commit 227a4fd801c8a9fa2c4700ab98ec1aec06e3b44d upstream.
When a device with an isochronous endpoint is plugged into the Intel
xHCI host controller, and the driver submits multiple frames per URB,
the xHCI driver will set the Block Event Interrupt (BEI) flag on all
but the last TD for the URB. This causes the host controller to place
an event on the event ring, but not send an interrupt. When the last
TD for the URB completes, BEI is cleared, and we get an interrupt for
the whole URB.
However, under Intel xHCI host controllers, if the event ring is full
of events from transfers with BEI set, an "Event Ring is Full" event
will be posted to the last entry of the event ring, but no interrupt
is generated. Host will cease all transfer and command executions and
wait until software completes handling the pending events in the event
ring. That means xHC stops, but event of "event ring is full" is not
notified. As the result, the xHC looks like dead to user.
This patch is to apply XHCI_AVOID_BEI quirk to Intel xHC devices. And
it should be backported to kernels as old as 3.0, that contains the
commit 69e848c2090a ("Intel xhci: Support EHCI/xHCI port switching.").
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Tested-by: Alistair Grant <akgrant0710@gmail.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 9425183d177aa4a2f09d01a74925124f0778b595 upstream.
Linux xHCI driver doesn't report and handle port cofig error change.
If Port Configure Error for root hub port occurs, CEC bit in PORTSC
would be set by xHC and remains 1. This happends when the root port
fails to configure its link partner, e.g. the port fails to exchange
port capabilities information using Port Capability LMPs.
Then the Port Status Change Events will be blocked until all status
change bits(CEC is one of the change bits) are cleared('0') (refer to
xHCI spec 4.19.2). Otherwise, the port status change event for this
root port will not be generated anymore, then root port would look
like dead for user and can't be recovered until a Host Controller
Reset(HCRST).
This patch is to check CEC bit in PORTSC in xhci_get_port_status()
and set a Config Error in the return status if CEC is set. This will
cause a ClearPortFeature request, where CEC bit is cleared in
xhci_clear_port_change_bit().
[The commit log is based on initial Marvell patch posted at
http://marc.info/?l=linux-kernel&m=142323612321434&w=2]
Reported-by: Gregory CLEMENT <gregory.clement@free-electrons.com>
commit b229a0f840f774d29d8fedbf5deb344ca36b7f1a upstream.
This patch uses the existing CALAO Systems ftdi_8u2232c_probe in order
to avoid attaching a TTY to the JTAG port as this board is based on the
CALAO Systems reference design and needs the same fix up.
Signed-off-by: Doug Goldstein <cardoe@cardoe.com>
[johan: clean up probe logic ]
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 4899c054a90439477b24da8977db8d738376fe90 upstream.
Synapse Wireless uses the FTDI VID with a custom PID of 0x9090 for their
SNAP Stick 200 product.
commit 5e71fc8629cefae5f3c1a4f498de3fe4f631924a upstream.
Add USB VID/PID for Xircom PGMFHUB USB/serial component. (The hub and SCSI
bridge on that hardware are recognized out of the box by existing drivers.)
Tested VID/PID using new_id and loopback connection and was met with
success, but that's all the testing done.
Signed-off-by: Nathaniel Wesley Filardo <nwf@cs.jhu.edu>
commit a886bd92267c9e3d5c912860c6fb5a68479a7643 upstream.
We should signal connect (pull up dp) after we have already
at peripheral mode, otherwise, the dp may be toggled due to
we reset controller or do disconnect during the initialization
for peripheral, then, the host may be confused during the
enumeration, eg, it finds the reset can't succeed, but the
device is still there, see below error message.
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
hub 1-0:1.0: cannot reset port 1 (err = -32)
hub 1-0:1.0: Cannot enable port 1. Maybe the USB cable is bad?
hub 1-0:1.0: unable to enumerate USB device on port 1
Fixes: the issue existed when the otg fsm code was added.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
commit d20f7807996c69537e07443ef8dec4e01a28b099 upstream.
This patch adds response to a_alt_hnp_support set feature request from legacy
A device, that is, B-device can provide a message to the user indicating that
the user needs to connect the B-device to an alternate port on the A-device.
A device sets this feature indicates to the B-device that it is connected
to an A-device port that is not capable of HNP, but that the A-device does have
an alternate port that is capable of HNP.
[Peter]
Without this patch, the OTG B device can't be enumerated on
non-HNP port at A device, see below log:
[ 2.287464] usb 1-1: Dual-Role OTG device on non-HNP port
[ 2.293105] usb 1-1: can't set HNP mode: -32
[ 2.417422] usb 1-1: new high-speed USB device number 4 using ci_hdrc
[ 2.460635] usb 1-1: Dual-Role OTG device on non-HNP port
[ 2.466424] usb 1-1: can't set HNP mode: -32
[ 2.587464] usb 1-1: new high-speed USB device number 5 using ci_hdrc
[ 2.630649] usb 1-1: Dual-Role OTG device on non-HNP port
[ 2.636436] usb 1-1: can't set HNP mode: -32
[ 2.641003] usb usb1-port1: unable to enumerate USB device
Acked-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Li Jun <b47624@freescale.com>
commit d0f347d62814ec0f599a05c61c5619d5e999e4ae upstream.
This fixes a potential null pointer dereference.
Fixes: d4332013919a ("driver core: dev_get_drvdata: Don't check for NULL dev")
Acked-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: David Dueck <davidcdueck@googlemail.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit bda13e35d584dabf52c9f77e0fe62683ac4d9f86 upstream.
A new uas compatible controller has shown up in some people's devices from
the manufacturer Initio Corporation, this controller needs the US_FL_NO_ATA_1X
quirk to work properly with uas, so add it to the uas quirks table.
Reported-and-tested-by: Benjamin Tissoires <benjamin.tissoires@redhat.com>
Cc: Benjamin Tissoires <benjamin.tissoires@redhat.com>
commit f01d35a15fa04162a58b95970fc01fa70ec9dacd upstream.
AIO_PREAD requests call ->aio_read() with iovec on caller's stack, so if
we are going to access it asynchronously, we'd better get ourselves
a copy - the one on kernel stack of aio_run_iocb() won't be there
anymore. function/f_fs.c take care of doing that, legacy/inode.c
doesn't...
commit ca4383a3947a83286bc9b9c598a1f55e867871d7 upstream.
Add missing error handling when registering the tty device at port
probe. This avoids trying to remove an uninitialised character device
when the port device is removed.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Reported-by: Takashi Iwai <tiwai@suse.de>
Acked-by: Greg Kroah-Hartman <greg@kroah.com>
commit 07fdfc5e9f1c966be8722e8fa927e5ea140df5ce upstream.
Fix return value in probe error path, which could end up returning
success (0) on errors. This could in turn lead to use-after-free or
double free (e.g. in port_remove) when the port device is removed.
Fixes: c706ebdfc895 ("USB: usb-serial: call port_probe and port_remove
at the right times")
commit f528bf4f57e43d1af4b2a5c97f09e43e0338c105 upstream.
Make sure to handle an infinite timeout (0).
Note that wait_until_sent is currently never called with a 0-timeout
argument due to a bug in tty_wait_until_sent.
Fixes: dcf010503966 ("USB: serial: add generic wait_until_sent
implementation")
commit b8cb91e058cd0c0f02059c1207293c5b31d350fa upstream.
The xhci in Intel Sunrisepoint and Cherryview platforms need a driver
workaround for a Stuck PME that might either block PME events in suspend,
or create spurious PME events preventing runtime suspend.
Workaround is to clear a internal PME flag, BIT(28) in a vendor specific
PMCTRL register at offset 0x80a4, in both suspend resume callbacks
Without this, xhci connected usb devices might never be able to wake up the
system from suspend, or prevent device from going to suspend (xhci d3)
commit 45ba2154d12fc43b70312198ec47085f10be801a upstream.
When a control transfer has a short data stage, the xHCI controller generates
two transfer events: a COMP_SHORT_TX event that specifies the untransferred
amount, and a COMP_SUCCESS event. But when the data stage is not short, only the
COMP_SUCCESS event occurs. Therefore, xhci-hcd must set urb->actual_length to
urb->transfer_buffer_length while processing the COMP_SUCCESS event, unless
urb->actual_length was set already by a previous COMP_SHORT_TX event.
The driver checks this by seeing whether urb->actual_length == 0, but this alone
is the wrong test, as it is entirely possible for a short transfer to have an
urb->actual_length = 0.
This patch changes the xhci driver to rely on a new td->urb_length_set flag,
which is set to true when a COMP_SHORT_TX event is received and the URB length
updated at that stage.
This fixes a bug which affected the HSO plugin, which relies on URBs with
urb->actual_length == 0 to halt re-submitting the RX URB in the control
endpoint.
Signed-off-by: Aleksander Morgado <aleksander@aleksander.es>
commit 6596a926b0b6c80b730a1dd2fa91908e0a539c37 upstream.
Include the high order bit fields for Max scratchpad buffers when
calculating how many scratchpad buffers are needed.
I'm suprised this hasn't caused more issues, we never allocated more than
32 buffers even if xhci needed more. Either we got lucky and xhci never
really used past that area, or then we got enough zeroed dma memory anyway.
Should be backported as far back as possible
Reported-by: Tim Chen <tim.c.chen@linux.intel.com>
Tested-by: Tim Chen <tim.c.chen@linux.intel.com>
commit 1e7e4fb66489cc84366656ca5318f1cb61afd4ba upstream.
The commit 973747928514 ("usb: host: xhci-plat: add support for the Armada
375/38x XHCI controllers") extended the xhci-plat driver to support the Armada
375/38x SoCs, mostly by adding a quirk configuring the MBUS window.
However, that quirk was run before the clock the controllers needs has been
enabled. This usually worked because the clock was first enabled by the
bootloader, and left as such until the driver is probe, where it tries to
access the MBUS configuration registers before enabling the clock.
Things get messy when EPROBE_DEFER is involved during the probe, since as part
of its error path, the driver will rightfully disable the clock. When the
driver will be reprobed, it will retry to access the MBUS registers, but this
time with the clock disabled, which hangs forever.
Fix this by running the quirks after the clock has been enabled by the driver.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
commit a0456399fb07155637a2b597b91cc1c63bc25141 upstream.
The "Extended Compat ID OS Feature Descriptor Specification" does not
require the (sub)compatible ids to be NUL-terminated, because they
are placed in a fixed-size buffer and only unused parts of it should
contain NULs. If the buffer is fully utilized, there is no place for NULs.
Consequently, the code which uses desc->ext_compat_id never expects the
data contained to be NUL terminated.
If the compatible id is stored after sub-compatible id, and the compatible
id is full length (8 bytes), the (useless) NUL terminator overwrites the
first byte of the sub-compatible id.
If the sub-compatible id is full length (8 bytes), the (useless) NUL
terminator ends up out of the buffer. The situation can happen in the RNDIS
function, where the buffer is a part of struct f_rndis_opts. The next
member of struct f_rndis_opts is a mutex, so its first byte gets
overwritten. The said byte is a part of a mutex'es member which contains
the information on whether the muext is locked or not. This can lead to a
deadlock, because, in a configfs-composed gadget when a function is linked
into a configuration with config_usb_cfg_link(), usb_get_function()
is called, which then calls rndis_alloc(), which tries locking the same
mutex and (wrongly) finds it already locked.
This patch eliminates NUL terminating of the (sub)compatible id.
Fixes: da4243145fb1: "usb: gadget: configfs: OS Extended Compatibility descriptors support"
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
commit 96e5d31244c5542f5b2ea81d76f14ba4b8a7d440 upstream.
In the wrapper the IRQ disable should be done by writing 1's to the
IRQ*_CLR register. Existing code is broken because it instead writes
zeros to IRQ*_SET register.
Fix this by adding functions dwc3_omap_write_irqmisc_clr() and
dwc3_omap_write_irq0_clr() which do the right thing.
Fixes: 72246da40f37 ("usb: Introduce DesignWare USB3 DRD Driver")
Signed-off-by: George Cherian <george.cherian@ti.com>
commit c7d373c3f0da2b2b78c4b1ce5ae41485b3ef848c upstream.
This patch integrates Cyber Cortex AV boards with the existing
ftdi_jtag_quirk in order to use serial port 0 with JTAG which is
required by the manufacturers' software.
Steps: 2
[ftdi_sio_ids.h]
1. Defined the device PID
[ftdi_sio.c]
2. Added a macro declaration to the ids array, in order to enable the
jtag quirk for the device.
Signed-off-by: Max Mansfield <max.m.mansfield@gmail.com>
commit f6950344d3cf4a1e231b5828b50c4ac168db3886 upstream.
These product identifiers (PID) all deal with marine NMEA format data
used on motor boats and yachts. We supply the programmed devices to
Chetco, for use inside their equipment. The PIDs are a direct copy of
our Windows device drivers (FTDI drivers with altered PIDs).
Signed-off-by: Mark Glover <mark@actisense.com>
[johan: edit commit message slightly ]
commit f0c2b68198589249afd2b1f2c4e8de8c03e19c16 upstream.
When a signal is delivered, the information in the siginfo structure
is copied to userspace. Good security practice dicatates that the
unused fields in this structure should be initialized to 0 so that
random kernel stack data isn't exposed to the user. This patch adds
such an initialization to the two places where usbfs raises signals.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Reported-by: Dave Mielke <dave@mielke.cc>
commit db81de767e375743ebb0ad2bcad3326962c2b67e upstream.
Fix null-pointer dereference at probe when the device is used as a
console, in which case the tty argument to open will be NULL.
Fixes: ee467a1f2066 ("USB: serial: add Moxa UPORT 12XX/14XX/16XX
driver")
commit 675af70856d7cc026be8b6ea7a8b9db10b8b38a1 upstream.
These device ID's are not associated with the cp210x module currently,
but should be. This patch allows the devices to operate upon connecting
them to the usb bus as intended.
Signed-off-by: Michiel van de Garde <mgparser@gmail.com>
commit bc4b1f486fe69b86769e07c8edce472327a8462b upstream.
This reverts commit 5083fd7bdfe6760577235a724cf6dccae13652c2.
A bulk-out size smaller than the end-point size is indeed valid. The
offending commit broke the usb-debug driver for EHCI debug devices,
which use 8-byte buffers.
Fixes: 5083fd7bdfe6 ("USB: serial: make bulk_out_size a lower limit")
Reported-by: "Li, Elvin" <elvin.li@intel.com>
commit 59e980efafd27df83a5c85c054f906d82bcbf752 upstream.
Like the JMicron JMS567 enclosures with the JMS539 choke on report-opcodes,
so avoid it.
Tested-and-reported-by: Tom Arild Naess <tanaess@gmail.com>
commit 7e860a6e7aa62b337a61110430cd633db5b0d2dd upstream.
Check the special CDC headers for a plausible minimum length.
Another big operating systems ignores such garbage.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Reviewed-by: Adam Lee <adam8157@gmail.com>
Tested-by: Adam Lee <adam8157@gmail.com>
commit 074f9dd55f9cab1b82690ed7e44bcf38b9616ce0 upstream.
Currently the USB stack assumes that all host controller drivers are
capable of receiving wakeup requests from downstream devices.
However, this isn't true for the isp1760-hcd driver, which means that
it isn't safe to do a runtime suspend of any device attached to a
root-hub port if the device requires wakeup.
This patch adds a "cant_recv_wakeups" flag to the usb_hcd structure
and sets the flag in isp1760-hcd. The core is modified to prevent a
direct child of the root hub from being put into runtime suspend with
wakeup enabled if the flag is set.
Tested-by: Nicolas Pitre <nico@linaro.org>
Signed-off-by: Greg Kroah-Hartman <greg@kroah.com>
commit 524134d422316a59d5464ccbc12036bbe90c5563 upstream.
The USB stack provides a mechanism for drivers to request an
asynchronous device reset (usb_queue_reset_device()). The mechanism
uses a work item (reset_ws) embedded in the usb_interface structure
used by the driver, and the reset is carried out by a work queue
routine.
The asynchronous reset can race with driver unbinding. When this
happens, we try to cancel the queued reset before unbinding the
driver, on the theory that the driver won't care about any resets once
it is unbound.
However, thanks to the fact that lockdep now tracks work queue
accesses, this can provoke a lockdep warning in situations where the
device reset causes another interface's driver to be unbound; see
http://marc.info/?l=linux-usb&m=141893165203776&w=2
for an example. The reason is that the work routine for reset_ws in
one interface calls cancel_queued_work() for the reset_ws in another
interface. Lockdep thinks this might lead to a work routine trying to
cancel itself. The simplest solution is not to cancel queued resets
when unbinding drivers.
This means we now need to acquire a reference to the usb_interface
when queuing a reset_ws work item and to drop the reference when the
work routine finishes. We also need to make sure that the
usb_interface structure doesn't outlive its parent usb_device; this
means acquiring and dropping a reference when the interface is created
and destroyed.
In addition, cancelling a queued reset can fail (if the device is in
the middle of an earlier reset), and this can cause usb_reset_device()
to try to rebind an interface that has been deallocated (see
http://marc.info/?l=linux-usb&m=142175717016628&w=2 for details).
Acquiring the extra references prevents this failure.
Reported-by: Russell King - ARM Linux <linux@arm.linux.org.uk>
Reported-by: Olivier Sobrie <olivier@sobrie.be>
Tested-by: Olivier Sobrie <olivier@sobrie.be>
commit 5efd2ea8c9f4f12916ffc8ba636792ce052f6911 upstream.
the following error pops up during "testusb -a -t 10"
| musb-hdrc musb-hdrc.1.auto: dma_pool_free buffer-128, f134e000/be842000 (bad dma)
hcd_buffer_create() creates a few buffers, the smallest has 32 bytes of
size. ARCH_KMALLOC_MINALIGN is set to 64 bytes. This combo results in
hcd_buffer_alloc() returning memory which is 32 bytes aligned and it
might by identified by buffer_offset() as another buffer. This means the
buffer which is on a 32 byte boundary will not get freed, instead it
tries to free another buffer with the error message.
This patch fixes the issue by creating the smallest DMA buffer with the
size of ARCH_KMALLOC_MINALIGN (or 32 in case ARCH_KMALLOC_MINALIGN is
smaller). This might be 32, 64 or even 128 bytes. The next three pools
will have the size 128, 512 and 2048.
In case the smallest pool is 128 bytes then we have only three pools
instead of four (and zero the first entry in the array).
The last pool size is always 2048 bytes which is the assumed PAGE_SIZE /
2 of 4096. I doubt it makes sense to continue using PAGE_SIZE / 2 where
we would end up with 8KiB buffer in case we have 16KiB pages.
Instead I think it makes sense to have a common size(s) and extend them
if there is need to.
There is a BUILD_BUG_ON() now in case someone has a minalign of more than
128 bytes.
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 5c7b3b02de766a8634708953e805399e3544a290 upstream.
commit 8e74475b0e0a (usb: dwc3: gadget: use udc-core's
reset notifier) added support for the new UDC core's
reset notifier to dwc3 but while at it, it removed
a spin_lock() from dwc3_reset_gadget() which might
cause an unbalanced spin_unlock() further down the line
Fixes: 8e74475b0e0a (usb: dwc3: gadget: use udc-core's reset notifier)
commit c99197902da284b4b723451c1471c45b18537cde upstream.
The usb_hcd_unlink_urb() routine in hcd.c contains two possible
use-after-free errors. The dev_dbg() statement at the end of the
routine dereferences urb and urb->dev even though both structures may
have been deallocated.
This patch fixes the problem by storing urb->dev in a local variable
(avoiding the dereference of urb) and moving the dev_dbg() up before
the usb_put_dev() call.
Reported-by: Joe Lawrence <joe.lawrence@stratus.com>
Tested-by: Joe Lawrence <joe.lawrence@stratus.com>
commit a6f0331236fa75afba14bbcf6668d42cebb55c43 upstream.
Added the USB serial console device ID for Siemens Ruggedcom devices
which have a USB port for their serial console.
Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca>
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-linus
Felipe writes:
usb: fixes for v3.19-rc6
Just two fixes pending. A fix USB PHY for non-OF case and
a fix for dwc2 running on samsung SoC.
OTG device shall support this device for allowing compliance automated testing.
The modification is derived from Pavankumar and Vijayavardhans' previous work.
Signed-off-by: Macpaul Lin <macpaul@gmail.com>
Cc: Pavankumar Kondeti <pkondeti@codeaurora.org>
Cc: Vijayavardhan Vennapusa <vvreddy@codeaurora.org>
Cc: stable <stable@vger.kernel.org>
It looks like FUA support is broken on JMicron 152d:2566 bridge:
[223159.885704] sd 7:0:0:0: [sdc] Write Protect is off
[223159.885706] sd 7:0:0:0: [sdc] Mode Sense: 47 00 10 08
[223159.885942] sd 7:0:0:0: [sdc] Write cache: enabled, read cache: enabled, supports DPO and FUA
[223283.691677] sd 7:0:0:0: [sdc]
[223283.691680] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[223283.691681] sd 7:0:0:0: [sdc]
[223283.691682] Sense Key : Illegal Request [current]
[223283.691684] sd 7:0:0:0: [sdc]
[223283.691685] Add. Sense: Invalid field in cdb
[223283.691686] sd 7:0:0:0: [sdc] CDB:
[223283.691687] Write(10): 2a 08 15 d0 83 0d 00 00 01 00
[223283.691690] blk_update_request: critical target error, dev sdc, sector 2927892584
This patch adds blacklist flag so that sd will not use FUA
Signed-off-by: Dmitry Nezhevenko <dion@dion.org.ua>
Cc: Phil Dibowitz <phil@ipom.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Like some other uas devices these devices hang when a report-opcodes scsi
command is send to them.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1124119
Cc: stable@vger.kernel.org # 3.16
I recently posted a patch ("storage: Add quirk for another SCM-based
USB-SCSI converter") to add a quirk for the converter with ID 04E6:000F,
which is listed along with 04E6:000B in the Windows INF file for the
Startech ICUSBSCSI2 as "eUSB SCSI Adapter (Bus Powered)".
The already-present quirk for 04E6:000B has USB_SC_SCSI/USB_PR_BULK, not
USB_SC_DEVICE/USB_PR_DEVICE. Change the 04E6:000F quirk to match that,
since it will probably be required.
Signed-off-by: Mark Knibbs <markk@clara.co.uk>
In practice failure to find phy when requested in non-OF
case means it will never become available, so
__usb_find_phy() must return -ENODEV and not -EPROBE_DEFER.
This fixes a regression caused by commit 9c9d82492b73
(usb: phy: Fix deferred probing), where the USB
controller driver is left infinitely into deferred probe
when there are no phys.
Fixes: 9c9d82492b73 (usb: phy: Fix deferred probing)
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
This patch fixes the following problem: data transmission in direction
IN break unless the GSNPSID register access is done with spinlock held.
This issue occurs at least in Exynos4412 SoC, probably in many SoC's
from Exynos familly.
The problem is described here:
https://lkml.org/lkml/2014/12/22/185
And there is linux mailing list discussion:
https://lkml.org/lkml/2015/1/14/17
Signed-off-by: Robert Baldyga <r.baldyga@samsung.com>
Felipe writes:
The final set of fixes for v3.19. Two of the fixes are
related to dwc3 scatter/gather implementation when we have
more requests queued than available TRBs, while the other
is a build fix for mv-usb PHY.
git://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial into usb-linus
Johan writes:
USB-serial fixes for v3.18-rc5
Here are a few fixes for reported problems including a possible
null-deref on probe with keyspan, a misbehaving modem, and a couple of
issues with the USB console.
Some new device IDs are also added.
DWC3 gadget sets up a pool of 32 TRBs for each EP during initialization. This
means, the max TRBs that can be submitted for an EP is fixed to 32. Since the
request queue for an EP is a linked list, any number of requests can be queued
to it by the gadget layer. However, the dwc3 driver must not submit TRBs more
than the pool it has created for. This limit wasn't respected when SG was used
resulting in submitting more than the max TRBs, eventually leading to
non-transfer of the TRBs submitted over the max limit.
Root cause:
When SG is used, there are two loops iterating to prepare TRBs:
- Outer loop over the request_list
- Inner loop over the SG list
The code was missing break to get out of the outer loop.
Fixes: eeb720fb21d6 (usb: dwc3: gadget: add support for SG lists)
Cc: <stable@vger.kernel.org> # v3.9+
Signed-off-by: Amit Virdi <amit.virdi@st.com>
When scatter gather (SG) is used, multiple TRBs are prepared from one DWC3
request (dwc3_request). So while preparing TRBs, the 'last' flag should be set
only when it is the last TRB being prepared from the last dwc3_request entry.
The current implementation uses list_is_last to check if the dwc3_request is the
last entry from the request_list. However, list_is_last returns false for the
last entry too. This is because, while preparing the first TRB from a request,
the function dwc3_prepare_one_trb modifies the request's next and prev pointers
while moving the URB to req_queued. Hence, list_is_last always returns false no
matter what.
The correct way is not to access the modified pointers of dwc3_request but to
use list_empty macro instead.
Fixes: e5ba5ec833aa (usb: dwc3: gadget: fix scatter gather implementation)
The driver was recently adapted to a core API change, but the
change was incomplete, missing out the suspend helper and
leaving an extraneous local variable around:
usb/phy/phy-mv-usb.c: In function 'mv_otg_update_state':
usb/phy/phy-mv-usb.c:341:18: warning: unused variable 'phy' [-Wunused-variable]
usb/phy/phy-mv-usb.c: In function 'mv_otg_suspend':
usb/phy/phy-mv-usb.c:861:16: error: 'struct usb_phy' has no member named 'state'
Fixes: e47d92545c297 ("usb: move the OTG state from the USB PHY to the OTG structure")
Felipe writes:
usb: fixes for v3.19-rc5
Just three fixes this time. An oops fix in ep_write() from gadgetfs,
another oops for the Atmel UDC when unloading a gadget driver and
the fix for PHY deferred probing.
drivers/usb/phy/phy.c
If a USB serial device (e.g. /dev/ttyUSB0) with an active program is
unplugged, an -ENODEV (19) error will be produced after it gives up
trying to resubmit a read.
usb_serial_generic_submit_read_urb - usb_submit_urb failed: -19
Add -ENODEV as one of the permanent errors along with -EPERM that
usb_serial_generic_submit_read_urb() handles quietly without an error.
Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com>
If a USB serial device is unplugged while there is an active program
using the device it may spam the logs with -EPROTO (71) messages as it
attempts to retry.
Most serial usb drivers (metro-usb, pl2303, mos7840, ...) only output
these messages for debugging. The generic driver treats these as
errors.
Change the default output for the generic serial driver from error to
debug to silence these non-critical errors.
Use tty kref to release the fake tty in usb_console_setup to avoid use
after free if the underlying serial driver has acquired a reference.
Note that using the tty destructor release_one_tty requires some more
state to be initialised.
Fixes: 4a90f09b20f4 ("tty: usb-serial krefs")
The USB console currently allocates a temporary fake tty which is used
to pass terminal settings to the underlying serial driver.
The tty struct is not fully initialised, something which can lead to a
lockdep warning (or worse) if a serial driver tries to acquire a
line-discipline reference:
usbserial: USB Serial support registered for pl2303
pl2303 1-2.1:1.0: pl2303 converter detected
usb 1-2.1: pl2303 converter now attached to ttyUSB0
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 0 PID: 68 Comm: udevd Tainted: G W 3.18.0-rc5 #10
[<c0016f04>] (unwind_backtrace) from [<c0013978>] (show_stack+0x20/0x24)
[<c0013978>] (show_stack) from [<c0449794>] (dump_stack+0x24/0x28)
[<c0449794>] (dump_stack) from [<c006f730>] (__lock_acquire+0x1e50/0x2004)
[<c006f730>] (__lock_acquire) from [<c0070128>] (lock_acquire+0xe4/0x18c)
[<c0070128>] (lock_acquire) from [<c027c6f8>] (ldsem_down_read_trylock+0x78/0x90)
[<c027c6f8>] (ldsem_down_read_trylock) from [<c027a1cc>] (tty_ldisc_ref+0x24/0x58)
[<c027a1cc>] (tty_ldisc_ref) from [<c0340760>] (usb_serial_handle_dcd_change+0x48/0xe8)
[<c0340760>] (usb_serial_handle_dcd_change) from [<bf000484>] (pl2303_read_int_callback+0x210/0x220 [pl2303])
[<bf000484>] (pl2303_read_int_callback [pl2303]) from [<c031624c>] (__usb_hcd_giveback_urb+0x80/0x140)
[<c031624c>] (__usb_hcd_giveback_urb) from [<c0316fc0>] (usb_giveback_urb_bh+0x98/0xd4)
[<c0316fc0>] (usb_giveback_urb_bh) from [<c0042e44>] (tasklet_hi_action+0x9c/0x108)
[<c0042e44>] (tasklet_hi_action) from [<c0042380>] (__do_softirq+0x148/0x42c)
[<c0042380>] (__do_softirq) from [<c00429cc>] (irq_exit+0xd8/0x114)
[<c00429cc>] (irq_exit) from [<c007ae58>] (__handle_domain_irq+0x84/0xdc)
[<c007ae58>] (__handle_domain_irq) from [<c000879c>] (omap_intc_handle_irq+0xd8/0xe0)
[<c000879c>] (omap_intc_handle_irq) from [<c0014544>] (__irq_svc+0x44/0x7c)
Exception stack(0xdf4e7f08 to 0xdf4e7f50)
7f00: debc0b80 df4e7f5c 00000000 00000000 debc0b80 be8da96c
7f20: 00000000 00000128 c000fc84 df4e6000 00000000 df4e7f94 00000004 df4e7f50
7f40: c038ebc0 c038d74c 600f0013 ffffffff
[<c0014544>] (__irq_svc) from [<c038d74c>] (___sys_sendmsg.part.29+0x0/0x2e0)
[<c038d74c>] (___sys_sendmsg.part.29) from [<c038ec08>] (SyS_sendmsg+0x18/0x1c)
[<c038ec08>] (SyS_sendmsg) from [<c000fa00>] (ret_fast_syscall+0x0/0x48)
console [ttyUSB0] enabled
Fixes: 36697529b5bb ("tty: Replace ldisc locking with ldisc_sem")
