commit b81c2c33eab79dfd3650293b2227ee5c6036585c upstream.
Add new Motorola Tetra device id for Motorola Solutions TETRA PEI device
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0cad ProdID=9016 Rev=24.16
S: Manufacturer=Motorola Solutions, Inc.
S: Product=TETRA PEI interface
C: #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=usb_serial_simple
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=usb_serial_simple
Signed-off-by: Max Schulze <max.schulze@posteo.de>
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit f5fad711c06e652f90f581fc7c2caee327c33d31 upstream.
Add device-id for the Motorola Tetra radio MTP6550.
Bus 001 Device 004: ID 0cad:9012 Motorola CGISS
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0cad Motorola CGISS
idProduct 0x9012
bcdDevice 24.16
iManufacturer 1 Motorola Solutions, Inc.
iProduct 2 TETRA PEI interface
iSerial 0
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 55
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 3 Generic Serial config
bmAttributes 0x80
(Bus Powered)
MaxPower 500mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
Reported-by: Hans Hult <hanshult35@gmail.com>
commit fe710508b6ba9d28730f3021fed70e7043433b2e upstream.
Add simple driver for libtransistor USB console.
This device is implemented in software:
https://github.com/reswitched/libtransistor/blob/development/lib/usb_serial.c
Signed-off-by: Collin May <collin@collinswebsite.com>
commit 46fe895e22ab3845515ec06b01eaf1282b342e29 upstream.
Add new Motorola Tetra (simple) driver for Motorola Solutions TETRA PEI
devices.
P: Vendor=0cad ProdID=9011 Rev=24.16
S: Manufacturer=Motorola Solutions Inc.
S: Product=Motorola Solutions TETRA PEI interface
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
Note that these devices do not support the CDC SET_CONTROL_LINE_STATE
request (for any interface).
Reported-by: Max Schulze <max.schulze@posteo.de>
Tested-by: Max Schulze <max.schulze@posteo.de>
This patch adds support for Infineon flashloader 0x8087/0x0801.
The flashloader is used in Telit LE940B modem family with Telit
flashing application.
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
The flash loader has been seen on a Telit UE910 modem. The flash loader
is a bit special, it presents both an ACM and CDC Data interface but
only the latter is useful. Unless a magic string is sent to the device
it will disappear and the regular modem device appears instead.
Signed-off-by: Jonas Jonsson <jonas@ludd.ltu.se>
Tested-by: Daniele Palmas <dnlplm@gmail.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big set of USB and PHY patches for 3.19-rc1.
The normal churn in the USB gadget area is in here, as well as xhci
and other individual USB driver updates. The PHY tree is also in
here, as there were dependancies on the USB tree.
All of these have been in linux-next"
* tag 'usb-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (351 commits)
arm: omap3: twl: remove usb phy init data
usbip: fix error handling in stub_probe()
usb: gadget: udc: missing curly braces
USB: mos7720: delete some unneeded code
wusb: replace memset by memzero_explicit
usbip: remove unneeded structure
usb: xhci: fix comment for PORT_DEV_REMOVE
xhci: don't use the same variable for stopped and halted rings current TD
xhci: clear extra bits from slot context when setting max exit latency
xhci: cleanup finish_td function
USB: adutux: NULL dereferences on disconnect
usb: chipidea: fix platform_no_drv_owner.cocci warnings
usb: chipidea: Fixed a few typos in comments
Documentation: bindings: add doc for the USB2 ChipIdea USB driver
usb: chipidea: add a usb2 driver for ci13xxx
usb: chipidea: fix phy handling
usb: chipidea: remove duplicate dev_set_drvdata for host_start
usb: chipidea: parameter 'mode' isn't needed for hw_device_reset
usb: chipidea: add controller reset API
usb: chipidea: remove flag CI_HDRC_REQUIRE_TRANSCEIVER
current trivial.git base
Add support for Google devices that export simple serial
interfaces using the vendor specific SubClass/Protocol pair
0x50/0x01.
Signed-off-by: Anton Staaf <robotboy@chromium.org>
Reviewed-by: Benson Leung <bleung@chromium.org>
[johan: move id entries and update Kconfig]
Signed-off-by: Roman Mindalev <r000n@r000n.net>
Add simple driver for Medtronic CareLink USB devices.
Reported-by: Benjamin West <bewest@gmail.com>
Tested-by: Benjamin West <bewest@gmail.com>
Add simple driver for Novatel Wireless GPS receivers.
Reported-by: Kirk Madsen <kirkm@Navsys.com>
Tested-by: Kirk Madsen <kirkm@Navsys.com>
Add support for multi-port simple drivers.
Add support for ANT USB-m Stick from Dynastream Innovations, by listing
USB pid
[34366.944805] usb 6-1: New USB device found, idVendor=0fcf, idProduct=1009
[34366.944817] usb 6-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[34366.944824] usb 6-1: Product: ANT USB-m Stick
[34366.944831] usb 6-1: Manufacturer: Dynastream Innovations
Device reported (https://code.google.com/p/antpm/issues/detail?id=5) to
work through:
$ modprobe usbserial vendor=0x0fcf product=0x1009
Signed-off-by: Kristóf Ralovich <kristof.ralovich@gmail.com>
Signed-off-by: Johan Hovold <jhovold@gmail.com>
None of these files are actually using any __init type directives
and hence don't need to include <linux/init.h>. Most are just a
left over from __devinit and __cpuinit removal, or simply due to
code getting copied from one driver to the next.
usb-serial-simple uses an unknown stringify macro that make
all drivers being named "stringify(vendor)".
This can be a problem when two drivers have the same (wrong) name:
kernel: usbcore: registered new interface driver usb_serial_simple
kernel: usbserial: USB Serial support registered for stringify(vendor)
kernel Error: Driver 'stringify(vendor)' is already registered, aborting...
kernel: usbserial: problem -16 when registering driver stringify(vendor)
kernel: usbserial: USB Serial deregistering driver stringify(vendor)
kernel: usbcore: deregistering interface driver usb_serial_simple
Before the fix:
$ strings drivers/usb/serial/usb-serial-simple.o
usb_serial_simple
stringify(vendor)
After the fix:
usb_serial_simple
funsoft
flashloader
vivopay
moto_modem
hp4x
suunto
siemens_mpi
This patch makes usb-serial-simple use the correct stringify operator.
Signed-off-by: Yann Droneaud <ydroneaud@opteya.com>
Instead of having to create a new driver for a "simple" usb to serial
device, mush them all into one file, with a macro, so as to make it easy
to add new ones.
Cc: "René Bürgel" <rene.buergel@sohard.de>
Acked-by: Wei Shuai <cpuwolf@gmail.com>
Cc: Josh Triplett <josh@joshtriplett.org>
Acked-by: Frans Klaver <frans.klaver@xsens.com>
Cc: "Wesley W. Terpstra" <w.terpstra@gsi.de>
Cc: Johan Hovold <jhovold@gmail.com>
