commit 68693b8ea4e284c46bff919ac62bd9ccdfdbb6ba upstream.
since the split of host+gadget mode in commit 74c2e9360058 ("usb: musb:
factor out hcd initalization") we leak the usb_hcd struct. We call now
musb_host_cleanup() which does basically usb_remove_hcd() and also sets
the hcd variable to NULL. Doing so makes the finall call to
musb_host_free() basically a nop and the usb_hcd remains around for ever
without anowner.
This patch drops that NULL assignment for that reason.
Fixes: 74c2e9360058 ("usb: musb: factor out hcd initalization")
Cc: Daniel Mack <zonque@gmail.com>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
Signed-off-by: Felipe Balbi <balbi@ti.com>
commit 6d89252a998a695ecb0348fc2d717dc33d90cae9 upstream.
Commit c3ee9b76aa93 (EHCI: improved logic for isochronous scheduling)
introduced the idea of using ehci->last_iso_frame as the origin (or
base) for the circular calculations involved in modifying the
isochronous schedule. However, the new code it added used
ehci->last_iso_frame before the value was properly initialized. This
patch rectifies the mistake by moving the initialization lines earlier
in iso_stream_schedule().
This fixes Bugzilla #72891.
Signed-off-by: Alan Stern <stern@rowland.harvard.edu>
Fixes: c3ee9b76aa93
Reported-by: Joe Bryant <tenminjoe@yahoo.com>
Tested-by: Joe Bryant <tenminjoe@yahoo.com>
Tested-by: Martin Long <martin@longhome.co.uk>
commit 32a4bf2e81ec378e5925d4e069e0677a6c86a6ad upstream.
Use tty kref to release the fake tty in usb_console_setup to avoid use
after free if the underlying serial driver has acquired a reference.
Note that using the tty destructor release_one_tty requires some more
state to be initialised.
Fixes: 4a90f09b20f4 ("tty: usb-serial krefs")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit d269d4434c72ed0da3a9b1230c30da82c4918c63 upstream.
The USB console currently allocates a temporary fake tty which is used
to pass terminal settings to the underlying serial driver.
The tty struct is not fully initialised, something which can lead to a
lockdep warning (or worse) if a serial driver tries to acquire a
line-discipline reference:
usbserial: USB Serial support registered for pl2303
pl2303 1-2.1:1.0: pl2303 converter detected
usb 1-2.1: pl2303 converter now attached to ttyUSB0
INFO: trying to register non-static key.
the code is fine but needs lockdep annotation.
turning off the locking correctness validator.
CPU: 0 PID: 68 Comm: udevd Tainted: G W 3.18.0-rc5 #10
[<c0016f04>] (unwind_backtrace) from [<c0013978>] (show_stack+0x20/0x24)
[<c0013978>] (show_stack) from [<c0449794>] (dump_stack+0x24/0x28)
[<c0449794>] (dump_stack) from [<c006f730>] (__lock_acquire+0x1e50/0x2004)
[<c006f730>] (__lock_acquire) from [<c0070128>] (lock_acquire+0xe4/0x18c)
[<c0070128>] (lock_acquire) from [<c027c6f8>] (ldsem_down_read_trylock+0x78/0x90)
[<c027c6f8>] (ldsem_down_read_trylock) from [<c027a1cc>] (tty_ldisc_ref+0x24/0x58)
[<c027a1cc>] (tty_ldisc_ref) from [<c0340760>] (usb_serial_handle_dcd_change+0x48/0xe8)
[<c0340760>] (usb_serial_handle_dcd_change) from [<bf000484>] (pl2303_read_int_callback+0x210/0x220 [pl2303])
[<bf000484>] (pl2303_read_int_callback [pl2303]) from [<c031624c>] (__usb_hcd_giveback_urb+0x80/0x140)
[<c031624c>] (__usb_hcd_giveback_urb) from [<c0316fc0>] (usb_giveback_urb_bh+0x98/0xd4)
[<c0316fc0>] (usb_giveback_urb_bh) from [<c0042e44>] (tasklet_hi_action+0x9c/0x108)
[<c0042e44>] (tasklet_hi_action) from [<c0042380>] (__do_softirq+0x148/0x42c)
[<c0042380>] (__do_softirq) from [<c00429cc>] (irq_exit+0xd8/0x114)
[<c00429cc>] (irq_exit) from [<c007ae58>] (__handle_domain_irq+0x84/0xdc)
[<c007ae58>] (__handle_domain_irq) from [<c000879c>] (omap_intc_handle_irq+0xd8/0xe0)
[<c000879c>] (omap_intc_handle_irq) from [<c0014544>] (__irq_svc+0x44/0x7c)
Exception stack(0xdf4e7f08 to 0xdf4e7f50)
7f00: debc0b80 df4e7f5c 00000000 00000000 debc0b80 be8da96c
7f20: 00000000 00000128 c000fc84 df4e6000 00000000 df4e7f94 00000004 df4e7f50
7f40: c038ebc0 c038d74c 600f0013 ffffffff
[<c0014544>] (__irq_svc) from [<c038d74c>] (___sys_sendmsg.part.29+0x0/0x2e0)
[<c038d74c>] (___sys_sendmsg.part.29) from [<c038ec08>] (SyS_sendmsg+0x18/0x1c)
[<c038ec08>] (SyS_sendmsg) from [<c000fa00>] (ret_fast_syscall+0x0/0x48)
console [ttyUSB0] enabled
Fixes: 36697529b5bb ("tty: Replace ldisc locking with ldisc_sem")
commit 5fb694f96e7c19e66b1c55124b98812e32e3efa5 upstream.
When unloading the module 'g_hid.ko', the urb request will be dequeued and the
completion routine will be excuted. If there is no urb packet, the urb request
will not be added to the endpoint queue and the completion routine pointer in
urb request is NULL.
Accessing to this NULL function pointer will cause the Oops issue reported
below.
Add the code to check if the urb request is in the endpoint queue
or not. If the urb request is not in the endpoint queue, a negative
error code will be returned.
Here is the Oops log:
Unable to handle kernel NULL pointer dereference at virtual address 00000000
pgd = dedf0000
[00000000] *pgd=3ede5831, *pte=00000000, *ppte=00000000
Internal error: Oops: 80000007 [#1] ARM
Modules linked in: g_hid(-) usb_f_hid libcomposite
CPU: 0 PID: 923 Comm: rmmod Not tainted 3.18.0+ #2
Hardware name: Atmel SAMA5 (Device Tree)
task: df6b1100 ti: dedf6000 task.ti: dedf6000
PC is at 0x0
LR is at usb_gadget_giveback_request+0xc/0x10
pc : [<00000000>] lr : [<c02ace88>] psr: 60000093
sp : dedf7eb0 ip : df572634 fp : 00000000
r10: 00000000 r9 : df52e210 r8 : 60000013
r7 : df6a9858 r6 : df52e210 r5 : df6a9858 r4 : df572600
r3 : 00000000 r2 : ffffff98 r1 : df572600 r0 : df6a9868
Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c53c7d Table: 3edf0059 DAC: 00000015
Process rmmod (pid: 923, stack limit = 0xdedf6230)
Stack: (0xdedf7eb0 to 0xdedf8000)
7ea0: 00000000 c02adbbc df572580 deced608
7ec0: df572600 df6a9868 df572634 c02aed3c df577c00 c01b8608 00000000 df6be27c
7ee0: 00200200 00100100 bf0162f4 c000e544 dedf6000 00000000 00000000 bf010c00
7f00: bf0162cc bf00159c 00000000 df572980 df52e218 00000001 df5729b8 bf0031d0
[<c02ace88>] (usb_gadget_giveback_request) from [<c02adbbc>] (request_complete+0x64/0x88)
[<c02adbbc>] (request_complete) from [<c02aed3c>] (usba_ep_dequeue+0x70/0x128)
[<c02aed3c>] (usba_ep_dequeue) from [<bf010c00>] (hidg_unbind+0x50/0x7c [usb_f_hid])
[<bf010c00>] (hidg_unbind [usb_f_hid]) from [<bf00159c>] (remove_config.isra.6+0x98/0x9c [libcomposite])
[<bf00159c>] (remove_config.isra.6 [libcomposite]) from [<bf0031d0>] (__composite_unbind+0x34/0x98 [libcomposite])
[<bf0031d0>] (__composite_unbind [libcomposite]) from [<c02acee0>] (usb_gadget_remove_driver+0x50/0x78)
[<c02acee0>] (usb_gadget_remove_driver) from [<c02ad570>] (usb_gadget_unregister_driver+0x64/0x94)
[<c02ad570>] (usb_gadget_unregister_driver) from [<bf0160c0>] (hidg_cleanup+0x10/0x34 [g_hid])
[<bf0160c0>] (hidg_cleanup [g_hid]) from [<c0056748>] (SyS_delete_module+0x118/0x19c)
[<c0056748>] (SyS_delete_module) from [<c000e3c0>] (ret_fast_syscall+0x0/0x30)
Code: bad PC value
Signed-off-by: Songjun Wu <songjun.wu@atmel.com>
[nicolas.ferre@atmel.com: reworked the commit message]
Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Fixes: 914a3f3b3754 ("USB: add atmel_usba_udc driver")
commit 6785a1034461c2d2c205215f63a50a740896e55b upstream.
When receive data, the RXRDY in status register set by hardware
after a new packet has been stored in the endpoint FIFO. When it
is copied from FIFO, this bit is cleared which make the FIFO can
be accessed again.
In the receive_data() function, this bit RXRDY has been cleared.
So, after the receive_data() function return, this bit should
not be cleared again, or else it may cause the accessing FIFO
corrupt, which will make the data loss.
Fixes: 914a3f3b3754 (USB: add atmel_usba_udc driver)
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
Signed-off-by: Bo Shen <voice.shen@atmel.com>
commit f40afdddeb6c54ffd1e2920a5e93e363d6748db6 upstream.
According to the datasheet, when transfer using DMA, the control
setting for IN packet only need END_BUF_EN, END_BUF_IE, CH_EN,
while for OUT packet, need more two bits END_TR_EN and END_TR_IE
to be configured.
commit b44be2462dbe3e23f0aedff64de52a1e8e47a1cd upstream.
Commit 3b74c73f8d6f053f422e85fce955b61fb181cfe7 switched over to memdup_user()
in ep_write() function and removed kfree (kbuf).
memdup_user() function allocates memory which is never freed.
Fixes: 3b74c73 (usb: gadget: inode: switch over to memdup_user())
Signed-off-by: Mario Schuknecht <mario.schuknecht@dresearch-fe.de>
commit b5122236bba8d7ef62153da5b55cc65d0944c61e upstream.
Fix null-pointer dereference during probe if the interface-status
completion handler is called before the individual ports have been set
up.
Fixes: f79b2d0fe81e ("USB: keyspan: fix NULL-pointer dereferences and
memory leaks")
Reported-by: Richard <richjunk@pacbell.net>
Tested-by: Richard <richjunk@pacbell.net>
commit d80c0d14183516f184a5ac88e11008ee4c7d2a2e upstream.
As has been discussed in the thread starting with
https://lkml.kernel.org/g/549748e9.d+SiJzqu50f1r4lSAL043YSc@arcor.de
Sierra Wireless MC73xx devices with USB VID/PID 0x1199:0x68c0 require the
option_send_setup() code to be used on the USB interface for the AT port
to make unsolicited response codes work correctly. Move these devices from
the qcserial driver where they have been added by commit
70a3615fc07c2330ed7c1e922f3c44f4a67c0762 ("usb: qcserial: add Sierra Wireless
MC73xx") to the option driver and add a MC73xx-specific blacklist
to ensure that
1. the sendsetup code is not used for the DIAG/DM and NMEA interfaces
2. the option driver does not attach to the QMI/network interfaces
Signed-off-by: Reinhard Speyerer <rspmn@arcor.de>
commit 1ae78a4870989a354028cb17dabf819b595e70e3 upstream.
Added virtual com port VID/PID entries for CEL USB sticks and MeshWorks
devices.
Signed-off-by: David Peterson <david.peterson@cel.com>
commit 90441b4dbe90ba0c38111ea89fa093a8c9627801 upstream.
Fixing typo for MeshConnect IDs. The original PID (0x8875) is not in
production and is not needed. Instead it has been changed to the
official production PID (0x8857).
Signed-off-by: Preston Fick <pffick@gmail.com>
commit 39e60635a01520e8c8ed3946a28c2b98e6a46f79 upstream.
DWC3 gadget sets up a pool of 32 TRBs for each EP during initialization. This
means, the max TRBs that can be submitted for an EP is fixed to 32. Since the
request queue for an EP is a linked list, any number of requests can be queued
to it by the gadget layer. However, the dwc3 driver must not submit TRBs more
than the pool it has created for. This limit wasn't respected when SG was used
resulting in submitting more than the max TRBs, eventually leading to
non-transfer of the TRBs submitted over the max limit.
Root cause:
When SG is used, there are two loops iterating to prepare TRBs:
- Outer loop over the request_list
- Inner loop over the SG list
The code was missing break to get out of the outer loop.
Fixes: eeb720fb21d6 (usb: dwc3: gadget: add support for SG lists)
Signed-off-by: Amit Virdi <amit.virdi@st.com>
commit ec512fb8e5611fed1df2895f90317ce6797d6b32 upstream.
When scatter gather (SG) is used, multiple TRBs are prepared from one DWC3
request (dwc3_request). So while preparing TRBs, the 'last' flag should be set
only when it is the last TRB being prepared from the last dwc3_request entry.
The current implementation uses list_is_last to check if the dwc3_request is the
last entry from the request_list. However, list_is_last returns false for the
last entry too. This is because, while preparing the first TRB from a request,
the function dwc3_prepare_one_trb modifies the request's next and prev pointers
while moving the URB to req_queued. Hence, list_is_last always returns false no
matter what.
The correct way is not to access the modified pointers of dwc3_request but to
use list_empty macro instead.
Fixes: e5ba5ec833aa (usb: dwc3: gadget: fix scatter gather implementation)
commit 56abcab833fafcfaeb2f5b25e0364c1dec45f53e upstream.
Commit 8dccddbc2368 ("OHCI: final fix for NVIDIA problems (I hope)")
introduced into 3.1.9 broke boot on e.g. Freescale P2020DS development
board. The code path that was previously specific to NVIDIA controllers
had then become taken for all chips.
However, the M5237 installed on the board wedges solid when accessing
its base+OHCI_FMINTERVAL register, making it impossible to boot any
kernel newer than 3.1.8 on this particular and apparently other similar
machines.
Don't readl() and writel() base+OHCI_FMINTERVAL on PCI ID 10b9:5237.
The patch is suitable for the -next tree as well as all maintained
kernels up to 3.2 inclusive.
Signed-off-by: Arseny Solokha <asolokha@kb.kras.ru>
Acked-by: Alan Stern <stern@rowland.harvard.edu>
commit 3ca8c717429b90f621aed28af029da4c3da378bc upstream.
Just like all previous UAS capable Seagate disk enclosures, these need the
US_FL_NO_ATA_1X to not crash when udev probes them.
commit c6fa3945c8b5baf62f2e849104ecd6f3a1e5e407 upstream.
Like the JMicron JMS567 enclosures with the JMS566 choke on report-opcodes,
so avoid it.
Tested-and-reported-by: Takeo Nakayama <javhera@gmx.com>
commit e5797a3d079f3e5049140055d850691b5cc7d10a upstream.
This is yet another Seagate device which needs the US_FL_NO_ATA_1X quirk
Reported-by: Marcin Zajączkowski <mszpak@wp.pl>
commit 7f5c4d631aed243ca89c6673427954210b1628ec upstream.
Streams do not work reliabe on Fresco Logic FL1000G xhci controllers,
trying to use them results in errors like this:
21:37:33 kernel: xhci_hcd 0000:04:00.0: ERROR Transfer event for disabled endpoint or incorrect stream ring
21:37:33 kernel: xhci_hcd 0000:04:00.0: @00000000368b3570 9067b000 00000000 05000000 01078001
21:37:33 kernel: xhci_hcd 0000:04:00.0: @00000000368b3580 9067b400 00000000 05000000 01038001
As always I've ordered a pci-e addon card with a Fresco Logic controller for
myself to see if I can come up with a better fix then the big hammer, in
the mean time this will make uas devices work again (in usb-storage mode)
for FL1000G users.
commit f161ead70fa6a62e432dff6e9dab8e3cfbeabea6 upstream.
Solves xhci error cases with debug messages:
xhci_hcd 0000:00:14.0: Setup ERROR: setup context command for slot 1.
usb 1-6: hub failed to enable device, error -22
xhci will give a context state error if we try to set a slot in default
state to the same default state with a special address device command.
Turns out this happends in several cases:
- retry reading the device rescriptor in hub_port_init()
- usb_reset_device() is called for a slot in default state
- in resume path, usb_port_resume() calls hub_port_init()
The default state is usually reached from most states with a reset device
command without any context state errors, but using the address device
command with BSA bit set (block set address) only works from the enabled
state and will otherwise cause context error.
solve this by checking if we are already in the default state before issuing
a address device BSA=1 command.
Fixes: 48fc7dbd52c0 ("usb: xhci: change enumeration scheme to 'new scheme'")
Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com>
commit d908f8478a8d18e66c80a12adb27764920c1f1ca upstream.
If probe() fails not only the attributes need to be removed
but also the memory freed.
Reported-by: Ahmed Tamrawi <ahmedtamrawi@gmail.com>
Signed-off-by: Oliver Neukum <oneukum@suse.de>
commit e7181d005e84b15fe3121a8d22840adc3395d496 upstream.
Added new device layout "DEVICE_HWI" and also added the USB VID/PID for the
HP lt4112 LTE/HSPA+ Gobi 4G Modem (Huawei me906e)
Signed-off-by: Martin Hauke <mardnh@gmx.de>
commit b2ba27a5c56ff7204d8a8684893d64d4afe2cee5 upstream.
Commit 7628083227b6bc4a7e33d7c381d7a4e558424b6b (usb: gadget: at91_udc:
prepare clk before calling enable) added clock preparation in interrupt
context. This is not allowed as it might sleep. Also setting the clock
rate is unsafe to call from there for the same reason. Move clock
preparation and setting clock rate into process context (at91udc_probe).
Signed-off-by: Ronald Wahl <ronald.wahl@raritan.com>
Acked-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
Acked-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Felipe Balbi <balbi@ti.com>
commit 11432050f070810ba139d0226344eef120c3a559 upstream.
This patch fixes an issue that the NULL pointer dereference happens
when we uses g_audio driver. Since the g_audio driver will call
usb_ep_disable() in afunc_set_alt() before it calls usb_ep_enable(),
the uep->pipe of renesas usbhs driver will be NULL. So, this patch
adds a condition to avoid the oops.
Signed-off-by: Kazuya Mizuguchi <kazuya.mizuguchi.ks@renesas.com>
Signed-off-by: Takeshi Kihara <takeshi.kihara.df@renesas.com>
Signed-off-by: Yoshihiro Shimoda <yoshihiro.shimoda.uh@renesas.com>
Fixes: 2f98382dc (usb: renesas_usbhs: Add Renesas USBHS Gadget)
commit 403dff4e2c94f275e24fd85f40b2732ffec268a1 upstream.
We need to check that we have both a valid data and control inteface for both
types of headers (union and not union.)
References: https://bugzilla.kernel.org/show_bug.cgi?id=83551
Reported-by: Simon Schubert <2+kernel@0x2c.org>
commit a32c99e7ab8410bae7c276a7e94ca84d108de034 upstream.
The touchscreen needs the same quirk as the other models.
Reported-by: Bryan Poling <poli0048@umn.edu>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
This wireless mouse receiver needs a reset-resume quirk to properly come
out of reset.
BugLink: https://bugzilla.redhat.com/show_bug.cgi?id=1165206
Cc: stable <stable@vger.kernel.org>
When system is being suspended, if host device is not allowed to do wakeup,
xhci_suspend() needs to clear all root port wake on bits. Otherwise, some
platforms may generate spurious wakeup, even if PCI PME# is disabled.
The initial commit ff8cbf250b44 ("xhci: clear root port wake on bits"),
which also got into stable, turned out to not work correctly and had to
be reverted, and is now rewritten.
Cc: stable <stable@vger.kernel.org> # v3.2+
Signed-off-by: Lu Baolu <baolu.lu@linux.intel.com>
Suggested-by: Alan Stern <stern@rowland.harvard.edu>
[Mathias Nyman: reword commit message]
If a device is halted and reuturns a STALL, then the halted endpoint
needs to be cleared both on the host and device side. The host
side halt is cleared by issueing a xhci reset endpoint command. The device side
is cleared with a ClearFeature(ENDPOINT_HALT) request, which should
be issued by the device driver if a URB reruen -EPIPE.
Previously we cleared the host side halt after the device side was cleared.
To make sure the host side halt is cleared in time we want to issue the
reset endpoint command immedialtely when a STALL status is encountered.
Otherwise we end up not following the specs and not returning -EPIPE
several times in a row when trying to transfer data to a halted endpoint.
Fixes: bcef3fd (USB: xhci: Handle errors that cause endpoint halts.)
Cc: <stable@vger.kernel.org> # v2.6.33+
Tested-by: Felipe Balbi <balbi@ti.com>
commit ff8cbf250b44 ("xhci: clear root port wake on bits if controller isn't")
can cause device detection error if runtime PM is enabled, and S3 wake
is disabled. Revert it.
https://bugzilla.kernel.org/show_bug.cgi?id=85701
This commit got into stable and should be reverted from there as well.
Reported-by: Dmitry Nezhevenko <dion@inhex.net>
A halted endpoint ring must first be reset, then move the ring
dequeue pointer past the problematic TRB. If we start the ring too
early after reset, but before moving the dequeue pointer we
will end up executing the same problematic TRB again.
As we always issue a set transfer dequeue command after a reset
endpoint command we can skip starting endpoint rings at reset endpoint
command completion.
Without this fix we end up trying to handle the same faulty TD for
contol endpoints. causing timeout, and failing testusb ctrl_out write
tests.
Fixes: e9df17e (USB: xhci: Correct assumptions about number of rings per endpoint.)
Cc: <stable@vger.kernel.org> #v2.6.35
These disks have a broken uas implementation, the tag field of the status
iu-s is not set properly, so we need to fall-back to usb-storage for these.
Cc: stable@vger.kernel.org # 3.16
git://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial into usb-linus
Johan writes:
USB-serial fixes for v3.18-rc6
Three fixes for bugs related to TTY error reporting, which can to lead
to data being dropped by the line discipline.
Included is also some new device ids for ftdi_sio and cp210x.
Fix reporting of overrun errors, which should only be reported once
using the inserted null character.
Fixes: 6b8f1ca5581b ("USB: ssu100: set tty_flags in ssu100_process_packet")
Fix reporting of overrun errors, which are not associated with a
character. Instead insert a null character and report only once.
Fixes: 1da177e4c3f4 ("Linux-2.6.12-rc2")
Fix handling of TTY error flags, which are not bitmasks and must
specifically not be ORed together as this prevents the line discipline
from recognising them.
Also insert null characters when reporting overrun errors as these are
not associated with the received character.
Add PIDs for new Matrix Orbital GTT series products.
Signed-off-by: Troy Clark <tclark@matrixorbital.ca>
[johan: shorten commit message ]
commit 6856d30 (usb: dwc3: ep0: return early
on NULL requests) tried to fix a minor corner
case where we could dereference a NULL pointer
but it also ended up introducing some dead code.
Unfortunately, that dead code, if reached, could
end up starving the endpoint request list because
a request would never be given back when it should.
Fix this by moving the check for empty request list
before its first use.
Reported-by: Dave Jones <davej@redhat.com>
Add new quirk for devices that cannot handle control-line state
requests.
Note that we currently send these requests to all devices, regardless of
whether they claim to support it, but that errors are only logged if
support is claimed.
Since commit 0943d8ead30e ("USB: cdc-acm: use tty-port dtr_rts"), which
only changed the timings for these requests slightly, this has been
reported to cause occasional firmware crashes on Simtec Electronics
Entropy Key devices after re-enumeration. Enable the quirk for this
device.
Reported-by: Nix <nix@esperi.org.uk>
Tested-by: Nix <nix@esperi.org.uk>
Cc: stable <stable@vger.kernel.org> # v3.16
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-linus
Felipe writes:
usb: fixes for v3.18-rc4
A single fix this for dwc2 this time. Because of
excessive debugging messages, dwc2 would sometimes
fail enumeration. The fix is simple, just converting
a dev_info() into dev_dbg().
Johan writes:
USB-serial fixes for v3.18-rc4
Two fixes of non-atomic allocations in write paths.
usb_stor_huawei_e220_init()
The timeout argument to usb_stor_control_msg() is specified in jiffies, not
milliseconds.
Signed-off-by: Mark Knibbs <markk@clara.co.uk>
Make sure to only raise DTR on transitions from B0 in set_termios.
Also allow set_termios to be called from open with a termios_old of
NULL. Note that DTR will not be raised prematurely in this case.
This reverts commit bda9893c50fb56253d3c206c14e3f933e5f68b3c as it was
incorrect.
Reported-by: Mark Knibbs <markk@clara.co.uk>
It is safe to call notify disconnect when the usb core
thinks the device is disconnected.
This commit also fixes one bug found at below situation:
we have not enabled usb wakeup, we do system suspend when
there is an usb device at the port, after suspend, we plug out
the usb device, then plug in device again. At that time,
the nofity disconnect was not called at current code, as
the controller doesn't know the usb device was disconnected
during the suspend, but USB core knows the port has changed
during that periods.
So to fix this problem, and let the usb core call notify disconnect.
Cc: 3.17+ <stable@vger.kernel.org>
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Since we notify disconnecting based on the usb device is existed
(port_dev->child, the child device at roothub is not NULL), we
need to notify connect after device has been registered.
This fixes a bug that do fast plug in/out test, and the notify_disconnect
is not called due to roothub child is NULL and the enumeration has failed.
Cc: v3.17+ <stable@vger.kernel.org>
Signed-off-by: Tony Zheng <Tony.Zheng@freescale.com>
These drives hang when receiving ATA12 commands, so set the US_FL_NO_ATA_1X
quirk to filter these out.
The switch back is limited to ULT even on HP. The contrary
finding arose by bad luck in BIOS versions for testing.
This fixes spontaneous resume from S3 on some HP laptops.
Yet another device affected by this.
Tested-by: Kevin Fenzi <kevin@scrye.com>
Signed-off-by: Adel Gadllah <adel.gadllah@gmail.com>
