted as having a lot of pending bytes.
Reported by Jeff Harris who provided a list of some of the remaining
offenders.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Cc: stable <stable@kernel.org>
commit 1a1fab513734b3a4fca1bee8229e5ff7e1cb873c accidentally added the
device id to both tables in the driver, which causes problems as this is
only a single port device, not a multiple port device.
This patch (as1254) splits up the shutdown method of usb_serial_driver
into a disconnect and a release method.
The problem is that the usb-serial core was calling shutdown during
disconnect handling, but drivers didn't expect it to be called until
after all the open file references had been closed. The result was an
oops when the close method tried to use memory that had been
deallocated by shutdown.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
This allows us to clean stuff up, but is probably also going to cause
some app breakage with buggy apps as we now implement proper POSIX behaviour
for USB ports matching all the other ports. This does also mean other apps
that break on USB will now work properly.
Signed-off-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
This removes tty->low_latency from all USB serial drivers that push
data into the tty layer at hard interrupt context. It's no longer needed
and actually harmful.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
If the ti-usb adapter returns an zero data length frame (which happens)
then we leak a kref. Found by Christoph Mair <christoph.mair@gmail.com>
who proposed a patch. The patch here is different as Christoph's patch
didn't work for the case where tty = NULL and data arrived but Christoph
did all the hard work chasing it down.
This patch adds device IDs and balances the counts to make the
hot ID additioning mechanism work.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Cc: Chris Adams <cmadams@hiwaay.net>
This adds a new device id
Add the Multi-Tech cellular modem firmware to the TI USB serial driver.
This firmware was extracted from:
ftp://ftp.multitech.com/wireless/wireless_linux.zip
Firmware licence: "all firmware components are redistributable in binary
form" per support@multitech.com
Copyright (C) 2005 Multi-Tech Systems, Inc.
Signed-off-by: Chris Adams <cmadams@hiwaay.net>
Signed-off-by: Alan Cox <alan@redhat.com>
Add Multi-Tech cellular modem support to the ti_usb_3410_5052 driver.
The TI USB serial driver supports specifying alternate vendor and
product IDs (since the chips can and are used in devices under other
vendor/product IDs). However, the alternate IDs were not loaded in the
combined product table. This patch also adds support for loading
alternate firmware for alternate vendor/product IDs.
This driver transfers firmware. It may just as well set the correct
configuration.
USB should not be having it's own printk macros, so remove info() and
use the system-wide standard of dev_info() wherever possible.
Removed duplicated #include <linux/firmware.h> in
drivers/usb/serial/ti_usb_3410_5052.c.
Signed-off-by: Huang Weiyi <hwy@cn.fujitsu.com>
Use kref in the USB serial drivers so that we don't free tty structures
from under the URB receive handlers as has historically been the case if
you were unlucky. This also gives us a framework for general tty drivers to
use tty_port objects and refcount.
Contains two err->dev_err changes merged together to fix clashes in the
-next tree.
While making some other changes to ti_usb_3410_5052, I noticed that the
changes made to move the firmware loading to a separate function are
broken (in ti_download_firmware(), status is set to -ENOMEM and never
changed). This means the driver will never initialize the device
properly. It looks like status was supposed to get the result of
ti_do_download().
USB serial likes to use port->tty back pointers for the real work it does and
to do so without any actual locking. Unfortunately when you consider hangup
events, hangup/parallel reopen or even worse hangup followed by parallel close
events the tty->port and port->tty pointers are not guaranteed to be the same
as port->tty is the active tty while tty->port is the port the tty may or
may not still be attached to.
So rework the entire API to pass the tty struct. For console cases we need
to pass both for now. This shows up multiple drivers that immediately crash
with USB console some of which have been fixed in the process.
Longer term we need a proper tty as console abstraction
urb->context code cleanup
Signed-off-by: Ming Lei <tom.leiming@gmail.com>
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
The usb-serial core no longer checks these fields so remove them from
all of the individual drivers. They will be removed from the usb-serial
core in a patch later in the series.
None of these files use any of the functionality promised by
asm/semaphore.h. It's possible that they rely on it dragging in some
unrelated header file, but I can't build all these files, so we'll have
fix any build failures as they come up.
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
The changes introduced in commit
063a2da8f01806906f7d7b1a1424b9afddebc443 changed the semantics of the
num_interrupt_in, num_interrupt_out, num_bulk_in and num_bulk_out
entries of the usb_serial_driver struct to be the number of endpoints
the device has when probed.
This patch changes the ti_1port_device usb_serial_driver struct to
reflect this change. The single port devices only have 1
bulk_out endpoint in their initial configuration, and so this patch
changes the number of other types to NUM_DONT_CARE.
The same change probably needs doing to the ti_2port_device struct,
but I don't have a two port device at hand.
Signed-off-by: Robert Spanton <rspanton@zepler.net>
these drivers abused intfdata in close() as flags for binding.
That races with reprobing of those devices. This patch fixes that by using
the flag and the locks introduced with the patch against mos7720.
Remove internal NULL passing in termios code
Remove all the if checks it causes
Encode the baud rate back properly
Clear CMSPAR as it is not supported
TI 3410/5052 USB Serial: convert semaphore td_open_close_lock to the mutex
API.
Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com>
... should be unsigned int
This done in anticipation of removal of urb->status, which will make
that patch easier to review and apply in the future.
Cc: <linux-usb-devel@lists.sourceforge.net>
Cc: Al Borchers <alborchers@steinerpoint.com>
Cc: Peter Berger <pberger@brimson.com>
you are submitting an URB with GFP_KERNEL holding a spinlock.
In this case the spinlock can be dropped earlier.
Every usb serial driver should have a pointer to the corresponding usb driver.
So the usb serial core can add a new id not only to the usb serial driver, but
also to the usb driver.
Also the usb drivers of ark3116, mos7720 and mos7840 missed the flag
no_dynamic_id=1. This is added now.
Signed-off-by: Johannes Hölzl <johannes.hoelzl@gmx.de>
Run this:
#!/bin/sh
for f in $(grep -Erl "\([^\)]*\) *k[cmz]alloc" *) ; do
echo "De-casting $f..."
perl -pi -e "s/ ?= ?\([^\)]*\) *(k[cmz]alloc) *\(/ = \1\(/" $f
done
And then go through and reinstate those cases where code is casting pointers
to non-pointers.
And then drop a few hunks which conflicted with outstanding work.
Cc: Russell King <rmk@arm.linux.org.uk>, Ian Molton <spyro@f2s.com>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Yoshinori Sato <ysato@users.sourceforge.jp>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Kyle McMartin <kyle@mcmartin.ca>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Greg KH <greg@kroah.com>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Paul Fulghum <paulkf@microgate.com>
Cc: Karsten Keil <kkeil@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Ian Kent <raven@themaw.net>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Jaroslav Kysela <perex@suse.cz>
Cc: Takashi Iwai <tiwai@suse.de>
This is the grungy swap all the occurrences in the right places patch that
goes with the updates. At this point we have the same functionality as
before (except that sgttyb() returns speeds not zero) and are ready to
begin turning new stuff on providing nobody reports lots of bugs
If you are a tty driver author converting an out of tree driver the only
impact should be termios->ktermios name changes for the speed/property
setting functions from your upper layers.
If you are implementing your own TCGETS function before then your driver
was broken already and its about to get a whole lot more painful for you so
please fix it 8)
Also fill in c_ispeed/ospeed on init for most devices, although the current
code will do this for you anyway but I'd like eventually to lose that extra
paranoia
[akpm@osdl.org: bluetooth fix]
[mp3@de.ibm.com: sclp fix]
[mp3@de.ibm.com: warning fix for tty3270]
[hugh@veritas.com: fix tty_ioctl powerpc build]
[jdike@addtoit.com: uml: fix ->set_termios declaration]
Signed-off-by: Martin Peschke <mp3@de.ibm.com>
Acked-by: Peter Oberparleiter <oberpar@de.ibm.com>
Cc: Cornelia Huck <cornelia.huck@de.ibm.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Replace kmalloc+memset with kzalloc
Signed-off-by: Yan Burman <yan_952@hotmail.com>
usb-serial: ti_usb, TI ez430 development tool ID
Signed-off-by: Oleg Verych <olecom@flower.upol.cz>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
USB serial outside of the kernel tree can not build properly due to
usb-serial.h being buried down in the source tree. This patch moves the
location of the file to include/linux/usb and fixes up all of the usb
serial drivers to handle the move properly.
Cc: Sergei Organov <osv@javad.com>
Signed-off-by: Jörn Engel <joern@wohnheim.fh-wedel.de>
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
The API and code have been through various bits of initial review by
serial driver people but they definitely need to live somewhere for a
while so the unconverted drivers can get knocked into shape, existing
drivers that have been updated can be better tuned and bugs whacked out.
This replaces the tty flip buffers with kmalloc objects in rings. In the
normal situation for an IRQ driven serial port at typical speeds the
behaviour is pretty much the same, two buffers end up allocated and the
kernel cycles between them as before.
When there are delays or at high speed we now behave far better as the
buffer pool can grow a bit rather than lose characters. This also means
that we can operate at higher speeds reliably.
For drivers that receive characters in blocks (DMA based, USB and
especially virtualisation) the layer allows a lot of driver specific
code that works around the tty layer with private secondary queues to be
removed. The IBM folks need this sort of layer, the smart serial port
people do, the virtualisers do (because a virtualised tty typically
operates at infinite speed rather than emulating 9600 baud).
Finally many drivers had invalid and unsafe attempts to avoid buffer
overflows by directly invoking tty methods extracted out of the innards
of work queue structs. These are no longer needed and all go away. That
fixes various random hangs with serial ports on overflow.
The other change in here is to optimise the receive_room path that is
used by some callers. It turns out that only one ldisc uses receive room
except asa constant and it updates it far far less than the value is
read. We thus make it a variable not a function call.
I expect the code to contain bugs due to the size alone but I'll be
watching and squashing them and feeding out new patches as it goes.
Because the buffers now dynamically expand you should only run out of
buffering when the kernel runs out of memory for real. That means a lot of
the horrible hacks high performance drivers used to do just aren't needed any
more.
Description:
tty_insert_flip_char is an old API and continues to work as before, as does
tty_flip_buffer_push() [this is why many drivers dont need modification]. It
does now also return the number of chars inserted
There are also
tty_buffer_request_room(tty, len)
which asks for a buffer block of the length requested and returns the space
found. This improves efficiency with hardware that knows how much to
transfer.
and tty_insert_flip_string_flags(tty, str, flags, len)
to insert a string of characters and flags
For a smart interface the usual code is
len = tty_request_buffer_room(tty, amount_hardware_says);
tty_insert_flip_string(tty, buffer_from_card, len);
More description!
At the moment tty buffers are attached directly to the tty. This is causing a
lot of the problems related to tty layer locking, also problems at high speed
and also with bursty data (such as occurs in virtualised environments)
I'm working on ripping out the flip buffers and replacing them with a pool of
dynamically allocated buffers. This allows both for old style "byte I/O"
devices and also helps virtualisation and smart devices where large blocks of
data suddenely materialise and need storing.
So far so good. Lots of drivers reference tty->flip.*. Several of them also
call directly and unsafely into function pointers it provides. This will all
break. Most drivers can use tty_insert_flip_char which can be kept as an API
but others need more.
At the moment I've added the following interfaces, if people think more will
be needed now is a good time to say
int tty_buffer_request_room(tty, size)
Try and ensure at least size bytes are available, returns actual room (may be
zero). At the moment it just uses the flipbuf space but that will change.
Repeated calls without characters being added are not cumulative. (ie if you
call it with 1, 1, 1, and then 4 you'll have four characters of space. The
other functions will also try and grow buffers in future but this will be a
more efficient way when you know block sizes.
int tty_insert_flip_char(tty, ch, flag)
As before insert a character if there is room. Now returns 1 for success, 0
for failure.
int tty_insert_flip_string(tty, str, len)
Insert a block of non error characters. Returns the number inserted.
int tty_prepare_flip_string(tty, strptr, len)
Adjust the buffer to allow len characters to be added. Returns a buffer
pointer in strptr and the length available. This allows for hardware that
needs to use functions like insl or mencpy_fromio.
Signed-off-by: Hirokazu Takata <takata@linux-m32r.org>
Signed-off-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: John Hawkes <hawkes@sgi.com>
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove
duplicates of ARRAY_SIZE. Some trailing whitespaces are also removed.
Patch is compile-tested on i386.
Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch>
It is no longer needed, so let's remove it, saving a bit of memory.
This lets drivers, like the usb-serial ones, disable the ability to add
ids from sysfs.
The usb-serial drivers are "odd" in that they are really usb-serial bus
drivers, not usb bus drivers, so the dynamic id logic will have to go
into the usb-serial bus core for those drivers to get that ability.
This fixes up a lot of problems in sysfs with some of the usb serial
drivers, they had incorrect driver names. Also saves a tiny ammount
of memory.
Don't duplicate something that's already in struct driver.
I'm tired of trying to explain why a "device_type" is really a driver.
This better describes exactly what this structure is.
