commit a78f4f1a16d87f3d33158d036af94e48e32f8aad upstream.
These Appotech controllers are found in Picture Frames, they provide a
(buggy) emulation of a cdrom drive which contains the windows software
Uploading of pictures happens over the corresponding /dev/sg device.
commit 46216e4fbe8c62059b5440dec0b236f386248a41 upstream.
Enable the SD-Card interface on multiple Option 3G sticks.
The unusual_devs.h entry is necessary because the device descriptor is
vendor-specific. That prevents usb-storage from binding to it as an interface
driver.
Signed-off-by: Jan Dumon <j.dumon@option.com>
Signed-off-by: Phil Dibowitz <phil@ipom.com>
commit 10d2cdb6102669279bee2d9a00a22431b74583d5 upstream.
Resolves kernel.org bug 14914.
Remove entry for 2770:915d (usb digital camera with mass storage
support) from unusual_devs.h. The fix triggered by the entry causes
the file system on the camera to be completely inaccessible (no
partition table, the device is not mountable).
The patch works, but let me clarify a few things about it. All the
patch does is remove the entry for this device from the
drivers/usb/storage/unusual_devs.h, which is supposed to help with a
problem with the device's reported size (I think). I'm pretty sure it
was originally added for a reason, so I'm not sure removing it won't
cause other problems to reappear. Also, I should note that this
unusual_devs.h entry was present (and activating workarounds) in
2.6.29, but in that version everything works fine. Starting with
2.6.30, things no longer work.
Signed-off-by: Ryan May <rmay31@gmail.com>
Cc: Rohan Hart <rohan.hart17@gmail.com>
commit a0bb108112a872c0b0c4b3ef4974f95fb75b155d upstream.
This patch (as1311) fixes a problem in usb-storage: Some devices are
pretty broken when it comes to reporting sense data. The information
they send back indicates that they have more than 18 bytes of sense
data available, but when the system asks for more than 18 they fail or
hang. The symptom is that probing fails with multiple resets.
The patch adds a new BAD_SENSE flag to indicate that usb-storage
should never ask for more than 18 bytes of sense data. The flag can
be set in an unusual_devs entry or via the "quirks=" module parameter,
and it is set automatically whenever a REQUEST SENSE command for more
than 18 bytes fails or times out.
An unusual_devs entry is added for the Agfa photo frame, which uses a
Prolific chip having this bug.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Daniel Kukula <daniel.kuku@gmail.com>
We set pdt_1f_for_no_lun for UFI devices, so most floppy entiries should
be unnecessary. This patch removes three entries which I'm certain are.
- For Mitsumi I have a customer with RHEL 5 (bz#514296)
- For SMSC I accessed Novell's Bugzilla and verified the entry
- For Y-E I tested the patch with the actual device
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
Add a quirk entry for the Leading Driver UD-11 usb flash drive.
As Alan Stern told me, the device doesn't deal correctly with the
locking media feature of the device, and this patch incorporates it.
Compiled, tested, working.
Signed-off-by: Rogerio Brito <rbrito@ime.usp.br>
Cc: Phil Dibowitz <phil@ipom.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Robert Hancock <hancockrwd@gmail.com>
Cc: stable <stable@kernel.org>
D-Link DWN-652 in Modem mode exposes 3 interfaces
- First one is the USB storage one
- Second one is for both control and connection
- Third one is unknown
This patch avoids usb-storage trying to switch again when already in
modem mode, and exposes only 2 ttyUSB instead of 3 by not attaching
to the storage interface
Signed-off-by: Pascal Terjan <pterjan@mandriva.com>
This patch was originaly submitted by Phillip Potter
<phillipinda@hotmail.com> but was re-diffed to conform with
SubmittingPatches and to rebase on a newer tree by me.
Reported by Alessio Treglia on
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/125250
User was getting the following errors in dmesg:
[ 2158.139386] sd 5:0:0:1: ioctl_internal_command return code = 8000002
[ 2158.139390] : Current: sense key: No Sense
[ 2158.139393] Additional sense: No additional sense information
Adds unusual device support.
modified: drivers/usb/storage/unusual_devs.h
Signed-off-by: Chuck Short <zulcss@ubuntu.com>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
This patch (as1227) adds the MAX_SECTORS_64 flag to the unusual_devs
entry for the Simple Tech/Datafab controller. This fixes Bugzilla
#12882.
Reported-and-tested-by: binbin <binbinsh@gmail.com>
This patch allows D-Link DWM-652 3.5G modem to work.
It is an express card but was only tested with the provided usb adapter as I
don't have machines with express card connector.
/dev/ttyUSB{0,1,2} get created, and using comgt on ttyUSB1 works fine :
[root@plop tmp]# comgt -d /dev/ttyUSB1 -e
Enter PIN number: XXXX
Waiting for Registration..(120 sec max).
Registered on Home network: "Orange France",2
Signal Quality: 15,99
This patch (as1217) converts usb-storage's onetouch subdriver into a
separate module.
This patch (as1216) converts usb-storage's karma subdriver into a
separate module.
This patch (as1215) converts usb-storage's alauda subdriver into a
separate module.
This patch (as1214) converts usb-storage's jumpshot subdriver into a
separate module.
This patch (as1213) converts usb-storage's datafab subdriver into a
separate module.
This patch (as1212) converts usb-storage's freecom subdriver into a
separate module.
This patch (as1211) converts usb-storage's shuttle_usbat subdriver
into a separate module.
This patch (as1210) converts usb-storage's cypress_atacb subdriver
This patch (as1209) converts usb-storage's sddr55 subdriver into a
separate module.
This patch (as1208) converts usb-storage's isd200 subdriver into a
separate module.
This patch (as1207) converts usb-storage's sddr09 subdriver into a
separate module.
An unexpected complication arises because of DPCM devices, in which
one LUN uses the sddr09 transport and one uses the standard CB
transport. Since these devices can be used even when
USB_STORAGE_SDDR09 isn't configured, their entries in unusual_devs.h
require special treatment. If SDDR09 isn't configured then the
entries remain in unusual_devs.h; if it is then the entries are
present in unusual_sddr09.h instead.
The "c-enter" USB to Toshiba 1.8" IDE enclosure needs special treatment
to work flawlessly. This patch is absolutely trivial, as the integrated
USB-IDE bridge is already identified to be an "unusual" device, only the
bcdDevice is different (lower) to the bcdDeviceMin already included in
the kernel.
It is a Prolific 2507 bridge.
T: Bus=02 Lev=01 Prnt=01 Port=02 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=067b ProdID=2507 Rev= 0.01
S: Manufacturer=Prolific Technology Inc.
S: Product=ATAPI-6 Bridge Controller
S: SerialNumber=00000272
C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr=100mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Signed-off-by: Thomas Bartosik <tbartdev@gmx-topmail.de>
Current firmware revision 5.60 still behaves the same,
so update the quirk up a (non-existing) 99.99 revision.
http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=493415
Signed-off-by: Moritz Muehlenhoff <jmm@debian.org>
Tested-by: Jan Heitkoetter <devnull@heitkoetter.net>
Enable the SD-Card interface on the GI 0431 HSUPA stick from Option.
interface driver.
T: Bus=07 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 15 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ff(vend.) Sub=ff Prot=ff MxPS=64 #Cfgs= 1
P: Vendor=0af0 ProdID=7501 Rev= 0.00
S: Manufacturer=Option N.V.
S: Product=Globetrotter HSUPA Modem
C:* #Ifs=11 Cfg#= 1 Atr=a0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 6 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=07(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 7 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=08(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 8 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=89(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=09(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#= 9 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=hso
E: Ad=8a(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=8b(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=0a(O) Atr=02(Bulk) MxPS= 512 Ivl=4ms
I:* If#=10 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=0b(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=8c(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
This patch (as1219) adds the IGNORE_RESIDUE flag to the unusual_devs
entries for Genesys Logic's USB-IDE adapter. Although this device
usually gets the residue correct, there is one command crucial to the
operation of CD and DVD drives which it messes up.
Tested-by: Mike Lampard <mike@mtgambier.net>
This device suffers from the off-by-one error when reporting the capacity,
so add US_FL_FIX_CAPACITY to the existing entry.
Signed-off-by: Nick Holloway <Nick.Holloway@pyrites.org.uk>
This patch (as1202) adds Pentax to usb-storage's list of bad vendors
whose devices always need the CAPACITY_HEURISTICS flag. This is in
addition to the existing entries: Nokia, Nikon, and Motorola.
Tested-by: Virgo Pärna <virgo.parna@mail.ee>
Argosy has released another device with the off-by-one sector. This is a
harddrive with an internal cardreader which is affected.
Based on a patch written by Martijn Hijdra <martijn.hijdra@gmail.com>
Cc: Martijn Hijdra <martijn.hijdra@gmail.com>
This patch adds an unusual_devs entry for a Sony Ericsson modem. Like many
other modems, we have to ignore the storage device in order to access the
modem.
At this time usb_modeswitch does not work with this device.
Reported-by: The Solutor <thesolutor@gmail.com>.
The ZTE modem entry causes usb-storage to ignore the device, but for some
versions of the device, usb-storage mode is required to get to modem ode. For
both kinds the tool: http://www.draisberghof.de/usb_modeswitch/ should work.
Note that the various versions of the device have the same ProductId,
VendorId, and bcdDevice number, so we cannot have the entry for some and not
others.
This adds another unusual_devs.h entry for a device that can't handle more
than 64k reads/writes in a single command.
Signed-off-by: Jean-Baptiste Onofre <jb@nanthrax.net>
This adds an unusual devs entry for 2116:0320
Signed-off-by: Oliver Neukum <oneukum@suse.de>
This patch (as1194) makes usb-storage set the CAPACITY_HEURISTICS flag
for all devices made by Nokia, Nikon, or Motorola. These companies
seem to include the READ CAPACITY bug in all of their devices.
Since cell phones and digital cameras rely on flash storage, which
always has an even number of sectors, setting CAPACITY_HEURISTICS
shouldn't cause any problems. Not even if the companies wise up and
start making devices without the bug.
A large number of unusual_devs entries are now unnecessary, so the
patch removes them.
This patch (as1189b) adds some hacks to usb-storage for dealing with
the growing problems involving bad capacity values and last-sector
accesses:
A new flag, US_FL_CAPACITY_OK, is created to indicate that
the device is known to report its capacity correctly. An
unusual_devs entry for Linux's own File-backed Storage Gadget
is added with this flag set, since g_file_storage always
reports the correct capacity and since the capacity need
not be even (it is determined by the size of the backing
file).
An entry in unusual_devs.h which has only the CAPACITY_OK
flag set shouldn't prejudice libusual, since the device will
work perfectly well with either usb-storage or ub. So a
new macro, COMPLIANT_DEV, is added to let libusual know
about these entries.
When a last-sector access succeeds and the total number of
sectors is odd (the unexpected case, in which guessing that
the number is even might cause trouble), a WARN is triggered.
The kerneloops.org project will collect these warnings,
allowing us to add CAPACITY_OK flags for the devices in
question before implementing the default-to-even heuristic.
If users want to prevent the stack dump produced by the WARN,
they can disable the hack by adding an unusual_devs entry
for their device with the CAPACITY_OK flag.
When a last-sector access fails three times in a row and
neither the FIX_CAPACITY nor the CAPACITY_OK flag is set,
we assume the last-sector bug is present. We replace the
existing status and sense data with values that will cause
the SCSI core to fail the access immediately rather than
retry indefinitely. This should fix the difficulties
people have been having with Nokia phones.
Many newer Option mobile broadband devices initially provide a
usb-storage "driver CD" device that's pretty useless on Linux since
any software on it most likely wouldn't be compatible with your
kernel or distro anyway. Thus, by default just kill the driver
CD device by sending the SCSI 'rezero' command, but allow override
of the default behavior via usb-storage module parameter so users
can keep the ZeroCD device if they really want to. Inspired by
the Sierra TruInstall patch.
Signed-off-by: Dan Williams <dcbw@redhat.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Cc: Peter Henn <p.henn@option.com
Cc: Denis Joseph Barrow <D.Barow@option.com>
The DPCM subdriver is a little peculiar, in that it's meant to support
devices where LUN 0 is Compact Flash and uses the CB transport whereas
LUN 1 is SmartMedia and uses the SDDR09 transport. Thus DPCM isn't
really a transport in itself; it's more like a demultiplexer.
Much of the DPCM code is part of the SDDR09 subdriver already, and the
remaining part is fairly small. This patch (as1182) moves that extra
piece into sddr09.c, thereby eliminating dpcm.c. Also eliminated is
the Kconfig entry for DPCM support; it is now listed as part of the
SDDR09 entry.
In order to make sure that the semantics are the same as before, each
unusual_devs entry for DPCM is now present twice: once with DPCM
support if SDDR09 is configured (as before), and once with the
SINGLE_LUN flag and CB support otherwise.
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Add a few devices known to have support for larger sense buffers.
Supporting SANE_SENSE does not necessarily mean SAT-1 or SAT-2 is fully
supported.
Depends on SANE_SENSE patch [1]. Incorporates the Maxtor and Western
Digital devices originally submitted by Matthieu CASTET [2].
[1] https://lists.one-eyed-alien.net/pipermail/usb-storage/2008-November/004181.html
[2] http://marc.info/?l=linux-usb&m=121762869915609&w=2
Signed-off-by: Ben Efros <ben@pc-doctor.com>
Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
This patch (as1170) removes some duplicate entries in unusual_devs.h
and rearranges a few others to put the list in proper numerical order.
Jason Johnston reported these problems with his external USB hard drive:
http://bugs.gentoo.org/show_bug.cgi?id=250789
The number of reported sectors is off-by-one.
/proc/bus/usb/devices:
T: Bus=01 Lev=02 Prnt=08 Port=00 Cnt=01 Dev#= 9 Spd=480 MxCh= 0
P: Vendor=0dc4 ProdID=0073 Rev= 0.00
S: Manufacturer=Macpower Technology Co.LTD.
S: Product=USB 2.0 3.5" DEVICE
S: SerialNumber=03006C
Signed-off-by: Sergey Ovcharenko <velegrin@mail.mipt.ru>
This patch corrects the issue when one connects a Nokia 5200 cell
phone in data storage mode. If one uses an unpatched unusual_devs.h,
the following messages appear on /var/log/messages:
Dec 12 01:03:24 alberich kernel: usb 4-2: new full speed USB device
using uhci_hcd and address 3
Dec 12 01:03:25 alberich kernel: usb 4-2: configuration #1 chosen from 1 choice
Dec 12 01:03:25 alberich kernel: scsi10 : SCSI emulation for USB Mass
Storage devices
Dec 12 01:03:25 alberich kernel: usb 4-2: New USB device found,
idVendor=0421, idProduct=04bd
Dec 12 01:03:25 alberich kernel: usb 4-2: New USB device strings:
Mfr=1, Product=2, SerialNumber=3
Dec 12 01:03:25 alberich kernel: usb 4-2: Product: Nokia 5200
Dec 12 01:03:25 alberich kernel: usb 4-2: Manufacturer: Nokia
Dec 12 01:03:25 alberich kernel: usb 4-2: SerialNumber: 353930018354523
Dec 12 01:03:25 alberich kernel: usbcore: registered new interface driver ub
Dec 12 01:03:30 alberich kernel: scsi 10:0:0:0: Direct-Access
Nokia Nokia 5200 0000 PQ: 0 AN
SI: 4
Dec 12 01:03:30 alberich kernel: sd 10:0:0:0: [sdg] 3985409 512-byte
hardware sectors (2041 MB)
Dec 12 01:03:30 alberich kernel: sd 10:0:0:0: [sdg] Write Protect is off
Dec 12 01:03:30 alberich kernel: sd 10:0:0:0: [sdg] Assuming drive
cache: write through
Dec 12 01:03:30 alberich kernel: sdg: sdg1
Dec 12 01:03:30 alberich kernel: sd 10:0:0:0: [sdg] Attached SCSI removable disk
Dec 12 01:03:30 alberich kernel: sd 10:0:0:0: Attached scsi generic sg9 type 0
Dec 12 01:03:30 alberich kernel: sd 10:0:0:0: [sdg] Sense Key : No
Sense [current]
Dec 12 01:03:30 alberich kernel: sd 10:0:0:0: [sdg] Add. Sense: No
Sense [current]
Sense [current]
The MicroSD card in the phone remains inaccessible and finally the
cell phone turns itself off. The patch solves this problem and makes
the cell phone fully accessible:
[root@alberich kernel-linus-2.6.27.5-1mdv]# df -h
Sist. Arq. Tam Usad Disp Uso% Montado em
/dev/sda6 31G 5,2G 26G 17% /
/dev/sda1 92M 27M 61M 31% /boot
/dev/mapper/homevg-homelv 240G 237G 3,5G 99% /home
/dev/sda3 21G 7,9G 13G 40% /mnt/windows
/dev/sdg1 2,0G 287M 1,7G 15% /media/disk <--------
I've found necessary to use the FL_US_CAPACITY_FIX switch, as without
it the cell phone is recognized but it went berserk when performing
low-level functions on it (a fdisk -l /dev/uba for example).
lsusb -v output follows:
Bus 004 Device 004: ID 0421:04bd Nokia Mobile Phones
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0421 Nokia Mobile Phones
idProduct 0x04bd
bcdDevice 6.03
iManufacturer 1 Nokia
iProduct 2 Nokia 5200
iSerial 3 353930018354523
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 100mA
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 8 Mass Storage
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk (Zip)
iInterface 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Status: 0x0001
Self Powered
Signed-off-by: Paulo Afonso Graner Fessel <pfessel@gmail.com>
This device has been released in a new revision which is still buggy.
I have another Argosy USB storage device, which has the same problem
with the Argosy USB storage device already fixed in 2.6.27.7. But this
device has another product ID (840:84), so this patch adds a new entry
into unusual_devs to fix the mount problem.
I enclose here two patches: one against 2.6.27.8, and another against
the latest linus-git tree.
The information about the Argosy device is like below:
#lsusb -v -d 840:84
Bus 005 Device 005: ID 0840:0084 Argosy Research, Inc.
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x0840 Argosy Research, Inc.
idProduct 0x0084
bcdDevice 0.01
iManufacturer 1 Generic
iProduct 2 USB 2.0 Storage Device
iSerial 3 8400000000002549
bLength 9
bDescriptorType 2
wTotalLength 32
bNumInterfaces 1
iConfiguration 0
bmAttributes 0xc0
Self Powered
MaxPower 2mA
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 2
iInterface 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0000
(Bus Powered)
Before the patch, dmesg returns a lot of information like below (my
dmesg is overflown):
[ 138.833390] sd 7:0:0:0: [sdb] Add. Sense: No additional sense information
[ 138.877631] sd 7:0:0:0: [sdb] Sense Key : No Sense [current]
[ 138.877643] sd 7:0:0:0: [sdb] Add. Sense: No additional sense information
[ 138.921906] sd 7:0:0:0: [sdb] Sense Key : No Sense [current]
[ 138.921923] sd 7:0:0:0: [sdb] Add. Sense: No additional sense information
After the fix, dmesg returns below information:
usb 5-1: new high speed USB device using ehci_hcd and address 5
usb 5-1: configuration #1 chosen from 1 choice
scsi7 : SCSI emulation for USB Mass Storage devices
usb-storage: device found at 5
usb-storage: waiting for device to settle before scanning
usb-storage: device scan complete
scsi 7:0:0:0: Direct-Access HTS54808 0M9AT00 MG4O PQ: 0 ANSI: 0
sd 7:0:0:0: [sdb] 156301488 512-byte hardware sectors (80026 MB)
sd 7:0:0:0: [sdb] Write Protect is off
sd 7:0:0:0: [sdb] Mode Sense: 03 00 00 00
sd 7:0:0:0: [sdb] Assuming drive cache: write through
sdb: sdb1
sd 7:0:0:0: [sdb] Attached SCSI disk
sd 7:0:0:0: Attached scsi generic sg1 type 0
kjournald starting. Commit interval 5 seconds
EXT3 FS on sdb1, internal journal
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
Cc: Kuniyasu Suzaki <k.suzaki@aist.go.jp>
Signed-off-by: Nguyen Anh Quynh <aquynh@gmail.com>
Jaak Ristioja reported problems with his Pentax K10D camera:
https://bugs.gentoo.org/show_bug.cgi?id=250406
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=12 MxCh= 0
P: Vendor=0a17 ProdID=006e Rev= 1.00
S: Manufacturer=PENTAX Corporation
S: Product=K10D
C:* #Ifs= 1 Cfg#= 1 Atr=c0 MxPwr= 2mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=81(I) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=100ms
Signed-off-by: Daniel Drake <dsd@gentoo.org>
Cc: Kadianakis George <desnacked@gmail.com>
This patch (as1179) updates the unusual_devs entry for Nokia's 5310
phone to include a more recent firmware revision.
This fixes Bugzilla #12099.
Tested-by: Robson Roberto Souza Peixoto <robsonpeixoto@gmail.com>
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 3 Spd=12 MxCh= 0
P: Vendor=0421 ProdID=0060 Rev= 5.51
S: Manufacturer=Nokia
S: Product=Nokia 3500c
S: SerialNumber=357687010280751
E: Ad=01(O) Atr=02(Bulk) MxPS= 64 Ivl=0ms
2.6.26(.x, cannot remember) could handle the microSD card in my Nokia
3109c attached via USB as mass storage, 2.6.27(.x, up to and included
2.6.27.8) cannot. Please find the attached patch which fixes this
regression, and a copy of /proc/bus/usb/devices with my phone plugged in
running with this patch on Frugalware.
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=02 Dev#= 4 Spd=12 MxCh= 0
P: Vendor=0421 ProdID=0063 Rev= 6.01
S: Product=Nokia 3109c
S: SerialNumber=359561013742570
This patch adds an unusual_devs entry for the Nikon D2H camera.
This patch (as1176) adds an unusual_devs entry for the Mio C520 GPS
unit. Other devices also based on the Mitac hardware use the same USB
interface firmware, so the Vendor and Product names are generalized.
This fixes Bugzilla #11583.
Tested-by: Tamas Kerecsen <kerecsen@bigfoot.com>
