git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-linus
Felipe writes:
usb: fixes for v5.0-rc4
Dwc3 got a fix for cases when gadget driver queue an OUT request of
length 0; this is a case that has been overlooked for quite some time
now.
Exynos' dwc3 glue layer got a fix on the error path for those cases
where clk_prepare_enable() fails.
TI's AM335x PHY driver got a fix for a race condition during
probe. This race happened because driver was powering off the PHY only
after adding the PHY handle to the framework. The result is that we
could fall into a situation where user of the PHY (MUSB) could call
phy_init() before phy driver's probe() called phy_poweroff() which
would result in a powered off PHY after phy_init() was called.
The old net2272 driver got a fix for an erroneous use of bitwise
negation.
* tag 'fixes-for-v5.0-rc4' of git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb:
usb: phy: am335x: fix race condition in _probe
usb: dwc3: exynos: Fix error handling of clk_prepare_enable
usb: phy: fix link errors
usb: gadget: udc: net2272: Fix bitwise and boolean operations
usb: dwc3: gadget: Handle 0 xfer length for OUT EP
Handling short packets (length < max packet size) in the Inventra DMA
engine in the MUSB driver causes the MUSB DMA controller to hang. An
example of a problem that is caused by this problem is when streaming
video out of a UVC gadget, only the first video frame is transferred.
For short packets (mode-0 or mode-1 DMA), MUSB_TXCSR_TXPKTRDY must be
set manually by the driver. This was previously done in musb_g_tx
(musb_gadget.c), but incorrectly (all csr flags were cleared, and only
MUSB_TXCSR_MODE and MUSB_TXCSR_TXPKTRDY were set). Fixing that problem
allows some requests to be transferred correctly, but multiple requests
were often put together in one USB packet, and caused problems if the
packet size was not a multiple of 4. Instead, set MUSB_TXCSR_TXPKTRDY
in dma_controller_irq (musbhsdma.c), just like host mode transfers.
This topic was originally tackled by Nicolas Boichat [0] [1] and is
discussed further at [2] as part of his GSoC project [3].
[0] https://groups.google.com/forum/?hl=en#!topic/beagleboard-gsoc/k8Azwfp75CU
[1] https://gitorious.org/beagleboard-usbsniffer/beagleboard-usbsniffer-kernel/commit/b0be3b6cc195ba732189b04f1d43ec843c3e54c9?p=beagleboard-usbsniffer:beagleboard-usbsniffer-kernel.git;a=patch;h=b0be3b6cc195ba732189b04f1d43ec843c3e54c9
[2] http://beagleboard-usbsniffer.blogspot.com/2010/07/musb-isochronous-transfers-fixed.html
[3] http://elinux.org/BeagleBoard/GSoC/USBSniffer
Fixes: 550a7375fe72 ("USB: Add MUSB and TUSB support")
Signed-off-by: Paul Elder <paul.elder@ideasonboard.com>
Signed-off-by: Bin Liu <b-liu@ti.com>
Cc: stable <stable@vger.kernel.org>
power off the phy should be done before populate the phy. Otherwise,
am335x_init() could be called by the phy owner to power on the phy first,
then am335x_phy_probe() turns off the phy again without the caller knowing
it.
Fixes: 2fc711d76352 ("usb: phy: am335x: Enable USB remote wakeup using PHY wakeup")
Cc: stable@vger.kernel.org # v3.18+
Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com>
If clk_prepare_enable() fails in dwc3_exynos_probe() or in
dwc3_exynos_resume(), exynos->clks[0] is left undisabled
because of usage preincrement in while condition.
Found by Linux Driver Verification project (linuxtesting.org).
Fixes: 9f2168367a0a ("usb: dwc3: exynos: Rework clock handling and prepare for new variants")
Acked-by: Marek Szyprowski <m.szyprowski@samsung.com>
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Fix link errors when CONFIG_FSL_USB2_OTG is enabled and USB_OTG_FSM is
set to module then the following link error occurs.
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_ioctl':
drivers/usb/phy/phy-fsl-usb.c:1083: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:1083:(.text+0x574): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_start_srp':
drivers/usb/phy/phy-fsl-usb.c:674: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:674:(.text+0x61c): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_set_host':
drivers/usb/phy/phy-fsl-usb.c:593: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:593:(.text+0x7a4): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_start_hnp':
drivers/usb/phy/phy-fsl-usb.c:695: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:695:(.text+0x858): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `a_wait_enum':
drivers/usb/phy/phy-fsl-usb.c:274: undefined reference to `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.c:274:(.text+0x16f0): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o:drivers/usb/phy/phy-fsl-usb.c:619: more undefined references to `otg_statemachine' follow
aarch64-linux-gnu-ld: drivers/usb/phy/phy-fsl-usb.o: in function `fsl_otg_set_peripheral':
drivers/usb/phy/phy-fsl-usb.c:619:(.text+0x1fa0): relocation truncated to fit: R_AARCH64_CALL26 against undefined symbol `otg_statemachine'
make[1]: *** [Makefile:1020: vmlinux] Error 1
make[1]: Target 'Image' not remade because of errors.
make: *** [Makefile:152: sub-make] Error 2
make: Target 'Image' not remade because of errors.
Rework so that FSL_USB2_OTG depends on that the USB_OTG_FSM is builtin.
Signed-off-by: Anders Roxell <anders.roxell@linaro.org>
(!x & y) strikes again.
Fix bitwise and boolean operations by enclosing the expression:
intcsr & (1 << NET2272_PCI_IRQ)
in parentheses, before applying the boolean operator '!'.
Notice that this code has been there since 2011. So, it would
be helpful if someone can double-check this.
This issue was detected with the help of Coccinelle.
Fixes: ceb80363b2ec ("USB: net2272: driver for PLX NET2272 USB device controller")
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
For OUT endpoints, zero-length transfers require MaxPacketSize buffer as
per the DWC_usb3 programming guide 3.30a section 4.2.3.3.
This patch fixes this by explicitly checking zero length
transfer to correctly pad up to MaxPacketSize.
Fixes: c6267a51639b ("usb: dwc3: gadget: align transfers to wMaxPacketSize")
Signed-off-by: Tejas Joglekar <joglekar@synopsys.com>
https://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial into usb-linus
Johan writes:
USB-serial fixes for 5.0-rc3
Here's a fix for the new ftdi gpio support, which failed to take
autosuspend into account, and a patch adding missing SPDX identifiers to
the keyspan headers.
Included are also some new device ids.
All but the SPDX patch have been in linux-next with no reported issues.
Signed-off-by: Johan Hovold <johan@kernel.org>
* tag 'usb-serial-5.0-rc3' of https://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial:
USB: serial: keyspan_usa: add proper SPDX lines for .h files
USB: serial: pl2303: add new PID to support PL2303TB
USB: serial: ftdi_sio: fix GPIO not working in autosuspend
USB: serial: simple: add Motorola Tetra TPG2200 device id
The keyspan_usa??msg.h files are under a BSD-3 style license, so
properly label them as such with a SPDX line at the top of the file.
This fixes autoloading the module by the OF compatible string.
Fixes: 813e18b18a87 ("USB: EHCI: ehci-mv: add DT support")
Signed-off-by: Lubomir Rintel <lkundrak@v3.sk>
The patch "usb: simplify usbport trigger" together with "leds: triggers:
add device attribute support" caused an regression for the usbport
trigger. it will no longer enumerate any active usb hub ports under the
"ports" directory in the sysfs class directory, if the usb host drivers
are fully initialized before the usbport trigger was loaded.
The reason is that the usbport driver tries to register the sysfs
entries during the activate() callback. And this will fail with -2 /
ENOENT because the patch "leds: triggers: add device attribute support"
made it so that the sysfs "ports" group was only being added after the
activate() callback succeeded.
This version of the patch reverts parts of the "usb: simplify usbport
trigger" patch and restores usbport trigger's functionality.
Fixes: 6f7b0bad8839 ("usb: simplify usbport trigger")
Signed-off-by: Christian Lamparter <chunkeey@gmail.com>
Acked-by: Jacek Anaszewski <jacek.anaszewski@gmail.com>
During the static checker, "data->usbmisc_data" may be NULL.
Fix it by adding this pointer judgement before using.
Reported-by: Dan Carpenter <dan.carpenter@oracle.com>
Signed-off-by: Peter Chen <peter.chen@nxp.com>
The README file ni the drivers/usb/usbip/ directory is not needed
anymore, so just delete it.
Cc: Valentina Manea <valentina.manea.m@gmail.com>
Acked-by: Shuah Khan <shuah@kernel.org>
Add new PID to support PL2303TB (TYPE_HX)
Signed-off-by: Charles Yeh <charlesyeh522@gmail.com>
To clear GINTSTS2_WKUP_ALERT_INT bit in GINTSTS2 register
require to write 1. This bit is implemented as "Write to clear".
Fixes: 187c5298a122 ("usb: dwc2: gadget: Add handler for WkupAlert interrupt")
Signed-off-by: Minas Harutyunyan <hminas@synopsys.com>
There is a bug in the current GPIO code for ftdi_sio: it failed to take USB
autosuspend into account. If the device is in autosuspend, calls to
usb_control_msg() fail with -EHOSTUNREACH. Because the standard value for
autosuspend timeout is usually 2-5 seconds, this made it almost impossible
to use the GPIOs on machines that have USB autosuspend enabled. This patch
fixes the issue by acquiring a PM lock on the device for the duration of
the USB transfers. Tested on an FT231X device.
Signed-off-by: Karoly Pados <pados@pados.hu>
[ johan: simplify code somewhat ]
Fixes: ba93cc7da896 ("USB: serial: ftdi_sio: implement GPIO support for FT-X devices")
Cc: stable <stable@vger.kernel.org> # 4.20
The source_sink_alloc_func() function is supposed to return error
pointers on error. The function is called from usb_get_function() which
doesn't check for NULL returns so it would result in an Oops.
Of course, in the current kernel, small allocations always succeed so
this doesn't affect runtime.
Currently the link_state is uninitialized and the default value is 0(U0)
before the first time we start the udc, and after we start the udc then
stop the udc, the link_state will be undefined.
We may have the following warnings if we start the udc again with
an undefined link_state:
WARNING: CPU: 0 PID: 327 at drivers/usb/dwc3/gadget.c:294 dwc3_send_gadget_ep_cmd+0x304/0x308
dwc3 100e0000.hidwc3_0: wakeup failed --> -22
Call Trace:
[<c010f270>] (unwind_backtrace) from [<c010b3d8>] (show_stack+0x10/0x14)
[<c010b3d8>] (show_stack) from [<c034a4dc>] (dump_stack+0x84/0x98)
[<c034a4dc>] (dump_stack) from [<c0118000>] (__warn+0xe8/0x100)
[<c0118000>] (__warn) from [<c0118050>](warn_slowpath_fmt+0x38/0x48)
[<c0118050>] (warn_slowpath_fmt) from [<c0442ec0>](dwc3_send_gadget_ep_cmd+0x304/0x308)
[<c0442ec0>] (dwc3_send_gadget_ep_cmd) from [<c0445e68>](dwc3_ep0_start_trans+0x48/0xf4)
[<c0445e68>] (dwc3_ep0_start_trans) from [<c0446750>](dwc3_ep0_out_start+0x64/0x80)
[<c0446750>] (dwc3_ep0_out_start) from [<c04451c0>](__dwc3_gadget_start+0x1e0/0x278)
[<c04451c0>] (__dwc3_gadget_start) from [<c04452e0>](dwc3_gadget_start+0x88/0x10c)
[<c04452e0>] (dwc3_gadget_start) from [<c045ee54>](udc_bind_to_driver+0x88/0xbc)
[<c045ee54>] (udc_bind_to_driver) from [<c045f29c>](usb_gadget_probe_driver+0xf8/0x140)
[<c045f29c>] (usb_gadget_probe_driver) from [<bf005424>](gadget_dev_desc_UDC_store+0xac/0xc4 [libcomposite])
[<bf005424>] (gadget_dev_desc_UDC_store [libcomposite]) from[<c023d8e0>] (configfs_write_file+0xd4/0x160)
[<c023d8e0>] (configfs_write_file) from [<c01d51e8>] (__vfs_write+0x1c/0x114)
[<c01d51e8>] (__vfs_write) from [<c01d5ff4>] (vfs_write+0xa4/0x168)
[<c01d5ff4>] (vfs_write) from [<c01d6d40>] (SyS_write+0x3c/0x90)
[<c01d6d40>] (SyS_write) from [<c0107400>] (ret_fast_syscall+0x0/0x3c)
Signed-off-by: Zeng Tao <prime.zeng@hisilicon.com>
OUT endpoint requests may somtimes have this flag set when
preparing to be submitted to HW indicating that there is an
additional TRB chained to the request for alignment purposes.
If that request is removed before the controller can execute the
transfer (e.g. ep_dequeue/ep_disable), the request will not go
through the dwc3_gadget_ep_cleanup_completed_request() handler
and will not have its needs_extra_trb flag cleared when
dwc3_gadget_giveback() is called. This same request could be
later requeued for a new transfer that does not require an
extra TRB and if it is successfully completed, the cleanup
and TRB reclamation will incorrectly process the additional TRB
which belongs to the next request, and incorrectly advances the
TRB dequeue pointer, thereby messing up calculation of the next
requeust's actual/remaining count when it completes.
The right thing to do here is to ensure that the flag is cleared
before it is given back to the function driver. A good place
to do that is in dwc3_gadget_del_and_unmap_request().
Signed-off-by: Jack Pham <jackp@codeaurora.org>
We see dwc3 endpoint stopped by unwanted irq during
suspend resume test, which is caused dwc3 ep can't be started
with error "No Resource".
Here, add synchronize_irq before suspend to sync the
pending IRQ handlers complete.
Signed-off-by: Bo He <bo.he@intel.com>
Signed-off-by: Yu Wang <yu.y.wang@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB fixes from Greg KH:
"Here are some small USB driver fixes and quirk updates for 5.0-rc2.
The majority here are some quirks for some storage devices to get them
to work properly. There's also a fix here to resolve the reported
issues with some audio devices that say they are UAC3 compliant, but
really are not.
And a fix up for the MAINTAINERS file to remove a dead url.
All have been in linux-next with no reported issues"
* tag 'usb-5.0-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb:
usb: storage: Remove outdated URL from MAINTAINERS
USB: Add USB_QUIRK_DELAY_CTRL_MSG quirk for Corsair K70 RGB
usbcore: Select only first configuration for non-UAC3 compliant devices
USB: storage: add quirk for SMI SM3350
USB: storage: don't insert sane sense for SPC3+ when bad sense specified
usb: cdc-acm: send ZLP for Telit 3G Intel based modems
We already need to zero out memory for dma_alloc_coherent(), as such
using dma_zalloc_coherent() is superflous. Phase it out.
This change was generated with the following Coccinelle SmPL patch:
@ replace_dma_zalloc_coherent @
expression dev, size, data, handle, flags;
-dma_zalloc_coherent(dev, size, handle, flags)
+dma_alloc_coherent(dev, size, handle, flags)
Suggested-by: Christoph Hellwig <hch@lst.de>
Signed-off-by: Luis Chamberlain <mcgrof@kernel.org>
[hch: re-ran the script on the latest tree]
To match the Corsair Strafe RGB, the Corsair K70 RGB also requires
USB_QUIRK_DELAY_CTRL_MSG to completely resolve boot connection issues
discussed here: https://github.com/ckb-next/ckb-next/issues/42.
Otherwise roughly 1 in 10 boots the keyboard will fail to be detected.
Patch that applied delay control quirk for Corsair Strafe RGB:
cb88a0588717 ("usb: quirks: add control message delay for 1b1c:1b20")
Previous K70 RGB patch to add delay-init quirk:
7a1646d92257 ("Add delay-init quirk for Corsair K70 RGB keyboards")
Signed-off-by: Jack Stocker <jackstocker.93@gmail.com>
In most of the UAC1 and UAC2 audio devices, the first
configuration is most often the best configuration.
However, with recent patch to support UAC3 configuration,
second configuration was unintentionally chosen for
some of the UAC1/2 devices that had more than one
configuration. This was because of the existing check
after the audio config check which selected any config
which had a non-vendor class. This patch fixes this issue.
Fixes: f13912d3f014 ("usbcore: Select UAC3 configuration for audio if present")
Reported-by: Con Kolivas <kernel@kolivas.org>
Signed-off-by: Saranya Gopal <saranya.gopal@intel.com>
Tested-by: Con Kolivas <kernel@kolivas.org>
The SMI SM3350 USB-UFS bridge controller cannot handle long sense request
correctly and will make the chip refuse to do read/write when requested
long sense.
Add a bad sense quirk for it.
Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Currently the code will set US_FL_SANE_SENSE flag unconditionally if
device claims SPC3+, however we should allow US_FL_BAD_SENSE flag to
prevent this behavior, because SMI SM3350 UFS-USB bridge controller,
which claims SPC4, will show strange behavior with 96-byte sense
(put the chip into a wrong state that cannot read/write anything).
Check the presence of US_FL_BAD_SENSE when assuming US_FL_SANE_SENSE on
SPC4+ devices.
Telit 3G Intel based modems require zero packet to be sent if
out data size is equal to the endpoint max packet size.
Signed-off-by: Daniele Palmas <dnlplm@gmail.com>
Add new Motorola Tetra device id for Motorola Solutions TETRA PEI device
T: Bus=02 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 4 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=0cad ProdID=9016 Rev=24.16
S: Manufacturer=Motorola Solutions, Inc.
S: Product=TETRA PEI interface
C: #Ifs= 2 Cfg#= 1 Atr=80 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=usb_serial_simple
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=usb_serial_simple
Signed-off-by: Max Schulze <max.schulze@posteo.de>
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci
Pull PCI updates from Bjorn Helgaas:
- Remove unused lists from ASPM pcie_link_state (Frederick Lawler)
- Fix Broadcom CNB20LE host bridge unintended sign extension (Colin Ian
King)
- Expand Kconfig "PF" acronyms (Randy Dunlap)
- Update MAINTAINERS for arch/x86/kernel/early-quirks.c (Bjorn Helgaas)
- Add missing include to drivers/pci.h (Alexandru Gagniuc)
- Override Synopsys USB 3.x HAPS device class so dwc3-haps can claim it
instead of xhci (Thinh Nguyen)
- Clean up P2PDMA documentation (Randy Dunlap)
- Allow runtime PM even if driver doesn't supply callbacks (Jarkko
Nikula)
- Remove status check after submitting Switchtec MRPC Firmware Download
commands to avoid Completion Timeouts (Kelvin Cao)
- Set Switchtec coherent DMA mask to allow 64-bit DMA (Boris Glimcher)
- Fix Switchtec SWITCHTEC_IOCTL_EVENT_IDX_ALL flag overwrite issue
(Joey Zhang)
- Enable write combining for Switchtec MRPC Input buffers (Kelvin Cao)
- Add Switchtec MRPC DMA mode support (Wesley Sheng)
- Skip VF scanning on powerpc, which does this in firmware (Sebastian
Ott)
- Add Amlogic Meson PCIe controller driver and DT bindings (Yue Wang)
- Constify histb dw_pcie_host_ops structure (Julia Lawall)
- Support multiple power domains for imx6 (Leonard Crestez)
- Constify layerscape driver data (Stefan Agner)
- Update imx6 Kconfig to allow imx6 PCIe in imx7 kernel (Trent Piepho)
- Support armada8k GPIO reset (Baruch Siach)
- Support suspend/resume support on imx6 (Leonard Crestez)
- Don't hard-code DesignWare DBI/ATU offst (Stephen Warren)
- Skip i.MX6 PHY setup on i.MX7D (Andrey Smirnov)
- Remove Jianguo Sun from HiSilicon STB maintainers (Lorenzo Pieralisi)
- Mask DesignWare interrupts instead of disabling them to avoid lost
interrupts (Marc Zyngier)
- Add locking when acking DesignWare interrupts (Marc Zyngier)
- Ack DesignWare interrupts in the proper callbacks (Marc Zyngier)
- Use devm resource parser in mediatek (Honghui Zhang)
- Remove unused mediatek "num-lanes" DT property (Honghui Zhang)
- Add UniPhier PCIe controller driver and DT bindings (Kunihiko
Hayashi)
- Enable MSI for imx6 downstream components (Richard Zhu)
* tag 'pci-v4.21-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (40 commits)
PCI: imx: Enable MSI from downstream components
s390/pci: skip VF scanning
PCI/IOV: Add flag so platforms can skip VF scanning
PCI/IOV: Factor out sriov_add_vfs()
PCI: uniphier: Add UniPhier PCIe host controller support
dt-bindings: PCI: Add UniPhier PCIe host controller description
PCI: amlogic: Add the Amlogic Meson PCIe controller driver
dt-bindings: PCI: meson: add DT bindings for Amlogic Meson PCIe controller
arm64: dts: mt7622: Remove un-used property for PCIe
arm: dts: mt7623: Remove un-used property for PCIe
dt-bindings: PCI: MediaTek: Remove un-used property
PCI: mediatek: Remove un-used variant in struct mtk_pcie_port
MAINTAINERS: Remove Jianguo Sun from HiSilicon STB DWC entry
PCI: dwc: Don't hard-code DBI/ATU offset
PCI: imx: Add imx6sx suspend/resume support
PCI: armada8k: Add support for gpio controlled reset signal
PCI: dwc: Adjust Kconfig to allow IMX6 PCIe host on IMX7
PCI: dwc: layerscape: Constify driver data
PCI: imx: Add multi-pd support
PCI: Override Synopsys USB 3.x HAPS device class
Nobody has actually used the type (VERIFY_READ vs VERIFY_WRITE) argument
of the user address range verification function since we got rid of the
old racy i386-only code to walk page tables by hand.
It existed because the original 80386 would not honor the write protect
bit when in kernel mode, so you had to do COW by hand before doing any
user access. But we haven't supported that in a long time, and these
days the 'type' argument is a purely historical artifact.
A discussion about extending 'user_access_begin()' to do the range
checking resulted this patch, because there is no way we're going to
move the old VERIFY_xyz interface to that model. And it's best done at
the end of the merge window when I've done most of my merges, so let's
just get this done once and for all.
This patch was mostly done with a sed-script, with manual fix-ups for
the cases that weren't of the trivial 'access_ok(VERIFY_xyz' form.
There were a couple of notable cases:
- csky still had the old "verify_area()" name as an alias.
- the iter_iov code had magical hardcoded knowledge of the actual
values of VERIFY_{READ,WRITE} (not that they mattered, since nothing
really used it)
- microblaze used the type argument for a debug printout
but other than those oddities this should be a total no-op patch.
I tried to fix up all architectures, did fairly extensive grepping for
access_ok() uses, and the changes are trivial, but I may have missed
something. Any missed conversion should be trivially fixable, though.
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu
Pull IOMMU updates from Joerg Roedel:
- Page table code for AMD IOMMU now supports large pages where smaller
page-sizes were mapped before. VFIO had to work around that in the
past and I included a patch to remove it (acked by Alex Williamson)
- Patches to unmodularize a couple of IOMMU drivers that would never
work as modules anyway.
- Work to unify the the iommu-related pointers in 'struct device' into
one pointer. This work is not finished yet, but will probably be in
the next cycle.
- NUMA aware allocation in iommu-dma code
- Support for r8a774a1 and r8a774c0 in the Renesas IOMMU driver
- Scalable mode support for the Intel VT-d driver
- PM runtime improvements for the ARM-SMMU driver
- Support for the QCOM-SMMUv2 IOMMU hardware from Qualcom
- Various smaller fixes and improvements
* tag 'iommu-updates-v4.21' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: (78 commits)
iommu: Check for iommu_ops == NULL in iommu_probe_device()
ACPI/IORT: Don't call iommu_ops->add_device directly
iommu/of: Don't call iommu_ops->add_device directly
iommu: Consolitate ->add/remove_device() calls
iommu/sysfs: Rename iommu_release_device()
dmaengine: sh: rcar-dmac: Use device_iommu_mapped()
xhci: Use device_iommu_mapped()
powerpc/iommu: Use device_iommu_mapped()
ACPI/IORT: Use device_iommu_mapped()
iommu/of: Use device_iommu_mapped()
driver core: Introduce device_iommu_mapped() function
iommu/tegra: Use helper functions to access dev->iommu_fwspec
iommu/qcom: Use helper functions to access dev->iommu_fwspec
iommu/of: Use helper functions to access dev->iommu_fwspec
iommu/mediatek: Use helper functions to access dev->iommu_fwspec
iommu/ipmmu-vmsa: Use helper functions to access dev->iommu_fwspec
iommu/dma: Use helper functions to access dev->iommu_fwspec
iommu/arm-smmu: Use helper functions to access dev->iommu_fwspec
ACPI/IORT: Use helper functions to access dev->iommu_fwspec
iommu: Introduce wrappers around dev->iommu_fwspec
Pull USB/PHY updates from Greg KH:
"Here is the big set of USB and PHY driver patches for 4.21-rc1.
All of the usual bits are in here:
- loads of USB gadget driver updates and additions
- new device ids
- phy driver updates
- xhci reworks and new features
- typec updates
Full details are in the shortlog.
All of these have been in linux-next for a long time with no reported
issues"
* tag 'usb-4.21-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (142 commits)
USB: serial: option: add Fibocom NL678 series
cdc-acm: fix abnormal DATA RX issue for Mediatek Preloader.
usb: r8a66597: Fix a possible concurrency use-after-free bug in r8a66597_endpoint_disable()
usb: typec: tcpm: Extend the matching rules on PPS APDO selection
usb: typec: Improve Alt Mode documentation
usb: musb: dsps: fix runtime pm for peripheral mode
usb: musb: dsps: fix otg state machine
USB: serial: pl2303: add ids for Hewlett-Packard HP POS pole displays
usb: renesas_usbhs: add support for RZ/G2E
usb: ehci-omap: Fix deferred probe for phy handling
usb: roles: Add a description for the class to Kconfig
usb: renesas_usbhs: mark PM functions as __maybe_unused
usb: core: Remove unnecessary memset()
usb: host: isp1362-hcd: convert to DEFINE_SHOW_ATTRIBUTE
phy: qcom-qmp: Expose provided clocks to DT
dt-bindings: phy-qcom-qmp: Move #clock-cells to child
phy: qcom-qmp: Utilize fully-specified DT registers
dt-bindings: phy-qcom-qmp: Fix register underspecification
phy: ti: fix semicolon.cocci warnings
phy: dphy: Add configuration helpers
Pull SCSI updates from James Bottomley:
"This is mostly update of the usual drivers: smarpqi, lpfc, qedi,
megaraid_sas, libsas, zfcp, mpt3sas, hisi_sas.
Additionally, we have a pile of annotation, unused variable and minor
updates.
The big API change is the updates for Christoph's DMA rework which
include removing the DISABLE_CLUSTERING flag.
And finally there are a couple of target tree updates"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (259 commits)
scsi: isci: request: mark expected switch fall-through
scsi: isci: remote_node_context: mark expected switch fall-throughs
scsi: isci: remote_device: Mark expected switch fall-throughs
scsi: isci: phy: Mark expected switch fall-through
scsi: iscsi: Capture iscsi debug messages using tracepoints
scsi: myrb: Mark expected switch fall-throughs
scsi: megaraid: fix out-of-bound array accesses
scsi: mpt3sas: mpt3sas_scsih: Mark expected switch fall-through
scsi: fcoe: remove set but not used variable 'port'
scsi: smartpqi: call pqi_free_interrupts() in pqi_shutdown()
scsi: smartpqi: fix build warnings
scsi: smartpqi: update driver version
scsi: smartpqi: add ofa support
scsi: smartpqi: increase fw status register read timeout
scsi: smartpqi: bump driver version
scsi: smartpqi: add smp_utils support
scsi: smartpqi: correct lun reset issues
scsi: smartpqi: correct volume status
scsi: smartpqi: do not offline disks for transient did no connect conditions
scsi: smartpqi: allow for larger raid maps
git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6
Pull crypto updates from Herbert Xu:
"API:
- Add 1472-byte test to tcrypt for IPsec
- Reintroduced crypto stats interface with numerous changes
- Support incremental algorithm dumps
Algorithms:
- Add xchacha12/20
- Add nhpoly1305
- Add adiantum
- Add streebog hash
- Mark cts(cbc(aes)) as FIPS allowed
Drivers:
- Improve performance of arm64/chacha20
- Improve performance of x86/chacha20
- Add NEON-accelerated nhpoly1305
- Add SSE2 accelerated nhpoly1305
- Add AVX2 accelerated nhpoly1305
- Add support for 192/256-bit keys in gcmaes AVX
- Add SG support in gcmaes AVX
- ESN for inline IPsec tx in chcr
- Add support for CryptoCell 703 in ccree
- Add support for CryptoCell 713 in ccree
- Add SM4 support in ccree
- Add SM3 support in ccree
- Add support for chacha20 in caam/qi2
- Add support for chacha20 + poly1305 in caam/jr
- Add support for chacha20 + poly1305 in caam/qi2
- Add AEAD cipher support in cavium/nitrox"
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (130 commits)
crypto: skcipher - remove remnants of internal IV generators
crypto: cavium/nitrox - Fix build with !CONFIG_DEBUG_FS
crypto: salsa20-generic - don't unnecessarily use atomic walk
crypto: skcipher - add might_sleep() to skcipher_walk_virt()
crypto: x86/chacha - avoid sleeping under kernel_fpu_begin()
crypto: cavium/nitrox - Added AEAD cipher support
crypto: mxc-scc - fix build warnings on ARM64
crypto: api - document missing stats member
crypto: user - remove unused dump functions
crypto: chelsio - Fix wrong error counter increments
crypto: chelsio - Reset counters on cxgb4 Detach
crypto: chelsio - Handle PCI shutdown event
crypto: chelsio - cleanup:send addr as value in function argument
crypto: chelsio - Use same value for both channel in single WR
crypto: chelsio - Swap location of AAD and IV sent in WR
crypto: chelsio - remove set but not used variable 'kctx_len'
crypto: ux500 - Use proper enum in hash_set_dma_transfer
crypto: ux500 - Use proper enum in cryp_set_dma_transfer
crypto: aesni - Add scatter/gather avx stubs, and use them in C
crypto: aesni - Introduce partial block macro
Pull networking updates from David Miller:
1) New ipset extensions for matching on destination MAC addresses, from
Stefano Brivio.
2) Add ipv4 ttl and tos, plus ipv6 flow label and hop limit offloads to
nfp driver. From Stefano Brivio.
3) Implement GRO for plain UDP sockets, from Paolo Abeni.
4) Lots of work from Michał Mirosław to eliminate the VLAN_TAG_PRESENT
bit so that we could support the entire vlan_tci value.
5) Rework the IPSEC policy lookups to better optimize more usecases,
from Florian Westphal.
6) Infrastructure changes eliminating direct manipulation of SKB lists
wherever possible, and to always use the appropriate SKB list
helpers. This work is still ongoing...
7) Lots of PHY driver and state machine improvements and
simplifications, from Heiner Kallweit.
8) Various TSO deferral refinements, from Eric Dumazet.
9) Add ntuple filter support to aquantia driver, from Dmitry Bogdanov.
10) Batch dropping of XDP packets in tuntap, from Jason Wang.
11) Lots of cleanups and improvements to the r8169 driver from Heiner
Kallweit, including support for ->xmit_more. This driver has been
getting some much needed love since he started working on it.
12) Lots of new forwarding selftests from Petr Machata.
13) Enable VXLAN learning in mlxsw driver, from Ido Schimmel.
14) Packed ring support for virtio, from Tiwei Bie.
15) Add new Aquantia AQtion USB driver, from Dmitry Bezrukov.
16) Add XDP support to dpaa2-eth driver, from Ioana Ciocoi Radulescu.
17) Implement coalescing on TCP backlog queue, from Eric Dumazet.
18) Implement carrier change in tun driver, from Nicolas Dichtel.
19) Support msg_zerocopy in UDP, from Willem de Bruijn.
20) Significantly improve garbage collection of neighbor objects when
the table has many PERMANENT entries, from David Ahern.
21) Remove egdev usage from nfp and mlx5, and remove the facility
completely from the tree as it no longer has any users. From Oz
Shlomo and others.
22) Add a NETDEV_PRE_CHANGEADDR so that drivers can veto the change and
therefore abort the operation before the commit phase (which is the
NETDEV_CHANGEADDR event). From Petr Machata.
23) Add indirect call wrappers to avoid retpoline overhead, and use them
in the GRO code paths. From Paolo Abeni.
24) Add support for netlink FDB get operations, from Roopa Prabhu.
25) Support bloom filter in mlxsw driver, from Nir Dotan.
26) Add SKB extension infrastructure. This consolidates the handling of
the auxiliary SKB data used by IPSEC and bridge netfilter, and is
designed to support the needs to MPTCP which could be integrated in
the future.
27) Lots of XDP TX optimizations in mlx5 from Tariq Toukan.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1845 commits)
net: dccp: fix kernel crash on module load
drivers/net: appletalk/cops: remove redundant if statement and mask
bnx2x: Fix NULL pointer dereference in bnx2x_del_all_vlans() on some hw
net/net_namespace: Check the return value of register_pernet_subsys()
net/netlink_compat: Fix a missing check of nla_parse_nested
ieee802154: lowpan_header_create check must check daddr
net/mlx4_core: drop useless LIST_HEAD
mlxsw: spectrum: drop useless LIST_HEAD
net/mlx5e: drop useless LIST_HEAD
iptunnel: Set tun_flags in the iptunnel_metadata_reply from src
net/mlx5e: fix semicolon.cocci warnings
staging: octeon: fix build failure with XFRM enabled
net: Revert recent Spectre-v1 patches.
can: af_can: Fix Spectre v1 vulnerability
packet: validate address length if non-zero
nfc: af_nfc: Fix Spectre v1 vulnerability
phonet: af_phonet: Fix Spectre v1 vulnerability
net: core: Fix Spectre v1 vulnerability
net: minor cleanup in skb_ext_add()
net: drop the unused helper skb_ext_get()
git://git.infradead.org/linux-platform-drivers-x86
Pull x86 platform driver updates from Andy Shevchenko:
- The USB Power Delivery discrete components now can be enumerated by
i2c-multi-instantiate driver via several resources under single ACPI
device node (ACPI ID is INT3515).
- Touchscreen support is added for the Mediacom Flexbook Edge 11.
- Mellanox driver got fixed due to updates in their firmware.
- The power management stub driver for AtomISP v2 is fixed in order to
support Intel Baytrail SoCs where same quirk is needed for S0ix to
work.
- Special key handling has been fixed for Favorites hotkey on Thinkpad,
and Screen LOCK on ASUS.
- Ideapad Yoga 2 13 has no HW rfkill switch, thus, driver has been
updated to support this.
- Few cleanups related to debugfs have been made in Intel IPS and Intel
PMC drivers. Besides that Intel PMC has been extended to show more
detailed information about Latency Tolerance
* tag 'platform-drivers-x86-v4.21-1' of git://git.infradead.org/linux-platform-drivers-x86: (41 commits)
platform/x86: mlx-platform: Convert to use SPDX identifier
Documentation/ABI: Add new attribute for mlxreg-io sysfs interfaces
platform/x86: mlx-platform: Allow mlxreg-io driver activation for new systems
platform/x86: mlx-platform: Fix LED configuration
platform/x86: mlx-platform: Fix tachometer registers
platform/x86: mlx-platform: Rename new systems product names
platform/x86: mlx-platform: Add definitions for new registers
platform/x86: intel_telemetry: convert to DEFINE_SHOW_ATTRIBUTE
platform/x86: intel_pmc_core: convert to DEFINE_SHOW_ATTRIBUTE
platform/x86: thinkpad_acpi: Cleanup quirks macros
platform/x86: touchscreen_dmi: Add info for the Mediacom Flexbook Edge 11
platform/x86: Fix config space access for intel_atomisp2_pm
platform/x86: Add the VLV ISP PCI ID to atomisp2_pm
platform/x86: intel_ips: Convert to use DEFINE_SHOW_ATTRIBUTE macro
platform/x86: intel_ips: Remove never happen condition
platform/x86: intel_ips: NULL check before some freeing functions is not needed
platform/x86: intel_ips: remove unnecessary checks in ips_debugfs_init
iio: inv_mpu6050: Use i2c_acpi_get_i2c_resource() helper
ACPI / scan: Create platform device for INT3515 ACPI nodes
platform/x86: i2c-multi-instantiate: Allow to have same slaves
Added USB serial option driver support for Fibocom NL678 series cellular
module: VID 2cb7 and PIDs 0x0104 and 0x0105.
Reserved network and ADB interfaces.
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
P: Vendor=2cb7 ProdID=0104 Rev=03.10
S: Manufacturer=Fibocom
S: Product=Fibocom NL678-E Modem
S: SerialNumber=12345678
C: #Ifs= 6 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
I: If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
I: If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=qmi_wwan
I: If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=42 Prot=01 Driver=(none)
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 3 Spd=480 MxCh= 0
P: Vendor=2cb7 ProdID=0105 Rev=03.10
C: #Ifs= 7 Cfg#= 1 Atr=a0 MxPwr=500mA
I: If#= 4 Alt= 0 #EPs= 1 Cls=02(commc) Sub=06 Prot=00 Driver=cdc_ether
I: If#= 5 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=00 Driver=cdc_ether
I: If#= 6 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=42 Prot=01 Driver=(none)
Signed-off-by: Jörgen Storvist <jorgen.storvist@gmail.com>
Acked-by: Johan Hovold <johan@kernel.org>
We need the USB changes in here for additional patches to be able to
apply cleanly.
https://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial into usb-next
Johan writes:
USB-serial updates for 4.21-rc1
Here are the USB-serial updates for 4.21-rc1, including:
- support for mos7840 3-port devices
- improved ftdi baud-rate divisor calculations
- support for a new class of f81534 devices
Included are also various clean ups and some new pl2303 device ids.
All have been in linux-next with no reported issues.
* tag 'usb-serial-4.21-rc1' of https://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial:
USB: serial: mos7840: remove set but not used variables 'number, serial'
USB: serial: mos7840: add a product ID for the new product
USB: serial: mos7840: clean up register handling
USB: serial: ftdi_sio: use rounding when calculating baud rate divisors
USB: serial: f81534: fix reading old/new IC config
USB: serial: mos7840: remove set but not used variables 'st, data1, iflag'
USB: serial: quatech2: remove set but not used variable 'port_priv'
Lots of conflicts, by happily all cases of overlapping
changes, parallel adds, things of that nature.
Thanks to Stephen Rothwell, Saeed Mahameed, and others
for their guidance in these resolutions.
Mediatek Preloader is a proprietary embedded boot loader for loading
Little Kernel and Linux into device DRAM.
This boot loader also handle firmware update. Mediatek Preloader will be
enumerated as a virtual COM port when the device is connected to Windows
or Linux OS via CDC-ACM class driver. When the USB enumeration has been
done, Mediatek Preloader will send out handshake command "READY" to PC
actively instead of waiting command from the download tool.
Since Linux 4.12, the commit "tty: reset termios state on device
registration" (93857edd9829e144acb6c7e72d593f6e01aead66) causes Mediatek
Preloader receiving some abnoraml command like "READYXX" as it sent.
This will be recognized as an incorrect response. The behavior change
also causes the download handshake fail. This change only affects
subsequent connects if the reconnected device happens to get the same minor
number.
By disabling the ECHO termios flag could avoid this problem. However, it
cannot be done by user space configuration when download tool open
/dev/ttyACM0. This is because the device running Mediatek Preloader will
send handshake command "READY" immediately once the CDC-ACM driver is
ready.
This patch wants to fix above problem by introducing "DISABLE_ECHO"
property in driver_info. When Mediatek Preloader is connected, the
CDC-ACM driver could disable ECHO flag in termios to avoid the problem.
Signed-off-by: Macpaul Lin <macpaul.lin@mediatek.com>
Reviewed-by: Johan Hovold <johan@kernel.org>
Acked-by: Oliver Neukum <oneukum@suse.com>
'arm/omap', 'arm/smmu', 'x86/vt-d', 'x86/amd' and 'core' into next
The function r8a66597_endpoint_disable() and r8a66597_urb_enqueue() may
be concurrently executed.
The two functions both access a possible shared variable "hep->hcpriv".
This shared variable is freed by r8a66597_endpoint_disable() via the
call path:
kfree(hep->hcpriv) (line 1995 in Linux-4.19)
This variable is read by r8a66597_urb_enqueue() via the call path:
spin_lock_irqsave(&r8a66597->lock)
init_pipe_info
enable_r8a66597_pipe
pipe = hep->hcpriv (line 802 in Linux-4.19)
The read operation is protected by a spinlock, but the free operation
is not protected by this spinlock, thus a concurrency use-after-free bug
may occur.
To fix this bug, the spin-lock and spin-unlock function calls in
r8a66597_endpoint_disable() are moved to protect the free operation.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Current matching rules ensure that the voltage range of selected Source
Capability is entirely within the range defined in one of the Sink
Capabilities. This is reasonable but not practical because Sink may not
support wide range of voltage when sinking power while Source could
advertise its capabilities in relatively wider range. For example, a
Source PDO advertising 3.3V-11V@3A (9V Prog of Fixed Nominal Voltage)
will not be selected if the Sink requires 5V-12V@3A PPS power. However,
the Sink could work well if the requested voltage range in RDOs is
5V-11V@3A.
Currently accepted:
|--------- source -----|
|----------- sink ---------------|
Currently not accepted:
|--------- source -----------------|
|------ sink -------|
To improve the usability, change the matching rules to what listed
below:
a. The Source PDO is selectable if any portion of the voltage range
overlaps one of the Sink PDO's voltage range.
b. The maximum operational voltage will be the lower one between the
selected Source PDO and the matching Sink PDO.
c. The maximum power will be the maximum operational voltage times the
maximum current defined in the selected Source PDO
d. Select the Source PDO with the highest maximum power
Signed-off-by: Kyle Tso <kyletso@google.com>
Acked-by: Adam Thomson <Adam.Thomson.Opensource@diasemi.com>
Reviewed-by: Heikki Krogerus <heikki.krogerus@linux.intel.com>
The same effects can be achieved by setting the dma_boundary to
PAGE_SIZE - 1 and the max_segment_size to PAGE_SIZE, so shift those
settings into the drivers. Note that in many cases the setting might
be bogus, but this keeps the status quo.
[mkp: fix myrs and myrb]
Most SCSI drivers want to enable "clustering", that is merging of
segments so that they might span more than a single page. Remove the
ENABLE_CLUSTERING define, and require drivers to explicitly set
DISABLE_CLUSTERING to disable this feature.
A few drivers were not setting the use_clustering flag at all and thus
default to disable. Fix them up to explicitly set this field in
preparation for additional cleanups.
Since the runtime PM support was added in musb, dsps relies on the timer
calling otg_timer() to activate the usb subsystem. However the driver
doesn't enable the timer for peripheral port, then the peripheral port is
unable to be enumerated by a host if the other usb port is disabled or in
peripheral mode too.
So let's start the timer for peripheral port too.
Fixes: ea2f35c01d5e ("usb: musb: Fix sleeping function called from invalid context for hdrc glue")
Due to lack of ID pin interrupt event on AM335x devices, the musb dsps
driver uses polling to detect usb device attach for dual-role port.
But in the case if a micro-A cable adapter is attached without a USB device
attached to the cable, the musb state machine gets stuck in a_wait_vrise
state waiting for the MUSB_CONNECT interrupt which won't happen due to the
usb device is not attached. The state is stuck in a_wait_vrise even after
the micro-A cable is detached, which could cause VBUS retention if then the
dual-role port is attached to a host port.
To fix the problem, make a_wait_vrise as a transient state, then move the
state to either a_wait_bcon for host port or a_idle state for dual-role
port, if no usb device is attached to the port.
Add device ids to pl2303 for the HP POS pole displays:
LM920: 03f0:026b
TD620: 03f0:0956
LD960TA: 03f0:4439
LD220TA: 03f0:4349
LM940: 03f0:5039
Signed-off-by: Scott Chen <scott@labau.com.tw>
