commit 35a2fbc941accd0e9f1bfadd669311786118d874 upstream.
Add product id for Abbott strip port cable for Precision meter which
uses the TI 3410 chip.
Signed-off-by: Anders Hammarquist <iko@iko.pp.se>
commit a816e3113b63753c330ca4751ea1d208e93e3015 upstream.
Pointers should not be compared to plain integers.
Quiets the sparse warning:
warning: Using plain integer as NULL pointer
Signed-off-by: Ying Xue <ying.xue@windriver.com>
Cc: Lotfi Manseur <lotfi.manseur@gmail.com>
commit a26f009a070e840fadacb91013b2391ba7ab6cc2 upstream.
The register access to enable hardware flow control depends on the
device port number and not the port minor number.
Signed-off-by: Johan Hovold <jhovold@gmail.com>
commit 849513a7809175420d353625b6f651d961e99d49 upstream.
The control and bulk-message timeouts are specified in milliseconds and
should not depend on HZ.
commit 72ea18a558ed7a63a50bb121ba60d73b5b38ae30 upstream.
The read_mos_reg function is called with stack-allocated buffers, which
must not be used for control messages.
commit fdc03438f53a00294ed9939eb3a1f6db6f3d8963 upstream.
This patch reverts commit 3e619d04159be54b3daa0b7036b0ce9e067f4b5d
(USB: EHCI: fix bug in scheduling periodic split transfers). The
commit was valid -- it fixed a real bug -- but the periodic scheduler
in ehci-hcd is in such bad shape (especially the part that handles
split transactions) that fixing one bug is very likely to cause
another to surface. That's what happened in this case; the result was
choppy and noisy playback on certain 24-bit audio devices.
The only real fix will be to rewrite this entire section of code. My
next project...
This fixes https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1136110.
Thanks to Tim Richardson for extra testing and feedback, and to Joseph
Salisbury and Tyson Tan for tracking down the original source of the
problem.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
CC: Joseph Salisbury <joseph.salisbury@canonical.com>
CC: Tim Richardson <tim@tim-richardson.net>
commit 5f8e2c07d75967ee49a5da1d21ddf5f50d48cda0 upstream.
The first and second interrupt-in urbs are swapped for some Treo/Kyocera
devices, but the urb context was never updated with the new port.
commit 9eecf22d2b375b9064a20421c6c307b760b03d46 upstream.
When configuring the port (e.g. set_termios) the port minor number
rather than the port number was used in the request (and they only
coincide for minor number 0).
commit 6529591e3eef65f0f528a81ac169f6e294b947a7 upstream.
The patch adds a new HIDCOM device and does not affect other devices
driven by the cypress_M8 module. Changes are:
- add VendorID ProductID to device tables
- skip unstable speed check because FRWD uses 115200bps
- skip reset at probe which is an issue workaround for this
particular device.
Signed-off-by: Robert Butora <robert.butora.fi@gmail.com>
commit 420021a395ce38b7ab2cceb52dee4038be7d8fa3 upstream.
Fix regression introduced by commit 214916f2e ("USB: visor: reimplement
using generic framework") which broke initialisation of Treo/Kyocera
devices that re-mapped bulk-in endpoints.
commit 634371911730a462626071065b64cd6e1fe213e0 upstream.
The control-message timeout is specified in milliseconds and should not
depend on HZ.
commit a07088098a650267b2eda689538133a324b9523f upstream.
The outcont_endpoints array was indexed using the port minor number
(which can be greater than the array size) rather than the device port
number.
commit 6c13ff68a7ce01da7a51b44241a7aad8eaaedde7 upstream.
The bulk-message timeout is specified in milliseconds and should not
depend on HZ.
commit 88696ae432ce7321540ac53d9caab3de9118b094 upstream.
If for whatever reason we fall into fail path in xhci_mem_init()
before bw table gets initialized we may access the uninitialized lists
in xhci_mem_cleanup().
Check for bw table before traversing lists in cleanup routine.
This patch should be backported to kernels as old as 3.2, that contain
the commit 839c817ce67178ca3c7c7ad534c571bba1e69ebe "xhci: Store
information about roothubs and TTs."
Reported-by: Sergey Dyasly <dserrg@gmail.com>
Tested-by: Sergey Dyasly <dserrg@gmail.com>
Signed-off-by: Vladimir Murzin <murzin.v@gmail.com>
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
commit 331de00a64e5027365145bdf51da27b9ce15dfd5 upstream.
It is possible that we fail on xhci_mem_init, just before doing
the INIT_LIST_HEAD, and calling xhci_mem_cleanup.
Problem is that, the list_for_each_entry_safe macro, assumes
list heads are initialized (not NULL), and dereferences their 'next'
pointer, causing a kernel panic if this is not yet initialized.
Let's protect from that by moving inits to the beginning.
contain the commit 9574323c39d1f8359a04843075d89c9f32d8b7e6 "xHCI: test
USB2 software LPM".
Signed-off-by: Sergio Aguirre <sergio.a.aguirre.rodriguez@intel.com>
Acked-by: David Cohen <david.a.cohen@intel.com>
commit 77df9e0b799b03e1d5d9c68062709af5f637e834 upstream.
Commit 71c731a2 (usb: host: xhci: Fix Compliance Mode on SN65LVPE502CP
Hardware) was a workaround for systems using the SN65LVPE502CP,
controller, but it introduced a bug in resume from hibernate.
The fix created a timer, comp_mode_recovery_timer, which is deleted from
a timer list when xhci_suspend() is called. However, the hibernate image,
including the timer list containing the comp_mode_recovery_timer, had
already been saved before the timer was deleted.
Upon resume from hibernate, the list containing the comp_mode_recovery_timer
is restored from the image saved to disk, and xhci_resume(), assuming that
the timer had been deleted by xhci_suspend(), makes a call to
compliance_mode_recoery_timer_init(), which creates a new instance of the
comp_mode_recovery_timer and attempts to place it into the same list in which
it is already active, thus corrupting the list during the list_add() call.
At this point, a call trace is emitted indicating the list corruption.
Soon afterward, the system locks up, the watchdog times out, and the
ensuing NMI crashes the system.
The problem did not occur when resuming from suspend. In suspend, the
image in RAM remains exactly as it was when xhci_suspend() deleted the
comp_mode_recovery_timer, so there is no problem when xhci_resume()
creates a new instance of this timer and places it in the still empty
list.
This patch avoids the problem by deleting the timer in xhci_resume()
when resuming from hibernate. Now xhci_resume() can safely make the
call to create a new instance of this timer, whether returning from
suspend or hibernate.
Thanks to Alan Stern for his help with understanding the problem.
[Sarah reworked this patch to cover the case where the xHCI restore
register operation fails, and (temp & STS_SRE) is true (and we re-init
the host, including re-init for the compliance mode), but hibernate is
false. The original patch would have caused list corruption in this
case.]
contain the commit 71c731a296f1b08a3724bd1b514b64f1bda87a23 "usb: host:
xhci: Fix Compliance Mode on SN65LVPE502CP Hardware"
Signed-off-by: Tony Camuso <tcamuso@redhat.com>
Tested-by: Tony Camuso <tcamuso@redhat.com>
Acked-by: Don Zickus <dzickus@redhat.com>
commit b8a24e6281d37243c06b9497dcbfaa98c1e2ad35 upstream.
The mode used by Windows for the Huawei E1820 will use the
same ff/ff/ff class codes for both serial and network
functions.
Reported-by: Graham Inggs <graham.inggs@uct.ac.za>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
commit 1ee0a224bc9aad1de496c795f96bc6ba2c394811 upstream.
The tty is NULL when the port is hanging up.
chase_port() needs to check for this.
This patch is intended for stable series.
The behavior was observed and tested in Linux 3.2 and 3.7.1.
Johan Hovold submitted a more elaborate patch for the mainline kernel.
[ 56.277883] usb 1-1: edge_bulk_in_callback - nonzero read bulk status received: -84
[ 56.278811] usb 1-1: USB disconnect, device number 3
[ 56.278856] usb 1-1: edge_bulk_in_callback - stopping read!
[ 56.279562] BUG: unable to handle kernel NULL pointer dereference at 00000000000001c8
[ 56.280536] IP: [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35
[ 56.281212] PGD 1dc1b067 PUD 1e0f7067 PMD 0
[ 56.282085] Oops: 0002 [#1] SMP
[ 56.282744] Modules linked in:
[ 56.283512] CPU 1
[ 56.283512] Pid: 25, comm: khubd Not tainted 3.7.1 #1 innotek GmbH VirtualBox/VirtualBox
[ 56.283512] RIP: 0010:[<ffffffff8144e62a>] [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35
[ 56.283512] RSP: 0018:ffff88001fa99ab0 EFLAGS: 00010046
[ 56.283512] RAX: 0000000000000046 RBX: 00000000000001c8 RCX: 0000000000640064
[ 56.283512] RDX: 0000000000010000 RSI: ffff88001fa99b20 RDI: 00000000000001c8
[ 56.283512] RBP: ffff88001fa99b20 R08: 0000000000000000 R09: 0000000000000000
[ 56.283512] R10: 0000000000000000 R11: ffffffff812fcb4c R12: ffff88001ddf53c0
[ 56.283512] R13: 0000000000000000 R14: 00000000000001c8 R15: ffff88001e19b9f4
[ 56.283512] FS: 0000000000000000(0000) GS:ffff88001fd00000(0000) knlGS:0000000000000000
[ 56.283512] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
[ 56.283512] CR2: 00000000000001c8 CR3: 000000001dc51000 CR4: 00000000000006e0
[ 56.283512] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000
[ 56.283512] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400
[ 56.283512] Process khubd (pid: 25, threadinfo ffff88001fa98000, task ffff88001fa94f80)
[ 56.283512] Stack:
[ 56.283512] 0000000000000046 00000000000001c8 ffffffff810578ec ffffffff812fcb4c
[ 56.283512] ffff88001e19b980 0000000000002710 ffffffff812ffe81 0000000000000001
[ 56.283512] ffff88001fa94f80 0000000000000202 ffffffff00000001 0000000000000296
[ 56.283512] Call Trace:
[ 56.283512] [<ffffffff810578ec>] ? add_wait_queue+0x12/0x3c
[ 56.283512] [<ffffffff812fcb4c>] ? usb_serial_port_work+0x28/0x28
[ 56.283512] [<ffffffff812ffe81>] ? chase_port+0x84/0x2d6
[ 56.283512] [<ffffffff81063f27>] ? try_to_wake_up+0x199/0x199
[ 56.283512] [<ffffffff81263a5c>] ? tty_ldisc_hangup+0x222/0x298
[ 56.283512] [<ffffffff81300171>] ? edge_close+0x64/0x129
[ 56.283512] [<ffffffff810612f7>] ? __wake_up+0x35/0x46
[ 56.283512] [<ffffffff8106135b>] ? should_resched+0x5/0x23
[ 56.283512] [<ffffffff81264916>] ? tty_port_shutdown+0x39/0x44
[ 56.283512] [<ffffffff8125d38c>] ? __tty_hangup+0x307/0x351
[ 56.283512] [<ffffffff812e6ddc>] ? usb_hcd_flush_endpoint+0xde/0xed
[ 56.283512] [<ffffffff8144e625>] ? _raw_spin_lock_irqsave+0x14/0x35
[ 56.283512] [<ffffffff812fd361>] ? usb_serial_disconnect+0x57/0xc2
[ 56.283512] [<ffffffff812ea99b>] ? usb_unbind_interface+0x5c/0x131
[ 56.283512] [<ffffffff8128d738>] ? __device_release_driver+0x7f/0xd5
[ 56.283512] [<ffffffff8128d9cd>] ? device_release_driver+0x1a/0x25
[ 56.283512] [<ffffffff8128d393>] ? bus_remove_device+0xd2/0xe7
[ 56.283512] [<ffffffff8128b7a3>] ? device_del+0x119/0x167
[ 56.283512] [<ffffffff812e8d9d>] ? usb_disable_device+0x6a/0x180
[ 56.283512] [<ffffffff812e2ae0>] ? usb_disconnect+0x81/0xe6
[ 56.283512] [<ffffffff812e4435>] ? hub_thread+0x577/0xe82
[ 56.283512] [<ffffffff8144daa7>] ? __schedule+0x490/0x4be
[ 56.283512] [<ffffffff8105798f>] ? abort_exclusive_wait+0x79/0x79
[ 56.283512] [<ffffffff812e3ebe>] ? usb_remote_wakeup+0x2f/0x2f
[ 56.283512] [<ffffffff810570b4>] ? kthread+0x81/0x89
[ 56.283512] [<ffffffff81057033>] ? __kthread_parkme+0x5c/0x5c
[ 56.283512] [<ffffffff8145387c>] ? ret_from_fork+0x7c/0xb0
[ 56.283512] Code: 8b 7c 24 08 e8 17 0b c3 ff 48 8b 04 24 48 83 c4 10 c3 53 48 89 fb 41 50 e8 e0 0a c3 ff 48 89 04 24 e8 e7 0a c3 ff ba 00 00 01 00
<f0> 0f c1 13 48 8b 04 24 89 d1 c1 ea 10 66 39 d1 74 07 f3 90 66
[ 56.283512] RIP [<ffffffff8144e62a>] _raw_spin_lock_irqsave+0x19/0x35
[ 56.283512] RSP <ffff88001fa99ab0>
[ 56.283512] ---[ end trace 49714df27e1679ce ]---
Signed-off-by: Wolfgang Frisch <wfpub@roembden.net>
Cc: Johan Hovold <jhovold@gmail.com>
commit 997ff893603c6455da4c5e26ba1d0f81adfecdfc upstream.
HP's virtual UHCI host controller takes a long time to suspend
(several hundred microseconds), even when no devices are attached.
This provokes a warning message from uhci-hcd in the auto-stop case.
To prevent this from happening, this patch adds a test to avoid
performing an auto-stop when the wait_for_hp quirk flag is set. The
controller will still suspend through the normal runtime PM mechanism.
And since that pathway includes a 1-ms delay, the slowness of the
virtual hardware won't matter.
Reported-and-tested-by: ZhenHua <zhen-hual@hp.com>
commit e4f47e3675e6f1f40906b785b934ce963e9f2eb3 upstream.
This patch shortens the logic in xhci_endpoint_init() by moving common
calculations involving max_packet and max_burst outside the switch
statement, rather than repeating the same code in multiple
case-specific statements. It also replaces two usages of max_packet
which were clearly intended to be max_burst all along.
More importantly, it compensates for a common bug in high-speed bulk
endpoint descriptors. In many devices there is a bulk endpoint having
a wMaxPacketSize value smaller than 512, which is forbidden by the USB
spec. Some xHCI controllers can't handle this and refuse to accept
the endpoint. This patch changes the max_packet value to 512, which
allows the controller to use the endpoint properly.
In practice the bogus maxpacket size doesn't matter, because none of
the transfers sent via these endpoints are longer than the maxpacket
value anyway.
Reported-and-tested-by: "Aurélien Leblond" <blablack@gmail.com>
commit bac6b03275184c912ad0818c9a0a736847804dca upstream.
Werner Fink has reported problems with this hub.
Signed-off-by: Oliver Neukum <oliver@neukum.org>
commit 8ff10bdb14a52e3f25d4ce09e0582a8684c1a6db upstream.
/drivers/usb/serial/option.c: Blacklisted Cinterion's PLxx WWAN
Interface (USB Interface 4), because it will be handled by QMI WWAN
driver. Product IDs renamed.
Signed-off-by: Hans-Christoph Schemmel <hans-christoph.schemmel@gemalto.com>
commit 2a0ebf80aa95cc758d4725f74a7016e992606a39 upstream.
The value of "offd" comes off the instance->rcv_buf[] and we used it as
the offset into an array. The problem is that we check the upper bound
but not for negative values.
commit 7138143972b7c293267c783fc99a194f0ceff7f2 upstream.
Here are two more devices that use FTDI USB-to-serial chips with new product ID's.
The devices are the Newport Conex-AGP and Conex-CC motor controllers.
(http://www.newport.com/CONEX-AGP-Integrated-Piezo-Motor-Rotation-Stages-/987623/1033/info.aspx)
(http://www.newport.com/CONEX-CC-DC-Servo-Controller-Actuators/934114/1033/info.aspx)
usb-devices command yields:
P: Vendor=104d ProdID=3002 Rev=06.00
S: Manufacturer=Newport
S: Product=CONEX-CC
as well as
P: Vendor=104d ProdID=3006 Rev=06.00
S: Product=CONEX-AGP
Signed-off-by: Andrew Gomella <andrew.gomella@nih.gov>
commit 49c6e370dd6400b84897c4100095089b5c13a061 upstream.
A rebranded Novatel E371 for AT&T's LTE bands.
Signed-off-by: Dan Williams <dcbw@redhat.com>
commit 73c042df6e1bc50544842a04b777b36bbe3630e6 upstream.
Information from driver description files:
diag: VID_19D2&PID_0412&MI_00
nmea: VID_19D2&PID_0412&MI_01
at: VID_19D2&PID_0412&MI_02
modem: VID_19D2&PID_0412&MI_03
net: VID_19D2&PID_0412&MI_04
Signed-off-by: Teppo Kotilainen <qubit303@gmail.com>
commit a83d6755814e4614ba77e15d82796af0f695c6b8 upstream.
When a device attached to the roothub is suspended, the endpoint rings
are stopped. The host may generate a completion event with the
completion code set to 'Stopped' or 'Stopped Invalid' when the ring is
halted. The current xHCI code prints a warning in that case, which can
be really annoying if the USB device is coming into and out of suspend.
Remove the unnecessary warning.
Tested-by: Stephen Hemminger <stephen@networkplumber.org>
Cc: Luis Henriques <luis.henriques@canonical.com>
commit 671b4b2ba9266cbcfe7210a704e9ea487dcaa988 upstream.
Many cards based on CY7C68300A/B/C use the USB ID 04b4:6830 but only the
B and C variants (EZ-USB AT2LP) support the ATA Command Block
functionality, according to the data sheets. The A variant (EZ-USB AT2)
locks up if ATACB is attempted, until a typical 30 seconds timeout runs
out and a USB reset is performed.
https://bugs.launchpad.net/bugs/428469
It seems that one way to spot a CY7C68300A (at least where the card
manufacturer left Cypress' EEPROM default vaules, against Cypress'
recommendations) is to look at the USB string descriptor indices.
A http://media.digikey.com/pdf/Data%20Sheets/Cypress%20PDFs/CY7C68300A.pdf
B http://www.farnell.com/datasheets/43456.pdf
C http://www.cypress.com/?rID=14189
Note that a CY7C68300B/C chip appears as CY7C68300A if it is running
in Backward Compatibility Mode, and if ATACB would be supported in this
case there is anyway no way to tell which chip it really is.
For 5 years my external USB drive has been locking up for half a minute
when plugged in and ata_id is run by udev, or anytime hdparm or similar
is run on it.
Finally looking at the /correct/ datasheet I think I found the reason. I
am aware the quirk in this patch is a bit hacky, but the hardware
manufacturers haven't made it easy for us.
Signed-off-by: Tormod Volden <debian.tormod@gmail.com>
commit 1361bf4b9f9ef45e628a5b89e0fd9bedfdcb7104 upstream.
When usbfs receives a ctrl-request from userspace it calls check_ctrlrecip,
which for a request with USB_RECIP_ENDPOINT tries to map this to an interface
to see if this interface is claimed, except for ctrl-requests with a type of
USB_TYPE_VENDOR.
When trying to use this device: http://www.akaipro.com/eiepro
redirected to a Windows vm running on qemu on top of Linux.
The windows driver makes a ctrl-req with USB_TYPE_CLASS and
USB_RECIP_ENDPOINT with index 0, and the mapping of the endpoint (0) to
the interface fails since ep 0 is the ctrl endpoint and thus never is
part of an interface.
This patch fixes this ctrl-req failing by skipping the checkintf call for
USB_RECIP_ENDPOINT ctrl-reqs on the ctrl endpoint.
Reported-by: Dave Stikkolorum <d.r.stikkolorum@hhs.nl>
Tested-by: Dave Stikkolorum <d.r.stikkolorum@hhs.nl>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 9f06d15f8db6946e41f73196a122b84a37938878 upstream.
The current ST Micro Connect Lite uses the FT4232H hi-speed quad USB
UART FTDI chip. It is also possible to drive STM reference targets
populated with an on-board JTAG debugger based on the FT2232H chip with
the same STMicroelectronics tools.
For this reason, the ST Micro Connect Lite PIDs should be
ST_STMCLT_2232_PID: 0x3746
ST_STMCLT_4232_PID: 0x3747
Signed-off-by: Adrian Thomasset <adrian.thomasset@st.com>
commit 58f8b6c4fa5a13cb2ddb400e26e9e65766d71e38 upstream.
This patch add a missing usb device id for the GDMBoost V1.x device
The patch is against 3.9-rc5
Signed-off-by: Stefani Seibold <stefani@seibold.net>
commit e7d3b6e22c871ba36d052ca99bc8ceca4d546a60 upstream.
Add the Apple 24" LED Cinema display to the supported devices.
Signed-off-by: Ben Jencks <ben@bjencks.net>
commit a2a2d6c7f93e160b52a4ad0164db1f43f743ae0f upstream.
Adding support for a Mediatek based device labelled as
D-Link Model: DWM-156, H/W Ver: A7
Also adding two other device IDs found in the Debian(!)
packages included on the embedded device driver CD.
This is a composite MBIM + serial ports + card reader device:
T: Bus=04 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 14 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=2001 ProdID=7d01 Rev= 3.00
S: Manufacturer=D-Link,Inc
S: Product=D-Link DWM-156
C:* #Ifs= 7 Cfg#= 1 Atr=a0 MxPwr=500mA
A: FirstIf#= 0 IfCount= 2 Cls=02(comm.) Sub=0e Prot=00
I:* If#= 0 Alt= 0 #EPs= 1 Cls=02(comm.) Sub=0e Prot=00 Driver=cdc_mbim
E: Ad=88(I) Atr=03(Int.) MxPS= 64 Ivl=125us
I: If#= 1 Alt= 0 #EPs= 0 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
I:* If#= 1 Alt= 1 #EPs= 2 Cls=0a(data ) Sub=00 Prot=02 Driver=cdc_mbim
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=02 Prot=01 Driver=option
E: Ad=87(I) Atr=03(Int.) MxPS= 64 Ivl=500us
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=83(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 5 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=85(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 6 Alt= 0 #EPs= 2 Cls=08(stor.) Sub=06 Prot=50 Driver=usb-storage
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
commit d19bf5cedfd7d53854a3bd699c98b467b139833b upstream.
This adds PID for Olivetti Olicard 145 in option.c
Signed-off-by: Filippo Turato <nnj7585@gmail.com>
commit 511f3c5326eabe1ece35202a404c24c0aeacc246 upstream.
This patch (as1666) fixes a regression in the UDC core. The core
takes care of unbinding gadget drivers, and it does the unbinding
before telling the UDC driver to turn off the controller hardware.
When the call to the udc_stop callback is made, the gadget no longer
has a driver. The callback routine should not be invoked with a
pointer to the old driver; doing so can cause problems (such as
use-after-free accesses in net2280).
This patch should be applied, with appropriate context changes, to all
the stable kernels going back to 3.1.
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 1c11a172cb30492f5f6a82c6e118fdcd9946c34f upstream.
Use proper macro while extracting TRB transfer length from
Transfer event TRBs. Adding a macro EVENT_TRB_LEN (bits 0:23)
for the same, and use it instead of TRB_LEN (bits 0:16) in
case of event TRBs.
This patch should be backported to kernels as old as 2.6.31, that
contain the commit b10de142119a676552df3f0d2e3a9d647036c26a "USB: xhci:
Bulk transfer support". This patch will have issues applying to older
kernels.
Signed-off-by: Vivek gautam <gautam.vivek@samsung.com>
commit 482b0b5d82bd916cc0c55a2abf65bdc69023b843 upstream.
It enhances the driver for FTDI-based USB serial adapters
to recognize Mitsubishi Electric Corp. USB/RS422 Converters
as FT232BM chips and support them.
https://search.meau.com/?q=FX-USB-AW
Signed-off-by: Konstantin Holoborodko <klh.kernel@gmail.com>
Tested-by: Konstantin Holoborodko <klh.kernel@gmail.com>
commit 5492bf3d5655b4954164f69c02955a7fca267611 upstream.
Add missing get_icount field to two-port driver.
The two-port driver was not updated when switching to the new icount
interface in commit 0bca1b913aff ("tty: Convert the USB drivers to the
new icount interface").
commit 618aa1068df29c37a58045fe940f9106664153fd upstream.
Remove bogus disconnect test introduced by 95bef012e ("USB: more serial
drivers writing after disconnect") which prevented queued data from
being freed on disconnect.
The possible IO it was supposed to prevent is long gone.
commit d7971051e4df825e0bc11b995e87bfe86355b8e5 upstream.
Make sure the interface is not released before our serial device.
Note that drivers are still not allowed to access the interface in
any way that may interfere with another driver that may have gotten
bound to the same interface after disconnect returns.
commit cb25505fc604292c70fc02143fc102f54c8595f0 upstream.
Unregister tty device in disconnect as is required by the USB stack.
By deferring unregistration to when the last tty reference is dropped,
the parent interface device can get unregistered before the child
resulting in broken hotplug events being generated when the tty is
finally closed:
KERNEL[2290.798128] remove /devices/pci0000:00/0000:00:1d.7/usb2/2-1/2-1:3.1 (usb)
KERNEL[2290.804589] remove /devices/pci0000:00/0000:00:1d.7/usb2/2-1 (usb)
KERNEL[2294.554799] remove /2-1:3.1/tty/ttyACM0 (tty)
The driver must deal with tty callbacks after disconnect by checking the
disconnected flag. Specifically, further opens must be prevented and
this is already implemented.
Acked-by: Oliver Neukum <oneukum@suse.de>
Cc: Oliver Neukum <oneukum@suse.de>
commit 00eed9c814cb8f281be6f0f5d8f45025dc0a97eb upstream.
xhci has its own interrupt enabling routine, which will try to
use MSI-X/MSI if present. So the usb core shouldn't try to enable
legacy interrupts; on some machines the xhci legacy IRQ setting
is invalid.
v3: Be careful to not break XHCI_BROKEN_MSI workaround (by trenn)
Cc: Bjorn Helgaas <bhelgaas@google.com>
Cc: Thomas Renninger <trenn@suse.de>
Cc: Yinghai Lu <yinghai@kernel.org>
Cc: Frederik Himpe <fhimpe@vub.ac.be>
Cc: David Haerdeman <david@hardeman.nu>
Cc: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Reviewed-by: Thomas Renninger <trenn@suse.de>
Signed-off-by: Hannes Reinecke <hare@suse.de>
commit f8264340e694604863255cc0276491d17c402390 upstream.
According to XHCI specification (5.5.2.1) the IP is bit 0 and IE is bit 1
of IMAN register. Previously their definitions were reversed.
Even though there are no ill effects being observed from the swapped
definitions (because IMAN_IP is RW1C and in legacy PCI case we come in
with it already set to 1 so it was clearing itself even though we were
setting IMAN_IE instead of IMAN_IP), we should still correct the values.
This patch should be backported to kernels as old as 2.6.36, that
contain the commit 4e833c0b87a30798e67f06120cecebef6ee9644c "xhci: don't
re-enable IE constantly".
Signed-off-by: Dmitry Torokhov <dtor@vmware.com>
commit 29f86e66428ee083aec106cca1748dc63d98ce23 upstream.
Device stucks on filesystem writes, unless following quirk is passed:
echo 04e8:5136:m > /sys/module/usb_storage/parameters/quirks
Add corresponding entry to unusual_devs.h
Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru>
This reverts commit 0319f9909ce68a7516dfc8d53400e07168d281a8, which is commit
feca7746d5d9e84b105a613b7f3b6ad00d327372 upstream.
It shouldn't have gone into this stable release.
Cc: Joseph Salisbury <joseph.salisbury@canonical.com>
Cc: Stephen Thirlwall <sdt@dr.com>
commit feca7746d5d9e84b105a613b7f3b6ad00d327372 upstream.
This patch (as1661) fixes a rather obscure bug in ehci-hcd. In a
couple of places, the driver compares the DMA address stored in a QH's
overlay region with the address of a particular qTD, in order to see
whether that qTD is the one currently being processed by the hardware.
(If it is then the status in the QH's overlay region is more
up-to-date than the status in the qTD, and if it isn't then the
overlay's value needs to be adjusted when the QH is added back to the
active schedule.)
However, DMA address in the overlay region isn't always valid. It
sometimes will contain a stale value, which may happen by coincidence
to be equal to a qTD's DMA address. Instead of checking the DMA
address, we should check whether the overlay region is active and
valid. The patch tests the ACTIVE bit in the overlay, and clears this
bit when the overlay becomes invalid (which happens when the
currently-executing URB is unlinked).
This is the second part of a fix for the regression reported at:
https://bugs.launchpad.net/bugs/1088733
Reported-by: Joseph Salisbury <joseph.salisbury@canonical.com>
Reported-and-tested-by: Stephen Thirlwall <sdt@dr.com>
commit ab4b71644a26d1ab92b987b2fd30e17c25e89f85 upstream.
This reverts commit 200e0d99 ("USB: storage: optimize to match the
Huawei USB storage devices and support new switch command" and the
followup bugfix commit cd060956 ("USB: storage: properly handle
the endian issues of idProduct").
The commit effectively added a large number of Huawei devices to
the deprecated usb-storage mode switching logic. Many of these
devices have been in use and supported by the userspace
usb_modeswitch utility for years. Forcing the switching inside
the kernel causes a number of regressions as a result of ignoring
existing onfigurations, and also completely takes away the ability
to configure mode switching per device/system/user.
Known regressions caused by this:
- Some of the devices support multiple modes, using different
switching commands. There are existing configurations taking
advantage of this.
- There is a real use case for disabling mode switching and
instead mounting the exposed storage device. This becomes
impossible with switching logic inside the usb-storage driver.
- At least on device fail as a result of the usb-storage switching
command, becoming completely unswitchable. This is possibly a
firmware bug, but still a regression because the device work as
expected using usb_modeswitch defaults.
In-kernel mode switching was deprecated years ago with the
development of the more user friendly userspace alternatives. The
existing list of devices in usb-storage was only kept to prevent
breaking already working systems. The long term plan is to remove
the list, not to add to it. Ref:
http://permalink.gmane.org/gmane.linux.usb.general/28543
Cc: <fangxiaozhi@huawei.com>
commit a57e82a18779ab8a5e5a1f5841cef937cf578913 upstream.
The Rigblaster Advantage is an amateur radio interface sold by West Mountain
Radio. It contains a cp210x serial interface but the device ID is not in
the driver.
Signed-off-by: Steve Conklin <sconklin@canonical.com>
commit 1941138e1c024ecb5bd797d414928d3eb94d8662 upstream.
add support for Cinterion's products AH6 and PLS8 by adding Product IDs
and USB_DEVICE tuples.
Signed-off-by: Christian Schmiedl <christian.schmiedl@gemalto.com>
commit be3101c23394af59694c8a2aae6d07f5da62fea5 upstream.
This patch adds support for the Lake Shore Cryotronics devices to
the CP210x driver.
These lines are ported from cp210x driver distributed by Lake Shore web site:
http://www.lakeshore.com/Documents/Lake%20Shore%20cp210x-3.0.0.tar.gz
and licensed under the terms of GPLv2.
Moreover, I've tested this changes with Lake Shore 335 in my labs.
Signed-off-by: Matwey V. Kornilov <matwey@sai.msu.ru>
