There are several benefits for doing like this:
- hc_driver can be customized for each hcd
- Other hcd hc_driver's initialization will not affect current one.
We run out NULL pointer dereference problem when one hcd is started
by module_init, and the other is started by otg thread at SMP platform.
The reason for this problem is ehci_init_driver will do memory copy
for current uniform hc_driver, and this memory copy will do memset (as 0)
first, so when the first hcd is running usb_add_hcd, and the second
hcd may clear the uniform hc_driver's space (at ehci_init_driver),
then the first hcd will meet NULL pointer at the same time.
See below two logs:
LOG_1:
ci_hdrc ci_hdrc.0: EHCI Host Controller
ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: doesn't support gadget
Unable to handle kernel NULL pointer dereference at virtual address 00000014
pgd = 80004000
[00000014] *pgd=00000000
Internal error: Oops: 805 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 108 Comm: kworker/u8:2 Not tainted 3.14.38-222193-g24b2734-dirty #25
Workqueue: ci_otg ci_otg_work
task: d839ec00 ti: d8400000 task.ti: d8400000
PC is at ehci_run+0x4c/0x284
LR is at _raw_spin_unlock_irqrestore+0x28/0x54
pc : [<8041f9a0>] lr : [<8070ea84>] psr: 60000113
sp : d8401e30 ip : 00000000 fp : d8004400
r10: 00000001 r9 : 00000001 r8 : 00000000
r7 : 00000000 r6 : d8419940 r5 : 80dd24c0 r4 : d8419800
r3 : 8001d060 r2 : 00000000 r1 : 00000001 r0 : 00000000
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c53c7d Table: 1000404a DAC: 00000015
Process kworker/u8:2 (pid: 108, stack limit = 0xd8400238)
Stack: (0xd8401e30 to 0xd8402000)
1e20: d87523c0 d8401e48 66667562 d8419800
1e40: 00000000 00000000 d8419800 00000000 00000000 00000000 d84198b0 8040fcdc
1e60: 00000000 80dd320c d8477610 d8419c00 d803d010 d8419800 00000000 00000000
1e80: d8004400 00000000 d8400008 80431494 80431374 d803d100 d803d010 d803d1ac
1ea0: 00000000 80432428 804323d4 d803d100 00000001 80435eb8 80e0d0bc d803d100
1ec0: 00000006 80436458 00000000 d803d100 80e92ec8 80436f44 d803d010 d803d100
1ee0: d83fde00 8043292c d8752710 d803d1f4 d803d010 8042ddfc 8042ddb8 d83f3b00
1f00: d803d1f4 80042b60 00000000 00000003 00000001 00000001 80054598 d83f3b00
1f20: d8004400 d83f3b18 d8004414 d8400000 80e3957b 00000089 d8004400 80043814
1f40: d839ec00 00000000 d83fcd80 d83f3b00 800436e4 00000000 00000000 00000000
1f60: 00000000 80048f34 00000000 00000000 00000000 d83f3b00 00000000 00000000
1f80: d8401f80 d8401f80 00000000 00000000 d8401f90 d8401f90 d8401fac d83fcd80
1fa0: 80048e68 00000000 00000000 8000e538 00000000 00000000 00000000 00000000
1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[<8041f9a0>] (ehci_run) from [<8040fcdc>] (usb_add_hcd+0x248/0x6e8)
[<8040fcdc>] (usb_add_hcd) from [<80431494>] (host_start+0x120/0x2e4)
[<80431494>] (host_start) from [<80432428>] (ci_otg_start_host+0x54/0xbc)
[<80432428>] (ci_otg_start_host) from [<80435eb8>] (otg_set_protocol+0xa4/0xd0)
[<80435eb8>] (otg_set_protocol) from [<80436458>] (otg_set_state+0x574/0xc58)
[<80436458>] (otg_set_state) from [<80436f44>] (otg_statemachine+0x408/0x46c)
[<80436f44>] (otg_statemachine) from [<8043292c>] (ci_otg_fsm_work+0x3c/0x190)
[<8043292c>] (ci_otg_fsm_work) from [<8042ddfc>] (ci_otg_work+0x44/0x1c4)
[<8042ddfc>] (ci_otg_work) from [<80042b60>] (process_one_work+0xf4/0x35c)
[<80042b60>] (process_one_work) from [<80043814>] (worker_thread+0x130/0x3bc)
[<80043814>] (worker_thread) from [<80048f34>] (kthread+0xcc/0xe4)
[<80048f34>] (kthread) from [<8000e538>] (ret_from_fork+0x14/0x3c)
Code: e5953018 e3530000 0a000000 e12fff33 (e5878014)
LOG_2:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = 80004000
[00000000] *pgd=00000000
In Online 00:00ternal e Offline rror: Oops: 80000005 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 0 PID: 108 Comm: kworker/u8:2 Not tainted 3.14.38-02007-g24b2734-dirty #127
Workque Online 00:00ue: ci_o Offline tg ci_otg_work
Online 00:00task: d8 Offline 39ec00 ti: d83ea000 task.ti: d83ea000
PC is at 0x0
LR is at usb_add_hcd+0x248/0x6e8
pc : [<00000000>] lr : [<8040f644>] psr: 60000113
sp : d83ebe60 ip : 00000000 fp : d8004400
r10: 00000001 r9 : 00000001 r8 : d85fd4b0
r7 : 00000000 r6 : 00000000 r5 : 00000000 r4 : d85fd400
r3 : 00000000 r2 : d85fd4f4 r1 : 80410178 r0 : d85fd400
Process kworker/u8:2 (pid: 108, stack limit = 0xd83ea238)
Stack: (0xd83ebe60 to 0xd83ec000)
be60: 00000000 80dd920c d8654e10 d85fd800 d803e010 d85fd400 00000000 00000000
be80: d8004400 00000000 d83ea008 80430e34 80430d14 d803e100 d803e010 d803e1ac
bea0: 00000000 80431dc8 80431d74 d803e100 00000001 80435858 80e130bc d803e100
bec0: 00000006 80435df8 00000000 d803e100 80e98ec8 804368e4 d803e010 d803e100
bee0: d86e8100 804322cc d86cf050 d803e1f4 d803e010 8042d79c 8042d758 d83cf900
bf00: d803e1f4 80042b78 00000000 00000003 00000001 00000001 800545e8 d83cf900
bf20: d8004400 d83cf918 d8004414 d83ea000 80e3f57b 00000089 d8004400 8004382c
bf40: d839ec00 00000000 d8393780 d83cf900 800436fc 00000000 00000000 00000000
bf60: 00000000 80048f50 80e019f4 00000000 0000264c d83cf900 00000000 00000000
bf80: d83ebf80 d83ebf80 00000000 00000000 d83ebf90 d83ebf90 d83ebfac d8393780
bfa0: 80048e84 00000000 00000000 8000e538 00000000 00000000 00000000 00000000
bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 ee66e85d 133ebd03
[<804 Online 00:000f644>] Offline (usb_add_hcd) from [<80430e34>] (host_start+0x120/0x2e4)
[<80430e34>] (host_start) from [<80431dc8>] (ci_otg_start_host+0x54/0xbc)
[<80431dc8>] (ci_otg_start_host) from [<80435858>] (otg_set_protocol+0xa4/0xd0)
[<80435858>] (otg_set_protocol) from [<80435df8>] (otg_set_state+0x574/0xc58)
[<80435df8>] (otg_set_state) from [<804368e4>] (otg_statemachine+0x408/0x46c)
[<804368e4>] (otg_statemachine) from [<804322cc>] (ci_otg_fsm_work+0x3c/0x190)
[<804322cc>] (ci_otg_fsm_work) from [<8042d79c>] (ci_otg_work+0x44/0x1c4)
[<8042d79c>] (ci_otg_work) from [<80042b78>] (process_one_work+0xf4/0x35c)
[<80042b78>] (process_one_work) from [<8004382c>] (worker_thread+0x130/0x3bc)
[<8004382c>] (worker_thread) from [<80048f50>] (kthread+0xcc/0xe4)
[<80048f50>] (kthread) from [<8000e538>] (ret_from_fork+0x14/0x3c)
Code: bad PC value
Signed-off-by: Peter Chen <peter.chen@freescale.com>
(cherry picked from commit 8d0ca70bdac986f5886ba8ccfff46a41e7a555ec)
The current condition may not true even we have driven vbus on already.
The vbus drive operation may be async, eg through i2c gpio expendor,
so the vbus may not be valid when we unload usb module.
We meet this issue when we do fast load/unload usb module test.
(cherry picked from commit a4dec7730c98f2639fe250a1a67f782b6f73bdf5)
While A device as peripheral ends session by a_bus_drop, it will go
back to host role by transition to a_wait_vfall state, then ehci
host driver may access portsc status after controller enters suspend
, this will result in system hang since its clock is gated off.
This patch use existing autosuspend to delay the controller suspend
if it comes to a_wait_vfall state.
Signed-off-by: Li Jun <jun.li@freescale.com>
(cherry picked from commit b140fa6803ef6ececec17e435212a960a3169cc2)
Add usb otg ADP support for imx usb driver, and enable it on i.MX7D.
ADP(Attach Detection Protocol) is part of USB OTG 2.0 release, which can be
used to find device attachment after session ends(vbus is off). This patch adds
OTG ADP feature for chipdea usb driver.
When otg fsm leaves a_idle or b_idle, ADP probe and sense should be stopped,
therefore ADP timers should be removed.
Check property of usb hardware to get if ADP is supported.
With commit "95b62fe MLK-10750 usb: chipidea: otg: remove otg fsm
before destory gdaget and host", the otg fsm will be removed first,
but when the host is removing, it will trigger pcd interrupt, and otg
work is still queued to ci_otg workqueue(otg state is OTG_STATE_A_HOST),
but at that time, ci_otg workqueue has been destroyed.
In this commit, we make sure the otg work is not queued if ci->wq is NULL,
and keep otg state is OTG_STATE_UNDEFINED after otg fsm has been removed.
The NULL pointer deference error like belows:
pgd = a873c000
[00000000] *pgd=a90f9831, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1] PREEMPT SMP ARM
Modules linked in: usb_f_ecm u_ether libcomposite configfs ci_hdrc_imx(-) ci_hdrc udc_core ehci_hcd mxc_vadc mx6s_capture mxc_dcic ov5640_camera usbmisc_imx phy_mxs_usb evbug [last unloaded: usb_f_rndis]
CPU: 0 PID: 162 Comm: udevd Not tainted 3.14.38-02187-g5639985-dirty #160
task: a863e880 ti: a872e000 task.ti: a872e000
PC is at __queue_work+0x68/0x268
LR is at __queue_work+0x68/0x268
pc : [<80045060>] lr : [<80045060>] psr: 600e0193
sp : a872fed0 ip : 00000000 fp : 00000000
r10: 00000004 r9 : a872e000 r8 : 0000004b
r7 : 80e4c804 r6 : a9295000 r5 : a87f8294 r4 : 00000000
r3 : a80690e0 r2 : 00000000 r1 : a8069108 r0 : a8003400
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: a873c04a DAC: 00000015
Process udevd (pid: 162, stack limit = 0xa872e238)
Stack: (0xa872fed0 to 0xa8730000)
fec0: 00ff3d34 80743750 00000000 600e0193
fee0: a87f8294 a9295000 00000004 0000004b a8008900 80eb51ff 00ff3d34 800452a8
ff00: 00000000 a87f8010 00000000 00000000 00000000 7f060ac0 a8dfced0 a87f8010
ff20: 00002e20 7f059730 a8e7e2c0 a800895c 00000000 8006c1b4 80e46080 80e40458
ff40: a8008900 a800895c a8e7e2c0 c0802100 00fc40e8 00000000 00000048 8006c320
ff60: a8008900 a800895c 00000000 8006f1c4 8006f140 0000004b 0000004b 8006b92c
ff80: 80e40e54 8000f9cc c080210c 80e4c970 a872ffb0 8000856c 00fc4308 76d9c890
ffa0: 600e0010 ffffffff 7edef480 800130bc 00fc4308 00ff3d70 00000000 000000ff
ffc0: 00000671 00000000 00ff3b90 7edef480 00fc40e8 00000000 00000048 00ff3d34
ffe0: 000321b8 7edef140 000240a0 76d9c890 600e0010 ffffffff abf5e821 abf5ec21
[<80045060>] (__queue_work) from [<800452a8>] (queue_work_on+0x48/0x54)
[<800452a8>] (queue_work_on) from [<7f060ac0>] (ci_otg_fsm_irq+0x108/0x310 [ci_hdrc])
[<7f060ac0>] (ci_otg_fsm_irq [ci_hdrc]) from [<7f059730>] (ci_irq+0x94/0x158 [ci_hdrc])
[<7f059730>] (ci_irq [ci_hdrc]) from [<8006c1b4>] (handle_irq_event_percpu+0x50/0x180)
[<8006c1b4>] (handle_irq_event_percpu) from [<8006c320>] (handle_irq_event+0x3c/0x5c)
[<8006c320>] (handle_irq_event) from [<8006f1c4>] (handle_fasteoi_irq+0x84/0x14c)
[<8006f1c4>] (handle_fasteoi_irq) from [<8006b92c>] (generic_handle_irq+0x2c/0x3c)
[<8006b92c>] (generic_handle_irq) from [<8000f9cc>] (handle_IRQ+0x40/0x90)
[<8000f9cc>] (handle_IRQ) from [<8000856c>] (gic_handle_irq+0x2c/0x5c)
[<8000856c>] (gic_handle_irq) from [<800130bc>] (__irq_usr+0x3c/0x60)
Exception stack(0xa872ffb0 to 0xa872fff8)
ffa0: 00fc4308 00ff3d70 00000000 000000ff
Code: e5964084 e0844003 e1a00005 ebfffa14 (e5943000)
---[ end trace 53dc25e918ff7216 ]---
Kernel panic - not syncing: Fatal exception in interrupt
If PORT_RWC_BITS is set, it will still be cleared by writing 1.
portsc.ptw can only be changed when PHY clock is off and portsc.phcd is set,
if not, the PHY will be error, so we keep portsc.ptw unchanging
in this patch.
Current code just do not do reusme signaling for clear suspend feature if it's
a OTG port with b_hnp_enable set, this result in OTG host cannot clear suspend
and resume OTG device after system resume from sleep, then host will disconnect
the OTG B-device and enumerate it again. To make OTG A-device in host state can
do clear feature of suspend like an usual host, and also be compatible legacy
OTG device, this patch adds another condition to check if OTG FSM driver is used
,as in OTG FSM driver, we need not do HNP in that case.
Acked-by: Peter Chen <peter.chen@freescale.com>
(cherry picked from commit f92731f787ca00ef8cd0ab9d591e4e24d5a40cc4)
While system resume, the connected udev as B-device may not has been resumed,
if HNP polling request is sent to it, HNP polling may fail, this patch adds
check of the udev state to make sure it finished resume and to be configured
state before sending host request message, otherwise try next HNP polling
request.
(cherry picked from commit 2cff5eb7bd4feb70cd28ac4655e7433e57a17938)
We set b_hnp_enable and a_set_b_hnp_en when enumeration of HNP capable
otg device, those 2 flags should be cleared beforehand for any new usb
devices connected.
(cherry picked from commit e332229d38c15a83bb3ee0bfc3638a539a836b8a)
This patch is to clear the flag b_conn when turns off vbus to end a session.
when otg fsm is a_host -> a_suspend -> a_wait_vfall -> a_idle, current otg
fsm implementation does not handle disconnect event since the disconnection
does not happen while a_host state, so the b_conn is still set when in a_idle,
this patch clear b_conn flag after turn off vbus.
Signed-off-by: Li Jun <b47624@freescale.com>
(cherry picked from commit 043b79264051454de18488cb746ee617d86f3568)
If it's A host and b_hnp_enable is set, or B host, we can do HNP polling
because B host will not check OTG descriptor and set b_hnp_enable flag
when enumeration.
(cherry picked from commit 6148c9df6d1c68dfc91cfe274101058c8edf979b)
500ms is enough for vbus fall to VOTG_VBUS_LKG(0.7v, OTG device or EH
Leakage Voltage).
(cherry picked from commit 41295ac496aa7697585e65223797e0cb4e5fb153)
This patch is to fix one OTG HNP timing requirement, TA_BIDL_ADIS should be
in range of 155ms~200ms per OTG spec 2.0 reverion 1.1a.
(cherry picked from commit a6de1be200984b01d784f6558229adbb67fcb380)
B-device detects that bus is idle for more than TB_AIDL_BDIS min and begins HNP
by turning off pullup on DP, this allows the bus to discharge to the SE0 state.
This timer was missed and failed with one PET test, this patch is to fix this
timing issue.
Show 'Device no response' message if A-device fails to connect as a peripheral.
If b device does not detect vbus on after TB_SRP_FAIL of data pulse,
b device should show 'Device no response' message.
When a host start a session and wait b device to connnect within
TA_WAIT_BCON, if failed, should show a message 'Device no response'
according to otg and EH compliance plan version 1.2 section 6.7.22
(cherry picked from commit 1762592ead672d27b281df8becf90f8c7d7fe61c)
According to "USB On-The-Go and Embedded Host Automated Compliance Plan Version
1.2", chapter 6.7.23, unknown Device Not Supporting HNP:'Unsupported Device';
chapter 6.7.24 unknown Device Supporting HNP: 'Device No Response'
(cherry picked from commit 32df700386fff1d1eef90007604055f1d013aaf3)
This patch is clearing b_bus_req input to be 0 when entering b_peripheral state.
b_bus_req is only TRUE when b device wants to use the bus and switch to be host
role.
(cherry picked from commit eb610e73aa38bbb45aed6a79265cd79fe80cdd05)
This patch is clearing a_conn flag when b device leave b_host state.
(cherry picked from commit e511cc08879fa97035900ae8626051e473f30cd9)
This patch adds response to getting OTG descriptor request from host.
(cherry picked from commit 560690f1b24448b94806f390add9d91d602e3ef4)
This patch changes hub power stable wait time for root hub of b host from
100ms to 50ms to meet OTG HNP timing requirment.
(cherry picked from commit 31889db617b7ecf4cdf9f9e98957ec9b6de49a4e)
This patch changes bus reset time for B host enumuration, from entering B host
to the time clear USB_PORT_FEAT_C_CONNECTION, a random time after B host detect
port change for A peripheral connection may not work.
(cherry picked from commit b87d3bb0672ebcfb29c7db8708c586b2d38558d1)
This patch adds host port reset implementation for HNP timing requirement,
which will be called when B host starts enumuration.
(cherry picked from commit 5df2a65c073dcdf227f1eb340a686a589db5009b)
This patch replaces b_hnp_enable with a_set_b_hnp_en to comply with state diagram
of USB and EH spec.
(cherry picked from commit 4734ed1f813959a7544ad744d60ab119efb04ba9)
This patch updates condition from a_host to a_suspend according to On-The-Go
and Embedded Host Supplement to the USB Revision 2.0 Specification Revision
2.0 version 1.1a.
(cherry picked from commit f3acf74150683d4555c82ad32b9c669d8a0a7fb5)
Use a_set_b_hnp_en to identify if a host can succeed to set b_hnp_enable
for B device, use b_hnp_enable flag to identify if the connected OTG device
is HNP capable. So if the connected otg device is HNP capable but b_hnp_enable
is not set for A host, the host which support HNP polling should continue
enumeration to see if the B device can talk to it later by hnp polling.
(cherry picked from commit b715d0773eea212a25d6b8c5d94530e12935fdaf)
This patch enables hnp_polling flag for chipidea host driver in otg fsm mode.
(cherry picked from commit acb43a932263edd9b80c6d6d9ee858176c201542)
If a HNP capable device STALL b_hnp_enable set feature request, A device
as host should not break otg device enumeration, because this set feature
failure only indicates the B device does not want to be host role for the
moment, A device as host talk to it should be okay.
see charpter 6.2.2.2 of OTG and EH 2.0:
"If the a_hnp_support feature is set, but the b_hnp_enable feature is not set,
then it is likely that b_hnp_enable will be set later when the A-device is
finished using the bus."
(cherry picked from commit 51317577d16034ba151da8d502319f4befb91278)
This patch adds a_hnp_support feature to maintain compatibility with legacy
B-devices.The A-device shall set this feature on any legacy B-device, complying
with OTG supplement version 1.3 or earlier, that is attached to an A-device port
that supports HNP.
(cherry picked from commit 925980190a5f341ed1110239ea481b9452094f6c)
Since legacy OTG test device which is only compliant with OTG supplement version
1.3 or earlier, cannot support HNP polling, so directly start role switch.
(cherry picked from commit 688bbca155159978cd520923f2c3029c7778fa9c)
This patch clears otg_hnp_reqd feature related flags when the HNP test ends.
There are two otg fsm paths to end this feature request:
- b_peripheral --> b_wait_acon --> b_idle: we clear them when entering b_idle;
- b_peripheral --> b_wait_acon --> b_host --> b_peripheral : we clear them
when leaving b_host.
(cherry picked from commit 39d25f04ed047e15f23b44e8465ce46257547df7)
This patch implements a timer for B host to start host role switch back to A
device.
(cherry picked from commit 139bcc46841f73199bdc3ca308e46a5af3dd2fc1)
After B device as host enumerates A peripheral and sets configuration,
B host should start to hand host role back to A device when this timer
expires.
(cherry picked from commit 3f4a8c8a20ef69721f9e7886b8d245036d41d91a)
This patch adds otg_hnp_reqd set feature request from A host for chipidea udc
driver.
(cherry picked from commit 450d4a1eb40ec4284661c1130bdcc4f4d2e6c527)
This patch adds a timer for chipidea otg fsm driver to start data pulse
after A host ends the session.
(cherry picked from commit 35e92b59080b58925c3b96e36511056cb51d4a00)
This patch adds otg_srp_reqd set feature request from A host for chipidea
udc driver.
(cherry picked from commit 5edca27c518e8a69accb429c946c19243e156656)
When the connected otg test device disconnects before test maintain timer
expires, A device should end the session if otg_vbus_off is set; and do
a_wait_bcon if otg_vbus_off is not set.
(cherry picked from commit 204fa72fe4e2be468fe61f1ede555e072610c932)
This patch implements otg test device session maintain timer, if the timer
expires, A device as host should end the session, and clear tst_maint flag
when turn off vbus.
(cherry picked from commit c0d2dc56012a2308b0bf48429fefa559fc4c80e4)
If B device set host request flag before test maintain timer expires, remove
the timer and clear test maintain session flag, do HNP as a normal OTG device.
(cherry picked from commit d914c80921652419037d935f14545fe87f74a71c)
This patch adds 2 variables: tst_maint and otg_vbus_off, tst_maint is to check if
current session for test device; otg_vbus_off is to notify if A device need turn
off vbus immediately after B device disconnects.
The otg test device handling is added into ehset driver, for that device,
A-device should start a timer for maintain the session, and set otg_vbus_off
flag according to its bcdDevice value.
(cherry picked from commit 78a2c14bdea4b8e334c7e0afad074b61b71193cb)
This patch add otg test device with VID(0x1a0a) and PID(0x0200) into otg and
EH TPL.
(cherry picked from commit b88ee5e2cbf55aaed3b6c5dd0aff7f826f9e357d)
This patch sets and clear is_b_host flag of usb_bus when start and stop host in
chipidea host driver.
(cherry picked from commit c164e65922235efcacc3743a9719adc7a9ef7413)
This is required for USB OTG and EH compliance test 6.7.22(A-UUT “Device No
Response” for connection timeout). When the connected usb device(PET) does
not response to transactions, host will fail to get device descriptor.
(cherry picked from commit 86d0bd661ecbbdf97dd9a8ddbaf0d3811de7f39e)
After device power up, insert usb OTG ID cable, otg fsm from undefined state
to a_idle, the BSV cannot be disabled, this will result BSV irq generated but
which is actually only for B device.
For some platforms, time delay is requried between putting PHY into low power
mode and gate PHY clock.
In some situations, we need vbus level which lower than vbus valid
as wakeup source, eg, at the OTG certification test, the valid bus
level for b device is from 4.0v to 6.0v.
