[ Upstream commit d595259fbb7a7afed241b1afb2c4fe4b47de47fa ]
This USB-SATA bridge chip is used in a StarTech enclosure for
optical drives.
Without the quirk MakeMKV fails during the key exchange with an
installed BluRay drive:
> Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED'
> occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:2'
Signed-off-by: Tobias Jakobi <tjakobi@math.uni-bielefeld.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 674aea07e38200ea6f31ff6d5f200f0cf6cdb325 upstream.
This device gives the following error on detection.
xhci_hcd 0000:00:11.0: ERROR Transfer event for disabled endpoint or
incorrect stream ring
The same error is not seen when it is added to unusual_device
list with US_FL_NO_REPORT_OPCODES passed.
Signed-off-by: George Cherian <george.cherian@cavium.com>
Signed-off-by: Oliver Neukum <oneukun@suse.com>
Some SATA to USB bridges fail to cooperate with some
drives resulting in no cache being present being reported
to the host. That causes the host to skip sending
a command to synchronize caches. That causes data loss
when the drive is powered down.
Signed-off-by: Oliver Neukum <oneukum@suse.com>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
No functional changes here, just making sure our
storage driver uses a consistent multi-line comment
style.
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
The patch extends the family of SATA-to-USB JMicron adapters that need
FUA to be disabled and applies the same policy for uas driver.
See details in http://unix.stackexchange.com/questions/237204/
Signed-off-by: Dmitry Katsubo <dmitry.katsubo@gmail.com>
Tested-by: Dmitry Katsubo <dmitry.katsubo@gmail.com>
Cc: stable <stable@vger.kernel.org>
Grain-media GM12U320 based devices are mini video projectors using USB for
both power and video data transport.
Their usb-storage interface is a virtual windows driver CD.
The gm12u320 kms driver needs these interfaces to talk to the device and
export it as framebuffer & kms dri device nodes, so make sure that the
usb-storage driver does not bind to it.
This device automatically switches itself to another mode (0x1405)
unless the specific access pattern of Windows is followed in its
initial mode. That makes a dirty unmount of the internal storage
devices inevitable if they are mounted. So the card reader of
such a device should be ignored, lest an unclean removal become
inevitable.
This replaces an earlier patch that ignored all LUNs of this device.
That patch was overly broad.
CC: stable@vger.kernel.org
Reviewed-by: Lars Melin <larsm17@gmail.com>
Without this flag some versions of these enclosures do not work.
Cc: stable@vger.kernel.org
Reported-and-tested-by: Christian Schaller <cschalle@redhat.com>
It looks like FUA support is broken on JMicron 152d:2566 bridge:
[223159.885704] sd 7:0:0:0: [sdc] Write Protect is off
[223159.885706] sd 7:0:0:0: [sdc] Mode Sense: 47 00 10 08
[223159.885942] sd 7:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[223283.691677] sd 7:0:0:0: [sdc]
[223283.691680] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[223283.691681] sd 7:0:0:0: [sdc]
[223283.691682] Sense Key : Illegal Request [current]
[223283.691684] sd 7:0:0:0: [sdc]
[223283.691685] Add. Sense: Invalid field in cdb
[223283.691686] sd 7:0:0:0: [sdc] CDB:
[223283.691687] Write(10): 2a 08 15 d0 83 0d 00 00 01 00
[223283.691690] blk_update_request: critical target error, dev sdc, sector 2927892584
This patch adds blacklist flag so that sd will not use FUA
Signed-off-by: Dmitry Nezhevenko <dion@dion.org.ua>
Cc: Phil Dibowitz <phil@ipom.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
I recently posted a patch ("storage: Add quirk for another SCM-based
USB-SCSI converter") to add a quirk for the converter with ID 04E6:000F,
which is listed along with 04E6:000B in the Windows INF file for the
Startech ICUSBSCSI2 as "eUSB SCSI Adapter (Bus Powered)".
The already-present quirk for 04E6:000B has USB_SC_SCSI/USB_PR_BULK, not
USB_SC_DEVICE/USB_PR_DEVICE. Change the 04E6:000F quirk to match that,
since it will probably be required.
Signed-off-by: Mark Knibbs <markk@clara.co.uk>
There is apparently another SCM USB-SCSI converter with ID 04E6:000F. It
is listed along with 04E6:000B in the Windows INF file for the Startech
ICUSBSCSI2 as "eUSB SCSI Adapter (Bus Powered)". The quirk allows
devices with SCSI ID other than 0 to be accessed.
Also make a couple of existing SCM product IDs lower case to be
consistent with other entries.
Castlewood Systems supplied various models of USB-SCSI converter with their
ORB external removable-media drive. The ORB Windows and Macintosh drivers
support six USB IDs:
084B:A001 [VID 084B is Castlewood Systems]
04E6:0002 (*) ORB USB Smart Cable P/N 88205-001 (generic SCM ID)
2027:A001 Double-H Technology DH-2000SC
1822:0001 (*) Ariston iConnect/iSCSI
07AF:0004 (*) Microtech XpressSCSI (25-pin)
07AF:0005 (*) Microtech XpressSCSI (50-pin)
*: quirk already in unusual-devs.h
[Apparently the official VID for Double-H Technology is 0x07EB = 2027
decimal. That's another hex/decimal mix-up with these SCM-based products
(in addition to the Ariston and Entrega ones). Perhaps the USB-IF informed
companies of their allocated VID in decimal, but they assumed it was hex?
It seems all Entrega products used VID 0x1645, not just the USB-SCSI
converter.]
Double-H Technology Co., Ltd. produced a USB-SCSI converter, model
DH-2000SC, which is probably the one supported by the ORB drivers. Perhaps
the Castlewood-bundled product had a different label or PID though?
Castlewood mentioned Conmate as being one type of USB-SCSI converter.
Conmate and Double-H seem related somehow; both company addresses in the
same road, and at one point the Conmate web site mentioned DH-2000H4,
DH-200D4/DH-2000C4 as models of USB hub (DH short for Double-H presumably).
Conmate did show a USB-SCSI converter model CM-660 on their web site at one
point. My guess is that was identical to the DH-2000SC.
Mention of the Double-H product:
http://web.archive.org/web/20010221010141/http://www.doubleh.com.tw/dh-2000sc.htm
The only picture I could find is at
http://jp.acesuppliers.com/catalog/j64/component/page03.html
The casing design looks the same as my ORB USB Smart Cable which has ID
04E6:0002.
Anyway, that's enough rambling. Here's the patch.
storage: Add quirks for Castlewood and Double-H USB-SCSI converters
Add quirks for two SCM-based USB-SCSI converters which were bundled with
some Castlewood ORB removable drives. Without the quirk only the (single)
drive with SCSI ID 0 can be accessed.
This patch adds quirks for Entrega Technologies (later Xircom PortGear) USB-
SCSI converters. They use Shuttle Technology EUSB-01/EUSB-S1 chips. The
US_FL_SCM_MULT_TARG quirk is needed to allow multiple devices on the SCSI
chain to be accessed. Without it only the (single) device with SCSI ID 0
can be used.
The standalone converter sold by Entrega had model number U1-SC25. Xircom
acquired Entrega and re-branded the product line PortGear. The PortGear USB
to SCSI Converter (model PGSCSI) is internally identical to the Entrega
product, but later models may use a different USB ID. The Entrega-branded
units have USB ID 1645:0007, as does my Xircom PGSCSI, but the Windows and
Macintosh drivers also support 085A:0028.
Entrega also sold the "Mac USB Dock", which provides two USB ports, a Mac
(8-pin mini-DIN) serial port and a SCSI port. It appears to the computer as
a four-port hub, USB-serial, and USB-SCSI converters. The USB-SCSI part may
have initially used the same ID as the standalone U1-SC25 (1645:0007), but
later production used 085A:0026.
My Xircom PortGear PGSCSI has bcdDevice=0x0100. Units with bcdDevice=0x0133
probably also exist.
This patch adds quirks for 1645:0007, 085A:0026 and 085A:0028. The Windows
driver INF file also mentions 085A:0032 "PortStation SCSI Module", but I
couldn't find any mention of that actually existing in the wild; perhaps it
was cancelled before release?
The Ariston Technologies iConnect 025 and iConnect 050 (also known as e.g.
iSCSI-50) are SCSI-USB converters which use Shuttle Technology/SCM
Microsystems chips. Only the connectors differ; both have the same USB ID.
The US_FL_SCM_MULT_TARG quirk is required to use SCSI devices with ID other
than 0.
I don't have one of these, but based on the other entries for Shuttle/
SCM-based converters this patch is very likely correct. I used 0x0000 and
0x9999 for bcdDeviceMin and bcdDeviceMax because I'm not sure which
bcdDevice value the products use.
The Adaptec USBConnect 2000 is another SCSI-USB converter which uses
Shuttle Technology/SCM Microsystems chips. The US_FL_SCM_MULT_TARG quirk is
required to use SCSI devices with ID other than 0.
I don't have a USBConnect 2000, but based on the other entries for Shuttle/
bcdDevice value the product uses.
The Iomega Jaz USB Adapter is a SCSI-USB converter cable. The hardware
seems to be identical to e.g. the Microtech XpressSCSI, using a Shuttle/
SCM chip set. However its firmware restricts it to only work with Jaz
drives.
On connecting the cable a message like this appears four times in the log:
reset full speed USB device number 4 using uhci_hcd
That's non-fatal but the US_FL_SINGLE_LUN quirk fixes it.
The uSCSI from Newer Technology is a SCSI-USB converter with USB ID 06ca:2003.
Like several other SCSI-USB products, it's a Shuttle Technology OEM device.
Without a suitable entry in unusual-devs.h, the converter can only access the
(single) device with SCSI ID 0. Copying the entry for device 04e6:0002 allows
it to work with devices with other SCSI IDs too.
There are currently six entries for Shuttle-developed SCSI-USB devices in
unusual-devs.h (grep for euscsi):
04e6:0002 Shuttle eUSCSI Bridge USB_SC_DEVICE, USB_PR_DEVICE
04e6:000b Shuttle eUSCSI Bridge USB_SC_SCSI, USB_PR_BULK
04e6:000c Shuttle eUSCSI Bridge USB_SC_SCSI, USB_PR_BULK
050d:0115 Belkin USB SCSI Adaptor USB_SC_SCSI, USB_PR_BULK
07af:0004 Microtech USB-SCSI-DB25 USB_SC_DEVICE, USB_PR_DEVICE
07af:0005 Microtech USB-SCSI-HD50 USB_SC_DEVICE, USB_PR_DEVICE
lsusb -v output for the uSCSI lists
bInterfaceSubClass 6 SCSI
bInterfaceProtocol 80 Bulk (Zip)
This patch adds an entry for the uSCSI to unusual_devs.h.
Some buggy JMicron USB-ATA bridges don't know how to translate the FUA
bit in READs or WRITEs. This patch adds an entry in unusual_devs.h
and a blacklist flag to tell the sd driver not to use FUA.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Michael Büsch <m@bues.ch>
Tested-by: Michael Büsch <m@bues.ch>
Acked-by: James Bottomley <James.Bottomley@HansenPartnership.com>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
CC: <stable@vger.kernel.org>
Signed-off-by: Daniele Forsi <dforsi@gmail.com>
Signed-off-by: Victor A. Santos <victoraur.santos@gmail.com>
uas devices have 2 alternative settings on their usb-storage interface,
one for usb-storage and one for uas. Using the uas driver is preferred, so if
the uas driver is enabled, and the device has an uas alt setting, don't bind.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
This patch adds an unusual-devs entry for the BlackBerry 9000. This
fixes Bugzilla #22442.
Reported-by: Moritz Moeller-Herrmann <moritz-kernel@moeller-herrmann.de>
Tested-by: Moritz Moeller-Herrmann <moritz-kernel@moeller-herrmann.de>
The USB storage operation of Nokia Asha 502 Dual SIM smartphone running Asha
Platform 1.1.1 is unreliable in respect of data consistency (i.e. transfered
files are corrupted). A similar issue is described here:
http://discussions.nokia.com/t5/Asha-and-other-Nokia-Series-30/Nokia-301-USB-transfers-and-corrupted-files/td-p/1974170
The workaround is (MAX_SECTORS_64):
rmmod usb_storage && modprobe usb_storage quirks=0421:06aa:m
The patch adds the tested device to the unusual list permanently.
Signed-off-by: Mikhail Zolotaryov <lebon@lebon.org.ua>
Some USB drive enclosures do not correctly report an
overflow condition if they hold a drive with a capacity
over 2TB and are confronted with a READ_CAPACITY_10.
They answer with their capacity modulo 2TB.
The generic layer cannot cope with that. It must be told
to use READ_CAPACITY_16 from the beginning.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
The device report an error capacity when read_capacity_16().
Using read_capacity_10() can get the correct capacity.
Signed-off-by: Ren Bigcren <bigcren.ren@sonymobile.com>
Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Signed-off-by: Oskar Andero <oskar.andero@sonymobile.com>
Device stucks on filesystem writes, unless following quirk is passed:
echo 04e8:5136:m > /sys/module/usb_storage/parameters/quirks
Add corresponding entry to unusual_devs.h
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
This reverts commit 200e0d99 ("USB: storage: optimize to match the
Huawei USB storage devices and support new switch command" and the
followup bugfix commit cd060956 ("USB: storage: properly handle
the endian issues of idProduct").
The commit effectively added a large number of Huawei devices to
the deprecated usb-storage mode switching logic. Many of these
devices have been in use and supported by the userspace
usb_modeswitch utility for years. Forcing the switching inside
the kernel causes a number of regressions as a result of ignoring
existing onfigurations, and also completely takes away the ability
to configure mode switching per device/system/user.
Known regressions caused by this:
- Some of the devices support multiple modes, using different
switching commands. There are existing configurations taking
advantage of this.
- There is a real use case for disabling mode switching and
instead mounting the exposed storage device. This becomes
impossible with switching logic inside the usb-storage driver.
- At least on device fail as a result of the usb-storage switching
command, becoming completely unswitchable. This is possibly a
firmware bug, but still a regression because the device work as
expected using usb_modeswitch defaults.
In-kernel mode switching was deprecated years ago with the
development of the more user friendly userspace alternatives. The
existing list of devices in usb-storage was only kept to prevent
breaking already working systems. The long term plan is to remove
the list, not to add to it. Ref:
http://permalink.gmane.org/gmane.linux.usb.general/28543
Cc: <fangxiaozhi@huawei.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Acked-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
new switch command
1. Optimize the match rules with new macro for Huawei USB storage devices,
to avoid to load USB storage driver for the modem interface
with Huawei devices.
2. Add to support new switch command for new Huawei USB dongles.
Signed-off-by: fangxiaozhi <huananhu@huawei.com>
This commit sets removable subclass for Casio EX-N1 digital camera.
The patch has been tested within an ALT Linux kernel:
http://git.altlinux.org/people/led/packages/?p=kernel-image-3.0.git;a=commitdiff;h=c0fd891836e89fe0c93a4d536a59216d90e4e3e7
See also https://bugzilla.kernel.org/show_bug.cgi?id=49221
Signed-off-by: Oleksandr Chumachenko <ledest@gmail.com>
Signed-off-by: Michael Shigorin <mike@osdn.org.ua>
The "Low Performance USB Block driver" has been removed which a user of
libusual. Now we have only the usb-storage driver as the only driver in
tree. This makes libusual needless.
This patch removes libusal, fixes up all users. The usual-table is now
linked into usb-storage.
usb_usual.h remains in public include directory because some staging
users seem to need it.
Signed-off-by: Sebastian Andrzej Siewior <sebastian@breakpoint.cc>
Update information of Seagate Portable HDD and WD My Passport HDD in
quirk list.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Pankaj Kumar <pankaj.km@samsung.com>
Signed-off-by: Amit Sahrawat <a.sahrawat@samsung.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
This patch (as1560) reverts commit
afff07e61a5243e14ee3f0a272a0380cd744a8a3 (usb-storage: Add 090c:1000
to unusal-devs). It is no longer needed, because usb-storage now
tells the sd driver to try READ CAPACITY(10) before READ CAPACITY(16)
for every USB mass-storage device.
Acked-by: Hans de Goede <hdegoede@redhat.com>
This device gives a bogus answer to get_capacity(16):
[ 8628.278614] scsi 8:0:0:0: Direct-Access USB 2.0 USB Flash Drive 1100 PQ: 0 ANSI: 4
[ 8628.279452] sd 8:0:0:0: Attached scsi generic sg4 type 0
[ 8628.280338] sd 8:0:0:0: [sdd] 35747322042253313 512-byte logical blocks: (18.3 EB/15.8 EiB)
So set the quirk flag to avoid using get_capacity(16) with it:
[11731.386014] usb-storage 2-1.6:1.0: Quirks match for vid 090c pid 1000: 80000
[11731.386075] scsi9 : usb-storage 2-1.6:1.0
[11731.386172] usbcore: registered new interface driver usb-storage
[11731.386175] USB Mass Storage support registered.
[11732.387394] scsi 9:0:0:0: Direct-Access USB 2.0 USB Flash Drive 1100 PQ: 0 ANSI: 4
[11732.388462] sd 9:0:0:0: Attached scsi generic sg3 type 0
[11732.389432] sd 9:0:0:0: [sdc] 7975296 512-byte logical blocks: (4.08 GB/3.80 GiB)
Which makes the capacity look a lot more sane :)
Tested-by: Simon Raffeiner <sturmflut@lieberbiber.de>
Pull trivial updates from Jiri Kosina:
"As usual, it's mostly typo fixes, redundant code elimination and some
documentation updates."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (57 commits)
edac, mips: don't change code that has been removed in edac/mips tree
xtensa: Change mail addresses of Hannes Weiner and Oskar Schirmer
lib: Change mail address of Oskar Schirmer
net: Change mail address of Oskar Schirmer
arm/m68k: Change mail address of Sebastian Hess
i2c: Change mail address of Oskar Schirmer
net: Fix tcp_build_and_update_options comment in struct tcp_sock
atomic64_32.h: fix parameter naming mismatch
Kconfig: replace "--- help ---" with "---help---"
c2port: fix bogus Kconfig "default no"
edac: Fix spelling errors.
qla1280: Remove redundant NULL check before release_firmware() call
remoteproc: remove redundant NULL check before release_firmware()
qla2xxx: Remove redundant NULL check before release_firmware() call.
aic94xx: Get rid of redundant NULL check before release_firmware() call
tehuti: delete redundant NULL check before release_firmware()
qlogic: get rid of a redundant test for NULL before call to release_firmware()
bna: remove redundant NULL test before release_firmware()
tg3: remove redundant NULL test before release_firmware() call
typhoon: get rid of redundant conditional before all to release_firmware()
This patch (as1553) adds an unusual_dev entrie for the Yarvik PMP400
MP4 music player.
Reported-by: Jesse Feddema <jdfeddema@gmail.com>
Tested-by: Jesse Feddema <jdfeddema@gmail.com>
This patch updates Jonathan Woithe's contact details across the kernel tree.
Signed-off-by: Jonathan Woithe <jwoithe@just42.net>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits)
Kconfig: acpi: Fix typo in comment.
misc latin1 to utf8 conversions
devres: Fix a typo in devm_kfree comment
btrfs: free-space-cache.c: remove extra semicolon.
fat: Spelling s/obsolate/obsolete/g
SCSI, pmcraid: Fix spelling error in a pmcraid_err() call
tools/power turbostat: update fields in manpage
mac80211: drop spelling fix
types.h: fix comment spelling for 'architectures'
typo fixes: aera -> area, exntension -> extension
devices.txt: Fix typo of 'VMware'.
sis900: Fix enum typo 'sis900_rx_bufer_status'
decompress_bunzip2: remove invalid vi modeline
treewide: Fix comment and string typo 'bufer'
hyper-v: Update MAINTAINERS
treewide: Fix typos in various parts of the kernel, and fix some comments.
clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR
gpio: Kconfig: drop unknown symbol 'CS5535_GPIO'
leds: Kconfig: Fix typo 'D2NET_V2'
sound: Kconfig: drop unknown symbol ARCH_CLPS7500
Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new
kconfig additions, close to removed commented-out old ones)
Kingston DT 101 G2 replies a wrong tag while transporting, add an
unusal_devs entry to ignore the tag validation.
Signed-off-by: Qinglin Ye <yestyle@gmail.com>
Connecting the V2M to a Linux host results in a constant stream of
errors spammed to the console, all of the form
sd 1:0:0:0: ioctl_internal_command return code = 8070000
: Sense Key : 0x4 [current]
: ASC=0x0 ASCQ=0x0
The errors appear to be otherwise harmless. Add an unusual_devs entry
which eliminates all of the error messages.
Signed-off-by: Nick Bowler <nbowler@elliptictech.com>
Cc: stable <stable@kernel.org>
Some USB mass-storage devices have bugs that cause them not to handle
the first READ(10) command they receive correctly. The Corsair
Padlock v2 returns completely bogus data for its first read (possibly
it returns the data in encrypted form even though the device is
supposed to be unlocked). The Feiya SD/SDHC card reader fails to
complete the first READ(10) command after it is plugged in or after a
new card is inserted, returning a status code that indicates it thinks
the command was invalid, which prevents the kernel from retrying the
read.
Since the first read of a new device or a new medium is for the
partition sector, the kernel is unable to retrieve the device's
partition table. Users have to manually issue an "hdparm -z" or
"blockdev --rereadpt" command before they can access the device.
This patch (as1470) works around the problem. It adds a new quirk
flag, US_FL_INVALID_READ10, indicating that the first READ(10) should
always be retried immediately, as should any failing READ(10) commands
(provided the preceding READ(10) command succeeded, to avoid getting
stuck in a loop). The patch also adds appropriate unusual_devs
entries containing the new flag.
Tested-by: Sven Geggus <sven-usbst@geggus.net>
Tested-by: Paul Hartman <paul.hartman+linux@gmail.com>
CC: <stable@kernel.org>
This patch (as1444) adds an unusual_devs entry for an MP3 player from
Coby electronics. The device has two nasty bugs.
Tested-by: Jasper Mackenzie <scarletpimpernal@hotmail.com>
This device suffers from the off-by-one error when reporting the capacity,
so add entry with US_FL_FIX_CAPACITY.
Signed-off-by: Nick Holloway <Nick.Holloway@pyrites.org.uk>
This patch (as1438) adds an unusual_devs entry for the MagicPixel
FW_Omega2 chip, used in the CamSport Evo camera. The firmware
incorrectly reports a vendor-specific bDeviceClass.
Reported-by: <ttkspam@free.fr>
external hard drive enclosure
The TrekStor DataStation maxi g.u external hard drive enclosure uses a
JMicron USB to SATA chip which needs the US_FL_IGNORE_RESIDUE flag to work
properly.
Signed-off-by: Richard Schütz <r.schtz@t-online.de>
Add an unusual_devs entry for the Samsung YP-CP3 MP4 player.
User was getting the following errors in dmesg:
usb 2-6: reset high speed USB device using ehci_hcd and address 2
usb 2-6: USB disconnect, address 2
sd 3:0:0:0: [sdb] Assuming drive cache: write through
sdb:<2>ldm_validate_partition_table(): Disk read failed.
Dev sdb: unable to read RDB block 0
unable to read partition table
Signed-off-by: Vitaly Kuznetsov <vitty@altlinux.ru>
CC: stable@kernel.org
Some Rockbox based mp4 players will crash when ever they see a
read_capacity_16 scsi command. So add a new US_FL which tells the scsi sd
driver to not issue any read_capacity_16 scsi commands.
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Appotech ax3003 (the larger brother of the ax203) based devices are even
more buggy then the ax203. They will go of into lala land when ever they
see a READ_DISC_INFO scsi command. So add a new US_FL which tells the
scsi sr driver to not issue any READ_DISC_INFO scsi commands.
[akpm@linux-foundation.org: fix build]
This commit changes prefix for some of the USB mass storage
class related macros (ie. USB_SC_ for subclass and USB_PR_
for class).
Signed-off-by: Michal Nazarewicz <mina86@mina86.com>
Cc: Matthew Wilcox <willy@linux.intel.com>
