path: root/drivers/uwb
2013-04-29uwb: rename random32() to prandom_u32()Akinobu Mita
Use preferable function name which implies using a pseudo-random number generator. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-02-06driver-core: constify data for class_find_device()Michał Mirosław
All in-kernel users of class_find_device() don't really need mutable data for match callback. In two places (kernel/power/suspend_test.c, drivers/scsi/osd/osd_uld.c) this patch changes match callbacks to use const search data. The const is propagated to rtc_class_open() and power_supply_get_by_name() parameters. Note that there's a dev reference leak in suspend_test.c that's not touched in this patch. Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-26uwb: fix uwb_dev_unlock() missed at an error path in uwb_rc_cmd_async()Alexey Khoroshilov
There is the only path in uwb_rc_cmd_async() where rc->uwb_dev is left unlocked. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-15drivers/uwb: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-25umc-bus.c: fix usage of device_trylockClaudio Scordino
Fix usage of device_trylock. It has the same semantics of mutex_trylock, so it returns 1 if the lock has been acquired successfully. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Bruno Morelli <bruno@evidence.eu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-18uwb: fix error handlingOliver Neukum
Fatal errors such as a device disconnect must not trigger error handling. The error returns must be checked. Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-18uwb: fix use of del_timer_sync() in interruptOliver Neukum
del_timer_sync() cannot be used in interrupt. Replace it with del_timer() and a flag Signed-off-by: Oliver Neukum <oneukum@suse.de> Cc: stable <stable@vger.kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-05simple_open: automatically convert to simple_open()Stephen Boyd
Many users of debugfs copy the implementation of default_open() when they want to support a custom read/write function op. This leads to a proliferation of the default_open() implementation across the entire tree. Now that the common implementation has been consolidated into libfs we can replace all the users of this function with simple_open(). This replacement was done with the following semantic patch: <smpl> @ open @ identifier open_f != simple_open; identifier i, f; @@ -int open_f(struct inode *i, struct file *f) -{ ( -if (i->i_private) -f->private_data = i->i_private; | -f->private_data = i->i_private; ) -return 0; -} @ has_open depends on open @ identifier fops; identifier open.open_f; @@ struct file_operations fops = { ... -.open = open_f, +.open = simple_open, ... }; </smpl> [akpm@linux-foundation.org: checkpatch fixes] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-23uwb: use for_each_clear_bit()Akinobu Mita
Use for_each_clear_bit() to iterate over all the cleared bit in a memory region. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Stefano Panella <stefano.panella@csr.com> Cc: David Vrabel <david.vrabel@csr.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-09Merge branch 'usb-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb * 'usb-next' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (232 commits) USB: Add USB-ID for Multiplex RC serial adapter to cp210x.c xhci: Clean up 32-bit build warnings. USB: update documentation for usbmon usb: usb-storage doesn't support dynamic id currently, the patch disables the feature to fix an oops drivers/usb/class/cdc-acm.c: clear dangling pointer drivers/usb/dwc3/dwc3-pci.c: introduce missing kfree drivers/usb/host/isp1760-if.c: introduce missing kfree usb: option: add ZD Incorporated HSPA modem usb: ch9: fix up MaxStreams helper USB: usb-skeleton.c: cleanup open_count USB: usb-skeleton.c: fix open/disconnect race xhci: Properly handle COMP_2ND_BW_ERR USB: remove dead code from suspend/resume path USB: add quirk for another camera drivers: usb: wusbcore: Fix dependency for USB_WUSB xhci: Better debugging for critical host errors. xhci: Be less verbose during URB cancellation. xhci: Remove debugging about ring structure allocation. xhci: Remove debugging about toggling cycle bits. xhci: Remove debugging for individual transfers. ...
2012-01-08Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (53 commits) Kconfig: acpi: Fix typo in comment. misc latin1 to utf8 conversions devres: Fix a typo in devm_kfree comment btrfs: free-space-cache.c: remove extra semicolon. fat: Spelling s/obsolate/obsolete/g SCSI, pmcraid: Fix spelling error in a pmcraid_err() call tools/power turbostat: update fields in manpage mac80211: drop spelling fix types.h: fix comment spelling for 'architectures' typo fixes: aera -> area, exntension -> extension devices.txt: Fix typo of 'VMware'. sis900: Fix enum typo 'sis900_rx_bufer_status' decompress_bunzip2: remove invalid vi modeline treewide: Fix comment and string typo 'bufer' hyper-v: Update MAINTAINERS treewide: Fix typos in various parts of the kernel, and fix some comments. clockevents: drop unknown Kconfig symbol GENERIC_CLOCKEVENTS_MIGR gpio: Kconfig: drop unknown symbol 'CS5535_GPIO' leds: Kconfig: Fix typo 'D2NET_V2' sound: Kconfig: drop unknown symbol ARCH_CLPS7500 ... Fix up trivial conflicts in arch/powerpc/platforms/40x/Kconfig (some new kconfig additions, close to removed commented-out old ones)
2011-12-09uwb: Use kcalloc instead of kzalloc to allocate arrayThomas Meyer
The advantage of kcalloc is, that will prevent integer overflows which could result from the multiplication of number of elements and size and it is also a bit nicer to read. The semantic patch that makes this change is available in https://lkml.org/lkml/2011/11/25/107 Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-12-02treewide: Fix typos in various parts of the kernel, and fix some comments.Justin P. Mattock
The below patch fixes some typos in various parts of the kernel, as well as fixes some comments. Please let me know if I missed anything, and I will try to get it changed and resent. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-11-18USB: convert some miscellanies drivers to use module_usb_driver()Greg Kroah-Hartman
This converts the remaining USB drivers in the kernel to use the module_usb_driver() macro which makes the code smaller and a bit simpler. Added bonus is that it removes some unneeded kernel log messages about drivers loading and/or unloading. Cc: Guenter Roeck <guenter.roeck@ericsson.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Ben Dooks <ben-linux@fluff.org> Cc: Till Harbaum <till@harbaum.org> Cc: Karsten Keil <isdn@linux-pingi.de> Cc: Chris Ball <cjb@laptop.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Lauro Ramos Venancio <lauro.venancio@openbossa.org> Cc: Aloisio Almeida Jr <aloisio.almeida@openbossa.org> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Steve Glendinning <steve.glendinning@smsc.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Evgeniy Polyakov <zbr@ioremap.net> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: "David S. Miller" <davem@davemloft.net> Cc: Jesper Juhl <jj@chaosbits.net> Cc: Artem Bityutskiy <Artem.Bityutskiy@nokia.com> Cc: Jamie Iles <jamie@jamieiles.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-31uwb: Add export.h for EXPORT_SYMBOL/THIS_MODULE as requiredPaul Gortmaker
These macros are no longer in module.h and module.h is no longer present everywhere. Call out export.h for the real users who are making use of these macros, or else we'll get things like: CC drivers/uwb/umc-drv.o drivers/uwb/umc-dev.c:42: warning: data definition has no type or storage class drivers/uwb/umc-dev.c:42: warning: type defaults to ‘int’ in declaration of ‘EXPORT_SYMBOL_GPL’ drivers/uwb/umc-dev.c:42: warning: parameter names (without types) in function declaration Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31uwb: Add module.h to the real uwb modular users.Paul Gortmaker
Lots of files were getting an implicit include of module.h for years now. But that will be fixed shortly. So get the real users to call out the include explicitly. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-10-31drivers/uwb: fix implicit use of stat.hPaul Gortmaker
The module.h (via device.h) was pulling handfuls of implicitly present header files -- including basic stuff like stat.h. Fix up these stat.h users in advance so they don't break on the cleanup. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2011-09-15Remove unneeded version.h include from drivers/uwb/Jesper Juhl
It was pointed out by 'make versioncheck' that a include of linux/version.h is not needed in drivers/uwb/uwb-internal.h . This patch removes it. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-21uwb: Fix misspelling of neighbourhood in commentJesper Juhl
In drivers/uwb/uwbd.c, the word 'neighbourhood' is misspelled as 'neighboorhood' in a comment. Fix that. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-25drivers:uwb:scan.c remove one to many l's in the word.Justin P. Mattock
The patch below removes an extra "l" in the word. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-16Merge branch 'usb-next' into musb-mergeGreg Kroah-Hartman
* usb-next: (132 commits) USB: uas: Use GFP_NOIO instead of GFP_KERNEL in I/O submission path USB: uas: Ensure we only bind to a UAS interface USB: uas: Rename sense pipe and sense urb to status pipe and status urb USB: uas: Use kzalloc instead of kmalloc USB: uas: Fix up the Sense IU usb: musb: core: kill unneeded #include's DA8xx: assign name to MUSB IRQ resource usb: gadget: g_ncm added usb: gadget: f_ncm.c added usb: gadget: u_ether: prepare for NCM usb: pch_udc: Fix setup transfers with data out usb: pch_udc: Fix compile error, warnings and checkpatch warnings usb: add ab8500 usb transceiver driver USB: gadget: Implement runtime PM for MSM bus glue driver USB: gadget: Implement runtime PM for ci13xxx gadget USB: gadget: Add USB controller driver for MSM SoC USB: gadget: Introduce ci13xxx_udc_driver struct USB: gadget: Initialize ci13xxx gadget device's coherent DMA mask USB: gadget: Fix "scheduling while atomic" bugs in ci13xxx_udc USB: gadget: Separate out PCI bus code from ci13xxx_udc ...
2010-12-03uwb: fix compiler warning on i1480_est_id_tableNamhyung Kim
Annotate i1480_est_id_table as '__used' to fix following warning: CC drivers/uwb/i1480/i1480-est.o drivers/uwb/i1480/i1480-est.c:94: warning: ‘i1480_est_id_table’ defined but not used Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: David Vrabel <david.vrabel@csr.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-12-03uwb: fix compiler warning on whcrc_id_tableNamhyung Kim
Annotate whcrc_id_table as '__used' to fix following warning: CC drivers/uwb/whc-rc.o drivers/uwb/whc-rc.c:452: warning: ‘whcrc_id_table’ defined but not used Signed-off-by: Namhyung Kim <namhyung@gmail.com> Cc: David Vrabel <david.vrabel@csr.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-16drivers/uwb: Use printf extension %pR for struct resourceJoe Perches
Using %pR standardizes the struct resource output. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-11UWB: Return UWB_RSV_ALLOC_NOT_FOUND rather than crashing on NULL dereference ↵Jesper Juhl
if kzalloc fails Crashing on a null pointer deref is never a nice thing to do. It seems to me that it's better to simply return UWB_RSV_ALLOC_NOT_FOUND if kzalloc() fails in uwb_rsv_find_best_allocation(). Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: David Vrabel <david.vrabel@csr.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-10-25uwb: Remove the WLP subsystem and driversDavid Vrabel
The only Wimedia LLC Protocol (WLP) hardware was an Intel i1480 chip with a beta release of firmware that was never commercially available as a product. This hardware and firmware is no longer available as Intel sold their UWB/WLP IP. I also see little prospect of other WLP capable hardware ever being available. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2010-10-22uwb: use '%pM' format to print MAC addressAndy Shevchenko
Signed-off-by: Andy Shevchenko <andy.shevchenko@gmail.com> Cc: David Vrabel <david.vrabel@csr.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-19Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: uwb: remove duplicate cpu_to_le16() uwb: declare MODULE_FIRMWARE() in i1480 DFU driver uwb: make USB device id table constant uwb: wlp: refactor wlp_get_<attribute>() macros
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-07Driver core: create lock/unlock functions for struct deviceGreg Kroah-Hartman
In the future, we are going to be changing the lock type for struct device (once we get the lockdep infrastructure properly worked out) To make that changeover easier, and to possibly burry the lock in a different part of struct device, let's create some functions to lock and unlock a device so that no out-of-core code needs to be changed in the future. This patch creates the device_lock/unlock/trylock() functions, and converts all in-tree users to them. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Dave Young <hidave.darkstar@gmail.com> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Cc: Len Brown <len.brown@intel.com> Cc: Magnus Damm <damm@igel.co.jp> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Alex Chiang <achiang@hp.com> Cc: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andrew Patterson <andrew.patterson@hp.com> Cc: Yu Zhao <yu.zhao@intel.com> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Wolfram Sang <w.sang@pengutronix.de> Cc: CHENG Renquan <rqcheng@smu.edu.sg> Cc: Oliver Neukum <oliver@neukum.org> Cc: Frans Pop <elendil@planet.nl> Cc: David Vrabel <david.vrabel@csr.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07driver-core: Add attribute argument to class_attribute show/storeAndi Kleen
Passing the attribute to the low level IO functions allows all kinds of cleanups, by sharing low level IO code without requiring an own function for every piece of data. Also drivers can extend the attributes with own data fields and use that in the low level function. This makes the class attributes the same as sysdev_class attributes and plain attributes. This will allow further cleanups in drivers. Full tree sweep converting all users. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-25uwb: remove duplicate cpu_to_le16()Dan Carpenter
These parameters should be passed as cpu endian because we change it to little endian inside usb_control_msg(). On x86 cpu_to_le16() doesn't do anything so either way works but I think the original code would break on big endian systems. I removed the masks as well because that usb_control_msg() parameters are __u16 so we already only use the lower bits. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2010-02-05tree-wide: fix 'lenght' typo in comments and codeDaniel Mack
Some misspelled occurences of 'octet' and some comments were also fixed as I was on it. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Jiri Kosina <trivial@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-02-05uwb/i1480: add __init/__exit macrosPeter Huewe
Trivial patch which adds the __init/__exit macros to the module_init/ module_exit functions of uwb/i1480/i1480-est.c Signed-off-by: Peter Huewe <peterhuewe@gmx.de> Acked-by: David Vrabel <david.vrabel@csr.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-14uwb: declare MODULE_FIRMWARE() in i1480 DFU driverBen Hutchings
Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2010-01-14uwb: make USB device id table constantMárton Németh
The id_table field of the struct usb_device_id is constant in <linux/usb.h> so it is worth to make the initialization data also constant. Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2010-01-11uwb: wlp: refactor wlp_get_<attribute>() macrosDavid Vrabel
Refactor the wlp_get_<attribute>() macros to call a common function. This save over 4k of space and remove a spurious uninitialized variable warning with some versions of gcc. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-09tree-wide: fix a very frequent spelling mistakeDirk Hohndel
something-bility is spelled as something-blity so a grep for 'blit' would find these lines this is so trivial that I didn't split it by subsystem / copy additional maintainers - all changes are to comments The only purpose is to get fewer false positives when grepping around the kernel sources. Signed-off-by: Dirk Hohndel <hohndel@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-10-11headers: remove sched.h from interrupt.hAlexey Dobriyan
After m68k's task_thread_info() doesn't refer to current, it's possible to remove sched.h from interrupt.h and not break m68k! Many thanks to Heiko Carstens for allowing this. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com>
2009-10-01const: constify remaining file_operationsAlexey Dobriyan
[akpm@linux-foundation.org: fix KVM] Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-21trivial: remove unnecessary semicolonsJoe Perches
2009-09-17Merge branch 'for-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb * 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb: uwb: avoid radio controller reset loops uwb: stop uwbd thread if rc->start() fails uwb: handle radio controller events with out-of-range IDs correctly
2009-09-15driver model: constify attribute groupsDavid Brownell
Let attribute group vectors be declared "const". We'd like to let most attribute metadata live in read-only sections... this is a start. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-01uwb: convert to netdev_tx_tStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
