path: root/drivers/usb/storage/protocol.h
2009-01-07USB: usb-storage: merge ATAPI and QIC-157 protocol routinesAlan Stern
This patch (as1174) merges usb-storage's QIC-157 and ATAPI protocol routines. Since the two functions are identical, there's no reason to keep them separate. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: remove CVS keywordsAdrian Bunk
This patch removes CVS keywords that weren't updated for a long time from comments. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-16USB storage: sg chaining supportJens Axboe
[PATCH] USB storage: sg chaining support Modify usb_stor_access_xfer_buf() to take a pointer to an sg entry pointer, so we can keep track of that instead of passing around an integer index (which we can't use when dealing with multiple scatterlist arrays). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-01-04[PATCH] USB: drivers/usb/storage/libusualPete Zaitcev
This patch adds a shim driver libusual, which routes devices between usb-storage and ub according to the common table, based on unusual_devs.h. The help and example syntax is in Kconfig. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
