commit bb94a406682770a35305daaa241ccdb7cab399de upstream.
This patch (as1521b) fixes the interaction between usb-storage's
scanning thread and the freezer. The current implementation has a
race: If the device is unplugged shortly after being plugged in and
just as a system sleep begins, the scanning thread may get frozen
before the khubd task. Khubd won't be able to freeze until the
disconnect processing is complete, and the disconnect processing can't
proceed until the scanning thread finishes, so the sleep transition
will fail.
The implementation in the 3.2 kernel suffers from an additional
problem. There the scanning thread calls set_freezable_with_signal(),
and the signals sent by the freezer will mess up the thread's I/O
delays, which are all interruptible.
The solution to both problems is the same: Replace the kernel thread
used for scanning with a delayed-work routine on the system freezable
work queue. Freezable work queues have the nice property that you can
cancel a work item even while the work queue is frozen, and no signals
are needed.
The 3.2 version of this patch solves the problem in Bugzilla #42730.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Seth Forshee <seth.forshee@canonical.com>
Some USB mass-storage devices have bugs that cause them not to handle
the first READ(10) command they receive correctly. The Corsair
Padlock v2 returns completely bogus data for its first read (possibly
it returns the data in encrypted form even though the device is
supposed to be unlocked). The Feiya SD/SDHC card reader fails to
complete the first READ(10) command after it is plugged in or after a
new card is inserted, returning a status code that indicates it thinks
the command was invalid, which prevents the kernel from retrying the
read.
Since the first read of a new device or a new medium is for the
partition sector, the kernel is unable to retrieve the device's
partition table. Users have to manually issue an "hdparm -z" or
"blockdev --rereadpt" command before they can access the device.
This patch (as1470) works around the problem. It adds a new quirk
flag, US_FL_INVALID_READ10, indicating that the first READ(10) should
always be retried immediately, as should any failing READ(10) commands
(provided the preceding READ(10) command succeeded, to avoid getting
stuck in a loop). The patch also adds appropriate unusual_devs
entries containing the new flag.
Tested-by: Sven Geggus <sven-usbst@geggus.net>
Tested-by: Paul Hartman <paul.hartman+linux@gmail.com>
CC: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
CC: <stable@kernel.org>
This patch (as1350) removes all usages of coherent buffers for USB
control-request setup-packet buffers. There's no good reason to
reserve coherent memory for these things; control requests are hardly
ever used in large quantity (the major exception is firmware
transfers, and they aren't time-critical). Furthermore, only seven
drivers used it. We might as well always use streaming DMA mappings
for setup-packet buffers, and remove some extra complexity from
usbcore.
The DMA-mapping portion of hcd.c is currently in flux. A separate
patch will be submitted to remove support for URB_NO_SETUP_DMA_MAP
after everything else settles down. The removal should go smoothly,
as by then nobody will be using it.
Instead of reporting "SCSI emulation for USB Mass Storage devices",
report "usb-storage 1-4:1.0".
Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
This patch (as1206) is the first step in converting usb-storage's
subdrivers into separate modules. It makes the following large-scale
changes:
Remove a bunch of unnecessary #ifdef's from usb_usual.h.
Not truly necessary, but it does clean things up.
Move the USB device-ID table (which is duplicated between
libusual and usb-storage) into its own source file,
usual-tables.c, and arrange for this to be linked with
either libusual or usb-storage according to whether
USB_LIBUSUAL is configured.
Add to usual-tables.c a new usb_usual_ignore_device()
function to detect whether a particular device needs to be
managed by a subdriver and not by the standard handlers
in usb-storage.
Export a whole bunch of functions in usb-storage, renaming
some of them because their names don't already begin with
"usb_stor_". These functions will be needed by the new
subdriver modules.
Split usb-storage's probe routine into two functions.
The subdrivers will call the probe1 routine, then fill in
their transport and protocol settings, and then call the
probe2 routine.
Take the default cases and error checking out of
get_transport() and get_protocol(), which run during
probe1, and instead put a check for invalid transport
or protocol values into the probe2 function.
Add a new probe routine to be used for standard devices,
i.e., those that don't need a subdriver. This new routine
checks whether the device should be ignored (because it
should be handled by ub or by a subdriver), and if not,
calls the probe1 and probe2 functions.
This patch (as1189b) adds some hacks to usb-storage for dealing with
the growing problems involving bad capacity values and last-sector
accesses:
A new flag, US_FL_CAPACITY_OK, is created to indicate that
the device is known to report its capacity correctly. An
unusual_devs entry for Linux's own File-backed Storage Gadget
is added with this flag set, since g_file_storage always
reports the correct capacity and since the capacity need
not be even (it is determined by the size of the backing
file).
An entry in unusual_devs.h which has only the CAPACITY_OK
flag set shouldn't prejudice libusual, since the device will
work perfectly well with either usb-storage or ub. So a
new macro, COMPLIANT_DEV, is added to let libusual know
about these entries.
When a last-sector access succeeds and the total number of
sectors is odd (the unexpected case, in which guessing that
the number is even might cause trouble), a WARN is triggered.
The kerneloops.org project will collect these warnings,
allowing us to add CAPACITY_OK flags for the devices in
question before implementing the default-to-even heuristic.
If users want to prevent the stack dump produced by the WARN,
they can disable the hack by adding an unusual_devs entry
for their device with the CAPACITY_OK flag.
When a last-sector access fails three times in a row and
neither the FIX_CAPACITY nor the CAPACITY_OK flag is set,
we assume the last-sector bug is present. We replace the
existing status and sense data with values that will cause
the SCSI core to fail the access immediately rather than
retry indefinitely. This should fix the difficulties
people have been having with Nokia phones.
Cc: stable <stable@kernel.org>
This patch (as1171) removes us->sensebuf, since it isn't used anywhere.
This patch removes CVS keywords that weren't updated for a long time
from comments.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This patch (as1092) implements "soft" unbinding for usb-storage. When
the disconnect routine is called, all commands and reset delays are
allowed to complete normally until after scsi_remove_host() returns.
This means that the commands needed for an orderly shutdown will be
sent through to the device.
Unlike before, the driver will now execute every command that it
accepts. Hence there's no need for special code to catch unexecuted
commands and fail them.
The new sequence of events when disconnect runs goes as follows:
If the device is truly unplugged, set the DISCONNECTING
flag so we won't try to access it any more.
If the SCSI-scanning thread hasn't started up yet, prevent
it from doing anything by setting the new DONT_SCAN flag.
Then wake it up and wait for it to terminate.
Remove the SCSI host. This unbinds the upper-level drivers,
doing an orderly shutdown. Commands sent to quiesce the
device will be transmitted normally, unless the device is
unplugged.
Set the DISCONNECTING flag so that we won't accept any new
commands that might get submitted (there aren't supposed to be
any) and we won't try to access the device for resets.
Tell the control thread to exit by waking it up with no
pending command, and wait for it to terminate.
Go on to do all the other normal stuff: releasing resources,
freeing memory, and so on.
This patch (as1090) converts the one remaining semaphore in
usb-storage into a completion.
Cc: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
This patch (as1089) separates out the dynamic atomic bitflags and the
static bitfields in usb-storage. Until now the two sorts of flags
have been sharing the same word; this has always been awkward.
To help prevent possible confusion, the two new fields each have a
different name from the original. us->fflags contains the fixed
bitfields (mostly taken from the USB ID table in unusual_devs.h), and
us->dflags contains the dynamic atomic bitflags (used with set_bit,
test_bit, and so on).
This patch (as961) fixes a couple of bugs in the disconnect pathway of
usb-storage.
The first problem, which apparently has been around for a while
although nobody noticed it, shows up when an aborted command is still
pending when a disconnect occurs. The SCSI error-handler will
continue to wait in command_abort() until the us->notify completion is
signalled. Thus quiesce_and_remove_host() needs to signal it.
The second problem was introduced recently along with autosuspend
support. Since usb_stor_scan_thread() now calls
usb_autopm_put_interface() before exiting, we can't simply leave the
scanning thread running after a disconnect; we must wait until the
thread exits. This is solved by adding a new struct completion to the
private data structure. Fortuitously, it allows the removal of the
rather clunky mechanism used in the past to insure that all threads
have finished before the module is unloaded.
This patch (as923) makes usb-storage's control thread use
kthread_should_stop()/kthread_stop(). The scanning thread can't be
similarly converted until the core kthread implementation allows
threads to call do_exit().
The advantage of this change is that we can now be certain the control
thread has terminated before storage_disconnect() returns. This will
simplify the locking requirements when autosuspend support is added.
Signed-off-by: Matthew Dharm <mdharm-usb@one-eyed-alien.net>
Remove includes of <linux/smp_lock.h> where it is not used/needed.
Suggested by Al Viro.
Builds cleanly on x86_64, i386, alpha, ia64, powerpc, sparc,
sparc64, and arm (all 59 defconfigs).
This patch adds a US_FL_MAX_SECTORS_64 and removes the Genesys special-cases
for this that were in scsiglue.c. It also adds the flag to other devices
reported to need it.
Signed-off-by: Phil Dibowitz <phil@ipom.com>
Usually we don't care much about 'gcc -W' warnings, but some of us do build
kernels that way to look for problems, and then the fewer warnings we have
to wade through the better. Especially when they are very easy and
non-intrusive to clean up. Which is the case for the following warnings
spewed by drivers/usb/storage/usb.h :
drivers/usb/storage/usb.h:163: warning: `inline' is not at beginning of
+declaration
drivers/usb/storage/usb.h:166: warning: `inline' is not at beginning of
+declaration
There's also some precedence for cleaning up these warnings. I've had
a few patches merged in the past that remove exactly this class of
warnings.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
the patch below converts a bunch of semaphores-used-as-mutex in the USB
code to mutexes
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
The OneTouch subdriver submits its own interrupt URB for notifications
about button presses. Consequently it needs to know about suspend and
resume events, so it can cancel or restart the URB.
This patch (as593) adds a hook to struct us_data, to be used for
notifying subdrivers about Power Management events, and it implements
the hook in the OneTouch driver.
Signed-off-by: Nick Sillik <n.sillik@temple.edu>
This patch adds a shim driver libusual, which routes devices between
usb-storage and ub according to the common table, based on unusual_devs.h.
The help and example syntax is in Kconfig.
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
This patch is originally from Alan Stern (as569). It has been rediffed
against a current tree.
This patch converts usb-storage to use the kthread API for creating its
control and scanning threads. The new code doesn't use kthread_stop
because the threads need (or will need in the future) to exit
asynchronously.
This patch is from Alan Stern (as560). It has been rediffed against a
current tree.
This patch allocates a separate buffer for usb-storage to use when
auto-sensing. Up to now we have been using the sense buffer embedded in a
scsi_cmnd struct, which is dangerous on hosts that (a) don't do
cache-coherent DMA or (b) have DMA alignment restrictions.
This patch started life as as531 from Alan Stern. It has been rediffed
against the latest tree.
The SCSI people have deprecated the use of scsi_cmnd.serial_number for
anything other than printk. Worse than that, the SCSI core doesn't
always increment the number (when the error handler is running, for
example). So this patch creates a locally-stored value for use in
bulk-only tags. The net result is a simplification, since we no longer
have to save & restore the serial_number value while autosensing.
infrastructure for it.
Let it rip!
