The definitions in ti_usb_3410_5052.h are only used in
ti_usb_3410_5052.c.
The content of the header is copied in ti_usb_3410_5052.c.
Also correct a typo in macro TI_PIPE_MODE_CONTINOUS.
Signed-off-by: Mathieu OTHACEHE <m.othacehe@gmail.com>
[johan: actually remove the header file ]
Signed-off-by: Johan Hovold <johan@kernel.org>
__packed is preferred over __attribute__((packed)) for portability.
Add support for :
- UPort 1110 : 1 port RS-232 USB to Serial Hub.
- UPort 1130 : 1 port RS-422/485 USB to Serial Hub.
- UPort 1130I : 1 port RS-422/485 USB to Serial Hub with Isolation.
- UPort 1150 : 1 port RS-232/422/485 USB to Serial Hub.
- UPort 1150I : 1 port RS-232/422/485 USB to Serial Hub with Isolation.
These devices are based on TI 3410 chip.
[johan: fix rs485-only check ]
The Honeywell HGI80 is a wireless interface to the evohome connected
thermostat. It uses a TI 3410 USB-serial port.
Cc: stable@vger.kernel.org
Add product id for Abbott strip port cable for Precision meter which
uses the TI 3410 chip.
Signed-off-by: Anders Hammarquist <iko@iko.pp.se>
Cc: stable <stable@vger.kernel.org>
The Kontron M2M development board, also known as the Fish River Island II,
has an optional daughter card providing access to the PCH_UART (EG20T) via
a ti_usb_3410_5052 uart to usb chip.
http://us.kontron.com/products/systems+and+platforms/m2m/m2m+smart+services+developer+kit.html
Signed-off-by: Darren Hart <dvhart@linux.intel.com>
CC: Al Borchers <alborchers@steinerpoint.com>
CC: Peter Berger <pberger@brimson.com>
This USB-serial cable with mini stereo jack enumerates as:
Bus 001 Device 004: ID 1a61:3410 Abbott Diabetes Care
It is a TI3410 inside.
Signed-off-by: Andrew Lunn <andrew@lunn.ch>
The following patch adds support for Multitech Systems' MT9234MU and
MT9234ZBA usb dialup fax modems. It is based on a patch and firmware
provided to me by Multitech Systems' support, after I reported to them
that my MT9234MU modem was not working with recent linux kernels.
Signed-off-by: Alex Manoussakis <alex@juniper.net>
This patch adds device IDs and balances the counts to make the
hot ID additioning mechanism work.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Cc: stable <stable@kernel.org>
Cc: Chris Adams <cmadams@hiwaay.net>
This adds a new device id
Add Multi-Tech cellular modem support to the ti_usb_3410_5052 driver.
Signed-off-by: Chris Adams <cmadams@hiwaay.net>
Signed-off-by: Alan Cox <alan@redhat.com>
usb-serial: ti_usb, TI ez430 development tool ID
Signed-off-by: Oleg Verych <olecom@flower.upol.cz>
infrastructure for it.
Let it rip!
