commit 3d54d10c6afed34fd45b852bf76f55e8da31d8ef upstream.
When EXTCON is a loadable module, mtu3 fails to link as built-in:
drivers/usb/mtu3/mtu3_plat.o: In function `mtu3_probe':
mtu3_plat.c:(.text+0x690): undefined reference to `extcon_get_edev_by_phandle'
Add a Kconfig dependency to force mtu3 also to be a loadable module
if extconn is, but still allow it to be built without extcon.
Fixes: d0ed062a8b75 ("usb: mtu3: dual-role mode support")
Cc: stable <stable@vger.kernel.org>
commit 84f3b43f7378b98b7e3096d5499de75183d4347c upstream.
This is a Qualcomm based device with a QMI function on interface 4.
It is mode switched from 2020:2030 using a standard eject message.
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 6 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2020 ProdID=2031 Rev= 2.32
S: Manufacturer=Mobile Connect
S: Product=Mobile Connect
S: SerialNumber=0123456789ABCDEF
C:* #Ifs= 6 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=83(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=85(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=87(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=89(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=(none)
E: Ad=8a(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=125us
Cc: stable@vger.kernel.org
Signed-off-by: Bjørn Mork <bjorn@mork.no>
[ johan: use tabs to align comments in adjacent lines ]
Signed-off-by: Johan Hovold <johan@kernel.org>
commit d1252f0237238b912c3e7a51bf237acf34c97983 upstream.
The Quectel EM12 is a Cat. 12 LTE modem. It behaves in the exactly the
same way as the EP06 (including the dynamic configuration behavior), so
the same checks on reserved interfaces, etc. are needed.
Signed-off-by: Kristian Evensen <kristian.evensen@gmail.com>
commit f8df5c2c3e2df5ffaf9fb5503da93d477a8c7db4 upstream.
The SIMCom SIM5218 and compatible devices have 5 USB interfaces, only 4
of which are serial ports. The fifth is a network interface supported
by the qmi-wwan driver. Furthermore, the serial ports do not support
modem control signals. Add driver_info flags to reflect this.
Signed-off-by: Mans Rullgard <mans@mansr.com>
Fixes: ec0cd94d881c ("usb: option: add SIMCom SIM5218")
Cc: stable <stable@vger.kernel.org> # 3.2
commit 2908b076f5198d231de62713cb2b633a3a4b95ac upstream.
The write_parport_reg_nonblock() helper takes a reference to the struct
mos_parport, but failed to release it in a couple of error paths after
allocation failures, leading to a memory leak.
Johan said that move the kref_get() and mos_parport assignment to the
end of urbtrack initialisation is a better way, so move it. and
mos_parport do not used until urbtrack initialisation.
Signed-off-by: Lin Yi <teroincn@163.com>
Fixes: b69578df7e98 ("USB: usbserial: mos7720: add support for parallel port on moschip 7715")
Cc: stable <stable@vger.kernel.org> # 2.6.35
commit 422c2537ba9d42320f8ab6573940269f87095320 upstream.
Add PIDs for the NovaTech OrionLX+ and Orion I/O so they can be
automatically detected.
Signed-off-by: George McCollister <george.mccollister@gmail.com>
commit a595ecdd5f60b2d93863cebb07eec7f935839b54 upstream.
Lorenz Messtechnik has a device that is controlled by the cp210x driver,
so add the device id to the driver. The device id was provided by
Silicon-Labs for the devices from this vendor.
Reported-by: Uli <t9cpu@web.de>
This is the 4.19.31 stable release
mm/swap.c
This is the 4.19.29 stable release
drivers/irqchip/irq-gic-v3-its.c
commit 8a863a608d47fa5d9dd15cf841817f73f804cf91 upstream.
Commit 1a2f474d328f handles block _reads_ separately with plain-I2C
adapters, but the problem described with regmap-i2c not handling
SMBus block transfers (i.e. read and writes) correctly also exists
with writes.
As workaround, this patch adds a block write function the same way
1a2f474d328f adds a block read function.
Fixes: 1a2f474d328f ("usb: typec: tps6598x: handle block reads separately with plain-I2C adapters")
Fixes: 0a4c005bd171 ("usb: typec: driver for TI TPS6598x USB Power Delivery controllers")
Signed-off-by: Nikolaus Voss <nikolaus.voss@loewensteinmedical.de>
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Acked-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
commit 563b9372f7ec57e44e8f9a8600c5107d7ffdd166 upstream.
The ChipIdea's platform device need to be unregistered on Tegra's driver
module removal.
Fixes: dfebb5f43a78827a ("usb: chipidea: Add support for Tegra20/30/114/124")
Signed-off-by: Dmitry Osipenko <digetx@gmail.com>
Acked-by: Peter Chen <peter.chen@nxp.com>
[ Upstream commit f2105d42597f4d10e431b195d69e96dccaf9b012 ]
Fix link errors when CONFIG_FSL_USB2_OTG is enabled and USB_OTG_FSM is
set to module then the following link error occurs.
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_ioctl':
drivers/usb/phy/phy-fsl-usb.c:1083: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:1083:(.text+0x574): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_start_srp':
drivers/usb/phy/phy-fsl-usb.c:674: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:674:(.text+0x61c): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_set_host':
drivers/usb/phy/phy-fsl-usb.c:593: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:593:(.text+0x7a4): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_start_hnp':
drivers/usb/phy/phy-fsl-usb.c:695: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:695:(.text+0x858): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `a_wait_enum':
drivers/usb/phy/phy-fsl-usb.c:274: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:274:(.text+0x16f0): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o:drivers/usb/phy/phy-fsl-usb.c:619: more undefined references to `otg_statemachine' follow
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_set_peripheral':
drivers/usb/phy/phy-fsl-usb.c:619:(.text+0x1fa0): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
make[1]: *** [Makefile:1020: vmlinux] Error 1
make[1]: Target 'Image' not remade because of errors.
make: *** [Makefile:152: sub-make] Error 2
make: Target 'Image' not remade because of errors.
Rework so that FSL_USB2_OTG depends on that the USB_OTG_FSM is builtin.
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
commit 7b0b644b9aa2de5032db0f468fddca091d0b7b90 upstream.
Current GPIO code in cp210x fails to take USB autosuspend into account,
making it practically impossible to use GPIOs with autosuspend enabled
without user configuration. Fix this like for ftdi_sio in a previous patch.
Tested on a CP2102N.
Signed-off-by: Karoly Pados <pados@pados.hu>
Fixes: cf5276ce7867 ("USB: serial: cp210x: Adding GPIO support for CP2105")
commit 8fde481ef3674ae5ad0dbfef4df18ff507c5675a upstream.
This fix enables USB role feature on intel commercial nuc
platform which is based on Kabylake chipset.
Signed-off-by: Balaji Manoharan <m.balaji@intel.com>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Reviewed-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit 8d7fa3d4ea3f0ca69554215e87411494e6346fdc upstream.
This adds the USB ID of the Hjelmslund Electronics USB485 Iso stick.
commit dd9d3d86b08d6a106830364879c42c78db85389c upstream.
Here is how this device appears in kernel log:
usb 3-1: new full-speed USB device number 18 using xhci_hcd
usb 3-1: New USB device found, idVendor=0b00, idProduct=3070
usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 3-1: Product: Ingenico 3070
usb 3-1: Manufacturer: Silicon Labs
usb 3-1: SerialNumber: 0001
Apparently this is a POS terminal with embedded USB-to-Serial converter.
Signed-off-by: Ivan Mironov <mironov.ivan@gmail.com>
commit 6431866b6707d27151be381252d6eef13025cfce upstream.
This patch adds Telit ME910 family ECM composition 0x1102.
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
[ Upstream commit df28169e1538e4a8bcd8b779b043e5aa6524545c ]
The source_sink_alloc_func() function is supposed to return error
pointers on error. The function is called from usb_get_function() which
doesn't check for NULL returns so it would result in an Oops.
Of course, in the current kernel, small allocations always succeed so
this doesn't affect runtime.
[ Upstream commit 88b1bb1f3b88e0bf20b05d543a53a5b99bd7ceb6 ]
Currently the link_state is uninitialized and the default value is 0(U0)
before the first time we start the udc, and after we start the udc then
stop the udc, the link_state will be undefined.
We may have the following warnings if we start the udc again with
an undefined link_state:
WARNING: CPU: 0 PID: 327 at drivers/usb/dwc3/gadget.c:294 dwc3_send_gadget_ep_cmd+0x304/0x308
dwc3 100e0000.hidwc3_0: wakeup failed --> -22
Call Trace:
[<c010f270>] (unwind_backtrace) from [<c010b3d8>] (show_stack+0x10/0x14)
[<c010b3d8>] (show_stack) from [<c034a4dc>] (dump_stack+0x84/0x98)
[<c034a4dc>] (dump_stack) from [<c0118000>] (__warn+0xe8/0x100)
[<c0118000>] (__warn) from [<c0118050>](warn_slowpath_fmt+0x38/0x48)
[<c0118050>] (warn_slowpath_fmt) from [<c0442ec0>](dwc3_send_gadget_ep_cmd+0x304/0x308)
[<c0442ec0>] (dwc3_send_gadget_ep_cmd) from [<c0445e68>](dwc3_ep0_start_trans+0x48/0xf4)
[<c0445e68>] (dwc3_ep0_start_trans) from [<c0446750>](dwc3_ep0_out_start+0x64/0x80)
[<c0446750>] (dwc3_ep0_out_start) from [<c04451c0>](__dwc3_gadget_start+0x1e0/0x278)
[<c04451c0>] (__dwc3_gadget_start) from [<c04452e0>](dwc3_gadget_start+0x88/0x10c)
[<c04452e0>] (dwc3_gadget_start) from [<c045ee54>](udc_bind_to_driver+0x88/0xbc)
[<c045ee54>] (udc_bind_to_driver) from [<c045f29c>](usb_gadget_probe_driver+0xf8/0x140)
[<c045f29c>] (usb_gadget_probe_driver) from [<bf005424>](gadget_dev_desc_UDC_store+0xac/0xc4 [libcomposite])
[<bf005424>] (gadget_dev_desc_UDC_store [libcomposite]) from[<c023d8e0>] (configfs_write_file+0xd4/0x160)
[<c023d8e0>] (configfs_write_file) from [<c01d51e8>] (__vfs_write+0x1c/0x114)
[<c01d51e8>] (__vfs_write) from [<c01d5ff4>] (vfs_write+0xa4/0x168)
[<c01d5ff4>] (vfs_write) from [<c01d6d40>] (SyS_write+0x3c/0x90)
[<c01d6d40>] (SyS_write) from [<c0107400>] (ret_fast_syscall+0x0/0x3c)
Signed-off-by: Zeng Tao <prime.zeng@hisilicon.com>
[ Upstream commit 01c10880d24291a96a4ab0da773e3c5ce4d12da8 ]
We see dwc3 endpoint stopped by unwanted irq during
suspend resume test, which is caused dwc3 ep can't be started
with error "No Resource".
Here, add synchronize_irq before suspend to sync the
pending IRQ handlers complete.
Signed-off-by: Bo He <bo.he@intel.com>
Signed-off-by: Yu Wang <yu.y.wang@intel.com>
This is the 4.19.23 stable release
commit c418fd6c01fbc5516a2cd1eaf1df1ec86869028a upstream.
Handling short packets (length < max packet size) in the Inventra DMA
engine in the MUSB driver causes the MUSB DMA controller to hang. An
example of a problem that is caused by this problem is when streaming
video out of a UVC gadget, only the first video frame is transferred.
For short packets (mode-0 or mode-1 DMA), MUSB_TXCSR_TXPKTRDY must be
set manually by the driver. This was previously done in musb_g_tx
(musb_gadget.c), but incorrectly (all csr flags were cleared, and only
MUSB_TXCSR_MODE and MUSB_TXCSR_TXPKTRDY were set). Fixing that problem
allows some requests to be transferred correctly, but multiple requests
were often put together in one USB packet, and caused problems if the
packet size was not a multiple of 4. Instead, set MUSB_TXCSR_TXPKTRDY
in dma_controller_irq (musbhsdma.c), just like host mode transfers.
This topic was originally tackled by Nicolas Boichat [0] [1] and is
discussed further at [2] as part of his GSoC project [3].
[0] https://groups.google.com/forum/?hl=en#!topic/beagleboard-gsoc/k8Azwfp75CU
[1] https://gitorious.org/beagleboard-usbsniffer/beagleboard-usbsniffer-kernel/commit/b0be3b6cc195ba732189b04f1d43ec843c3e54c9?p=beagleboard-usbsniffer:beagleboard-usbsniffer-kernel.git;a=patch;h=b0be3b6cc195ba732189b04f1d43ec843c3e54c9
[2] http://beagleboard-usbsniffer.blogspot.com/2010/07/musb-isochronous-transfers-fixed.html
[3] http://elinux.org/BeagleBoard/GSoC/USBSniffer
Fixes: 550a7375fe72 ("USB: Add MUSB and TUSB support")
Signed-off-by: Paul Elder <paul.elder@ideasonboard.com>
Signed-off-by: Bin Liu <b-liu@ti.com>
commit 07c69f1148da7de3978686d3af9263325d9d60bd upstream.
(!x & y) strikes again.
Fix bitwise and boolean operations by enclosing the expression:
intcsr & (1 << NET2272_PCI_IRQ)
in parentheses, before applying the boolean operator '!'.
Notice that this code has been there since 2011. So, it would
be helpful if someone can double-check this.
This issue was detected with the help of Coccinelle.
Fixes: ceb80363b2ec ("USB: net2272: driver for PLX NET2272 USB device controller")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
commit 1e19cdc8060227b0802bda6bc0bd22b23679ba32 upstream.
For OUT endpoints, zero-length transfers require MaxPacketSize buffer as
per the DWC_usb3 programming guide 3.30a section 4.2.3.3.
This patch fixes this by explicitly checking zero length
transfer to correctly pad up to MaxPacketSize.
Fixes: c6267a51639b ("usb: dwc3: gadget: align transfers to wMaxPacketSize")
Signed-off-by: Tejas Joglekar <joglekar@synopsys.com>
commit a53469a68eb886e84dd8b69a1458a623d3591793 upstream.
power off the phy should be done before populate the phy. Otherwise,
am335x_init() could be called by the phy owner to power on the phy first,
then am335x_phy_probe() turns off the phy again without the caller knowing
it.
Fixes: 2fc711d76352 ("usb: phy: am335x: Enable USB remote wakeup using PHY wakeup")
Cc: stable@vger.kernel.org # v3.18+
[ Upstream commit 54578ee883e34d2d1c518d48f1c1e2dd3f387188 ]
Since the runtime PM support was added in musb, dsps relies on the timer
calling otg_timer() to activate the usb subsystem. However the driver
doesn't enable the timer for peripheral port, then the peripheral port is
unable to be enumerated by a host if the other usb port is disabled or in
peripheral mode too.
So let's start the timer for peripheral port too.
Fixes: ea2f35c01d5e ("usb: musb: Fix sleeping function called from invalid context for hdrc glue")
[ Upstream commit 6010abf2c2c0e382d7e8ee44bd11f343aae90cce ]
Due to lack of ID pin interrupt event on AM335x devices, the musb dsps
driver uses polling to detect usb device attach for dual-role port.
But in the case if a micro-A cable adapter is attached without a USB device
attached to the cable, the musb state machine gets stuck in a_wait_vrise
state waiting for the MUSB_CONNECT interrupt which won't happen due to the
usb device is not attached. The state is stuck in a_wait_vrise even after
the micro-A cable is detached, which could cause VBUS retention if then the
dual-role port is attached to a host port.
To fix the problem, make a_wait_vrise as a transient state, then move the
state to either a_wait_bcon for host port or a_idle state for dual-role
port, if no usb device is attached to the port.
[ Upstream commit 1d6e81a288e28d8d0e38e0501a324216f79bba35 ]
HS-USB found in RZ/G2E (a.k.a. r8a774c0) is very similar to the
one found in R-Car E3 (a.k.a. r8a77990), as it needs to release
the PLL reset by the UGCTRL register like R-Car E3, therefore add
r8a774c0 support in a similar fashion to what was done for the
r8a77990.
Signed-off-by: Fabrizio Castro <fabrizio.castro@bp.renesas.com>
Reviewed-by: Simon Horman <horms+renesas@verge.net.au>
Acked-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
[ Upstream commit 244add8ebfb231c39db9e33b204bd0ce8f24f782 ]
In stream mode, when fast-forwarding TRBs, the stream number
is not cleared causing the new stream to not get assigned. So
we don't want controller to carry on transfers when short packet
is received. So disable the CSP for stream capable endpoint.
This is based on the 3.30a Programming guide, where table 3-1
device descriptor structure field definitions says for CSP bit
If this bit is 0, the controller generates an XferComplete event
and remove the stream. So if we keep CSP as 1 then switching between
streams would not happen as in stream mode, when fast-forwarding
TRBs, the stream number is not cleared causing the new stream to not get
assigned.
[ Upstream commit 54d48183d21e03f780053d7129312049cb5dd591 ]
The missed break statement in the outer switch makes the code fall through
always and thus always same value will be printed.
Besides that, compiler warns about missed fall through marker:
drivers/usb/dwc3/./trace.h: In function ‘trace_raw_output_dwc3_log_trb’:
drivers/usb/dwc3/./trace.h:246:4: warning: this statement may fall through [-Wimplicit-fallthrough=]
switch (pcm) {
Add the missing break statement to work correctly without compilation
warnings.
Fixes: fa8d965d736b ("usb: dwc3: trace: pretty print high-bandwidth transfers too")
Cc: Felipe Balbi <felipe.balbi@linux.intel.com>
[ Upstream commit a0678e2eed41e81004308693ac84ea95614b0920 ]
Fix the issue: device doesn't accept LGO_U1/U2:
1. set SW_U1/U2_ACCEPT_ENABLE to eanble controller to accept LGO_U1/U2
by default;
2. enable/disable controller to initiate requests for transition into
U1/U2 by SW_U1/U2_REQUEST_ENABLE instead of SW_U1/U2_ACCEPT_ENABLE;
Signed-off-by: Chunfeng Yun <chunfeng.yun@mediatek.com>
[ Upstream commit e86108940e541febf35813402ff29fa6f4a9ac0b ]
When initializing a hub we want to give a USB3 port in link training
the same debounce delay time before autosuspening the hub as already
trained, connected enabled ports.
USB3 ports won't reach the enabled state with "current connect status" and
"connect status change" bits set until the USB3 link training finishes.
Catching the port in link training (polling) and adding the debounce delay
prevents unnecessary failed attempts to autosuspend the hub.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
[ Upstream commit 35a6054132286a4ab92b536595093b82e6bdfcbc ]
Power down feature of DWC2 module integrated in Samsung SoCs doesn't work
properly or needs some additional handling in PHY or SoC glue layer, so
disable it for now. Without disabling power down, DWC2 causes random memory
trashes and fails enumeration if there is no USB link to host on driver
probe.
Fixes: 03ea6d6e9e1ff1 ("usb: dwc2: Enable power down")
Acked-by: Minas Harutyunyan <hminas@synopsys.com>
[ Upstream commit b7a4fbe2300a8965ea760c7e871507b84aea17f6 ]
Availability of TRB's is calculated using dwc3_calc_trbs_left(), which
determines total available TRB's based on the HWO bit set in a TRB.
In the present code, __dwc3_prepare_one_trb() is called with a TRB which
needs to be prepared for transfer. This __dwc3_prepare_one_trb() calls
dwc3_calc_trbs_left() to determine total available TRBs and set IOC bit
if the total available TRBs are zero. Since the present working TRB (which
is passed as an argument to __dwc3_prepare_one_trb() ) doesn't yet have
the HWO bit set before calling dwc3_calc_trbs_left(), there are chances
that dwc3_calc_trbs_left() wrongly calculates this present working TRB
as free(since the HWO bit is not yet set) and returns the total available
TRBs as greater than zero (including the present working TRB). This could
be a problem.
This patch corrects the above mentioned problem in __dwc3_prepare_one_trb()
by increementing the dep->trb_enqueue at the last (after preparing the TRB)
instead of increementing at the start and setting the IOC bit only if the
total available TRBs returned by dwc3_calc_trbs_left() is 1 . Since we are
increementing the dep->trb_enqueue at the last, the present working TRB is
also considered as available by dwc3_calc_trbs_left() and non zero value is
returned . So, according to the modified logic, when the total available
TRBs is equal to 1 that means the total available TRBs in the pool are 0.
Signed-off-by: Anurag Kumar Vulisha <anurag.kumar.vulisha@xilinx.com>
Reviewed-by: Thinh Nguyen <thinhn@synopsys.com>
Tested-by: Tejas Joglekar <tejas.joglekar@synopsys.com>
commit bd6742249b9ca918565e4e3abaa06665e587f4b5 upstream.
OUT endpoint requests may somtimes have this flag set when
preparing to be submitted to HW indicating that there is an
additional TRB chained to the request for alignment purposes.
If that request is removed before the controller can execute the
transfer (e.g. ep_dequeue/ep_disable), the request will not go
through the dwc3_gadget_ep_cleanup_completed_request() handler
and will not have its needs_extra_trb flag cleared when
dwc3_gadget_giveback() is called. This same request could be
later requeued for a new transfer that does not require an
extra TRB and if it is successfully completed, the cleanup
and TRB reclamation will incorrectly process the additional TRB
which belongs to the next request, and incorrectly advances the
TRB dequeue pointer, thereby messing up calculation of the next
requeust's actual/remaining count when it completes.
The right thing to do here is to ensure that the flag is cleared
before it is given back to the function driver. A good place
to do that is in dwc3_gadget_del_and_unmap_request().
Signed-off-by: Jack Pham <jackp@codeaurora.org>
[jackp: backport to <= 4.20: replaced 'needs_extra_trb' with 'unaligned'
and 'zero' members in patch and reworded commit text]
commit 4dcf9ddc9ad5ab649abafa98c5a4d54b1a33dabb upstream.
Add new PID to support PL2303TB (TYPE_HX)
Signed-off-by: Charles Yeh <charlesyeh522@gmail.com>
commit b81c2c33eab79dfd3650293b2227ee5c6036585c upstream.
Add new Motorola Tetra device id for Motorola Solutions TETRA PEI device
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
P: Vendor=0cad ProdID=9016 Rev=24.16
S: Manufacturer=Motorola Solutions, Inc.
S: Product=TETRA PEI interface
C: #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=usb_serial_simple
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=usb_serial_simple
Signed-off-by: Max Schulze <max.schulze@posteo.de>
commit 91f7d2e89868fcac0e750a28230fdb1ad4512137 upstream.
The patch "usb: simplify usbport trigger" together with "leds: triggers:
add device attribute support" caused an regression for the usbport
trigger. it will no longer enumerate any active usb hub ports under the
"ports" directory in the sysfs class directory, if the usb host drivers
are fully initialized before the usbport trigger was loaded.
The reason is that the usbport driver tries to register the sysfs
entries during the activate() callback. And this will fail with -2 /
ENOENT because the patch "leds: triggers: add device attribute support"
made it so that the sysfs "ports" group was only being added after the
activate() callback succeeded.
This version of the patch reverts parts of the "usb: simplify usbport
trigger" patch and restores usbport trigger's functionality.
Fixes: 6f7b0bad8839 ("usb: simplify usbport trigger")
Signed-off-by: Christian Lamparter <chunkeey@gmail.com>
Acked-by: Jacek Anaszewski <jacek.anaszewski@gmail.com>
[ Upstream commit ceb94bc52c437463f0903e61060a94a2226fb672 ]
This patch adds a safety connection way for "forced_b_device" with
"workaround_for_vbus" like below:
< Example for R-Car E3 Ebisu >
# modprobe <any usb gadget driver>
# echo 1 > /sys/kernel/debug/ee020000.usb/b_device
(connect a usb cable to host side.)
# echo 2 > /sys/kernel/debug/ee020000.usb/b_device
Previous code should have connected a usb cable before the "b_device"
is set to 1 on the Ebisu board. However, if xHCI driver on the board
is probed, it causes some troubles:
- Conflicts USB VBUS/signals between the board and another host.
- "Cannot enable. Maybe the USB cable is bad?" might happen on
both the board and another host with a usb hub.
- Cannot enumerate a usb gadget correctly because an interruption
of VBUS change happens unexpectedly.
Reported-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
[ Upstream commit 23b5f73266e59a598c1e5dd435d87651b5a7626b ]
During HARD_RESET the data link is disconnected.
For self powered device, the spec is advising against doing that.
>From USB_PD_R3_0
7.1.5 Response to Hard Resets
Device operation during and after a Hard Reset is defined as follows:
Self-powered devices Should Not disconnect from USB during a Hard Reset
(see Section 9.1.2).
Bus powered devices will disconnect from USB during a Hard Reset due to the
loss of their power source.
Tackle this by letting TCPM know whether the device is self or bus powered.
This overcomes unnecessary port disconnections from hard reset.
Also, speeds up the enumeration time when connected to Type-A ports.
Signed-off-by: Badhri Jagan Sridharan <badhri@google.com>
Version history:
V3:
Rebase on top of usb-next
V2:
Based on feedback from heikki.krogerus@linux.intel.com
- self_powered added to the struct tcpm_port which is populated from
a. "connector" node of the device tree in tcpm_fw_get_caps()
b. "self_powered" node of the tcpc_config in tcpm_copy_caps
Based on feedbase from linux@roeck-us.net
- Code was refactored
- SRC_HARD_RESET_VBUS_OFF sets the link state to false based
on self_powered flag
V1 located here:
https://lkml.org/lkml/2018/9/13/94
commit 3483254b89438e60f719937376c5e0ce2bc46761 upstream.
To match the Corsair Strafe RGB, the Corsair K70 RGB also requires
USB_QUIRK_DELAY_CTRL_MSG to completely resolve boot connection issues
discussed here: https://github.com/ckb-next/ckb-next/issues/42.
Otherwise roughly 1 in 10 boots the keyboard will fail to be detected.
Patch that applied delay control quirk for Corsair Strafe RGB:
cb88a0588717 ("usb: quirks: add control message delay for 1b1c:1b20")
Previous K70 RGB patch to add delay-init quirk:
7a1646d92257 ("Add delay-init quirk for Corsair K70 RGB keyboards")
Signed-off-by: Jack Stocker <jackstocker.93@gmail.com>
commit 0a99cc4b8ee83885ab9f097a3737d1ab28455ac0 upstream.
The SMI SM3350 USB-UFS bridge controller cannot handle long sense request
correctly and will make the chip refuse to do read/write when requested
long sense.
Add a bad sense quirk for it.
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
commit c5603d2fdb424849360fe7e3f8c1befc97571b8c upstream.
Currently the code will set US_FL_SANE_SENSE flag unconditionally if
device claims SPC3+, however we should allow US_FL_BAD_SENSE flag to
prevent this behavior, because SMI SM3350 UFS-USB bridge controller,
which claims SPC4, will show strange behavior with 96-byte sense
(put the chip into a wrong state that cannot read/write anything).
Check the presence of US_FL_BAD_SENSE when assuming US_FL_SANE_SENSE on
SPC4+ devices.
commit 34aabf918717dd14e05051896aaecd3b16b53d95 upstream.
Telit 3G Intel based modems require zero packet to be sent if
out data size is equal to the endpoint max packet size.
This is the 4.19.15 stable release
commit eafb27fa5283599ce6c5492ea18cf636a28222bb upstream.
Mediatek Preloader is a proprietary embedded boot loader for loading
Little Kernel and Linux into device DRAM.
This boot loader also handle firmware update. Mediatek Preloader will be
enumerated as a virtual COM port when the device is connected to Windows
or Linux OS via CDC-ACM class driver. When the USB enumeration has been
done, Mediatek Preloader will send out handshake command "READY" to PC
actively instead of waiting command from the download tool.
Since Linux 4.12, the commit "tty: reset termios state on device
registration" (93857edd9829e144acb6c7e72d593f6e01aead66) causes Mediatek
Preloader receiving some abnoraml command like "READYXX" as it sent.
This will be recognized as an incorrect response. The behavior change
also causes the download handshake fail. This change only affects
subsequent connects if the reconnected device happens to get the same minor
number.
By disabling the ECHO termios flag could avoid this problem. However, it
cannot be done by user space configuration when download tool open
/dev/ttyACM0. This is because the device running Mediatek Preloader will
send handshake command "READY" immediately once the CDC-ACM driver is
ready.
This patch wants to fix above problem by introducing "DISABLE_ECHO"
property in driver_info. When Mediatek Preloader is connected, the
CDC-ACM driver could disable ECHO flag in termios to avoid the problem.
Signed-off-by: Macpaul Lin <macpaul.lin@mediatek.com>
Reviewed-by: Johan Hovold <johan@kernel.org>
Acked-by: Oliver Neukum <oneukum@suse.com>
commit c3788cd9963eb2e77de3c24142fb7c67b61f1a26 upstream.
That makes the USB role switch support option visible and
selectable for the user. The class driver is also moved to
drivers/usb/roles/ directory.
This will fix an issue that we have with the Intel USB role
switch driver on systems that don't have USB Type-C connectors:
Intel USB role switch driver depends on the USB role switch
class as it should, but since there was no way for the user
to enable the USB role switch class, there was also no way
to select that driver. USB Type-C drivers select the USB
role switch class which makes the Intel USB role switch
driver available and therefore hides the problem.
So in practice Intel USB role switch driver was depending on
USB Type-C drivers.
Fixes: f6fb9ec02be1 ("usb: roles: Add Intel xHCI USB role switch driver")
Cc: <stable@vger.kernel.org>
Signed-off-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
commit 3004cfd6204927c1294060b849029cf0c2651074 upstream.
Commit 211f658b7b40 ("usb: dwc3: pci: Use devm functions to get
the phy GPIOs") changed the code to claim the PHY GPIOs permanently
for Intel Baytrail devices.
This causes issues when the actual PHY driver attempts to claim the
same GPIO descriptors. For example, tusb1210 now fails to probe with:
tusb1210: probe of dwc3.0.auto.ulpi failed with error -16 (EBUSY)
dwc3-pci needs to turn on the PHY once before dwc3 is loaded, but
usually the PHY driver will then hold the GPIOs to turn off the
PHY when requested (e.g. during suspend).
To fix the problem, this reverts the commit to restore the old
behavior to put the GPIOs immediately after usage.
Link: https://www.spinics.net/lists/linux-usb/msg174681.html
Signed-off-by: Stephan Gerhold <stephan@gerhold.net>
commit cc10ce0c51b13d1566d0ec1dcb472fb86330b391 upstream.
Disable power_down by setting the parameter to
DWC2_POWER_DOWN_PARAM_NONE. This fixes a problem on various Amlogic
Meson SoCs where USB devices are only recognized when plugged in before
booting Linux. A hot-plugged USB device was not detected even though the
device got power (my USB thumb drive for example has an LED which lit
up).
A similar fix was implemented for Rockchip SoCs in commit c216765d3a1def
("usb: dwc2: disable power_down on rockchip devices"). That commit
suggests that a change in the dwc2 driver is the cause because the
default value for the "hibernate" parameter (which then got renamed to
"power_down" to support other modes) was changed in the v4.17 merge
window with:
commit 6d23ee9caa6790 ("Merge tag 'usb-for-v4.17' of git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-testing").
Cc: <stable@vger.kernel.org> # 4.19
Suggested-by: Christian Hewitt <christianshewitt@gmail.com>
Signed-off-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com>
r8a66597_endpoint_disable()
commit c85400f886e3d41e69966470879f635a2b50084c upstream.
The function r8a66597_endpoint_disable() and r8a66597_urb_enqueue() may
be concurrently executed.
The two functions both access a possible shared variable "hep->hcpriv".
This shared variable is freed by r8a66597_endpoint_disable() via the
call path:
kfree(hep->hcpriv) (line 1995 in Linux-4.19)
This variable is read by r8a66597_urb_enqueue() via the call path:
spin_lock_irqsave(&r8a66597->lock)
init_pipe_info
enable_r8a66597_pipe
pipe = hep->hcpriv (line 802 in Linux-4.19)
The read operation is protected by a spinlock, but the free operation
is not protected by this spinlock, thus a concurrency use-after-free bug
may occur.
To fix this bug, the spin-lock and spin-unlock function calls in
r8a66597_endpoint_disable() are moved to protect the free operation.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
