Cleanup do_rebind() return path and use common return path.
Signed-off-by: Shuah Khan <skhan@linuxfoundation.org>
stub_probe() calls put_busid_priv() in an error path when device isn't
found in the busid_table. Fix it by making put_busid_priv() safe to be
called with null struct bus_id_priv pointer.
This problem happens when "usbip bind" is run without loading usbip_host
driver and then running modprobe. The first failed bind attempt unbinds
the device from the original driver and when usbip_host is modprobed,
stub_probe() runs and doesn't find the device in its busid table and calls
put_busid_priv(0 with null bus_id_priv pointer.
usbip-host 3-10.2: 3-10.2 is not in match_busid table... skip!
[ 367.359679] =====================================
[ 367.359681] WARNING: bad unlock balance detected!
[ 367.359683] 4.17.0-rc4+ #5 Not tainted
[ 367.359685] -------------------------------------
[ 367.359688] modprobe/2768 is trying to release lock (
[ 367.359689]
[ 367.359696] BUG: KASAN: null-ptr-deref in print_unlock_imbalance_bug+0x99/0x110
[ 367.359699] Read of size 8 at addr 0000000000000058 by task modprobe/2768
[ 367.359705] CPU: 4 PID: 2768 Comm: modprobe Not tainted 4.17.0-rc4+ #5
Fixes: 22076557b07c ("usbip: usbip_host: fix NULL-ptr deref and use-after-free errors") in usb-linus
Signed-off-by: Shuah Khan (Samsung OSG) <shuah@kernel.org>
Cc: stable <stable@kernel.org>
usbip_host updates device status without holding lock from stub probe,
disconnect and rebind code paths. When multiple requests to import a
device are received, these unprotected code paths step all over each
other and drive fails with NULL-ptr deref and use-after-free errors.
The driver uses a table lock to protect the busid array for adding and
deleting busids to the table. However, the probe, disconnect and rebind
paths get the busid table entry and update the status without holding
the busid table lock. Add a new finer grain lock to protect the busid
entry. This new lock will be held to search and update the busid entry
fields from get_busid_idx(), add_match_busid() and del_match_busid().
match_busid_show() does the same to access the busid entry fields.
get_busid_priv() changed to return the pointer to the busid entry holding
the busid lock. stub_probe(), stub_disconnect() and stub_device_rebind()
call put_busid_priv() to release the busid lock before returning. This
changes fixes the unprotected code paths eliminating the race conditions
in updating the busid entries.
Reported-by: Jakub Jirasek
After removing usbip_host module, devices it releases are left without
a driver. For example, when a keyboard or a mass storage device are
bound to usbip_host when it is removed, these devices are no longer
bound to any driver.
Fix it to run device_attach() from the module exit routine to restore
the devices to their original drivers. This includes cleanup changes
and moving device_attach() code to a common routine to be called from
rebind_store() and usbip_host_exit().
Device is left in the busid_table after unbind and rebind. Rebind
initiates usb bus scan and the original driver claims the device.
After rescan the device should be deleted from the busid_table as
it no longer belongs to usbip_host.
Fix it to delete the device after device_attach() succeeds.
usbip_host calls device_attach() without holding dev->parent lock.
Fix it.
Signed-off-by: Shuah Khan <shuahkh@osg.samsung.com>
Cc: stable <stable@vger.kernel.org>
Remove and/or change debug, info. and error messages to not print
kernel pointer addresses.
Now that the SPDX tag is in all USB files, that identifies the license
in a specific and legally-defined manner. So the extra GPL text wording
can be removed as it is no longer needed at all.
This is done on a quest to remove the 700+ different ways that files in
the kernel describe the GPL license text. And there's unneeded stuff
like the address (sometimes incorrect) for the FSF which is never
needed.
No copyright headers or other non-license-description text was removed.
Cc: Valentina Manea <valentina.manea.m@gmail.com>
Acked-by: Shuah Khan <shuahkh@osg.samsung.com>
It's good to have SPDX identifiers in all files to make it easier to
audit the kernel tree for correct licenses.
Update the drivers/usb/ and include/linux/usb* files with the correct
SPDX license identifier based on the license text in the file itself.
The SPDX identifier is a legally binding shorthand, which can be used
instead of the full boiler plate text.
This work is based on a script and data from Thomas Gleixner, Philippe
Ombredanne, and Kate Stewart.
Cc: Kate Stewart <kstewart@linuxfoundation.org>
Cc: Philippe Ombredanne <pombredanne@nexb.com>
Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Acked-by: Johan Hovold <johan@kernel.org>
MODULE_VERSION is useless for in-kernel drivers, so just remove all
usage of it in the USB usbip drivers. Along with this, the
USBIP_VERSION macros was removed as is was also pointless, as well as
printing out the driver version to the syslog at init time, which is not
necessary at all.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core updates from Greg KH:
"Here is the big driver core update for 4.13-rc1.
The large majority of this is a lot of cleanup of old fields in the
driver core structures and their remaining usages in random drivers.
All of those fixes have been reviewed by the various subsystem
maintainers. There's also some small firmware updates in here, a new
kobject uevent api interface that makes userspace interaction easier,
and a few other minor things.
All of these have been in linux-next for a long while with no reported
issues"
* tag 'driver-core-4.13-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (56 commits)
arm: mach-rpc: ecard: fix build error
zram: convert remaining CLASS_ATTR() to CLASS_ATTR_RO()
driver-core: remove struct bus_type.dev_attrs
powerpc: vio_cmo: use dev_groups and not dev_attrs for bus_type
powerpc: vio: use dev_groups and not dev_attrs for bus_type
USB: usbip: convert to use DRIVER_ATTR_RW
s390: drivers: convert to use DRIVER_ATTR_RO/WO
platform: thinkpad_acpi: convert to use DRIVER_ATTR_RO/RW
pcmcia: ds: convert to use DRIVER_ATTR_RO
wireless: ipw2x00: convert to use DRIVER_ATTR_RW
net: ehea: convert to use DRIVER_ATTR_RO
net: caif: convert to use DRIVER_ATTR_RO
TTY: hvc: convert to use DRIVER_ATTR_RW
PCI: pci-driver: convert to use DRIVER_ATTR_WO
IB: nes: convert to use DRIVER_ATTR_RW
HID: hid-core: convert to use DRIVER_ATTR_RO and drv_groups
arm: ecard: fix dev_groups patch typo
tty: serdev: use dev_groups and not dev_attrs for bus_type
sparc: vio: use dev_groups and not dev_attrs for bus_type
hid: intel-ish-hid: use dev_groups and not dev_attrs for bus_type
The usbip stack dynamically allocates the transfer_buffer and
setup_packet of each urb that got generated by the tcp to usb stub code.
As these pointers are always used only once we will set them to NULL
after use. This is done likewise to the free_urb code in vudc_dev.c.
This patch fixes double kfree situations where the usbip remote side
added the URB_FREE_BUFFER.
Cc: stable@vger.kernel.org
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
We are trying to get rid of DRIVER_ATTR(), and the usbip driver
attribute can be trivially changed to use DRIVER_ATTR_RW().
Cc: <linux-usb@vger.kernel.org>
At this point, USB/IP kernel code is fully functional
and can be moved out of staging.
Signed-off-by: Valentina Manea <valentina.manea.m@gmail.com>
