commit 5e5caf4fa8d3039140b4548b6ab23dd17fce9b2c upstream.
Different configuration/condition may draw different power. Inform the
controller driver of the change so it can respond properly (e.g.
GET_STATUS request). This fixes an issue with setting MaxPower from
configfs. The composite driver doesn't check this value when setting
self-powered.
Cc: stable@vger.kernel.org
Fixes: 88af8bbe4ef7 ("usb: gadget: the start of the configfs interface")
Signed-off-by: Thinh Nguyen <thinhn@synopsys.com>
Signed-off-by: Felipe Balbi <balbi@kernel.org>
commit f63ec55ff904b2f2e126884fcad93175f16ab4bb upstream.
In AIO case, the request is freed up if ep_queue fails.
However, io_data->req still has the reference to this freed
request. In the case of this failure if there is aio_cancel
call on this io_data it will lead to an invalid dequeue
operation and a potential use after free issue.
Fix this by setting the io_data->req to NULL when the request
is freed as part of queue failure.
Fixes: 2e4c7553cd6f ("usb: gadget: f_fs: add aio support")
Signed-off-by: Sriharsha Allenki <sallenki@codeaurora.org>
CC: stable <stable@vger.kernel.org>
Reviewed-by: Peter Chen <peter.chen@nxp.com>
Link: https://lore.kernel.org/r/20200326115620.12571-1-sallenki@codeaurora.org
commit c09b73cfac2a9317f1104169045c519c6021aa1d upstream.
This reverts
commit 6a4290cc28be1 ("usb: dwc3: gadget: set the OTG flag in dwc3 gadget driver.")
We don't yet support any of the OTG mechanisms (HNP/SRP/ADP)
and are not setting gadget->otg_caps, so don't set gadget->is_otg
flag.
If we do then we end up publishing a OTG1.0 descriptor in
the gadget descriptor which causes device enumeration to fail
if we are connected to a host with CONFIG_USB_OTG enabled.
Host side log without this patch
[ 96.720453] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[ 96.901391] usb 1-1: Dual-Role OTG device on non-HNP port
[ 96.907552] usb 1-1: set a_alt_hnp_support failed: -32
[ 97.060447] usb 1-1: new high-speed USB device number 3 using xhci-hcd
[ 97.241378] usb 1-1: Dual-Role OTG device on non-HNP port
[ 97.247536] usb 1-1: set a_alt_hnp_support failed: -32
[ 97.253606] usb usb1-port1: attempt power cycle
[ 97.960449] usb 1-1: new high-speed USB device number 4 using xhci-hcd
[ 98.141383] usb 1-1: Dual-Role OTG device on non-HNP port
[ 98.147540] usb 1-1: set a_alt_hnp_support failed: -32
[ 98.300453] usb 1-1: new high-speed USB device number 5 using xhci-hcd
[ 98.481391] usb 1-1: Dual-Role OTG device on non-HNP port
[ 98.487545] usb 1-1: set a_alt_hnp_support failed: -32
[ 98.493532] usb usb1-port1: unable to enumerate USB device
Signed-off-by: Roger Quadros <rogerq@ti.com>
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 52974d94a206ce428d9d9b6eaa208238024be82a upstream.
When handling a PIO bulk transfer with highmem buffer, a temporary
mapping is assigned to urb->transfer_buffer. After the transfer is
complete, an invalid address is left behind in this pointer. This is
not ordinarily a problem since nothing touches that buffer before the
urb is released. However, when usbmon is active, usbmon_urb_complete()
calls (indirectly) mon_bin_get_data() which does access the transfer
buffer if it is set. To prevent an invalid memory access here, reset
urb->transfer_buffer to NULL when finished (musb_host_rx()), or do not
set it at all (musb_host_tx()).
Fixes: 8e8a55165469 ("usb: musb: host: Handle highmem in PIO mode")
Signed-off-by: Mans Rullgard <mans@mansr.com>
Signed-off-by: Bin Liu <b-liu@ti.com>
Link: https://lore.kernel.org/r/20200316211136.2274-8-b-liu@ti.com
commit 57aa9f294b09463492f604feaa5cc719beaace32 upstream.
Fix slab-out-of-bounds read in the interrupt-URB completion handler.
The boundary condition should be (length - 1) as we access
data[position + 1].
Reported-and-tested-by: syzbot+37ba33391ad5f3935bbd@syzkaller.appspotmail.com
Signed-off-by: Qiujun Huang <hqjagain@gmail.com>
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 62d65bdd9d05158aa2547f8ef72375535f3bc6e3 upstream.
commit b401f8c4f492c ("USB: cdc-acm: fix rounding error in TIOCSSERIAL")
introduced a regression by changing the order of capability and close
settings change checks. When running with CAP_SYS_ADMIN setting the
close settings to the values already set resulted in -EOPNOTSUPP.
Fix this by changing the check order back to how it was before.
Fixes: b401f8c4f492c ("USB: cdc-acm: fix rounding error in TIOCSSERIAL")
Cc: Anthony Mallet <anthony.mallet@laas.fr>
Cc: Oliver Neukum <oneukum@suse.com>
Signed-off-by: Matthias Reichl <hias@horus.com>
Link: https://lore.kernel.org/r/20200327150350.3657-1-hias@horus.com
commit dfee7e2f478346b12ea651d5c28b069f6a4af563 upstream.
This modem is embedded on dlink dwr-960 router.
The oem configuration states:
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.10 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1435 ProdID=d191 Rev=ff.ff
S: Manufacturer=Android
S: Product=Android
S: SerialNumber=0123456789ABCDEF
C:* #Ifs= 6 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=42 Prot=01 Driver=(none)
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=84(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=(none)
E: Ad=86(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
E: Ad=88(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
E: Ad=87(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=(none)
E: Ad=89(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=125us
Tested on openwrt distribution
Signed-off-by: Pawel Dembicki <paweldembicki@gmail.com>
commit 6cb2669cb97fc4fdf526127159ac59caae052247 upstream.
BroadMobi BM806U is an Qualcomm MDM9225 based 3G/4G modem.
Tested hardware BM806U is mounted on D-Link DWR-921-C3 router.
T: Bus=01 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.01 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2020 ProdID=2033 Rev= 2.28
S: Manufacturer=Mobile Connect
S: Product=Mobile Connect
S: SerialNumber=f842866cfd5a
C:* #Ifs= 5 Cfg#= 1 Atr=80 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I:* If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=83(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=85(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=87(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=89(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
Co-developed-by: Cezary Jackiewicz <cezary@eko.one.pl>
Signed-off-by: Cezary Jackiewicz <cezary@eko.one.pl>
commit 007d20dca2376a751b1dad03442f118438b7e65e upstream.
ASKEY WWHC050 is a mcie LTE modem.
P: Vendor=1690 ProdID=7588 Rev=ff.ff
S: Product=Android
S: SerialNumber=813f0eef6e6e
Tested on openwrt distribution.
[ Upstream commit b401f8c4f492cbf74f3f59c9141e5be3071071bb ]
By default, tty_port_init() initializes those parameters to a multiple
of HZ. For instance in line 69 of tty_port.c:
port->close_delay = (50 * HZ) / 100;
https://github.com/torvalds/linux/blob/master/drivers/tty/tty_port.c#L69
With e.g. CONFIG_HZ = 250 (as this is the case for Ubuntu 18.04
linux-image-4.15.0-37-generic), the default setting for close_delay is
thus 125.
When ioctl(fd, TIOCGSERIAL, &s) is executed, the setting returned in
user space is '12' (125/10). When ioctl(fd, TIOCSSERIAL, &s) is then
executed with the same setting '12', the value is interpreted as '120'
which is different from the current setting and a EPERM error may be
raised by set_serial_info() if !CAP_SYS_ADMIN.
https://github.com/torvalds/linux/blob/master/drivers/usb/class/cdc-acm.c#L919
Fixes: ba2d8ce9db0a6 ("cdc-acm: implement TIOCSSERIAL to avoid blocking close(2)")
Signed-off-by: Anthony Mallet <anthony.mallet@laas.fr>
Link: https://lore.kernel.org/r/20200312133101.7096-2-anthony.mallet@laas.fr
[ Upstream commit 633e2b2ded739a34bd0fb1d8b5b871f7e489ea29 ]
close_delay and closing_wait are specified in hundredth of a second but stored
internally in jiffies. Use the jiffies_to_msecs() and msecs_to_jiffies()
functions to convert from each other.
Link: https://lore.kernel.org/r/20200312133101.7096-1-anthony.mallet@laas.fr
commit cecc113c1af0dd41ccf265c1fdb84dbd05e63423 upstream.
Add a device id for HP LD381 Display
LD381: 03f0:0f7f
Signed-off-by: Scott Chen <scott@labau.com.tw>
commit b433e340e7565110b0ce9ca4b3e26f4b97a1decf upstream.
When loading new kernel via kexec, we need to shutdown host controller to
avoid any un-expected memory accessing during new kernel boot.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
Tested-by: Stephen Boyd <swboyd@chromium.org>
Link: https://lore.kernel.org/r/20200306092328.41253-1-ran.wang_1@nxp.com
commit 8e852a7953be2a6ee371449f7257fe15ace6a1fc upstream.
Add ME910G1 ECM composition 0x110b: tty, tty, tty, ecm
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
Link: https://lore.kernel.org/r/20200304104310.2938-1-dnlplm@gmail.com
commit 75d7676ead19b1fbb5e0ee934c9ccddcb666b68c upstream.
We have been receiving bug reports that ethernet connections over
RTL8153 based ethernet adapters stops working after a while with
errors like these showing up in dmesg when the ethernet stops working:
[12696.189484] r8152 6-1:1.0 enp10s0u1: Tx timeout
[12702.333456] r8152 6-1:1.0 enp10s0u1: Tx timeout
[12707.965422] r8152 6-1:1.0 enp10s0u1: Tx timeout
This has been reported on Dell WD15 docks, Belkin USB-C Express Dock 3.1
docks and with generic USB to ethernet dongles using the RTL8153
chipsets. Some users have tried adding usbcore.quirks=0bda:8153:k to
the kernel commandline and all users who have tried this report that
this fixes this.
Also note that we already have an existing NO_LPM quirk for the RTL8153
used in the Microsoft Surface Dock (where it uses a different usb-id).
This commit adds a NO_LPM quirk for the generic Realtek RTL8153
0bda:8153 usb-id, fixing the Tx timeout errors on these devices.
BugLink: https://bugzilla.kernel.org/show_bug.cgi?id=198931
Cc: russianneuromancer@ya.ru
Link: https://lore.kernel.org/r/20200313120708.100339-1-hdegoede@redhat.com
commit b63e48fb50e1ca71db301ca9082befa6f16c55c4 upstream.
Realtek Hub (0bda:0x0487) used in Dell Dock WD19 sometimes drops off the
bus when bringing underlying ports from U3 to U0.
Disabling LPM on the hub during setting link state is not enough, so
let's disable LPM completely for this hub.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Kai-Heng Feng <kai.heng.feng@canonical.com>
Link: https://lore.kernel.org/r/20200205112633.25995-3-kai.heng.feng@canonical.com
commit 1f8b39bc99a31759e97a0428a5c3f64802c1e61d upstream.
Reviewing a fresh portion of coverity defects in USB core
(specifically CID 1458999), Alan Stern noted below in [1]:
On Tue, Feb 25, 2020 at 02:39:23PM -0500, Alan Stern wrote:
> A revised search finds line 997 in drivers/usb/core/hub.c and lines
> 216, 269 in drivers/usb/core/port.c. (I didn't try looking in any
> other directories.) AFAICT all three of these should check the
> return value, although a error message in the kernel log probably
> isn't needed.
Factor out the usb_port_runtime_{resume,suspend}() changes into a
standalone patch to allow conflict-free porting on top of stable v3.9+.
[1] https://lore.kernel.org/lkml/Pine.LNX.4.44L0.2002251419120.1485-100000@iolanthe.rowland.org
Fixes: 971fcd492cebf5 ("usb: add runtime pm support for usb port device")
Cc: stable@vger.kernel.org # v3.9+
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
Signed-off-by: Eugeniu Rosca <erosca@de.adit-jv.com>
Link: https://lore.kernel.org/r/20200226175036.14946-3-erosca@de.adit-jv.com
commit 60e3f6e4ac5b0fda43dad01c32e09409ec710045 upstream.
> isn't needed.
Factor out the usb_remove_device() change into a standalone patch to
allow conflict-free integration on top of the earliest stable branches.
Fixes: 253e05724f9230 ("USB: add a "remove hardware" sysfs attribute")
Cc: stable@vger.kernel.org # v2.6.33+
Link: https://lore.kernel.org/r/20200226175036.14946-2-erosca@de.adit-jv.com
commit b96ed52d781a2026d0c0daa5787c6f3d45415862 upstream.
LPM on the device appears to cause xHCI host controllers to claim
that there isn't enough bandwidth to support additional devices.
Signed-off-by: Dan Lazewatsky <dlaz@chromium.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.com>
Link: https://lore.kernel.org/r/20200226143438.1445-1-gustavo.padovan@collabora.com
commit 86d92f5465958752481269348d474414dccb1552 upstream.
Current driver has 240 (USB2.0) and 2048 (USB3.0) as max_sectors,
e.g., /sys/bus/scsi/devices/0:0:0:0/max_sectors
If data access times out, driver error handling will issue a port
reset.
Sometimes Samsung Fit (090C:1000) flash disk will not respond to
later Set Address or Get Descriptor command.
Adding this quirk to limit max_sectors to 64 sectors to avoid issue
occurring.
Signed-off-by: Jim Lin <jilin@nvidia.com>
Link: https://lore.kernel.org/r/1583158895-31342-1-git-send-email-jilin@nvidia.com
[ Upstream commit e4bfded56cf39b8d02733c1e6ef546b97961e18a ]
Symptom: application opens /dev/ttyGS0 and starts sending (writing) to
it while either USB cable is not connected, or nobody listens on the
other side of the cable. If driver circular buffer overflows before
connection is established, no data will be written to the USB layer
until/unless /dev/ttyGS0 is closed and re-opened again by the
application (the latter besides having no means of being notified about
the event of establishing of the connection.)
Fix: on open and/or connect, kick Tx to flush circular buffer data to
USB layer.
Signed-off-by: Sergey Organov <sorganov@gmail.com>
Reviewed-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
[ Upstream commit 43d565727a3a6fd24e37c7c2116475106af71806 ]
ffs_aio_cancel() can be called from both interrupt and thread context. Make
sure that the current IRQ state is saved and restored by using
spin_{un,}lock_irq{save,restore}().
Otherwise undefined behavior might occur.
Acked-by: Michal Nazarewicz <mina86@mina86.com>
Signed-off-by: Alexandru Ardelean <alexandru.ardelean@analog.com>
[ Upstream commit a2035411fa1d1206cea7d5dfe833e78481844a76 ]
USB 3.x SuperSpeed peripherals can draw up to 900mA of VBUS power
when in configured state. However, if a configuration wanting to
take advantage of this is added with MaxPower greater than 500
(currently possible if using a ConfigFS gadget) the composite
driver fails to accommodate this for a couple reasons:
- usb_gadget_vbus_draw() when called from set_config() and
composite_resume() will be passed the MaxPower value without
regard for the current connection speed, resulting in a
violation for USB 2.0 since the max is 500mA.
- the bMaxPower of the configuration descriptor would be
incorrectly encoded, again if the connection speed is only
at USB 2.0 or below, likely wrapping around U8_MAX since
the 2mA multiplier corresponds to a maximum of 510mA.
Fix these by adding checks against the current gadget->speed
when the c->MaxPower value is used (set_config() and
composite_resume()) and appropriately limit based on whether
it is currently at a low-/full-/high- or super-speed connection.
Because 900 is not divisible by 8, with the round-up division
currently used in encode_bMaxPower() a MaxPower of 900mA will
result in an encoded value of 0x71. When a host stack (including
Linux and Windows) enumerates this on a single port root hub, it
reads this value back and decodes (multiplies by 8) to get 904mA
which is strictly greater than 900mA that is typically budgeted
for that port, causing it to reject the configuration. Instead,
we should be using the round-down behavior of normal integral
division so that 900 / 8 -> 0x70 or 896mA to stay within range.
And we might as well change it for the high/full/low case as well
for consistency.
N.B. USB 3.2 Gen N x 2 allows for up to 1500mA but there doesn't
seem to be any any peripheral controller supported by Linux that
does two lane operation, so for now keeping the clamp at 900
should be fine.
Signed-off-by: Jack Pham <jackp@codeaurora.org>
commit c724417baf162bd3e035659e22cdf990cfb0d917 upstream.
SuperSpeedPlus peripherals must report their bMaxPower of the
configuration descriptor in units of 8mA as per the USB 3.2
specification. The current switch statement in encode_bMaxPower()
only checks for USB_SPEED_SUPER but not USB_SPEED_SUPER_PLUS so
the latter falls back to USB 2.0 encoding which uses 2mA units.
Replace the switch with a simple if/else.
Fixes: eae5820b852f ("usb: gadget: composite: Write SuperSpeedPlus config descriptors")
commit a3ae87dce3a5abe0b57c811bab02b2564b574106 upstream.
Intel Comet Lake based platform require the XHCI_PME_STUCK_QUIRK
quirk as well. Without this xHC can not enter D3 in runtime suspend.
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
Link: https://lore.kernel.org/r/20200210134553.9144-5-mathias.nyman@linux.intel.com
commit 8099f58f1ecddf4f374f4828a3dff8397c7cbd74 upstream.
Paul Zimmerman reports that his USB Bluetooth adapter sometimes
crashes following system resume, when it receives a
Get-Device-Descriptor request while it is busy doing something else.
Such a request was added by commit a4f55d8b8c14 ("usb: hub: Check
device descriptor before resusciation"). It gets sent when the hub
driver's work thread checks whether a connect-change event on an
enabled port really indicates a new device has been connected, as
opposed to an old device momentarily disconnecting and then
reconnecting (which can happen with xHCI host controllers, since they
automatically enable connected ports).
The same kind of thing occurs when a port's power session is lost
during system suspend. When the system wakes up it sees a
connect-change event on the port, and if the child device's
persist_enabled flag was set then hub_activate() sets the device's
reset_resume flag as well as the port's bit in hub->change_bits. The
reset-resume code then takes responsibility for checking that the same
device is still attached to the port, and it does this as part of the
device's resume pathway. By the time the hub driver's work thread
starts up again, the device has already been fully reinitialized and
is busy doing its own thing. There's no need for the work thread to
do the same check a second time, and in fact this unnecessary check is
what caused the problem that Paul observed.
Note that performing the unnecessary check is not actually a bug.
Devices are supposed to be able to send descriptors back to the host
even when they are busy doing something else. The underlying cause of
Paul's problem lies in his Bluetooth adapter. Nevertheless, we
shouldn't perform the same check twice in a row -- and as a nice side
benefit, removing the extra check allows the Bluetooth adapter to work
more reliably.
The work thread performs its check when it sees that the port's bit is
set in hub->change_bits. In this situation that bit is interpreted as
though a connect-change event had occurred on the port _after_ the
reset-resume, which is not what actually happened.
One possible fix would be to make the reset-resume code clear the
port's bit in hub->change_bits. But it seems simpler to just avoid
setting the bit during hub_activate() in the first place. That's what
this patch does.
(Proving that the patch is correct when CONFIG_PM is disabled requires
a little thought. In that setting hub_activate() will be called only
for initialization and resets, since there won't be any resumes or
reset-resumes. During initialization and hub resets the hub doesn't
have any child devices, and so this code path never gets executed.)
Reported-and-tested-by: Paul Zimmerman <pauldzim@gmail.com>
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Link: https://marc.info/?t=157949360700001&r=1&w=2
CC: David Heinzelmann <heinzelmann.david@gmail.com>
CC: <stable@vger.kernel.org>
Link: https://lore.kernel.org/r/Pine.LNX.4.44L0.2001311037460.1577-100000@iolanthe.rowland.org
commit b692056db8ecc7f452b934f016c17348282b7699 upstream.
Currently, the SourceControl will stay in power-down mode after resuming
from suspend. This patch resets the device after suspend to power it up.
Signed-off-by: Richard Dodd <richard.o.dodd@gmail.com>
Link: https://lore.kernel.org/r/20200212142220.36892-1-richard.o.dodd@gmail.com
commit 3e99862c05a9caa5a27969f41566b428696f5a9a upstream.
When a uas disk is plugged into an external hub, uas_probe()
will be called by the hub thread to do the probe. It will
first create a SCSI host and then do the scan for this host.
During the scan, it will probe the LUN using SCSI INQUERY command
which will be packed in the URB and submitted to uas disk.
There might be a chance that this external hub with uas disk
attached is unplugged during the scan. In this case, uas driver
will fail to submit the URB (due to the NOTATTACHED state of uas
device) and try to put this SCSI command back to request queue
waiting for next chance to run.
In normal case, this cycle will terminate when hub thread gets
disconnection event and calls into uas_disconnect() accordingly.
But in this case, uas_disconnect() will not be called because
hub thread of external hub gets stuck waiting for the completion
of this SCSI command. A deadlock happened.
In this fix, uas will call scsi_scan_host() asynchronously to
avoid the blocking of hub thread.
Signed-off-by: EJ Hsu <ejh@nvidia.com>
Acked-by: Oliver Neukum <oneukum@suse.com>
Link: https://lore.kernel.org/r/20200130092506.102760-1-ejh@nvidia.com
commit f148b9f402ef002b57bcff3964d45abc8ffb6c3f upstream.
A Full-speed bulk USB audio device (DJ-Tech CTRL) with a invalid Maximum
Packet Size of 4 causes a xHC "Parameter Error" at enumeration.
This is because valid Maximum packet sizes for Full-speed bulk endpoints
are 8, 16, 32 and 64 bytes. Hosts are not required to support other values
than these. See usb 2 specs section 5.8.3 for details.
The device starts working after forcing the maximum packet size to 8.
This is most likely the case with other devices as well, so force the
maximum packet size to a valid range.
Reported-by: Rene D Obermueller <cmdrrdo@gmail.com>
Link: https://lore.kernel.org/r/20200210134553.9144-2-mathias.nyman@linux.intel.com
[ Upstream commit 91b6dec32e5c25fbdbb564d1e5af23764ec17ef1 ]
We currently have musb_set_vbus() called from two different paths. Mostly
it gets called from the USB PHY via omap_musb_set_mailbox(), but in some
cases it can get also called from musb_stage0_irq() rather via .set_vbus:
(musb_set_host [musb_hdrc])
(omap2430_musb_set_vbus [omap2430])
(musb_stage0_irq [musb_hdrc])
(musb_interrupt [musb_hdrc])
(omap2430_musb_interrupt [omap2430])
This is racy and will not work with introducing generic helper functions
for musb_set_host() and musb_set_peripheral(). We want to get rid of the
busy loops in favor of usleep_range().
Let's just get rid of .set_vbus for omap2430 glue layer and let the PHY
code handle VBUS with musb_set_vbus(). Note that in the follow-up patch
we can completely remove omap2430_musb_set_vbus(), but let's do it in a
separate patch as this change may actually turn out to be needed as a
fix.
Reported-by: Pavel Machek <pavel@ucw.cz>
Acked-by: Pavel Machek <pavel@ucw.cz>
Link: https://lore.kernel.org/r/20200115132547.364-5-b-liu@ti.com
[ Upstream commit 9c1ed62ae0690dfe5d5e31d8f70e70a95cb48e52 ]
The driver may sleep while holding a spinlock.
The function call path (from bottom to top) in Linux 4.19 is:
drivers/usb/gadget/udc/core.c, 1175:
kzalloc(GFP_KERNEL) in usb_add_gadget_udc_release
drivers/usb/gadget/udc/core.c, 1272:
usb_add_gadget_udc_release in usb_add_gadget_udc
drivers/usb/gadget/udc/gr_udc.c, 2186:
usb_add_gadget_udc in gr_probe
drivers/usb/gadget/udc/gr_udc.c, 2183:
spin_lock in gr_probe
drivers/usb/gadget/udc/core.c, 1195:
mutex_lock in usb_add_gadget_udc_release
drivers/usb/gadget/udc/gr_udc.c, 212:
debugfs_create_file in gr_probe
drivers/usb/gadget/udc/gr_udc.c, 2197:
gr_dfs_create in gr_probe
drivers/usb/gadget/udc/gr_udc.c, 2114:
devm_request_threaded_irq in gr_request_irq
drivers/usb/gadget/udc/gr_udc.c, 2202:
gr_request_irq in gr_probe
kzalloc(GFP_KERNEL), mutex_lock(), debugfs_create_file() and
devm_request_threaded_irq() can sleep at runtime.
To fix these possible bugs, usb_add_gadget_udc(), gr_dfs_create() and
gr_request_irq() are called without handling the spinlock.
These bugs are found by a static analysis tool STCheck written by myself.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
commit d710562e01c48d59be3f60d58b7a85958b39aeda upstream.
Currently ecm->notify_req is used to flag when a request is in-flight.
ecm->notify_req is set to NULL and when a request completes it is
subsequently reset.
This is fundamentally buggy in that the unbind logic of the ECM driver will
unconditionally free ecm->notify_req leading to a NULL pointer dereference.
Fixes: da741b8c56d6 ("usb ethernet gadget: split CDC Ethernet function")
Signed-off-by: Bryan O'Donoghue <bryan.odonoghue@linaro.org>
commit 5b24c28cfe136597dc3913e1c00b119307a20c7e upstream.
Currently ncm->notify_req is used to flag when a request is in-flight.
ncm->notify_req is set to NULL and when a request completes it is
subsequently reset.
This is fundamentally buggy in that the unbind logic of the NCM driver will
unconditionally free ncm->notify_req leading to a NULL pointer dereference.
Fixes: 40d133d7f542 ("usb: gadget: f_ncm: convert to new function interface with backward compatibility")
commit 463f67aec2837f981b0a0ce8617721ff59685c00 upstream.
These interfaces do support super-speed so let's not
limit maximum speed to high-speed.
Cc: <stable@vger.kernel.org>
[ Upstream commit 09ed259fac621634d51cd986aa8d65f035662658 ]
VBUS should be turned off when leaving the host mode.
Set GCTL_PRTCAP to device mode in teardown to de-assert DRVVBUS pin to
turn off VBUS power.
Fixes: 5f94adfeed97 ("usb: dwc3: core: refactor mode initialization to its own function")
[ Upstream commit bc3bdb12bbb3492067c8719011576370e959a2e6 ]
Steve Ellis reported incorrect block sizes and alignement
offsets with a SATA enclosure. Adding a quirk to disable
UAS fixes the problems.
Reported-by: Steven Ellis <sellis@redhat.com>
Cc: Pacho Ramos <pachoramos@gmail.com>
Signed-off-by: Laura Abbott <labbott@fedoraproject.org>
commit 38c0d5bdf4973f9f5a888166e9d3e9ed0d32057a upstream.
Commit f4a4cbb2047e ("USB: ir-usb: reimplement using generic framework")
switched to using the generic write implementation which may combine
multiple write requests into larger transfers. This can break the IrLAP
protocol where end-of-frame is determined using the USB short packet
mechanism, for example, if multiple frames are sent in rapid succession.
Fixes: f4a4cbb2047e ("USB: ir-usb: reimplement using generic framework")
Cc: stable <stable@vger.kernel.org> # 2.6.35
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit 17a0184ca17e288decdca8b2841531e34d49285f upstream.
Commit e0d795e4f36c ("usb: irda: cleanup on ir-usb module") added a USB
IrDA header with common defines, but mistakingly switched to using the
class-descriptor baud-rate bitmask values for the outbound header.
This broke link-speed handling for rates above 9600 baud, but a device
would also be able to operate at the default 9600 baud until a
link-speed request was issued (e.g. using the TCGETS ioctl).
Fixes: e0d795e4f36c ("usb: irda: cleanup on ir-usb module")
Cc: stable <stable@vger.kernel.org> # 2.6.27
Cc: Felipe Balbi <balbi@kernel.org>
commit 2988a8ae7476fe9535ab620320790d1714bdad1d upstream.
Add missing endpoint sanity check to avoid dereferencing a NULL-pointer
on open() in case a device lacks a bulk-out endpoint.
Note that prior to commit f4a4cbb2047e ("USB: ir-usb: reimplement using
generic framework") the oops would instead happen on open() if the
device lacked a bulk-in endpoint and on write() if it lacked a bulk-out
endpoint.
[ Upstream commit 6269e4c76eacabaea0d0099200ae1a455768d208 ]
Don't do extra cpu_to_le32 conversion for
put_unaligned_le32 because it is already implemented
in this function.
Fixes sparse error:
xhci-hub.c:1152:44: warning: incorrect type in argument 1 (different base types)
xhci-hub.c:1152:44: expected unsigned int [usertype] val
xhci-hub.c:1152:44: got restricted __le32 [usertype]
Fixes: 395f540 "xhci: support new USB 3.1 hub request to get extended port status"
Cc: Mathias Nyman <mathias.nyman@linux.intel.com>
Signed-off-by: Ruslan Bilovol <ruslan.bilovol@gmail.com>
Link: https://lore.kernel.org/r/1562501839-26522-1-git-send-email-ruslan.bilovol@gmail.com
[ Upstream commit 2100e3ca3676e894fa48b8f6f01d01733387fe81 ]
The dependency to ensure this driver links correctly fails since
it can not be a loadable module:
drivers/usb/phy/phy-fsl-usb.o: In function `fsl_otg_set_peripheral':
phy-fsl-usb.c:(.text+0x2224): undefined reference to `usb_gadget_vbus_disconnect'
Make the option 'tristate' so it can work correctly.
Fixes: 5a8d651a2bde ("usb: gadget: move gadget API functions to udc-core")
[ Upstream commit 0742a338f5b3446a26de551ad8273fb41b2787f2 ]
'rv' is the correct return value, pass it upstream instead of 0
Fixes: 17d80d562fd7 ("USB: autosuspend for cdc-wdm")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ Upstream commit 5895d311d28f2605e2f71c1a3e043ed38f3ac9d2 ]
In remove(), use cancel_delayed_work_sync() to cancel the
delayed work. Otherwise there's a chance that this work
will continue to run until after the device has been removed.
This issue was detected with the help of Coccinelle.
Cc: Tony Lindgren <tony@atomide.com>
Cc: Bin Liu <b-liu@ti.com>
Fixes: b6a619a883c3 ("usb: phy: Check initial state for twl6030")
Signed-off-by: Sven Van Asbroeck <TheSven73@gmail.com>
[ Upstream commit 3018dd3fa114b13261e9599ddb5656ef97a1fa17 ]
Check for NULL port data in the control URB completion handlers to avoid
dereferencing a NULL pointer in the unlikely case where a port device
isn't bound to a driver (e.g. after an allocation failure on port
probe()).
Fixes: 0ca1268e109a ("USB Serial Keyspan: add support for USA-49WG & USA-28XG")
[ Upstream commit e37d1aeda737a20b1846a91a3da3f8b0f00cf690 ]
Check for NULL port data in the shared interrupt and bulk completion
callbacks to avoid dereferencing a NULL pointer in case a device sends
data for a port device which isn't bound to a driver (e.g. due to a
malicious device having unexpected endpoints or after an allocation
failure on port probe).
[ Upstream commit dd1fae527612543e560e84f2eba4f6ef2006ac55 ]
The USB completion callback does not disable interrupts while acquiring
the lock. We want to remove the local_irq_disable() invocation from
__usb_hcd_giveback_urb() and therefore it is required for the callback
handler to disable the interrupts while acquiring the lock.
The callback may be invoked either in IRQ or BH context depending on the
USB host controller.
Use the _irqsave() variant of the locking primitives.
Signed-off-by: John Ogness <john.ogness@linutronix.de>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
commit 9c06ac4c83df6d6fbdbf7488fbad822b4002ba19 upstream.
If hub_activate() is called before D+ has stabilized after remote
wakeup, the following situation might occur:
__ ___________________
D+ __/ \__/
Hub _______________________________
Host _____v__|___|___________|______
| | | \-- Interrupt Transfer (*3)
| | \-- ClearPortFeature (*2)
| \-- GetPortStatus (*1)
\-- Host detects remote wakeup
- D+ goes high, Host starts running by remote wakeup
- D+ is not stable, goes low
- Host requests GetPortStatus at (*1) and gets the following hub status:
- Current Connect Status bit is 0
- Connect Status Change bit is 1
- D+ stabilizes, goes high
- Host requests ClearPortFeature and thus Connect Status Change bit is
cleared at (*2)
- After waiting 100 ms, Host starts the Interrupt Transfer at (*3)
- Since the Connect Status Change bit is 0, Hub returns NAK.
In this case, port_event() is not called in hub_event() and Host cannot
recognize device. To solve this issue, flag change_bits even if only
Connect Status Change bit is 1 when got in the first GetPortStatus.
This issue occurs rarely because it only if D+ changes during a very
short time between GetPortStatus and ClearPortFeature. However, it is
fatal if it occurs in embedded system.
Signed-off-by: Keiya Nobuta <nobuta.keiya@fujitsu.com>
Link: https://lore.kernel.org/r/20200109051448.28150-1-nobuta.keiya@fujitsu.com
commit 9715a43eea77e42678a1002623f2d9a78f5b81a1 upstream.
Check for NULL port data in the modem- and line-status handlers to avoid
probe).
Note that the other (stubbed) event handlers qt2_process_xmit_empty()
and qt2_process_flush() would need similar sanity checks in case they
are ever implemented.
Fixes: f7a33e608d9a ("USB: serial: add quatech2 usb to serial driver")
Cc: stable <stable@vger.kernel.org> # 3.5
commit 1568c58d11a7c851bd09341aeefd6a1c308ac40d upstream.
The driver receives the active port number from the device, but never
made sure that the port number was valid. This could lead to a
NULL-pointer dereference or memory corruption in case a device sends
data for an invalid port.
commit 4d5ef53f75c22d28f490bcc5c771fcc610a9afa4 upstream.
Check for NULL port data in reset_resume() to avoid dereferencing a NULL
pointer in case the port device isn't bound to a driver (e.g. after a
failed control request at port probe).
Fixes: 1ded7ea47b88 ("USB: ch341 serial: fix port number changed after resume")
Cc: stable <stable@vger.kernel.org> # 2.6.30
