Using regmap update bits the way it was used is wrong as only additional bits
gets set but no bits would be cleared.
The whole register or NRD and PDS are reserved for those two function.
There are no bits which needs to be preserved in the registers so just
writting the new value is all that is needed.
(cherry picked from commit 02a78261315045011a5a987761d7a76e51b04480)
(cherry picked from commit b38bde54f80dbb67be727e04c8ee3e8d2969a3f9)
This allows to configure the NRD register from device tree or platform data.
(cherry picked from commit 92ed1faf672e46e3e54b1f41f0b38f533b53b1aa)
(cherry picked from commit 6b5280f4e71770600d5b89638d849896158f2ec3)
While the usb3503 variant uses a HSIC connection to upstream,
the usb3803 uses a regular USB connection and provides a
bypass mode which connects the upstream port with downstream
port 3.
This adds an additional control gpio to the configuration which
allows moving away from the bypass mode to either standby or hub
mode once the driver is instantiated.
(cherry picked from commit e7812f55781bd9453a231d104a2c6c520491e2e4)
(cherry picked from commit 8662817b83bee3c30336f104608752fcb652f5c4)
The existing usage of extcon in chipidea driver freezes the kernel
presumably due to OTGSC register access.
Prevent accessing any OTG registers for SoC with dual role devices
but no true OTG support. Use the flag CI_HDRC_DUAL_ROLE_NOT_OTG for
those devices and in case extcon is present, do the role switch
using extcon only.
Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
(cherry picked from commit 28291538966f8828be6d9e86d72cb3ea9ada28f1)
[rebased ontop of 4.9]
(cherry picked from commit 241a15ed4b8ebd49de06b7ce7e13db213d3bdee6)
4.14: follow changed extcon_get_cable_state_() -> extcon_get_state_()
(cherry picked from commit 452e295bf2537781813d7b9bdf4ae5abad622ce9)
This is the 4.14.164 stable release
arch/arm/Kconfig.debug
arch/arm/boot/dts/imx7s.dtsi
arch/arm/mach-imx/cpuidle-imx6q.c
arch/arm/mach-imx/cpuidle-imx6sx.c
arch/arm64/kernel/cpu_errata.c
arch/arm64/kvm/hyp/tlb.c
drivers/crypto/caam/caamalg.c
drivers/crypto/mxs-dcp.c
drivers/dma/imx-sdma.c
drivers/gpio/gpio-vf610.c
drivers/gpu/drm/bridge/adv7511/adv7511_drv.c
drivers/input/keyboard/imx_keypad.c
drivers/input/keyboard/snvs_pwrkey.c
drivers/mmc/core/block.c
drivers/mmc/core/queue.h
drivers/mmc/host/sdhci-esdhc-imx.c
drivers/net/can/flexcan.c
drivers/net/can/rx-offload.c
drivers/net/ethernet/freescale/fec_main.c
drivers/net/wireless/ath/ath10k/pci.c
drivers/net/wireless/broadcom/brcm80211/brcmfmac/cfg80211.c
drivers/pci/dwc/pci-imx6.c
drivers/spi/spi-fsl-lpspi.c
drivers/usb/dwc3/gadget.c
include/net/tcp.h
sound/soc/fsl/Kconfig
sound/soc/fsl/fsl_esai.c
commit 0d3010fa442429f8780976758719af05592ff19f upstream.
This patch adds the following Telit ME910G1 composition:
0x110a: tty, tty, tty, rmnet
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 3e4f8e21c4f27bcf30a48486b9dcc269512b79ff upstream.
Amend the endpoint-descriptor sanity checks to detect all duplicate
endpoint addresses in a configuration.
Commit 0a8fd1346254 ("USB: fix problems with duplicate endpoint
addresses") added a check for duplicate endpoint addresses within a
single alternate setting, but did not look for duplicate addresses in
other interfaces.
The current check would also not detect all duplicate addresses when one
endpoint is as a (bi-directional) control endpoint.
This specifically avoids overwriting the endpoint entries in struct
usb_device when enabling a duplicate endpoint, something which could
potentially lead to crashes or leaks, for example, when endpoints are
later disabled.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Link: https://lore.kernel.org/r/20191219161016.6695-1-johan@kernel.org
commit 8442b02bf3c6770e0d7e7ea17be36c30e95987b6 upstream.
When fuzzing the USB subsystem with syzkaller, we currently use 8 testing
processes within one VM. To isolate testing processes from one another it
is desirable to assign a dedicated USB bus to each of those, which means
we need at least 8 Dummy UDC/HCD devices.
This patch increases the maximum number of Dummy UDC/HCD devices to 32
(more than 8 in case we need more of them in the future).
Signed-off-by: Andrey Konovalov <andreyknvl@google.com>
Link: https://lore.kernel.org/r/665578f904484069bb6100fb20283b22a046ad9b.1571667489.git.andreyknvl@google.com
commit 6dabeb891c001c592645df2f477fed9f5d959987 upstream.
Commit fea3409112a9 ("USB: add direction bit to urb->transfer_flags") has
added a usb_urb_dir_in() helper function that can be used to determine
the direction of the URB. With that patch USB_DIR_IN control requests with
wLength == 0 are considered out requests by real USB HCDs. This patch
changes dummy-hcd to use the usb_urb_dir_in() helper to match that
behavior.
Link: https://lore.kernel.org/r/4ae9e68ebca02f08a93ac61fe065057c9a01f0a8.1571667489.git.andreyknvl@google.com
[ Upstream commit e5b5da96da50ef30abb39cb9f694e99366404d24 ]
Gadget driver should always use config_ep_by_speed() to initialize
usb_ep struct according to usb device's operating speed. Otherwise,
usb_ep struct may be wrong if usb devcie's operating speed is changed.
The key point in this patch is that we want to make sure the desc pointer
in usb_ep struct will be set to NULL when gadget is disconnected.
This will force it to call config_ep_by_speed() to correctly initialize
usb_ep struct based on the new operating speed when gadget is
re-connected later.
Reviewed-by: Peter Chen <peter.chen@nxp.com>
Signed-off-by: EJ Hsu <ejh@nvidia.com>
Signed-off-by: Felipe Balbi <balbi@kernel.org>
commit 64cc3f12d1c7dd054a215bc1ff9cc2abcfe35832 upstream.
When disconnecting a USB hub that has some child device(s) connected to it
(such as a USB mouse), then the stack tries to clear halt and
reset device(s) which are _already_ physically disconnected.
The issue has been reproduced with:
CPU: IMX6D5EYM10AD or MCIMX6D5EYM10AE.
SW: U-Boot 2019.07 and kernel 4.19.40.
CPU: HP Proliant Microserver Gen8.
SW: Linux version 4.2.3-300.fc23.x86_64
In this situation there will be error bit for MMF active yet the
CERR equals EHCI_TUNE_CERR + halt. Existing implementation
interprets this as a stall [1] (chapter 8.4.5).
The possible conditions when the MMF will be active + halt
can be found from [2] (Table 4-13).
Fix for the issue is to check whether MMF is active and PID Code is
IN before checking for the stall. If these conditions are true then
it is not a stall.
What happens after the fix is that when disconnecting a hub with
attached device(s) the situation is not interpret as a stall.
[1] [https://www.usb.org/document-library/usb-20-specification, usb_20.pdf]
[2] [https://www.intel.com/content/dam/www/public/us/en/documents/
technical-specifications/ehci-specification-for-usb.pdf]
Signed-off-by: Erkka Talvitie <erkka.talvitie@vincit.fi>
Reviewed-by: Alan Stern <stern@rowland.harvard.edu>
Link: https://lore.kernel.org/r/ef70941d5f349767f19c0ed26b0dd9eed8ad81bb.1576050523.git.erkka.talvitie@vincit.fi
commit aabb5b833872524eaf28f52187e5987984982264 upstream.
If a transaction error happens in vhci_recv_ret_submit(), event
handler closes connection and changes port status to kick hub_event.
Then hub tries to flush the endpoint URBs, but that causes infinite
loop between usb_hub_flush_endpoint() and vhci_urb_dequeue() because
"vhci_priv" in vhci_urb_dequeue() was already released by
vhci_recv_ret_submit() before a transmission error occurred. Thus,
vhci_urb_dequeue() terminates early and usb_hub_flush_endpoint()
continuously calls vhci_urb_dequeue().
The root cause of this issue is that vhci_recv_ret_submit()
terminates early without giving back URB when transaction error
occurs in vhci_recv_ret_submit(). That causes the error URB to still
be linked at endpoint list without “vhci_priv".
So, in the case of transaction error in vhci_recv_ret_submit(),
unlink URB from the endpoint, insert proper error code in
urb->status and give back URB.
Reported-by: Marek Marczykowski-Górecki <marmarek@invisiblethingslab.com>
Tested-by: Marek Marczykowski-Górecki <marmarek@invisiblethingslab.com>
Signed-off-by: Suwan Kim <suwan.kim027@gmail.com>
Acked-by: Shuah Khan <skhan@linuxfoundation.org>
Link: https://lore.kernel.org/r/20191213023055.19933-3-suwan.kim027@gmail.com
commit d986294ee55d719562b20aabe15a39bf8f863415 upstream.
When vhci uses SG and receives data whose size is smaller than SG
buffer size, it tries to receive more data even if it acutally
receives all the data from the server. If then, it erroneously adds
error event and triggers connection shutdown.
vhci-hcd should check if it received all the data even if there are
more SG entries left. So, check if it receivces all the data from
the server in for_each_sg() loop.
Fixes: ea44d190764b ("usbip: Implement SG support to vhci-hcd and stub driver")
Link: https://lore.kernel.org/r/20191213023055.19933-2-suwan.kim027@gmail.com
[ Upstream commit 6056a0f8ede27b296d10ef46f7f677cc9d715371 ]
The following build warning is seen if CONFIG_PM is disabled.
drivers/usb/host/xhci-pci.c:498:13: warning:
unused function 'xhci_pci_shutdown'
Fixes: f2c710f7dca8 ("usb: xhci: only set D3hot for pci device")
Cc: Henry Lin <henryl@nvidia.com>
Cc: stable@vger.kernel.org # all stable releases with f2c710f7dca8
Acked-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Link: https://lore.kernel.org/r/20191218011911.6907-1-linux@roeck-us.net
[ Upstream commit abb0b3d96a1f9407dd66831ae33985a386d4200d ]
commit 1455cf8dbfd0 ("driver core: emit uevents when device is bound
to a driver") added bind and unbind uevents when a driver is bound or
unbound to a physical device.
For USB devices which are handled via the generic usbfs layer (via
libusb for example), this is problematic:
Each time a user space program calls
ioctl(usb_fd, USBDEVFS_CLAIMINTERFACE, &usb_intf_nr);
and then later
ioctl(usb_fd, USBDEVFS_RELEASEINTERFACE, &usb_intf_nr);
The kernel will now produce a bind or unbind event, which does not
really contain any useful information.
This allows a user space program to run a DoS attack against programs
which listen to uevents (in particular systemd/eudev/upowerd):
A malicious user space program just has to call in a tight loop
With this loop the malicious user space program floods the kernel and
all programs listening to uevents with tons of bind and unbind
events.
This patch suppresses uevents for ioctls USBDEVFS_CLAIMINTERFACE and
USBDEVFS_RELEASEINTERFACE.
Signed-off-by: Ingo Rohloff <ingo.rohloff@lauterbach.com>
Link: https://lore.kernel.org/r/20191011115518.2801-1-ingo.rohloff@lauterbach.com
[ Upstream commit 39abcc84846bbc0538f13c190b6a9c7e36890cd2 ]
When R-Car Gen3 USB 2.0 is in Gadget mode, if host is detached an interrupt
will be generated and Suspended state bit is set in interrupt status
register. Interrupt handler will call driver->suspend(composite_suspend)
if suspended state bit is set. composite_suspend will call
ffs_func_suspend which will post FUNCTIONFS_SUSPEND and will be consumed
by user space application via /dev/ep0.
To be able to detect host detach, extend the DVSQ_MASK to cover the
Suspended bit of the DVSQ[2:0] bitfield from the Interrupt Status
Register 0 (INTSTS0) register and perform appropriate action in the
DVST interrupt handler (usbhsg_irq_dev_state).
Without this commit, disconnection of the phone from R-Car-H3 ES2.0
Salvator-X CN9 port is not recognized and reverse role switch does
not happen. If phone is connected again it does not enumerate.
With this commit, disconnection will be recognized and reverse role
switch will happen by a user space application. If phone is connected
again it will enumerate properly and will become visible in the output
of 'lsusb'.
Signed-off-by: Veeraiyan Chidambaram <veeraiyan.chidambaram@in.bosch.com>
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Reviewed-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Tested-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Link: https://lore.kernel.org/r/1568207756-22325-3-git-send-email-external.veeraiyan.c@de.adit-jv.com
commit 057d476fff778f1d3b9f861fdb5437ea1a3cfc99 upstream.
A race in xhci USB3 remote wake handling may force device back to suspend
after it initiated resume siganaling, causing a missed resume event or warm
reset of device.
When a USB3 link completes resume signaling and goes to enabled (UO)
state a interrupt is issued and the interrupt handler will clear the
bus_state->port_remote_wakeup resume flag, allowing bus suspend.
If the USB3 roothub thread just finished reading port status before
the interrupt, finding ports still in suspended (U3) state, but hasn't
yet started suspending the hub, then the xhci interrupt handler will clear
the flag that prevented roothub suspend and allow bus to suspend, forcing
all port links back to suspended (U3) state.
Example case:
usb_runtime_suspend() # because all ports still show suspended U3
usb_suspend_both()
hub_suspend(); # successful as hub->wakeup_bits not set yet
==> INTERRUPT
xhci_irq()
handle_port_status()
clear bus_state->port_remote_wakeup
usb_wakeup_notification()
sets hub->wakeup_bits;
kick_hub_wq()
<== END INTERRUPT
hcd_bus_suspend()
xhci_bus_suspend() # success as port_remote_wakeup bits cleared
Fix this by increasing roothub usage count during port resume to prevent
roothub autosuspend, and by making sure bus_state->port_remote_wakeup
flag is only cleared after resume completion is visible, i.e.
after xhci roothub returned U0 or other non-U3 link state link on a
get port status request.
Issue rootcaused by Chiasheng Lee
Cc: <stable@vger.kernel.org>
Cc: Lee, Hou-hsun <hou-hsun.lee@intel.com>
Reported-by: Lee, Chiasheng <chiasheng.lee@intel.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Link: https://lore.kernel.org/r/20191211142007.8847-3-mathias.nyman@linux.intel.com
[ Upstream commit bd82873f23c9a6ad834348f8b83f3b6a5bca2c65 ]
spin_unlock_irqrestore() might be called with stale flags after
reading port status, possibly restoring interrupts to a incorrect
state.
If a usb2 port just finished resuming while the port status is read
the spin lock will be temporary released and re-acquired in a separate
function. The flags parameter is passed as value instead of a pointer,
not updating flags properly before the final spin_unlock_irqrestore()
is called.
Cc: <stable@vger.kernel.org> # v3.12+
Fixes: 8b3d45705e54 ("usb: Fix xHCI host issues on remote wakeup.")
Link: https://lore.kernel.org/r/20191211142007.8847-7-mathias.nyman@linux.intel.com
[ Upstream commit ce91f1a43b37463f517155bdfbd525eb43adbd1a ]
When xHCI is part of Alpine or Titan Ridge Thunderbolt controller and
the xHCI device is hot-removed as a result of unplugging a dock for
example, the driver leaks memory it allocates for xhci->usb3_rhub.psi
and xhci->usb2_rhub.psi in xhci_add_in_port() as reported by kmemleak:
unreferenced object 0xffff922c24ef42f0 (size 16):
comm "kworker/u16:2", pid 178, jiffies 4294711640 (age 956.620s)
hex dump (first 16 bytes):
21 00 0c 00 12 00 dc 05 23 00 e0 01 00 00 00 00 !.......#.......
backtrace:
[<000000007ac80914>] xhci_mem_init+0xcf8/0xeb7
[<0000000001b6d775>] xhci_init+0x7c/0x160
[<00000000db443fe3>] xhci_gen_setup+0x214/0x340
[<00000000fdffd320>] xhci_pci_setup+0x48/0x110
[<00000000541e1e03>] usb_add_hcd.cold+0x265/0x747
[<00000000ca47a56b>] usb_hcd_pci_probe+0x219/0x3b4
[<0000000021043861>] xhci_pci_probe+0x24/0x1c0
[<00000000b9231f25>] local_pci_probe+0x3d/0x70
[<000000006385c9d7>] pci_device_probe+0xd0/0x150
[<0000000070241068>] really_probe+0xf5/0x3c0
[<0000000061f35c0a>] driver_probe_device+0x58/0x100
[<000000009da11198>] bus_for_each_drv+0x79/0xc0
[<000000009ce45f69>] __device_attach+0xda/0x160
[<00000000df201aaf>] pci_bus_add_device+0x46/0x70
[<0000000088a1bc48>] pci_bus_add_devices+0x27/0x60
[<00000000ad9ee708>] pci_bus_add_devices+0x52/0x60
unreferenced object 0xffff922c24ef3318 (size 8):
hex dump (first 8 bytes):
34 01 05 00 35 41 0a 00 4...5A..
backtrace:
Fix this by calling kfree() for the both psi objects in
xhci_mem_cleanup().
Cc: <stable@vger.kernel.org> # 4.4+
Fixes: 47189098f8be ("xhci: parse xhci protocol speed ID list for usb 3.1 usage")
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Link: https://lore.kernel.org/r/20191211142007.8847-2-mathias.nyman@linux.intel.com
commit 2d7b78f59e020b07fc6338eefe286f54ee2d6773 upstream.
Clear ep0's DWC3_EP_TRANSFER_STARTED flag if the END_TRANSFER command is
completed. Otherwise, we can't start control transfer again after
END_TRANSFER.
Signed-off-by: Thinh Nguyen <thinhn@synopsys.com>
commit 19e6317d24c25ee737c65d1ffb7483bdda4bb54a upstream.
The problem arises because our read() function grabs a lock of the
circular buffer, finds something of interest, then invokes copy_to_user()
straight from the buffer, which in turn takes mm->mmap_sem. In the same
time, the callback mon_bin_vma_fault() is invoked under mm->mmap_sem.
It attempts to take the fetch lock and deadlocks.
This patch does away with protecting of our page list with any
semaphores, and instead relies on the kernel not close the device
while mmap is active in a process.
In addition, we prohibit re-sizing of a buffer while mmap is active.
This way, when (now unlocked) fault is processed, it works with the
page that is intended to be mapped-in, and not some other random page.
Note that this may have an ABI impact, but hopefully no legitimate
program is this wrong.
Signed-off-by: Pete Zaitcev <zaitcev@redhat.com>
Reported-by: syzbot+56f9673bb4cdcbeb0e92@syzkaller.appspotmail.com
Fixes: 46eb14a6e158 ("USB: fix usbmon BUG trigger")
Link: https://lore.kernel.org/r/20191204203941.3503452b@suzdal.zaitcev.lan
commit 1cd17f7f0def31e3695501c4f86cd3faf8489840 upstream.
Explicitly initialize URB structure urb_list field in usb_init_urb().
This field can be potentially accessed uninitialized and its
initialization is coherent with the usage of list_del_init() in
usb_hcd_unlink_urb_from_ep() and usb_giveback_urb_bh() and its
explicit initialization in usb_hcd_submit_urb() error path.
Signed-off-by: Emiliano Ingrassia <ingrassia@epigenesys.com>
Link: https://lore.kernel.org/r/20191127160355.GA27196@ingrassia.epigenesys.com
commit 3c11c4bed02b202e278c0f5c319ae435d7fb9815 upstream.
Make sure to use the current alternate setting when verifying the
interface descriptors to avoid binding to an invalid interface.
Failing to do so could cause the driver to misbehave or trigger a WARN()
in usb_submit_urb() that kernels with panic_on_warn set would choke on.
Fixes: 03270634e242 ("USB: Add ADU support for Ontrak ADU devices")
Cc: stable <stable@vger.kernel.org> # 2.6.19
Link: https://lore.kernel.org/r/20191210112601.3561-3-johan@kernel.org
commit 7c5a2df3367a2c4984f1300261345817d95b71f8 upstream.
Make sure to use the current alternate setting when looking up the
endpoints on epic devices to avoid binding to an invalid interface.
Fixes: 6e8cf7751f9f ("USB: add EPIC support to the io_edgeport driver")
Cc: stable <stable@vger.kernel.org> # 2.6.21
Link: https://lore.kernel.org/r/20191210112601.3561-5-johan@kernel.org
commit 59920635b89d74b9207ea803d5e91498d39e8b69 upstream.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Link: https://lore.kernel.org/r/20191210112601.3561-4-johan@kernel.org
commit 09068c1ad53fb077bdac288869dec2435420bdc4 upstream.
Make sure that the interrupt interface has an endpoint before trying to
access its endpoint descriptors to avoid dereferencing a NULL pointer.
The driver binds to the interrupt interface with interface number 0, but
must not assume that this interface or its current alternate setting are
the first entries in the corresponding configuration arrays.
Fixes: b72458a80c75 ("[PATCH] USB: Eagle and ADI 930 usb adsl modem driver")
Cc: stable <stable@vger.kernel.org> # 2.6.16
Link: https://lore.kernel.org/r/20191210112601.3561-2-johan@kernel.org
commit 7ff11162808cc2ec66353fc012c58bb449c892c3 upstream.
xhci driver claims it needs XHCI_TRUST_TX_LENGTH quirk for both
Broadcom/Cavium and a Renesas xHC controllers.
The quirk was inteded for handling false "success" complete event for
transfers that had data left untransferred.
These transfers should complete with "short packet" events instead.
In these two new cases the false "success" completion is reported
after a "short packet" if the TD consists of several TRBs.
xHCI specs 4.10.1.1.2 say remaining TRBs should report "short packet"
as well after the first short packet in a TD, but this issue seems so
common it doesn't make sense to add the quirk for all vendors.
Turn these events into short packets automatically instead.
This gets rid of the "The WARN Successful completion on short TX for
slot 1 ep 1: needs XHCI_TRUST_TX_LENGTH quirk" warning in many cases.
Reported-by: Eli Billauer <eli.billauer@gmail.com>
Reported-by: Ard Biesheuvel <ardb@kernel.org>
Tested-by: Eli Billauer <eli.billauer@gmail.com>
Tested-by: Ard Biesheuvel <ardb@kernel.org>
Link: https://lore.kernel.org/r/20191211142007.8847-6-mathias.nyman@linux.intel.com
commit 7c67cf6658cec70d8a43229f2ce74ca1443dc95e upstream.
I've recently observed failed xHCI suspend attempt on AMD Raven Ridge
system:
kernel: xhci_hcd 0000:04:00.4: WARN: xHC CMD_RUN timeout
kernel: PM: suspend_common(): xhci_pci_suspend+0x0/0xd0 returns -110
kernel: PM: pci_pm_suspend(): hcd_pci_suspend+0x0/0x30 returns -110
kernel: PM: dpm_run_callback(): pci_pm_suspend+0x0/0x150 returns -110
kernel: PM: Device 0000:04:00.4 failed to suspend async: error -110
Similar to commit ac343366846a ("xhci: Increase STS_SAVE timeout in
xhci_suspend()") we also need to increase the HALT timeout to make it be
able to suspend again.
Cc: <stable@vger.kernel.org> # 5.2+
Fixes: f7fac17ca925 ("xhci: Convert xhci_handshake() to use readl_poll_timeout_atomic()")
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Link: https://lore.kernel.org/r/20191211142007.8847-5-mathias.nyman@linux.intel.com
commit f2c710f7dca8457e88b4ac9de2060f011254f9dd upstream.
Xhci driver cannot call pci_set_power_state() on non-pci xhci host
controllers. For example, NVIDIA Tegra XHCI host controller which acts
as platform device with XHCI_SPURIOUS_WAKEUP quirk set in some platform
hits this issue during shutdown.
Fixes: 638298dc66ea ("xhci: Fix spurious wakeups after S5 on Haswell")
Signed-off-by: Henry Lin <henryl@nvidia.com>
Link: https://lore.kernel.org/r/20191211142007.8847-4-mathias.nyman@linux.intel.com
commit e76b3bf7654c3c94554c24ba15a3d105f4006c80 upstream.
On Dell WD15 dock, sometimes USB ethernet cannot be detected after plugging
cable to the ethernet port, the hub and roothub get runtime resumed and
runtime suspended immediately:
[ 433.315169] xhci_hcd 0000:3a:00.0: hcd_pci_runtime_resume: 0
[ 433.315204] usb usb4: usb auto-resume
[ 433.315226] hub 4-0:1.0: hub_resume
[ 433.315239] xhci_hcd 0000:3a:00.0: Get port status 4-1 read: 0x10202e2, return 0x10343
[ 433.315264] usb usb4-port1: status 0343 change 0001
[ 433.315279] xhci_hcd 0000:3a:00.0: clear port1 connect change, portsc: 0x10002e2
[ 433.315293] xhci_hcd 0000:3a:00.0: Get port status 4-2 read: 0x2a0, return 0x2a0
[ 433.317012] xhci_hcd 0000:3a:00.0: xhci_hub_status_data: stopping port polling.
[ 433.422282] xhci_hcd 0000:3a:00.0: Get port status 4-1 read: 0x10002e2, return 0x343
[ 433.422307] usb usb4-port1: do warm reset
[ 433.422311] usb 4-1: device reset not allowed in state 8
[ 433.422339] hub 4-0:1.0: state 7 ports 2 chg 0002 evt 0000
[ 433.422346] xhci_hcd 0000:3a:00.0: Get port status 4-1 read: 0x10002e2, return 0x343
[ 433.422356] usb usb4-port1: do warm reset
[ 433.422358] usb 4-1: device reset not allowed in state 8
[ 433.422428] xhci_hcd 0000:3a:00.0: set port remote wake mask, actual port 0 status = 0xf0002e2
[ 433.422455] xhci_hcd 0000:3a:00.0: set port remote wake mask, actual port 1 status = 0xe0002a0
[ 433.422465] hub 4-0:1.0: hub_suspend
[ 433.422475] usb usb4: bus auto-suspend, wakeup 1
[ 433.426161] xhci_hcd 0000:3a:00.0: xhci_hub_status_data: stopping port polling.
[ 433.466209] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.510204] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.554051] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.598235] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.642154] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.686204] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.730205] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.774203] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.818207] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.862040] xhci_hcd 0000:3a:00.0: port 0 polling in bus suspend, waiting
[ 433.862053] xhci_hcd 0000:3a:00.0: xhci_hub_status_data: stopping port polling.
[ 433.862077] xhci_hcd 0000:3a:00.0: xhci_suspend: stopping port polling.
[ 433.862096] xhci_hcd 0000:3a:00.0: // Setting command ring address to 0x8578fc001
[ 433.862312] xhci_hcd 0000:3a:00.0: hcd_pci_runtime_suspend: 0
[ 433.862445] xhci_hcd 0000:3a:00.0: PME# enabled
[ 433.902376] xhci_hcd 0000:3a:00.0: restoring config space at offset 0xc (was 0x0, writing 0x20)
[ 433.902395] xhci_hcd 0000:3a:00.0: restoring config space at offset 0x4 (was 0x100000, writing 0x100403)
[ 433.902490] xhci_hcd 0000:3a:00.0: PME# disabled
[ 433.902504] xhci_hcd 0000:3a:00.0: enabling bus mastering
[ 433.902547] xhci_hcd 0000:3a:00.0: // Setting command ring address to 0x8578fc001
[ 433.902649] pcieport 0000:00:1b.0: PME: Spurious native interrupt!
[ 433.902839] xhci_hcd 0000:3a:00.0: Port change event, 4-1, id 3, portsc: 0xb0202e2
[ 433.902842] xhci_hcd 0000:3a:00.0: resume root hub
[ 433.902845] xhci_hcd 0000:3a:00.0: handle_port_status: starting port polling.
[ 433.902877] xhci_hcd 0000:3a:00.0: xhci_resume: starting port polling.
[ 433.902889] xhci_hcd 0000:3a:00.0: xhci_hub_status_data: stopping port polling.
[ 433.902891] xhci_hcd 0000:3a:00.0: hcd_pci_runtime_resume: 0
[ 433.902919] usb usb4: usb wakeup-resume
[ 433.902942] usb usb4: usb auto-resume
[ 433.902966] hub 4-0:1.0: hub_resume
As Mathias pointed out, the hub enters Cold Attach Status state and
requires a warm reset. However usb_reset_device() bails out early when
the device is in suspended state, as its callers port_event() and
hub_event() don't always resume the device.
Since there's nothing wrong to reset a suspended device, allow
usb_reset_device() to do so to solve the issue.
Link: https://lore.kernel.org/r/20191106062710.29880-1-kai.heng.feng@canonical.com
commit 335cbbd5762d5e5c67a8ddd6e6362c2aa42a328f upstream.
There is no need to ignore this flag. We should be as close
to storage in that regard as makes sense, so honor flags whose
cost is tiny.
Signed-off-by: Oliver Neukum <oneukum@suse.com>
Link: https://lore.kernel.org/r/20191114112758.32747-3-oneukum@suse.com
commit bff000cae1eec750d62e265c4ba2db9af57b17e1 upstream.
Copy the support over from usb-storage to get feature parity
Link: https://lore.kernel.org/r/20191114112758.32747-2-oneukum@suse.com
commit 66d1b0c0580b7f1b1850ee4423f32ac42afa2e92 upstream.
Remove pointer dereference after free.
pci_pool_free doesn't care about contents of td.
It's just a void* for it
Addresses-Coverity-ID: 1091173 ("Use after free")
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
Link: https://lore.kernel.org/r/20191106202821.GA20347@embeddedor
commit 093edc2baad2c258b1f55d1ab9c63c2b5ae67e42 upstream.
The driver allocates the spinlock but not initialize it.
Use spin_lock_init() on it to initialize it correctly.
This is detected by Coccinelle semantic patch.
Fixes: 1a1c851bbd70 ("usb: gadget: configfs: fix concurrent issue between composite APIs")
Signed-off-by: Wei Yongjun <weiyongjun1@huawei.com>
Link: https://lore.kernel.org/r/20191030034046.188808-1-weiyongjun1@huawei.com
[ Upstream commit f770e3bc236ee954a3b4052bdf55739e26ee25db ]
Fixes gcc '-Wunused-but-set-variable' warning:
drivers/usb/mtu3/mtu3_qmu.c: In function 'qmu_tx_zlp_error_handler':
drivers/usb/mtu3/mtu3_qmu.c:385:22: warning:
variable 'req' set but not used [-Wunused-but-set-variable]
It seems dbginfo original intention is print 'req' other than 'mreq'
Acked-by: Chunfeng Yun <chunfeng.yun@mediatek.com>
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit 408d3ba006af57380fa48858b39f72fde6405031 ]
It's not very useful to repeat a bunch of probe deferral errors. And
it's also not very useful to log "failed" without telling the error
code.
Signed-off-by: Brian Norris <briannorris@chromium.org>
[ Upstream commit 0d36dede457873404becd7c9cb9d0f2bcfd0dcd9 ]
Highspeed device and below has different state names than superspeed and
higher. Add proper checks and printouts of link states for highspeed and
below.
commit daf82bd24e308c5a83758047aff1bd81edda4f11 upstream.
gserial_alloc_line() misses locking (for a release barrier) while
resetting port entry on TTY allocation failure. Fix this.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
commit c1a1f273d0825774c80896b8deb1c9ea1d0b91e3 upstream.
This device presents itself as a USB hub with three attached devices:
- An ACM serial port connected to the GPS module (not affected by this
commit)
- An FTDI serial port connected to the GPS module (1546:0502)
- Another FTDI serial port connected to the ODIN-W2 radio module
(1546:0503)
This commit registers U-Blox's VID and the PIDs of the second and third
devices.
Datasheet: https://www.u-blox.com/sites/default/files/C099-F9P-AppBoard-Mbed-OS3-FW_UserGuide_%28UBX-18063024%29.pdf
Signed-off-by: Fabio D'Urso <fabiodurso@hotmail.it>
commit f0797095423e6ea3b4be61134ee353c7f504d440 upstream.
These are the Foxconn-branded variants of the Dell DW5821e modules,
same USB layout as those. The device exposes AT, NMEA and DIAG ports
in both USB configurations.
P: Vendor=0489 ProdID=e0b4 Rev=03.18
S: Manufacturer=FII
S: Product=T77W968 LTE
S: SerialNumber=0123456789ABCDEF
C: #Ifs= 6 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#=0x0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
I: If#=0x1 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=00 Prot=00 Driver=usbhid
I: If#=0x2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#=0x3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#=0x4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#=0x5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
S: Manufacturer=FII
C: #Ifs= 7 Cfg#= 2 Atr=a0 MxPwr=500mA
I: If#=0x0 Alt= 0 #EPs= 1 Cls=02(commc) Sub=0e Prot=00 Driver=cdc_mbim
I: If#=0x1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
I: If#=0x6 Alt= 0 #EPs= 1 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
Signed-off-by: Aleksander Morgado <aleksander@aleksander.es>
[ johan: drop id defines ]
commit 957c31ea082e3fe5196f46d5b04018b10de47400 upstream.
The device exposes AT, NMEA and DIAG ports in both USB configurations.
Exactly same layout as the default DW5821e module, just a different
vid/pid.
P: Vendor=413c ProdID=81e0 Rev=03.18
S: Manufacturer=Dell Inc.
S: Product=DW5821e-eSIM Snapdragon X20 LTE
commit 92fe35fb9c70a00d8fbbf5bd6172c921dd9c7815 upstream.
The driver was setting the device remote-wakeup feature during probe in
violation of the USB specification (which says it should only be set
just prior to suspending the device). This could potentially waste
power during suspend as well as lead to spurious wakeups.
Note that USB core would clear the remote-wakeup feature at first
resume.
Fixes: 3f5429746d91 ("USB: Moschip 7840 USB-Serial Driver")
commit ea422312a462696093b5db59d294439796cba4ad upstream.
resume.
Fixes: 0f64478cbc7a ("USB: add USB serial mos7720 driver")
commit e696d00e65e81d46e911f24b12e441037bf11b38 upstream.
Add USB ID for MOXA UPort 2210. This device contains mos7820 but
it passes GPIO0 check implemented by driver and it's detected as
mos7840. Hence product id check is added to force mos7820 mode.
Signed-off-by: Pavel Löbl <pavel@loebl.cz>
[ johan: rename id defines and add vendor-id check ]
commit 91feb01596e5efc0cc922cc73f5583114dccf4d2 upstream.
The work item can operate on
1. stale memory left over from the last transfer
the actual length of the data transfered needs to be checked
2. memory already freed
the error handling in appledisplay_probe() needs
to cancel the work in that case
Reported-and-tested-by: syzbot+495dab1f175edc9c2f13@syzkaller.appspotmail.com
Link: https://lore.kernel.org/r/20191106124902.7765-1-oneukum@suse.com
commit 92aa5986f4f7b5a8bf282ca0f50967f4326559f5 upstream.
In case of a timeout or if a signal aborts a read
communication with the device needs to be ended
lest we overwrite an active URB the next time we
do IO to the device, as the URB may still be active.
Signed-off-by: Oliver Neukum <oneukum@suse.de>
Link: https://lore.kernel.org/r/20191107142856.16774-1-oneukum@suse.com
commit 347bc8cb26388791c5881a3775cb14a3f765a674 upstream.
Add support for the Mark-10 digital force gauge device to the cp201x
driver.
Based on a report and a larger patch from Joel Jennings
Reported-by: Joel Jennings <joel.jennings@makeitlabs.com>
Acked-by: Johan Hovold <johan@kernel.org>
Link: https://lore.kernel.org/r/20191118092119.GA153852@kroah.com
commit 2a9125317b247f2cf35c196f968906dcf062ae2d upstream.
Smatch reported that nents is not initialized and used in
stub_recv_cmd_submit(). nents is currently initialized by sgl_alloc()
and used to allocate multiple URBs when host controller doesn't
support scatter-gather DMA. The use of uninitialized nents means that
buf_len is zero and use_sg is true. But buffer length should not be
zero when an URB uses scatter-gather DMA.
To prevent this situation, add the conditional that checks buf_len
and use_sg. And move the use of nents right after the sgl_alloc() to
avoid the use of uninitialized nents.
If the error occurs, it adds SDEV_EVENT_ERROR_MALLOC and stub_priv
will be released by stub event handler and connection will be shut
down.
Reported-by: kbuild test robot <lkp@intel.com>
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Link: https://lore.kernel.org/r/20191111141035.27788-1-suwan.kim027@gmail.com
[ Upstream commit 090158555ff8d194a98616034100b16697dd80d0 ]
Upon success the update_status handler returns a positive number
corresponding to the number of bytes transferred by usb_control_msg.
However the return code of the update_status handler should indicate if
an error occurred(negative) or how many bytes of the user's input to sysfs
that was consumed. Return code zero indicates all bytes were consumed.
The bug can for example result in the update_status handler being called
twice, the second time with only the "unconsumed" part of the user's input
to sysfs. Effectively setting an incorrect brightness.
Change the update_status handler to return zero for all successful
transactions and forward usb_control_msg's error code upon failure.
Signed-off-by: Mattias Jacobsson <2pi@mok.nu>
[ Upstream commit 56445eef55cb5904096fed7a73cf87b755dfffc7 ]
Fix interrupt-out transfer length which was being set to the
transfer-buffer length rather than the size of the outgoing packet.
Note that no slab data was leaked as the whole transfer buffer is always
cleared before each transfer.
Fixes: 9aa8dae7b1fa ("cypress_m8: use usb_fill_int_urb where appropriate")
