Fix SATA drive failure on Ubuntu 9.10
BugLink: https://bugs.launchpad.net/bugs/431963
Signed-off-by: Dinh Nguyen <r00091@freescale.com>
When add usb gadget driver in OTG mode, cause nobody cared irq,
this pach disable usbintr in udc driver probe.
Signed-off-by: Li Jun <r65092@freescale.com>
1. If there is no usb devices connectted or all connectted usb
devices are in suspend state, usb host can suspend its whole bus,
then put the PHY into low power mode and close all usb clocks.
2. close all usb clocks for usb device low power mode.
(The patch is splitted 2 patches, this is FSL specific driver
part.)
(The patch is splitted 2 patches, this is common code part.)
Miss some configuration and wrong use put_unaligned_be32
Signed-off-by: Frank Li <Frank.Li@freescale.com>
Add remote wakeup feature for host mode.
Signed-off-by: Albert Chen <r65187@freescale.com>
When register platform driver in 2.6.31 kernal, suspend
and resume are not set for device driver.
The patch fix this issue by using platform driver's
suspend/resume rountine directly in otg driver.
MX233: Restructure the STMP378xxx USB Host and Gadget device structures
to be similar to MXC structures. Enable fsl_otg_arc driver to work on
MX233 platform. Remove FSL_USB2_DONT_REMAP requirement.
Signed-off-by: Dinh Nguyen <Dinh.Nguyen@freescale.com>
arch/arm/mach-stmp3xxx/Kconfig
arch/arm/mach-stmp3xxx/Makefile
arch/arm/mach-stmp3xxx/devices.c
arch/arm/mach-stmp3xxx/include/mach/stmp3xxx.h
arch/arm/mach-stmp3xxx/stmp378x_devb.c
USB will enter low power mode if no vbus power supply.
Only finished this feature in Mx37.
1. When enter low power mode, driver will close usb related clocks
as possible as could.
set usb IP to stop.
Set PHY to low power suspend by setting PHCD bit of portsc.
2. This patch doesn't support low power mode in OTG mode yet.
This is i.MX BSP 5.0.0 release ported to 2.6.31
Signed-off-by: Rob Herring <r.herring@freescale.com>
Signed-off-by: Alan Tull <r80115@freescale.com>
Signed-off-by: Xinyu Chen <xinyu.chen@freescale.com>
This is gadget file storage changes needed for STMP universal updater
tool (manufacturing flashing tool).
Some i.MX parts (MX31, MX37) need to have usb host queue descriptors
and/or buffers in on-chip IRAM in cases of heavily loaded memory
system (i.e. large LCDs).
the USBPHY of STMP3xxx SoC has bug. The usb port power
is never enabled during standard ehci reset procedure if the
external device once passed plug/unplug procedure. This work-
around resets and reinitiates USBPHY before the ehci port reset
sequence started.
Add OTG support to ehci host controllers
This patch fix OTG pin-detect failure issue.
via sysfs set power/wakeup, i.MX51 can:
Put usb phy into low power mode when system enters stop or
standby mode; Enable usb device remote wakeup system by Vbus
and usb host remote wakeup system by device connection or
disconnection.
MTP protocol support using gadgetfs requires the ability to cancel
I/O transactions.
Signed-off-by: Jun Li <r65092@freescale.com>
This patch fixes an oops caused when during an unplug a device's table
of endpoints is zeroed before the driver is notified. A pointer to
the endpoint must be cached.
this fixes a regression caused by commit
5186ffee2320942c3dc9745f7930e0eb15329ca6
Therefore it should go into 2.6.31
Signed-off-by: Oliver Neukum <oliver@neukum.org>
Add a quirk entry for the Leading Driver UD-11 usb flash drive.
As Alan Stern told me, the device doesn't deal correctly with the
locking media feature of the device, and this patch incorporates it.
Compiled, tested, working.
Signed-off-by: Rogerio Brito <rbrito@ime.usp.br>
Cc: Phil Dibowitz <phil@ipom.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Robert Hancock <hancockrwd@gmail.com>
Cc: stable <stable@kernel.org>
reference:
http://www.open-rd.org
Signed-off-by: Dhaval Vasa <dhaval.vasa@einfochips.com>
converter cable
Attached patch adds USB vendor and product IDs for Bayer's USB to serial
converter cable used by Bayer blood glucose meters. It seems to be a
FT232RL based device and works without any problem with ftdi_sio driver
when this patch is applied. See: http://winglucofacts.com/cables/
Signed-off-by: Marko Hänninen <bugitus@gmail.com>
This patch (as1274) simplifies the counting of transaction-error
retries. Now we will count up from 0 to QH_XACTERR_MAX instead of
down from QH_XACTERR_MAX to 0.
The patch also fixes a small bug: qh->xacterr was not getting
initialized for interrupt endpoints.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Tested-by: Matthijs Kooijman <matthijs@stdin.nl>
This patch (as1273) fixes two(!) bugs introduced by the new
Clear-TT-Buffer implementation in ehci-hcd.
It is now possible for an idle QH to have some URBs on its
queue -- this will happen if a Clear-TT-Buffer is pending for
the QH's endpoint. Consequently we should not issue a warning
when someone tries to unlink an URB from an idle QH; instead
we should process the request immediately.
The refcounts for QHs could get messed up, because
submit_async() would increment the refcount when calling
qh_link_async() and qh_link_async() would then refuse to link
the QH into the schedule if a Clear-TT-Buffer was pending.
Instead we should increment the refcount only when the QH
actually is added to the schedule. The current code tries to
be clever by leaving the refcount alone if an unlink is
immediately followed by a relink; the patch changes this to an
unconditional decrement and increment (although they occur in
the opposite order).
CC: David Brownell <david-b@pacbell.net>
Tested-by: Manuel Lauss <manuel.lauss@gmail.com>
This patch (as1272) changes the error code returned when an open call
for a USB device node fails to locate the corresponding device. The
appropriate error code is -ENODEV, not -ENOENT.
CC: Kay Sievers <kay.sievers@vrfy.org>
OMAP3EVM uses ISP1504 phy which doesn't require any programming and
thus has to use NOP otg transceiver.
Cleanups being done:
- Remove unwanted code in usb-musb.c file
- Register NOP in OMAP3EVM board file using
usb_nop_xceiv_register().
- Select NOP_USB_XCEIV for OMAP3EVM boards.
- Don't enable TWL4030_USB in omap3_evm_defconfig
Signed-off-by: Ajay Kumar Gupta <ajay.gupta@ti.com>
Signed-off-by: Eino-Ville Talvala <talvala@stanford.edu>
Acked-by: David Brownell <dbrownell@users.sourceforge.net>
access_ok() checks must be done on every part of the userspace structure
that is accessed. If access_ok() on one part of the struct succeeded, it
does not imply it will succeed on other parts of the struct. (Does
depend on the architecture implementation of access_ok()).
This changes the __get_user() users to first check access_ok() on the
data structure.
Signed-off-by: Michael Buesch <mb@bu3sch.de>
Cc: Pete Zaitcev <zaitcev@redhat.com>
I am submitting a patch for the pl2303 driver. This patch adds support
for the "Sony QN-3USB" cable (vendor=0x054c, product=0x0437). This USB
cable is a so-called data cable used to connect a Sony mobile phone to a
computer. Supported models are Sony CMD-J5, J6, J7, J16, J26, J70 and
Z7.
I have used this patch with my Sony CMD-J70 for several days and I
haven't encountered any kernel/hardware issue.
Correct the xHCI code to handle stalls on USB endpoints. We need to move
the endpoint ring's dequeue pointer past the stalled transfer, or the HW
will try to restart the transfer the next time the doorbell is rung.
Don't attempt to clear a halt on an endpoint if we haven't seen a stalled
transfer for it. The USB core will attempt to clear a halt on all
endpoints when it selects a new configuration.
Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Adds support for controllers that use 64-byte contexts. The following context
data structures are affected by this: Device, Input, Input Control, Endpoint,
and Slot. To accommodate the use of either 32 or 64-byte contexts, a Device or
Input context can only be accessed through functions which look-up and return
pointers to their contained contexts.
Signed-off-by: John Youn <johnyoun@synopsys.com>
Acked-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
Make sure the xHCI output device context is 64-byte aligned. Previous
code was using the same structure for both the output device context and
the input control context. Since the structure had 32 bytes of flags
before the device context, the output device context wouldn't be 64-byte
aligned. Define a new structure to use for the output device context and
clean up the debugging for these two structures.
The copy of the device context in the input control context does *not*
need to be 64-byte aligned.
Allocates and initializes the scratchpad buffer array (XHCI 4.20). This is an
array of 64-bit DMA addresses to scratch pages that the controller may use
during operation. The number of pages is specified in the "Max Scratchpad
Buffers" field of HCSPARAMS2. The DMA address of this array is written into
slot 0 of the DCBAA.
usb_parse_ss_endpoint_companion() was supposed to allocate a structure to
hold the SuperSpeed Endpoint Companion descriptor, and either copy the
values the device returned, or fill in default values if the device
descriptor did not include the companion descriptor.
However, the previous code would miss the last endpoint in a configuration
with no descriptors after it. Make usb_parse_endpoint() allocate the SS
endpoint companion descriptor and fill it with default values, even if
we've run out of buffer space in this configuration descriptor.
This is a work around for a bug in the SuperSpeed Endpoint Companion Descriptor
parsing code. It fails in some corner cases, which means ep->ss_ep_comp may be
NULL.
Pass back a babble error when this error code is seen in the transfer event TRB.
The xHCI host controller can be programmed to retry a transfer a certain number
of times per endpoint before it passes back an error condition to the host
controller driver. The xHC will return an error code when the error count
transitions from 1 to 0. Programming an error count of 3 means the xHC tries
the transfer 3 times, programming it with a 1 means it tries to transfer once,
and programming it with 0 means the HW tries the transfer infinitely.
We want isochronous transfers to only be tried once, so set the error count to
one.
Add more debugging to the irq handler, slot context initialization, ring
operations, URB cancellation, and MMIO writes.
The Event Handler Busy bit in the event ring dequeue pointer is write 1 to
clear. Fix the interrupt service routine to clear that bit after the
event handler has run.
xhci_set_hc_event_deq() is designed to update the event ring dequeue pointer
without changing any of the four reserved bits in the lower nibble. The event
handler busy (EHB) bit is write one to clear, so the new value must always
contain a zero in that bit in order to preserve the EHB value.
When there is a short packet on a control transfer, the xHCI host controller
hardware will generate two events. The first event will be for the data stage
TD with a completion code for a short packet. The second event will be for the
status stage with a successful completion code. Before this patch, the xHCI
driver would giveback the short control URB when it received the event for the
data stage TD. Then it would become confused when it saw a status stage event
for the endpoint for an URB it had already finished processing.
Change the xHCI host controller driver to wait for the status stage event when
it receives a short transfer completion code for a data stage TD.
There are several xHCI data structures that use two 32-bit fields to
represent a 64-bit address. Since some architectures don't support 64-bit
PCI writes, the fields need to be written in two 32-bit writes. The xHCI
specification says that if a platform is incapable of generating 64-bit
writes, software must write the low 32-bits first, then the high 32-bits.
Hardware that supports 64-bit addressing will wait for the high 32-bit
write before reading the revised value, and hardware that only supports
32-bit writes will ignore the high 32-bit write.
Previous xHCI code represented 64-bit addresses with two u32 values. This
lead to buggy code that would write the 32-bits in the wrong order, or
forget to write the upper 32-bits. Change the two u32s to one u64 and
create a function call to write all 64-bit addresses in the proper order.
This new function could be modified in the future if all platforms support
64-bit writes.
The xHCI functions to queue an URB onto the hardware rings must be called
with the xhci spinlock held. Those functions will allocate memory, and
take a gfp_t memory flags argument. We must pass them the GFP_ATOMIC
flag, since we don't want the memory allocation to attempt to sleep while
waiting for more memory to become available.
When an endpoint on a device under an xHCI host controller stalls, the
host controller driver must let the hardware know that the USB core has
successfully cleared the halt condition. The HCD submits a Reset Endpoint
Command, which will clear the toggle bit for USB 2.0 devices, and set the
sequence number to zero for USB 3.0 devices.
The xHCI urb_enqueue will accept new URBs while the endpoint is halted,
and will queue them to the hardware rings. However, the endpoint doorbell
will not be rung until the Reset Endpoint Command completes.
Don't queue a reset endpoint command for root hubs. khubd clears halt
conditions on the roothub during the initialization process, but the roothub
isn't a real device, so the xHCI host controller doesn't need to know about the
cleared halt.
The 0.95 xHCI specification requires software to set the "TD size" field
in each transaction request block (TRB). This field gives the host
controller an indication of how much data is remaining in the TD
(including the buffer in the current TRB). Set this field in bulk TRBs
and data stage TRBs for control transfers.
Without this change the loops won't start
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com>
THis patch (as1270) allows the usbtest module to be built even when
USB_DEVICEFS isn't configured. Tests can be performed without
USB_DEVICEFS, using the /dev/bus/usb/*/* device files.
INDEX register has to be set to '0' before reading
CONFIGDATA register which is only present in TI musb
platforms.
Currently the default register access mode is set to
FLAT_MODE thus INDEX register is not getting set
properly with musb_ep_select() which is just a nop
operation in FLAT_MODE.This invalid register read is
causing module reinset failure.
Fixing the issue by moving INDEX register write part to
musb_read_configdata() function itself.
Signed-off-by: Vikram Pandita <vikram.pandita@ti.com>
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
musb_otg_timer_func() is defined under #ifdef CONFIG_USB_MUSB_OTG.
Make sure any reference to it is also under the same #ifdef.
Without this fix, the driver failes to compile when USB_OTG is defined
but USB_MUSB_OTG isn't.
Signed-off-by: Amit Kucheria <amit.kucheria@canonical.com>
Cc: Felipe Balbi <felipe.balbi@nokia.com>
Cc: David Brownell <dbrownell@users.sourceforge.net>
This function uses wrong bit mask to prevent clearing RXCSR status
bits when halting an endpoint -- which results in clearing SentStall
and RxPktRdy bits (that the code actually tries to avoid); must be
a result of cut-and-paste...
