[ Upstream commit dc51ff91cf2d1e9a2d941da483602f71d4a51472 ]
The ->parent_module is the one that use in try_module_get. It should
also be the one the we use in module_put during vfio_platform_open().
Fixes: 32a2d71c4e80 ("vfio: platform: introduce vfio-platform-base module")
Signed-off-by: Max Gurtovoy <mgurtovoy@nvidia.com>
Message-Id: <20210518192133.59195-1-mgurtovoy@nvidia.com>
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
[ Upstream commit d1ce2c79156d3baf0830990ab06d296477b93c26 ]
The error code returned from vfio_ext_cap_len() is stored in 'len', not
in 'ret'.
Fixes: 89e1f7d4c66d ("vfio: Add PCI device driver")
Signed-off-by: Zhen Lei <thunder.leizhen@huawei.com>
Reviewed-by: Max Gurtovoy <mgurtovoy@nvidia.com>
Message-Id: <20210515020458.6771-1-thunder.leizhen@huawei.com>
[ Upstream commit 852b1beecb6ff9326f7ca4bc0fe69ae860ebdb9e ]
The eventfd context is used as our irqbypass token, therefore if an
eventfd is re-used, our token is the same. The irqbypass code will
return an -EBUSY in this case, but we'll still attempt to unregister
the producer, where if that duplicate token still exists, results in
removing the wrong object. Clear the token of failed producers so
that they harmlessly fall out when unregistered.
Fixes: 6d7425f109d2 ("vfio: Register/unregister irq_bypass_producer")
Reported-by: guomin chen <guomin_chen@sina.com>
Tested-by: guomin chen <guomin_chen@sina.com>
[ Upstream commit b872d0640840018669032b20b6375a478ed1f923 ]
The vfio_pci_release call will free and clear the error and request
eventfd ctx while these ctx could be in use at the same time in the
function like vfio_pci_request, and it's expected to protect them under
the vdev->igate mutex, which is missing in vfio_pci_release.
This issue is introduced since commit 1518ac272e78 ("vfio/pci: fix memory
leaks of eventfd ctx"),and since commit 5c5866c593bb ("vfio/pci: Clear
error and request eventfd ctx after releasing"), it's very easily to
trigger the kernel panic like this:
[ 9513.904346] Unable to handle kernel NULL pointer dereference at virtual address 0000000000000008
[ 9513.913091] Mem abort info:
[ 9513.915871] ESR = 0x96000006
[ 9513.918912] EC = 0x25: DABT (current EL), IL = 32 bits
[ 9513.924198] SET = 0, FnV = 0
[ 9513.927238] EA = 0, S1PTW = 0
[ 9513.930364] Data abort info:
[ 9513.933231] ISV = 0, ISS = 0x00000006
[ 9513.937048] CM = 0, WnR = 0
[ 9513.940003] user pgtable: 4k pages, 48-bit VAs, pgdp=0000007ec7d12000
[ 9513.946414] [0000000000000008] pgd=0000007ec7d13003, p4d=0000007ec7d13003, pud=0000007ec728c003, pmd=0000000000000000
[ 9513.956975] Internal error: Oops: 96000006 [#1] PREEMPT SMP
[ 9513.962521] Modules linked in: vfio_pci vfio_virqfd vfio_iommu_type1 vfio hclge hns3 hnae3 [last unloaded: vfio_pci]
[ 9513.972998] CPU: 4 PID: 1327 Comm: bash Tainted: G W 5.8.0-rc4+ #3
[ 9513.980443] Hardware name: Huawei TaiShan 2280 V2/BC82AMDC, BIOS 2280-V2 CS V3.B270.01 05/08/2020
[ 9513.989274] pstate: 80400089 (Nzcv daIf +PAN -UAO BTYPE=--)
[ 9513.994827] pc : _raw_spin_lock_irqsave+0x48/0x88
[ 9513.999515] lr : eventfd_signal+0x6c/0x1b0
[ 9514.003591] sp : ffff800038a0b960
[ 9514.006889] x29: ffff800038a0b960 x28: ffff007ef7f4da10
[ 9514.012175] x27: ffff207eefbbfc80 x26: ffffbb7903457000
[ 9514.017462] x25: ffffbb7912191000 x24: ffff007ef7f4d400
[ 9514.022747] x23: ffff20be6e0e4c00 x22: 0000000000000008
[ 9514.028033] x21: 0000000000000000 x20: 0000000000000000
[ 9514.033321] x19: 0000000000000008 x18: 0000000000000000
[ 9514.038606] x17: 0000000000000000 x16: ffffbb7910029328
[ 9514.043893] x15: 0000000000000000 x14: 0000000000000001
[ 9514.049179] x13: 0000000000000000 x12: 0000000000000002
[ 9514.054466] x11: 0000000000000000 x10: 0000000000000a00
[ 9514.059752] x9 : ffff800038a0b840 x8 : ffff007ef7f4de60
[ 9514.065038] x7 : ffff007fffc96690 x6 : fffffe01faffb748
[ 9514.070324] x5 : 0000000000000000 x4 : 0000000000000000
[ 9514.075609] x3 : 0000000000000000 x2 : 0000000000000001
[ 9514.080895] x1 : ffff007ef7f4d400 x0 : 0000000000000000
[ 9514.086181] Call trace:
[ 9514.088618] _raw_spin_lock_irqsave+0x48/0x88
[ 9514.092954] eventfd_signal+0x6c/0x1b0
[ 9514.096691] vfio_pci_request+0x84/0xd0 [vfio_pci]
[ 9514.101464] vfio_del_group_dev+0x150/0x290 [vfio]
[ 9514.106234] vfio_pci_remove+0x30/0x128 [vfio_pci]
[ 9514.111007] pci_device_remove+0x48/0x108
[ 9514.115001] device_release_driver_internal+0x100/0x1b8
[ 9514.120200] device_release_driver+0x28/0x38
[ 9514.124452] pci_stop_bus_device+0x68/0xa8
[ 9514.128528] pci_stop_and_remove_bus_device+0x20/0x38
[ 9514.133557] pci_iov_remove_virtfn+0xb4/0x128
[ 9514.137893] sriov_disable+0x3c/0x108
[ 9514.141538] pci_disable_sriov+0x28/0x38
[ 9514.145445] hns3_pci_sriov_configure+0x48/0xb8 [hns3]
[ 9514.150558] sriov_numvfs_store+0x110/0x198
[ 9514.154724] dev_attr_store+0x44/0x60
[ 9514.158373] sysfs_kf_write+0x5c/0x78
[ 9514.162018] kernfs_fop_write+0x104/0x210
[ 9514.166010] __vfs_write+0x48/0x90
[ 9514.169395] vfs_write+0xbc/0x1c0
[ 9514.172694] ksys_write+0x74/0x100
[ 9514.176079] __arm64_sys_write+0x24/0x30
[ 9514.179987] el0_svc_common.constprop.4+0x110/0x200
[ 9514.184842] do_el0_svc+0x34/0x98
[ 9514.188144] el0_svc+0x14/0x40
[ 9514.191185] el0_sync_handler+0xb0/0x2d0
[ 9514.195088] el0_sync+0x140/0x180
[ 9514.198389] Code: b9001020 d2800000 52800022 f9800271 (885ffe61)
[ 9514.204455] ---[ end trace 648de00c8406465f ]---
[ 9514.212308] note: bash[1327] exited with preempt_count 1
Cc: Qian Cai <cai@lca.pw>
Cc: Alex Williamson <alex.williamson@redhat.com>
Fixes: 1518ac272e78 ("vfio/pci: fix memory leaks of eventfd ctx")
Signed-off-by: Zeng Tao <prime.zeng@hisilicon.com>
[ Upstream commit 5c5866c593bbd444d0339ede6a8fb5f14ff66d72 ]
The next use of the device will generate an underflow from the
stale reference.
Reported-by: Daniel Wagner <dwagner@suse.de>
Reviewed-by: Cornelia Huck <cohuck@redhat.com>
Tested-by: Daniel Wagner <dwagner@suse.de>
[ Upstream commit 1518ac272e789cae8c555d69951b032a275b7602 ]
Finished a qemu-kvm (-device vfio-pci,host=0001:01:00.0) triggers a few
memory leaks after a while because vfio_pci_set_ctx_trigger_single()
calls eventfd_ctx_fdget() without the matching eventfd_ctx_put() later.
Fix it by calling eventfd_ctx_put() for those memory in
vfio_pci_release() before vfio_device_release().
unreferenced object 0xebff008981cc2b00 (size 128):
comm "qemu-kvm", pid 4043, jiffies 4294994816 (age 9796.310s)
hex dump (first 32 bytes):
01 00 00 00 6b 6b 6b 6b 00 00 00 00 ad 4e ad de ....kkkk.....N..
ff ff ff ff 6b 6b 6b 6b ff ff ff ff ff ff ff ff ....kkkk........
backtrace:
[<00000000917e8f8d>] slab_post_alloc_hook+0x74/0x9c
[<00000000df0f2aa2>] kmem_cache_alloc_trace+0x2b4/0x3d4
[<000000005fcec025>] do_eventfd+0x54/0x1ac
[<0000000082791a69>] __arm64_sys_eventfd2+0x34/0x44
[<00000000b819758c>] do_el0_svc+0x128/0x1dc
[<00000000b244e810>] el0_sync_handler+0xd0/0x268
[<00000000d495ef94>] el0_sync+0x164/0x180
unreferenced object 0x29ff008981cc4180 (size 128):
comm "qemu-kvm", pid 4043, jiffies 4294994818 (age 9796.290s)
backtrace:
Signed-off-by: Qian Cai <cai@lca.pw>
[ Upstream commit bc138db1b96264b9c1779cf18d5a3b186aa90066 ]
The PCI Code and ID Assignment Specification changed capability ID 0
from reserved to a NULL capability in the v1.1 revision. The NULL
capability is defined to include only the 16-bit capability header,
ie. only the ID and next pointer. Unfortunately vfio-pci creates a
map of config space, where ID 0 is used to reserve the standard type
0 header. Finding an actual capability with this ID therefore results
in a bogus range marked in that map and conflicts with subsequent
capabilities. As this seems to be a dummy capability anyway and we
already support dropping capabilities, let's hide this one rather than
delving into the potentially subtle dependencies within our map.
Seen on an NVIDIA Tesla T4.
[ Upstream commit 3e63b94b6274324ff2e7d8615df31586de827c4e ]
vfio_pci_disable() calls vfio_config_free() but forgets to call
free_perm_bits() resulting in memory leaks,
unreferenced object 0xc000000c4db2dee0 (size 16):
comm "qemu-kvm", pid 4305, jiffies 4295020272 (age 3463.780s)
hex dump (first 16 bytes):
00 00 ff 00 ff ff ff ff ff ff ff ff ff ff 00 00 ................
backtrace:
[<00000000a6a4552d>] alloc_perm_bits+0x58/0xe0 [vfio_pci]
[<00000000ac990549>] vfio_config_init+0xdf0/0x11b0 [vfio_pci]
init_pci_cap_msi_perm at drivers/vfio/pci/vfio_pci_config.c:1125
(inlined by) vfio_msi_cap_len at drivers/vfio/pci/vfio_pci_config.c:1180
(inlined by) vfio_cap_len at drivers/vfio/pci/vfio_pci_config.c:1241
(inlined by) vfio_cap_init at drivers/vfio/pci/vfio_pci_config.c:1468
(inlined by) vfio_config_init at drivers/vfio/pci/vfio_pci_config.c:1707
[<000000006db873a1>] vfio_pci_open+0x234/0x700 [vfio_pci]
[<00000000630e1906>] vfio_group_fops_unl_ioctl+0x8e0/0xb84 [vfio]
[<000000009e34c54f>] ksys_ioctl+0xd8/0x130
[<000000006577923d>] sys_ioctl+0x28/0x40
[<000000006d7b1cf2>] system_call_exception+0x114/0x1e0
[<0000000008ea7dd5>] system_call_common+0xf0/0x278
unreferenced object 0xc000000c4db2e330 (size 16):
00 ff ff 00 ff ff ff ff ff ff ff ff ff ff 00 00 ................
backtrace:
[<000000004c71914f>] alloc_perm_bits+0x44/0xe0 [vfio_pci]
[aw: rolled in follow-up patch]
commit 967628827f404b3063016c138ccc7b06c54350f8 upstream.
This loop ends with count set to -1 and not zero so the warning message
isn't printed when it should be. I've fixed this by change the postop
to a preop.
Fixes: 0990822c9866 ('VFIO: platform: reset: AMD xgbe reset module')
Reviewed-by: Eric Auger <eric.auger@linaro.org>
commit ce7585f3c4d76bca1dff4b66ae1ea32552954f9e upstream.
The size of the VPD area is not necessarily 4-byte aligned, so a
pci_vpd_read() might return less than 4 bytes. Zero our buffer and
accept anything other than an error. Intel X710 NICs exercise this.
Fixes: 4e1a635552d3 ("vfio/pci: Use kernel VPD access functions")
commit 5cbf3264bc715e9eb384e2b68601f8c02bb9a61d upstream.
Use follow_pfn() to get the PFN of a PFNMAP VMA instead of assuming that
vma->vm_pgoff holds the base PFN of the VMA. This fixes a bug where
attempting to do VFIO_IOMMU_MAP_DMA on an arbitrary PFNMAP'd region of
memory calculates garbage for the PFN.
Hilariously, this only got detected because the first "PFN" calculated
by vaddr_get_pfn() is PFN 0 (vma->vm_pgoff==0), and iommu_iova_to_phys()
uses PA==0 as an error, which triggers a WARN in vfio_unmap_unpin()
because the translation "failed". PFN 0 is now unconditionally reserved
on x86 in order to mitigate L1TF, which causes is_invalid_reserved_pfn()
to return true and in turns results in vaddr_get_pfn() returning success
for PFN 0. Eventually the bogus calculation runs into PFNs that aren't
reserved and leads to failure in vfio_pin_map_dma(). The subsequent
call to vfio_remove_dma() attempts to unmap PFN 0 and WARNs.
WARNING: CPU: 8 PID: 5130 at drivers/vfio/vfio_iommu_type1.c:750 vfio_unmap_unpin+0x2e1/0x310 [vfio_iommu_type1]
Modules linked in: vfio_pci vfio_virqfd vfio_iommu_type1 vfio ...
CPU: 8 PID: 5130 Comm: sgx Tainted: G W 5.6.0-rc5-705d787c7fee-vfio+ #3
Hardware name: Intel Corporation Mehlow UP Server Platform/Moss Beach Server, BIOS CNLSE2R1.D00.X119.B49.1803010910 03/01/2018
RIP: 0010:vfio_unmap_unpin+0x2e1/0x310 [vfio_iommu_type1]
Code: <0f> 0b 49 81 c5 00 10 00 00 e9 c5 fe ff ff bb 00 10 00 00 e9 3d fe
RSP: 0018:ffffbeb5039ebda8 EFLAGS: 00010246
RAX: 0000000000000000 RBX: ffff9a55cbf8d480 RCX: 0000000000000000
RDX: 0000000000000000 RSI: 0000000000000001 RDI: ffff9a52b771c200
RBP: 0000000000000000 R08: 0000000000000040 R09: 00000000fffffff2
R10: 0000000000000001 R11: ffff9a51fa896000 R12: 0000000184010000
R13: 0000000184000000 R14: 0000000000010000 R15: ffff9a55cb66ea08
FS: 00007f15d3830b40(0000) GS:ffff9a55d5600000(0000) knlGS:0000000000000000
CR2: 0000561cf39429e0 CR3: 000000084f75f005 CR4: 00000000003626e0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
vfio_remove_dma+0x17/0x70 [vfio_iommu_type1]
vfio_iommu_type1_ioctl+0x9e3/0xa7b [vfio_iommu_type1]
ksys_ioctl+0x92/0xb0
__x64_sys_ioctl+0x16/0x20
do_syscall_64+0x4c/0x180
entry_SYSCALL_64_after_hwframe+0x44/0xa9
RIP: 0033:0x7f15d04c75d7
Code: <48> 3d 01 f0 ff ff 73 01 c3 48 8b 0d 81 48 2d 00 f7 d8 64 89 01 48
Fixes: 73fa0d10d077 ("vfio: Type1 IOMMU implementation")
Signed-off-by: Sean Christopherson <sean.j.christopherson@intel.com>
[ Upstream commit 0cfd027be1d6def4a462cdc180c055143af24069 ]
pci_map_rom/pci_get_rom_size() performs memory access in the ROM.
In case the Memory Space accesses were disabled, readw() is likely
to trigger a synchronous external abort on some platforms.
In case memory accesses were disabled, re-enable them before the
call and disable them back again just after.
Signed-off-by: Eric Auger <eric.auger@redhat.com>
Suggested-by: Alex Williamson <alex.williamson@redhat.com>
commit d567fb8819162099035e546b11a736e29c2af0ea upstream.
Since irq_bypass_register_producer() is called after request_irq(), we
should do tear-down in reverse order: irq_bypass_unregister_producer()
then free_irq().
Specifically free_irq() may release resources required by the
irqbypass del_producer() callback. Notably an example provided by
Marc Zyngier on arm64 with GICv4 that he indicates has the potential
to wedge the hardware:
free_irq(irq)
__free_irq(irq)
irq_domain_deactivate_irq(irq)
its_irq_domain_deactivate()
[unmap the VLPI from the ITS]
kvm_arch_irq_bypass_del_producer(cons, prod)
kvm_vgic_v4_unset_forwarding(kvm, irq, ...)
its_unmap_vlpi(irq)
[Unmap the VLPI from the ITS (again), remap the original LPI]
Signed-off-by: Jiang Yi <giangyi@amazon.com>
Cc: stable@vger.kernel.org # v4.4+
Fixes: 6d7425f109d26 ("vfio: Register/unregister irq_bypass_producer")
Link: https://lore.kernel.org/kvm/20191127164910.15888-1-giangyi@amazon.com
Reviewed-by: Marc Zyngier <maz@kernel.org>
Reviewed-by: Eric Auger <eric.auger@redhat.com>
[aw: commit log]
[ Upstream commit 30ea32ab1951c80c6113f300fce2c70cd12659e4 ]
Free allocated vdev->msi_perm in error path.
Signed-off-by: Li Qiang <liq3ea@gmail.com>
[ Upstream commit 92c8026854c25093946e0d7fe536fd9eac440f06 ]
vfio_pci_enable() saves the device's initial configuration information
with the intent that it is restored in vfio_pci_disable(). However,
the commit referenced in Fixes: below replaced the call to
__pci_reset_function_locked(), which is not wrapped in a state save
and restore, with pci_try_reset_function(), which overwrites the
restored device state with the current state before applying it to the
device. Reinstate use of __pci_reset_function_locked() to return to
the desired behavior.
Fixes: 890ed578df82 ("vfio-pci: Use pci "try" reset interface")
Signed-off-by: hexin <hexin15@baidu.com>
Signed-off-by: Liu Qi <liuqi16@baidu.com>
Signed-off-by: Zhang Yu <zhangyu31@baidu.com>
[ Upstream commit 426b046b748d1f47e096e05bdcc6fb4172791307 ]
When compiling with -Wformat, clang emits the following warnings:
drivers/vfio/pci/vfio_pci.c:1601:5: warning: format specifies type
'unsigned short' but the argument has type 'unsigned int' [-Wformat]
vendor, device, subvendor, subdevice,
drivers/vfio/pci/vfio_pci.c:1601:13: warning: format specifies type
drivers/vfio/pci/vfio_pci.c:1601:21: warning: format specifies type
drivers/vfio/pci/vfio_pci.c:1601:32: warning: format specifies type
drivers/vfio/pci/vfio_pci.c:1605:5: warning: format specifies type
drivers/vfio/pci/vfio_pci.c:1605:13: warning: format specifies type
drivers/vfio/pci/vfio_pci.c:1605:21: warning: format specifies type
drivers/vfio/pci/vfio_pci.c:1605:32: warning: format specifies type
The types of these arguments are unconditionally defined, so this patch
updates the format character to the correct ones for unsigned ints.
Link: https://github.com/ClangBuiltLinux/linux/issues/378
Signed-off-by: Louis Taylor <louis@kragniz.eu>
Reviewed-by: Nick Desaulniers <ndesaulniers@google.com>
commit 492855939bdb59c6f947b0b5b44af9ad82b7e38c upstream.
Memory backed DMA mappings are accounted against a user's locked
memory limit, including multiple mappings of the same memory. This
accounting bounds the number of such mappings that a user can create.
However, DMA mappings that are not backed by memory, such as DMA
mappings of device MMIO via mmaps, do not make use of page pinning
and therefore do not count against the user's locked memory limit.
These mappings still consume memory, but the memory is not well
associated to the process for the purpose of oom killing a task.
To add bounding on this use case, we introduce a limit to the total
number of concurrent DMA mappings that a user is allowed to create.
This limit is exposed as a tunable module option where the default
value of 64K is expected to be well in excess of any reasonable use
case (a large virtual machine configuration would typically only make
use of tens of concurrent mappings).
This fixes CVE-2019-3882.
Tested-by: Eric Auger <eric.auger@redhat.com>
Reviewed-by: Peter Xu <peterx@redhat.com>
[groeck: Adjust for missing upstream commit]
commit cf0d53ba4947aad6e471491d5b20a567cbe92e56 upstream.
MRRS defines the maximum read request size a device is allowed to
make. Drivers will often increase this to allow more data transfer
with a single request. Completions to this request are bound by the
MPS setting for the bus. Aside from device quirks (none known), it
doesn't seem to make sense to set an MRRS value less than MPS, yet
this is a likely scenario given that user drivers do not have a
system-wide view of the PCI topology. Virtualize MRRS such that the
user can set MRRS >= MPS, but use MPS as the floor value that we'll
write to hardware.
commit 523184972b282cd9ca17a76f6ca4742394856818 upstream.
With virtual PCI-Express chipsets, we now see userspace/guest drivers
trying to match the physical MPS setting to a virtual downstream port.
Of course a lone physical device surrounded by virtual interconnects
cannot make a correct decision for a proper MPS setting. Instead,
let's virtualize the MPS control register so that writes through to
hardware are disallowed. Userspace drivers like QEMU assume they can
write anything to the device and we'll filter out anything dangerous.
Since mismatched MPS can lead to AER and other faults, let's add it
to the kernel side rather than relying on userspace virtualization to
handle it.
commit ddf9dc0eb5314d6dac8b19b1cc37c739c6896e7e upstream.
We use a BAR restore trick to try to detect when a user has performed
a device reset, possibly through FLR or other backdoors, to put things
back into a working state. This is important for backdoor resets, but
we can actually just virtualize the "front door" resets provided via
PCIe and AF FLR. Set these bits as virtualized + writable, allowing
the default write to set them in vconfig, then we can simply check the
bit, perform an FLR of our own, and clear the bit. We don't actually
have the granularity in PCI to specify the type of reset we want to
do, but generally devices don't implement both PCIe and AF FLR and
we'll favor these over other types of reset, so we should generally
lineup. We do test whether the device provides the requested FLR type
to stay consistent with hardware capabilities though.
This seems to fix several instance of devices getting into bad states
with userspace drivers, like dpdk, running inside a VM.
Reviewed-by: Greg Rose <grose@lightfleet.com>
[ Upstream commit e19f32da5ded958238eac1bbe001192acef191a2 ]
Here, pci_iomap can fail, handle this case release selected
pci regions and return -ENOMEM.
Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com>
[ Upstream commit 45e869714489431625c569d21fc952428d761476 ]
Using ancient compilers (gcc-4.5 or older) on ARM, we get a link
failure with the vfio-pci driver:
ERROR: "__aeabi_lcmp" [drivers/vfio/pci/vfio-pci.ko] undefined!
The reason is that the compiler tries to do a comparison of
a 64-bit range. This changes it to convert to a 32-bit number
explicitly first, as newer compilers do for themselves.
commit 5d6dee80a1e94cc284d03e06d930e60e8d3ecf7d upstream.
At the point where the kvm-vfio pseudo device wants to release its
vfio group reference, we can't always acquire a new reference to make
that happen. The group can be in a state where we wouldn't allow a
new reference to be added. This new helper function allows a caller
to match a file to a group to facilitate this. Given a file and
group, report if they match. Thus the caller needs to already have a
group reference to match to the file. This allows the deletion of a
group without acquiring a new reference.
Reviewed-by: Paolo Bonzini <pbonzini@redhat.com>
commit 811642d8d8a82c0cce8dc2debfdaf23c5a144839 upstream.
If vfio_iommu_group_notifier() acquires a group reference and that
reference becomes the last reference to the group, then vfio_group_put
introduces a deadlock code path where we're trying to unregister from
the iommu notifier chain from within a callout of that chain. Use a
work_struct to release this reference asynchronously.
[ Upstream commit bd00fdf198e2da475a2f4265a83686ab42d998a8 ]
The recently added mediated VFIO driver doesn't know about powerpc iommu.
It thus doesn't register a struct iommu_table_group in the iommu group
upon device creation. The iommu_data pointer hence remains null.
This causes a kernel oops when userspace tries to set the iommu type of a
container associated with a mediated device to VFIO_SPAPR_TCE_v2_IOMMU.
[ 82.585440] mtty mtty: MDEV: Registered
[ 87.655522] iommu: Adding device 83b8f4f2-509f-382f-3c1e-e6bfe0fa1001 to group 10
[ 87.655527] vfio_mdev 83b8f4f2-509f-382f-3c1e-e6bfe0fa1001: MDEV: group_id = 10
[ 116.297184] Unable to handle kernel paging request for data at address 0x00000030
[ 116.297389] Faulting instruction address: 0xd000000007870524
[ 116.297465] Oops: Kernel access of bad area, sig: 11 [#1]
[ 116.297611] SMP NR_CPUS=2048
[ 116.297611] NUMA
[ 116.297627] PowerNV
[ 116.297954] CPU: 33 PID: 7067 Comm: qemu-system-ppc Not tainted 4.10.0-rc5-mdev-test #8
[ 116.297993] task: c000000e7718b680 task.stack: c000000e77214000
[ 116.298025] NIP: d000000007870524 LR: d000000007870518 CTR: 0000000000000000
[ 116.298064] REGS: c000000e77217990 TRAP: 0300 Not tainted (4.10.0-rc5-mdev-test)
[ 116.298103] MSR: 9000000000009033 <SF,HV,EE,ME,IR,DR,RI,LE>
[ 116.298107] CR: 84004444 XER: 00000000
[ 116.298154] CFAR: c00000000000888c DAR: 0000000000000030 DSISR: 40000000 SOFTE: 1
GPR00: d000000007870518 c000000e77217c10 d00000000787b0ed c000000eed2103c0
GPR04: 0000000000000000 0000000000000000 c000000eed2103e0 0000000f24320000
GPR08: 0000000000000104 0000000000000001 0000000000000000 d0000000078729b0
GPR12: c00000000025b7e0 c00000000fe08400 0000000000000001 000001002d31d100
GPR16: 000001002c22c850 00003ffff315c750 0000000043145680 0000000043141bc0
GPR20: ffffffffffffffed fffffffffffff000 0000000020003b65 d000000007706018
GPR24: c000000f16cf0d98 d000000007706000 c000000003f42980 c000000003f42980
GPR28: c000000f1575ac00 c000000003f429c8 0000000000000000 c000000eed2103c0
[ 116.298504] NIP [d000000007870524] tce_iommu_attach_group+0x10c/0x360 [vfio_iommu_spapr_tce]
[ 116.298555] LR [d000000007870518] tce_iommu_attach_group+0x100/0x360 [vfio_iommu_spapr_tce]
[ 116.298601] Call Trace:
[ 116.298610] [c000000e77217c10] [d000000007870518] tce_iommu_attach_group+0x100/0x360 [vfio_iommu_spapr_tce] (unreliable)
[ 116.298671] [c000000e77217cb0] [d0000000077033a0] vfio_fops_unl_ioctl+0x278/0x3e0 [vfio]
[ 116.298713] [c000000e77217d40] [c0000000002a3ebc] do_vfs_ioctl+0xcc/0x8b0
[ 116.298745] [c000000e77217de0] [c0000000002a4700] SyS_ioctl+0x60/0xc0
[ 116.298782] [c000000e77217e30] [c00000000000b220] system_call+0x38/0xfc
[ 116.298812] Instruction dump:
[ 116.298828] 7d3f4b78 409effc8 3d220000 e9298020 3c800140 38a00018 608480c0 e8690028
[ 116.298869] 4800249d e8410018 7c7f1b79 41820230 <e93e0030> 2fa90000 419e0114 e9090020
[ 116.298914] ---[ end trace 1e10b0ced08b9120 ]---
This patch fixes the oops.
Reported-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com>
Signed-off-by: Greg Kurz <groug@kaod.org>
commit 0cfef2b7410b64d7a430947e0b533314c4f97153 upstream.
If the mmap_sem is contented then the vfio type1 IOMMU backend will
defer locked page accounting updates to a workqueue task. This has a
few problems and depending on which side the user tries to play, they
might be over-penalized for unmaps that haven't yet been accounted or
race the workqueue to enter more mappings than they're allowed. The
original intent of this workqueue mechanism seems to be focused on
reducing latency through the ioctl, but we cannot do so at the cost
of correctness. Remove this workqueue mechanism and update the
callers to allow for failure. We can also now recheck the limit under
write lock to make sure we don't exceed it.
vfio_pin_pages_remote() also now necessarily includes an unwind path
which we can jump to directly if the consecutive page pinning finds
that we're exceeding the user's memory limits. This avoids the
current lazy approach which does accounting and mapping up to the
fault, only to return an error on the next iteration to unwind the
entire vfio_dma.
Reviewed-by: Kirti Wankhede <kwankhede@nvidia.com>
commit 05692d7005a364add85c6e25a6c4447ce08f913a upstream.
The VFIO_DEVICE_SET_IRQS ioctl did not sufficiently sanitize
user-supplied integers, potentially allowing memory corruption. This
patch adds appropriate integer overflow checks, checks the range bounds
for VFIO_IRQ_SET_DATA_NONE, and also verifies that only single element
in the VFIO_IRQ_SET_DATA_TYPE_MASK bitmask is set.
VFIO_IRQ_SET_ACTION_TYPE_MASK is already correctly checked later in
vfio_pci_set_irqs_ioctl().
Furthermore, a kzalloc is changed to a kcalloc because the use of a
kzalloc with an integer multiplication allowed an integer overflow
condition to be reached without this patch. kcalloc checks for overflow
and should prevent a similar occurrence.
Signed-off-by: Vlad Tsyrklevich <vlad@tsyrklevich.net>
Cc: Ben Hutchings <ben.hutchings@codethink.co.uk>
[ Upstream commit 39701e56f5f16ea0cf8fc9e8472e645f8de91d23 ]
The iommu_table struct manages a hardware TCE table and a vmalloc'd
table with corresponding userspace addresses. Both are allocated when
the default DMA window is created and this happens when the very first
group is attached to a container.
As we are going to allow the userspace to configure container in one
memory context and pas container fd to another, we have to postpones
such allocations till a container fd is passed to the destination
user process so we would account locked memory limit against the actual
container user constrainsts.
This postpones the it_userspace array allocation till it is used first
time for mapping. The unmapping patch already checks if the array is
allocated.
Signed-off-by: Alexey Kardashevskiy <aik@ozlabs.ru>
Reviewed-by: David Gibson <david@gibson.dropbear.id.au>
Acked-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
commit c8952a707556e04374d7b2fdb3a079d63ddf6f2f upstream.
There are multiple cases in vfio_pci_set_ctx_trigger_single() where
we assume we can safely read from our data pointer without actually
checking whether the user has passed any data via the count field.
VFIO_IRQ_SET_DATA_NONE in particular is entirely broken since we
attempt to pull an int32_t file descriptor out before even checking
the data type. The other data types assume the data pointer contains
one element of their type as well.
In part this is good news because we were previously restricted from
doing much sanitization of parameters because it was missed in the
past and we didn't want to break existing users. Clearly DATA_NONE
is completely broken, so it must not have any users and we can fix
it up completely. For DATA_BOOL and DATA_EVENTFD, we'll just
protect ourselves, returning error when count is zero since we
previously would have oopsed.
Reported-by: Chris Thompson <the_cartographer@hotmail.com>
commit 8160c4e455820d5008a1116d2dca35f0363bb062 upstream.
Calling return copy_to_user(...) in an ioctl will not
do the right thing if there's a pagefault:
copy_to_user returns the number of bytes not copied
in this case.
Fix up vfio to do
return copy_to_user(...)) ?
-EFAULT : 0;
everywhere.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Revert commit 033291eccbdb ("vfio: Include No-IOMMU mode") due to lack
of a user. This was originally intended to fill a need for the DPDK
driver, but uptake has been slow so rather than support an unproven
kernel interface revert it and revisit when userspace catches up.
The first argument to the WARN() macro has to be a condition. I'm sort
of disappointed that this code doesn't generate a compiler warning. I
guess -Wformat-extra-args doesn't work in the kernel.
request_module already takes format strings, so no need to duplicate
the effort.
This pci_error_handlers structure is never modified, like all the other
pci_error_handlers structures, so declare it as const.
Done with the help of Coccinelle.
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
platform_driver does not need to set an owner because
platform_driver_register() will set it.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com>
Acked-by: Baptiste Reynal <b.reynal@virtualopensystems.com>
Pull VFIO updates from Alex Williamson:
- Use kernel interfaces for VPD emulation (Alex Williamson)
- Platform fix for releasing IRQs (Eric Auger)
- Type1 IOMMU always advertises PAGE_SIZE support when smaller mapping
sizes are available (Eric Auger)
- Platform fixes for incorrectly using copies of structures rather than
pointers to structures (James Morse)
- Rework platform reset modules, fix leak, and add AMD xgbe reset
module (Eric Auger)
- Fix vfio_device_get_from_name() return value (Joerg Roedel)
- No-IOMMU interface (Alex Williamson)
- Fix potential out of bounds array access in PCI config handling (Dan
Carpenter)
* tag 'vfio-v4.4-rc1' of git://github.com/awilliam/linux-vfio:
vfio/pci: make an array larger
vfio: Fix bug in vfio_device_get_from_name()
vfio: platform: reset: calxedaxgmac: fix ioaddr leak
vfio: platform: add dev_info on device reset
vfio: platform: use list of registered reset function
vfio: platform: add compat in vfio_platform_device
vfio: platform: reset: calxedaxgmac: add reset function registration
vfio: platform: introduce module_vfio_reset_handler macro
vfio: platform: add capability to register a reset function
vfio/platform: store mapped memory in region, instead of an on-stack copy
vfio/type1: handle case where IOMMU does not support PAGE_SIZE size
VFIO: platform: clear IRQ_NOAUTOEN when de-assigning the IRQ
vfio: Whitelist PCI bridges
Smatch complains about a possible out of bounds error:
drivers/vfio/pci/vfio_pci_config.c:1241 vfio_cap_init()
error: buffer overflow 'pci_cap_length' 20 <= 20
The problem is that pci_cap_length[] was defined as large enough to
hold "PCI_CAP_ID_AF + 1" elements. The code in vfio_cap_init() assumes
it has PCI_CAP_ID_MAX + 1 elements. Originally, PCI_CAP_ID_AF and
PCI_CAP_ID_MAX were the same but then we introduced PCI_CAP_ID_EA in
commit f80b0ba95964 ("PCI: Add Enhanced Allocation register entries")
so now the array is too small.
Let's fix this by making the array size PCI_CAP_ID_MAX + 1. And let's
make a similar change to pci_ext_cap_length[] for consistency. Also
both these arrays can be made const.
There is really no way to safely give a user full access to a DMA
capable device without an IOMMU to protect the host system. There is
also no way to provide DMA translation, for use cases such as device
assignment to virtual machines. However, there are still those users
that want userspace drivers even under those conditions. The UIO
driver exists for this use case, but does not provide the degree of
device access and programming that VFIO has. In an effort to avoid
code duplication, this introduces a No-IOMMU mode for VFIO.
This mode requires building VFIO with CONFIG_VFIO_NOIOMMU and enabling
the "enable_unsafe_noiommu_mode" option on the vfio driver. This
should make it very clear that this mode is not safe. Additionally,
CAP_SYS_RAWIO privileges are necessary to work with groups and
containers using this mode. Groups making use of this support are
named /dev/vfio/noiommu-$GROUP and can only make use of the special
VFIO_NOIOMMU_IOMMU for the container. Use of this mode, specifically
binding a device without a native IOMMU group to a VFIO bus driver
will taint the kernel and should therefore not be considered
supported. This patch includes no-iommu support for the vfio-pci bus
driver only.
Acked-by: Michael S. Tsirkin <mst@redhat.com>
The vfio_device_get_from_name() function might return a
non-NULL pointer, when called with a device name that is not
found in the list. This causes undefined behavior, in my
case calling an invalid function pointer later on:
kernel tried to execute NX-protected page - exploit attempt? (uid: 0)
BUG: unable to handle kernel paging request at ffff8800cb3ddc08
Call Trace:
[<ffffffffa03bd733>] ? vfio_group_fops_unl_ioctl+0x253/0x410 [vfio]
[<ffffffff811efc4d>] do_vfs_ioctl+0x2cd/0x4c0
[<ffffffff811f9657>] ? __fget+0x77/0xb0
[<ffffffff811efeb9>] SyS_ioctl+0x79/0x90
[<ffffffff81001bb0>] ? syscall_return_slowpath+0x50/0x130
[<ffffffff8167f776>] entry_SYSCALL_64_fastpath+0x16/0x75
Fix the issue by returning NULL when there is no device with
the requested name in the list.
Cc: stable@vger.kernel.org # v4.2+
Fixes: 4bc94d5dc95d ("vfio: Fix lockdep issue")
Signed-off-by: Joerg Roedel <jroedel@suse.de>
This patch introduces a module that registers and implements a low-level
reset function for the AMD XGBE device.
it performs the following actions:
- reset the PHY
- disable auto-negotiation
- disable & clear auto-negotiation IRQ
- soft-reset the MAC
Those tiny pieces of code are inherited from the native xgbe driver.
Signed-off-by: Eric Auger <eric.auger@linaro.org>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
In the current code the vfio_platform_region is copied on the stack.
As a consequence the ioaddr address is not iounmapped in the vfio
platform driver (vfio_platform_regions_cleanup). The patch uses the
pointer to the region instead.
It might be helpful for the end-user to check the device reset
function was found by the vfio platform reset framework.
Lets store a pointer to the struct device in vfio_platform_device
and trace when the reset function is called or not found.
Remove the static lookup table and use the dynamic list of registered
reset functions instead. Also load the reset module through its alias.
The reset struct module pointer is stored in vfio_platform_device.
We also remove the useless struct device pointer parameter in
vfio_platform_get_reset.
This patch fixes the issue related to the usage of __symbol_get, which
besides from being moot, prevented compilation with CONFIG_MODULES
disabled.
Also usage of MODULE_ALIAS makes possible to add a new reset module
without needing to update the framework. This was suggested by Arnd.
Let's retrieve the compatibility string on probe and store it
in the vfio_platform_device struct
This patch adds the reset function registration/unregistration.
This is handled through the module_vfio_reset_handler macro. This
latter also defines a MODULE_ALIAS which simplifies the load from
vfio-platform.
The module_vfio_reset_handler macro
- define a module alias
- implement module init/exit function which respectively registers
and unregisters the reset function.
In preparation for subsequent changes in reset function lookup,
lets introduce a dynamic list of reset combos (compat string,
reset module, reset function). The list can be populated/voided with
vfio_platform_register/unregister_reset. Those are not yet used in
this patch.
To prepare for vfio platform reset rework let's build
vfio_platform_common.c and vfio_platform_irq.c in a separate
module from vfio-platform and vfio-amba. This makes possible
to have separate module inits and works around a race between
platform driver init and vfio reset module init: that way we
make sure symbols exported by base are available when vfio-platform
driver gets probed.
The open/release being implemented in the base module, the ref
count is applied to the parent module instead.
Suggested-by: Arnd Bergmann <arnd@arndb.de>
vfio_platform_{read,write}_mmio() call ioremap_nocache() to map
a region of io memory, which they store in struct vfio_platform_region to
be eventually re-used, or unmapped by vfio_platform_regions_cleanup().
These functions receive a copy of their struct vfio_platform_region
argument on the stack - so these mapped areas are always allocated, and
always leaked.
Pass this argument as a pointer instead.
Fixes: 6e3f26456009 "vfio/platform: read and write support for the device fd"
Signed-off-by: James Morse <james.morse@arm.com>
Tested-by: Baptiste Reynal <b.reynal@virtualopensystems.com>
Current vfio_pgsize_bitmap code hides the supported IOMMU page
sizes smaller than PAGE_SIZE. As a result, in case the IOMMU
does not support PAGE_SIZE page, the alignment check on map/unmap
is done with larger page sizes, if any. This can fail although
mapping could be done with pages smaller than PAGE_SIZE.
This patch modifies vfio_pgsize_bitmap implementation so that,
in case the IOMMU supports page sizes smaller than PAGE_SIZE
we pretend PAGE_SIZE is supported and hide sub-PAGE_SIZE sizes.
That way the user will be able to map/unmap buffers whose size/
start address is aligned with PAGE_SIZE. Pinning code uses that
granularity while iommu driver can use the sub-PAGE_SIZE size
to map the buffer.
Acked-by: Will Deacon <will.deacon@arm.com>
