commit ea5d404655ba3b356d0c06d6a3c4f24112124522
broke build for the vhost test module used
by tools/virtio. Fix it up.
Signed-off-by: Zhi Yong Wu <wuzhy@linux.vnet.ibm.com>
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
Signed-off-by: Cong Wang <amwang@redhat.com>
We shouldn't hold any locks on release path. Pass a flag to
vhost_dev_cleanup to use the lockdep info correctly.
Tested-by: Sasha Levin <levinsasha928@gmail.com>
This is a tiny, but important, patch to vhost.
Vhost's worker thread only called schedule() when it had no work to do, and
it wanted to go to sleep. But if there's always work to do, e.g., the guest
is running a network-intensive program like netperf with small message sizes,
schedule() was *never* called. This had several negative implications (on
non-preemptive kernels):
1. Passing time was not properly accounted to the "vhost" process (ps and
top would wrongly show it using zero CPU time).
2. Sometimes error messages about RCU timeouts would be printed, if the
core running the vhost thread didn't schedule() for a very long time.
3. Worst of all, a vhost thread would "hog" the core. If several vhost
threads need to share the same core, typically one would get most of the
CPU time (and its associated guest most of the performance), while the
others hardly get any work done.
The trivial solution is to add
if (need_resched())
schedule();
After doing every piece of work. This will not do the heavy schedule() all
the time, just when the timer interrupt decided a reschedule is warranted
(so need_resched returns true).
Thanks to Abel Gordon for this patch.
Signed-off-by: Nadav Har'El <nyh@il.ibm.com>
By adding some module aliases, programs (or users) won't have to explicitly
call modprobe. Vhost-net will always be available if built into the kernel.
It does require assigning a permanent minor number for depmod to work.
Also:
- use C99 style initialization.
- add missing entry in documentation for loop-control
Acked-By: Kay Sievers <kay.sievers@vrfy.org>
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
The meth for calculating the # of outstanding buffers gives
incorrect results when vq->upend_idx wraps around zero.
Fix that.
Signed-off-by: Shirley Ma <xma@us.ibm.com>
On backend change, we flushed out outstanding skbs
but forgot to update the used ring, so that
done entries were left in the ubuf_info ring.
As a result we lose heads or complete incorrect ones,
crashing the guest or leaking memory.
Fix by updating the used ring.
As we now only update used ring after enabling
the backend, we can write flags with __put_user:
as that's done on data path, it matters.
Fix get/put refcount imbalance with zero copy,
which caused qemu to hang forever on guest driver unload.
We need to log writes when updating used flags and avail event
fields. Otherwise the guest may see a stale value after migration and
miss notifying the host.
Signed-off-by: Jason Wang <jasowang@redhat.com>
Move the used ring initialization after backend was set. This
makes it possible to disable the backend and tweak the used ring,
then restart. This will also make it possible to log the used ring
write correctly.
>From: Shirley Ma <mashirle@us.ibm.com>
This adds experimental zero copy support in vhost-net,
disabled by default. To enable, set
experimental_zcopytx module option to 1.
This patch maintains the outstanding userspace buffers in the
sequence it is delivered to vhost. The outstanding userspace buffers
will be marked as done once the lower device buffers DMA has finished.
This is monitored through last reference of kfree_skb callback. Two
buffer indices are used for this purpose.
The vhost-net device passes the userspace buffers info to lower device
skb through message control. DMA done status check and guest
notification are handled by handle_tx: in the worst case is all buffers
in the vq are in pending/done status, so we need to notify guest to
release DMA done buffers first before we get any new buffers from the
vq.
One known problem is that if the guest stops submitting
buffers, buffers might never get used until some
further action, e.g. device reset. This does not
seem to affect linux guests.
Signed-off-by: Shirley <xma@us.ibm.com>
Support the new event index feature. When acked,
utilize it to reduce the # of interrupts sent to the guest.
- Documentation/kvm/ to Documentation/virtual/kvm
- Documentation/uml/ to Documentation/virtual/uml
- Documentation/lguest/ to Documentation/virtual/lguest
throughout the kernel source tree.
Signed-off-by: Rob Landley <rob@landley.net>
Use of skb_queue_empty(&sock->sk->sk_receive_queue)
without taking the sk_receive_queue.lock is unsafe
or useless. Take it out.
Reported-by: Eric Dumazet <eric.dumazet@gmail.com>
vhost takes a sock lock to try and prevent
the skb from being pulled from the receive queue
after skb_peek. However this is not the right lock to use for that,
sk_receive_queue.lock is. Fix that up.
Codes duplication were found between the handling of mergeable and big
buffers, so this patch tries to unify them. This could be easily done
by adding a quota to the get_rx_bufs() which is used to limit the
number of buffers it returns (for mergeable buffer, the quota is
simply UIO_MAXIOV, for big buffers, the quota is just 1), and then the
previous handle_rx_mergeable() could be resued also for big buffers.
No need to check the support of mergeable buffer inside the recevie
loop as the whole handle_rx()_xx is in the read critical region. So
this patch move it ahead of the receiving loop.
copy_from_user is pretty high on perf top profile,
replacing it with __copy_from_user helps.
It's also safe because we do access_ok checks during setup.
Minor cleanup of vhost.c and net.c to match coding style.
Signed-off-by: Krishna Kumar <krkumar2@in.ibm.com>
When built with rcu checks enabled, vhost triggers
bogus warnings as vhost features are read without
dev->mutex sometimes, and private pointer is read
with our kind of rcu where work serves as a
read side critical section.
Fixing it properly is not trivial.
Disable the warnings by stubbing out the checks for now.
To detect that a sequence number is done, we are doing math on unsigned
integers so the result is unsigned too. Not what was intended for the <=
comparison. The result is user stuck forever in flush call.
Convert to int to fix this.
Further, get rid of ({}) to make code clearer.
This adds a test module for vhost infrastructure.
Intentionally not tied to kbuild to prevent people
from installing and loading it accidentally.
We really store a page offset in write_address,
so rename it write_page to avoid confusion.
Fix two bugs in dirty page logging:
When counting pages we should increase address by 1 instead of
VHOST_PAGE_SIZE. Make log_write() correctly process requests
that cross pages with write_address not starting at page boundary.
Reported-by: Jason Wang <jasowang@redhat.com>
vhost.c does not need to know about sockets,
don't include sock.h
Incorrect rcu check was used as rcu isn't done
under mutex here. Force check to 1 for now,
to stop it from complaining.
We do access_ok checks on all ring values on an ioctl,
so we don't need to redo them on each access.
We do access_ok checks at setup time, so we don't need to
Move use/unuse mm to vhost.c which makes it possible to batch these
operations.
makes it possible to batch use/unuse mm
Delete successive assignments to the same location.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
expression i;
*i = ...;
i = ...;
// </smpl>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1699 commits)
bnx2/bnx2x: Unsupported Ethtool operations should return -EINVAL.
vlan: Calling vlan_hwaccel_do_receive() is always valid.
tproxy: use the interface primary IP address as a default value for --on-ip
tproxy: added IPv6 support to the socket match
cxgb3: function namespace cleanup
tproxy: added IPv6 support to the TPROXY target
tproxy: added IPv6 socket lookup function to nf_tproxy_core
be2net: Changes to use only priority codes allowed by f/w
tproxy: allow non-local binds of IPv6 sockets if IP_TRANSPARENT is enabled
tproxy: added tproxy sockopt interface in the IPV6 layer
tproxy: added udp6_lib_lookup function
tproxy: added const specifiers to udp lookup functions
tproxy: split off ipv6 defragmentation to a separate module
l2tp: small cleanup
nf_nat: restrict ICMP translation for embedded header
can: mcp251x: fix generation of error frames
can: mcp251x: fix endless loop in interrupt handler if CANINTF_MERRF is set
can-raw: add msg_flags to distinguish local traffic
9p: client code cleanup
rds: make local functions/variables static
Fix up conflicts in net/core/dev.c, drivers/net/pcmcia/smc91c92_cs.c and
drivers/net/wireless/ath/ath9k/debug.c as per David
* 'llseek' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl:
vfs: make no_llseek the default
vfs: don't use BKL in default_llseek
llseek: automatically add .llseek fop
libfs: use generic_file_llseek for simple_attr
mac80211: disallow seeks in minstrel debug code
lirc: make chardev nonseekable
viotape: use noop_llseek
raw: use explicit llseek file operations
ibmasmfs: use generic_file_llseek
spufs: use llseek in all file operations
arm/omap: use generic_file_llseek in iommu_debug
lkdtm: use generic_file_llseek in debugfs
net/wireless: use generic_file_llseek in debugfs
drm: use noop_llseek
net/core/dev.c
All file_operations should get a .llseek operation so we can make
nonseekable_open the default for future file operations without a
.llseek pointer.
The three cases that we can automatically detect are no_llseek, seq_lseek
and default_llseek. For cases where we can we can automatically prove that
the file offset is always ignored, we use noop_llseek, which maintains
the current behavior of not returning an error from a seek.
New drivers should normally not use noop_llseek but instead use no_llseek
and call nonseekable_open at open time. Existing drivers can be converted
to do the same when the maintainer knows for certain that no user code
relies on calling seek on the device file.
The generated code is often incorrectly indented and right now contains
comments that clarify for each added line why a specific variant was
chosen. In the version that gets submitted upstream, the comments will
be gone and I will manually fix the indentation, because there does not
seem to be a way to do that using coccinelle.
Some amount of new code is currently sitting in linux-next that should get
the same modifications, which I will do at the end of the merge window.
Many thanks to Julia Lawall for helping me learn to write a semantic
patch that does all this.
===== begin semantic patch =====
// This adds an llseek= method to all file operations,
// as a preparation for making no_llseek the default.
// The rules are
// - use no_llseek explicitly if we do nonseekable_open
// - use seq_lseek for sequential files
// - use default_llseek if we know we access f_pos
// - use noop_llseek if we know we don't access f_pos,
// but we still want to allow users to call lseek
@ open1 exists @
identifier nested_open;
nested_open(...)
nonseekable_open(...)
@ open exists@
identifier open_f;
identifier i, f;
identifier open1.nested_open;
int open_f(struct inode *i, struct file *f)
nested_open(...)
@ read disable optional_qualifier exists @
identifier read_f;
identifier f, p, s, off;
type ssize_t, size_t, loff_t;
expression E;
identifier func;
ssize_t read_f(struct file *f, char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ read_no_fpos disable optional_qualifier exists @
identifier read_f;
... when != off
@ write @
identifier write_f;
expression E;
identifier func;
ssize_t write_f(struct file *f, const char *p, size_t s, loff_t *off)
*off = E
*off += E
func(..., off, ...)
E = *off
@ write_no_fpos @
identifier write_f;
... when != off
@ fops0 @
identifier fops;
struct file_operations fops = {
@ has_llseek depends on fops0 @
identifier fops0.fops;
identifier llseek_f;
.llseek = llseek_f,
@ has_read depends on fops0 @
identifier read_f;
.read = read_f,
@ has_write depends on fops0 @
identifier write_f;
.write = write_f,
@ has_open depends on fops0 @
identifier open_f;
.open = open_f,
// use no_llseek if we call nonseekable_open
@ nonseekable1 depends on !has_llseek && has_open @
identifier nso ~= "nonseekable_open";
... .open = nso, ...
+.llseek = no_llseek, /* nonseekable */
@ nonseekable2 depends on !has_llseek @
identifier open.open_f;
... .open = open_f, ...
+.llseek = no_llseek, /* open uses nonseekable */
// use seq_lseek for sequential files
@ seq depends on !has_llseek @
identifier sr ~= "seq_read";
... .read = sr, ...
+.llseek = seq_lseek, /* we have seq_read */
// use default_llseek if there is a readdir
@ fops1 depends on !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier readdir_e;
// any other fop is used that changes pos
... .readdir = readdir_e, ...
+.llseek = default_llseek, /* readdir is present */
// use default_llseek if at least one of read/write touches f_pos
@ fops2 depends on !fops1 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read.read_f;
// read fops use offset
... .read = read_f, ...
+.llseek = default_llseek, /* read accesses f_pos */
@ fops3 depends on !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier write.write_f;
// write fops use offset
... .write = write_f, ...
+ .llseek = default_llseek, /* write accesses f_pos */
// Use noop_llseek if neither read nor write accesses f_pos
@ fops4 depends on !fops1 && !fops2 && !fops3 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
identifier read_no_fpos.read_f;
identifier write_no_fpos.write_f;
.write = write_f,
.read = read_f,
+.llseek = noop_llseek, /* read and write both use no f_pos */
@ depends on has_write && !has_read && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* write uses no f_pos */
@ depends on has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* read uses no f_pos */
@ depends on !has_read && !has_write && !fops1 && !fops2 && !has_llseek && !nonseekable1 && !nonseekable2 && !seq @
+.llseek = noop_llseek, /* no read or write fn */
===== End semantic patch =====
Cc: Julia Lawall <julia@diku.dk>
access_ok() returns 1 if it's OK otherwise it should return 0.
Merge reason: Update from -rc3 to -rc7.
git://git.kernel.org/pub/scm/linux/kernel/git/paulmck/linux-2.6-rcu into core/rcu
Qemu supports up to UIO_MAXIOV s/g so we have to match that because guest
drivers may rely on this.
Allocate indirect and log arrays dynamically to avoid using too much contigious
memory and make the length of hdr array to match the header length since each
iovec entry has a least one byte.
Test with copying large files w/ and w/o migration in both linux and windows
guests.
The log eventfd signalling got put in dead code.
We didn't notice because qemu currently does polling
instead of eventfd select.
In mergeable buffer case, we use headcount, log_num
and seg as indexes in same-size arrays, and
we know that headcount <= seg and
log_num equals either 0 or seg.
Therefore, the right thing to do is range-check seg,
not headcount as we do now: these will be different
if guest chains s/g descriptors (this does not
happen now, but we can not trust the guest).
Long term, we should add BUG_ON checks to verify
two other indexes are what we think they should be.
vhost should set worker to NULL on cgroups attach failure,
so that we won't try to destroy the worker again on close.
Since 2.6.36-rc1, non-root users of vhost-net fail to attach
if they are in any cgroups.
The reason is that when qemu uses vhost, vhost wants to attach
its thread to all cgroups that qemu has. But we got the API backwards,
so a non-priveledged process (Qemu) tried to control
the priveledged one (vhost), which fails.
Fix this by switching to the new cgroup_attach_task_all,
and running it from the vhost thread.
Its currently illegal to call kthread_stop(NULL)
Reported-by: Ingo Molnar <mingo@elte.hu>
Acked-by: Tejun Heo <tj@kernel.org>
Also add rcu_dereference_protected() for code paths where locks are held.
Cc: "Michael S. Tsirkin" <mst@redhat.com>
