path: root/drivers/usb/storage/datafab.c
2009-09-23USB: storage: Drop an unneeded a NULL testJulia Lawall
In each case, the NULL test is not necessary because the function is static and at the only places where it is called, the us argument has already been dereferenced. The semantic patch that finds the problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @@ type T; expression E,E1; identifier i,fld; statement S; @@ - T i = E->fld; + T i; ... when != E=E1 when != i if (E == NULL||...) S + i = E->fld; // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24USB: usb-storage: added missing MODULE_LICENSE("GPL") for usb-storage ums-* ↵Maciej Grela
modules The lack of a MODULE_LICENSE macro in ums-* subdrivers prevented them from loading. Needs to be applied after Alan Stern's usb-storage subdriver separation patchset. Also added missing MODULE_DESCRIPTION and MODULE_AUTHOR entries. Signed-off-by: Maciej Grela <maciej.grela@gmail.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24usb-storage: make datafab a separate moduleAlan Stern
This patch (as1213) converts usb-storage's datafab subdriver into a separate module. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-16USB storage: sg chaining supportJens Axboe
[PATCH] USB storage: sg chaining support Modify usb_stor_access_xfer_buf() to take a pointer to an sg entry pointer, so we can keep track of that instead of passing around an integer index (which we can't use when dealing with multiple scatterlist arrays). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-03-20[PATCH] USB: kzalloc for storageOliver Neukum
another one for kzalloc. This covers the storage subdirectory. Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
