path: root/drivers/usb/storage/shuttle_usbat.h
2006-06-21[PATCH] USB: shuttle_usbat: Hardcode detection of HP CDRW devicesPeter Chubb
Use USB vendor and product IDs to determine whether the attached device is a CDROM or a Flash device. Daniel Drake says that the *same* vendor and product IDs for non-HP vendor ID could be either flash or cdrom, so try to probe for them. Signed-off-by: Peter Chubb <peterc@gelato.unsw.edu.au> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] usb-storage: Some minor shuttle_usbat cleanupsDaniel Drake
A while ago, Matthew Dharm wrote: > Looks good. Tho, I would like to see a future patch to do two things: > 1) Change comments from C++ style to C-style > 2) Make sure we're naming consistently everywhere SCM, USBAT, > USBAT-02 (most noticably needing fixing is the string used at > transport-selection time, but a sweep of all uses to be consistent > would be in order). Sorry for the long delay, here is a patch to address this. I also clarified some ATA/ATAPI wording + function names. Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> drivers/usb/storage/shuttle_usbat.c | 306 ++++++++++++++++++++---------------- drivers/usb/storage/shuttle_usbat.h | 66 +++---- drivers/usb/storage/transport.h | 2 drivers/usb/storage/unusual_devs.h | 10 - drivers/usb/storage/usb.c | 4 5 files changed, 213 insertions(+), 175 deletions(-)
