path: root/drivers/usb/serial/wishbone-serial.c
2014-01-08usb: delete non-required instances of include <linux/init.h>Paul Gortmaker
None of these files are actually using any __init type directives and hence don't need to include <linux/init.h>. Most are just a left over from __devinit and __cpuinit removal, or simply due to code getting copied from one driver to the next. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-11USB: serial: wishbone-serial: fix up minor sparse warningGreg Kroah-Hartman
This fixes a sparse warning where we should be using NULL instead of 0 Cc: Wesley W. Terpstra <w.terpstra@gsi.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-04-11usb-serial: add support for USB Wishbone-serial adaptersWesley W. Terpstra
Wishbone is an open hardware SoC bus commonly used in FPGA designs. Bus access can be serialized using the Etherbone protocol <http://www.ohwr.org/projects/etherbone-core>. This driver is intended to be used with devices which attach their internal Wishbone bus to a USB serial interface using the Etherbone protocol. A userspace library is required to speak the protocol made available by this driver as ttyUSBx. Signed-off-by: Wesley W. Terpstra <w.terpstra@gsi.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
