path: root/drivers/usb/storage/transport.c
2008-04-24USB: remove unnecessary type casting of urb->contextMing Lei
urb->context code cleanup Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: mass storage: emulation of sat scsi_pass_thru with ATACBmatthieu castet
I have got a cypress usb-ide bridge and I would like to tune or monitor my disk with tools like hdparm, hddtemp or smartctl. My controller support a way to send raw ATA command to the disk with something call atacb (see http://download.cypress.com.edgesuite.net/design_resources/datasheets/contents/cy7c68300c_8.pdf). Atacb support can be added for each application, but there is some disadvantages : - all application need to be patched - A race is possible if there other accesses, because the emulation can be split in 2 atacb scsi transactions. One for sending the command, one for reading the register (if ck_cond is set). I have implemented the emulation in usb-storage with a special proto_handler, and an unsual entry. Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-24USB: add support for Motorola ROKR Z6 cellphone in mass storage modeConstantin Baranov
Motorola ROKR Z6 cellphone has bugs in its USB, so it is impossible to use it as mass storage. Patch describes new "unusual" USB device for it with FIX_INQUIRY and FIX_CAPACITY flags and new BULK_IGNORE_TAG flag. Last flag relaxes check for equality of bcs->Tag and us->tag in usb_stor_Bulk_transport routine. Signed-off-by: Constantin Baranov <const@tltsu.ru> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Daniel Drake <dsd@gentoo.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21USB: usb-storage: don't clear-halt when Get-Max-LUN stallsAlan Stern
This patch (as1032) removes the Clear-Halt calls in usb_stor_Bulk_max_lun(). Evidently some devices (such as the Oracom MP3 player) really don't like to receive these requests when their bulk endpoints aren't halted. The only reason for adding them originally was to get an ancient ZIP-100 drive to work. But since this device has only a single LUN, we don't need to send it a Get-Max-LUN request at all. Adding an unusual_devs entry for the ZIP-100 with the SINGLE_LUN flag set will cause this step to be skipped. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-01-11[SCSI] usb: transport - convert to accessors and !use_sg code path removalBoaz Harrosh
- This patch depends on: usb: transport.c use scsi_eh API in REQUEST_SENSE execution - Use scsi data accessors and remove of !use_sg code path. - New usb_stor_bulk_srb() for use by drivers [jejb: updated with corrective fix. had a bug in residual handling in the new usb_stor_bulk_srb() function. Found by Gabriel C. in -mm tree. Tested-by: Gabriel C <nix.or.die@googlemail.com> ] Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Matthew Dharm <mdharm-scsi@one-eyed-alien.net> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-12[SCSI] usb storage: use scsi_eh API in REQUEST_SENSE executionBoaz Harrosh
- Use new scsi_eh_prep/restor_cmnd() for synchronous REQUEST_SENSE invocation. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-12-07[PATCH] slab: remove SLAB_NOIOChristoph Lameter
SLAB_NOIO is an alias of GFP_NOIO with a single instance of use. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-09-27USB: Dealias -110 code (more complete)Pete Zaitcev
The purpose of this patch is to split off the case when a device does not reply on the lower level (which is reported by HC hardware), and a case when the device accepted the request, but does not reply at upper level. This redefinition allows to diagnose issues easier, without asking the user if the -110 happened "immediately". The usbmon splits such cases already thanks to its timestamp, but it's not always available. I adjusted all drivers which I found affected (by searching for "urb"). Out of tree drivers may suffer a little bit, but I do not expect much breakage. At worst they may print a few messages. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-10[PATCH] usb-storage: wait for URB to completeAlan Stern
We all failed to notice that Franck's recent update to usb-storage allowed an URB to complete after its context data was no longer valid. This patch (as746) makes the driver wait for the URB to complete whenever there's a timeout. Although timeouts in usb-storage are relatively uncommon, they do occur. Without this patch the code in 2.6.18-rc1 will fault within an interrupt handler, which is not nice at all. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-21[PATCH] usb-storage: use usb_reset_composite_deviceAlan Stern
This patch (as701) modifies usb-storage to take advantage of the new usb_reset_composite_device() API. Now we will be able to safely request port resets even if other drivers are bound to a mass-storage device. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] usb-storage: get rid of the timer during URB submissionFranck Bui-Huu
This patch uses completion timeout instead of a timer to implement a timeout when submitting an URB. It also put the task in interruptible state instead of an uninterruptible one while waiting for the completion. Signed-off-by: Franck Bui-Huu <vagabon.xyz@gmail.com> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] PATCH: usb-storage: allocate separate sense bufferAlan Stern
This patch is from Alan Stern (as560). It has been rediffed against a current tree. This patch allocates a separate buffer for usb-storage to use when auto-sensing. Up to now we have been using the sense buffer embedded in a scsi_cmnd struct, which is dangerous on hosts that (a) don't do cache-coherent DMA or (b) have DMA alignment restrictions. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-10-28[PATCH] PATCH: usb-storage: move GetMaxLUN later in timeAlan Stern
This patch is originally from Alan Stern (as557). It has been re-diffed against a current tree, and I also corrected a minor merging error. Some time ago we introduced a delay before device scanning, because many devices do not like to receive SCSI commands right after enumeration. Now it turns out there's a device that doesn't like to receive Get-Max-LUN right after enumeration either. Accordingly this patch delays the Get-Max-LUN request until the beginning of the scanning procedure. This fixes Bugzilla entry #5010. Three things are worth noting. First, I removed the locking code from usb_stor_acquire_resources. It's not needed, because the locking is to protect against disconnect events and acquire_resources is only called during probe (so the disconnect routine can't be called). Second, I initialized to 0 the buffer used for the Get-Max-LUN response. It's not really necessary, but it will prevent random values from showing up in the debugging log when the request fails. Third, I added a test against the SINGLE_LUN flag. This will allow us to use the flag to indicate Bulk-only devices that can't handle Get-Max-LUN. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB: URB_ASYNC_UNLINK flag removed from the kernelAlan Stern
29 July 2005, Cambridge, MA: This afternoon Alan Stern submitted a patch to remove the URB_ASYNC_UNLINK flag from the Linux kernel. Mr. Stern explained, "This flag is a relic from an earlier, less-well-designed system. For over a year it hasn't been used for anything other than printing warning messages." An anonymous spokesman for the Linux kernel development community commented, "This is exactly the sort of thing we see happening all the time. As the kernel evolves, support for old techniques and old code can be jettisoned and replaced by newer, better approaches. Proprietary operating systems do not have the freedom or flexibility to change so quickly." Mr. Stern, a staff member at Harvard University's Rowland Institute who works on Linux only as a hobby, noted that the patch (labelled as548) did not update two files, keyspan.c and option.c, in the USB drivers' "serial" subdirectory. "Those files need more extensive changes," he remarked. "They examine the status field of several URBs at times when they're not supposed to. That will need to be fixed before the URB_ASYNC_UNLINK flag is removed." Greg Kroah-Hartman, the kernel maintainer responsible for overseeing all of Linux's USB drivers, did not respond to our inquiries or return our calls. His only comment was "Applied, thanks." Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB Storage: remove dependency on SCSI-provided serial/tag numberMatthew Dharm
This patch started life as as531 from Alan Stern. It has been rediffed against the latest tree. The SCSI people have deprecated the use of scsi_cmnd.serial_number for anything other than printk. Worse than that, the SCSI core doesn't always increment the number (when the error handler is running, for example). So this patch creates a locally-stored value for use in bulk-only tags. The net result is a simplification, since we no longer have to save & restore the serial_number value while autosensing. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB Storage: port reset on transport errorMatthew Dharm
This patch causes a port reset whenever there's a transport error or abort. If that fails it reverts back to doing a mass-storage device reset. It started life as as497 and was rediffed by me. This makes error recovery a lot quicker and more reliable. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-27[PATCH] USB Storage: endpoint toggles and reset delaysMatthew Dharm
This patch does two things to help reset recovery. It started life as as496 and was rediffed by me. First, the patch checks the result of a CLEAR_HALT request and doesn't reset the endpoint's data toggle unless the request succeeded. Second, it reduces the timeout for a device reset from 20 seconds to 5 seconds. If all goes well, then I've finally figured quilt out and this patch should apply cleanly. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-04-18[PATCH] Fix GO_SLOW delayPhil Dibowitz
This patch changes the delay for the US_FL_GO_SLOW patch from 110us to 125. Some delays need this extra delay includign Jan De Luyck's drive which spawned the original increase from 110 to 110us. 125 is a microframe, so this delay seems to make sense more than just be a random delay (thanks to David Brownell for pointing that out after my original patch). Signed-off-by: Phil Dibowitz <phil@ipom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Index: gregkh-2.6/drivers/usb/storage/transport.c ===================================================================
