path: root/drivers/video/atmel_lcdfb.c
2011-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: (140 commits) MAINTAINERS: de-orphan fbdev. MAINTAINERS: Add file pattern for fb dt bindings. video: Move sm501fb devicetree binding documentation to a better place. fbcon: fix situation where fbcon gets deinitialised and can't reinit. video, sm501: add OF binding to support SM501 video, sm501: add edid and commandline support video, sm501: add I/O functions for use on powerpc video: Fix EDID macros H_SYNC_WIDTH and H_SYNC_OFFSET fbcon: Bugfix soft cursor detection in Tile Blitting video: add missing framebuffer_release in error path video: metronomefb: add __devexit_p around reference to metronomefb_remove video: hecubafb: add __devexit_p around reference to hecubafb_remove drivers:video:aty:radeon_base Fix typo occationally to occasionally atmel_lcdfb: add fb_blank function atmel_lcdfb: implement inverted contrast pwm video: s3c-fb: return proper error if clk_get fails uvesafb,vesafb: create WC or WB PAT-entries video: ffb: fix ffb_probe error path radeonfb: Let hwmon driver probe the "monid" I2C bus fbdev: sh_mobile_lcdc: checking NULL instead of IS_ERR() ...
2011-03-22backlight: add backlight typeMatthew Garrett
There may be multiple ways of controlling the backlight on a given machine. Allow drivers to expose the type of interface they are providing, making it possible for userspace to make appropriate policy decisions. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-22atmel_lcdfb: add fb_blank functionAndreas Bießmann
Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-22atmel_lcdfb: implement inverted contrast pwmAndreas Bießmann
This patch introduces lcdc->lcdcon_pol_negative which set CONTRAST_CTR register to inverted polarity. Signed-off-by: Andreas Bießmann <biessmann@corscience.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-16backlight: constify backlight_opsLionel Debroux
backlight_device_register has been expecting a const "ops" argument, and using it as such, since 9905a43b2d563e6f89e4c63c4278ada03f2ebb14. Let's make the remaining backlight_ops instances const. Inspired by hunks of the grsecurity patch, updated for newer kernels. Signed-off-by: Lionel Debroux <lionel_debroux@yahoo.fr> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16backlight: Allow properties to be passed at registrationMatthew Garrett
Values such as max_brightness should be set before backlights are registered, but the current API doesn't allow that. Add a parameter to backlight_device_register and update drivers to ensure that they set this correctly. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2009-12-07Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: kernel/irq/chip.c
2009-11-12atmel_lcdfb: new alternate pixel clock formulaNicolas Ferre
at91sam9g45 non ES lots have an alternate pixel clock calculation formula. Introduce this one with condition on the cpu_is_xxxxx() macros. Newer 9g45 SOC will not have good pixel clock calculation without this fix. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-09atmel_lcdfb.c: fix printk() type mismatchClaudio Scordino
This patch fixes a type mismatch when calling dev_info() in the atmel_lcdfb.c driver. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-12Merge branches 'arm', 'at91', 'bcmring', 'ep93xx', 'mach-types', 'misc' and ↵Russell King
'w90x900' into devel
2009-07-23[ARM] 5614/1: at91: atmel_lcdfb: add at91sam9g10 support to atmel LCD driverNicolas Ferre
Modify atmel LCD driver: atmel_lcdfb for at91sam9g10. This add a clock management equivalent to at91sam9261. Signed-off-by: Hong Xu <hong.xu@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-07-08atmel_lcdfb: fix regression with uninitalized fb_info->mm_lock mutexKrzysztof Helt
Remove not needed locking of the fb_info->mm_lock mutex before a frambuffer is registered. This fixes a problem with uninitialized the fb_info->mm_lock mutex introduced by the commit 537a1bf059f " fbdev: add mutex for fb_mmap locking" Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30fbdev: add mutex for fb_mmap lockingKrzysztof Helt
Add a mutex to avoid a circular locking problem between the mm layer semaphore and fbdev ioctl mutex through the fb_mmap() call. Also, add mutex to all places where smem_start and smem_len fields change so the mutex inside the fb_mmap() is actually used. Changing of these fields before calling the framebuffer_register() are not mutexed. This is 2.6.31 material. It removes one lockdep (fb_mmap() and register_framebuffer()) but there is still another one (fb_release() and register_framebuffer()). It also cleans up handling of the smem_start and smem_len fields used by mutexed section of the fb_mmap(). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16atmel-lcdc: fix pixclock upper bound detectionBen Nizette
AFAICT the code which checks that the requested pixclock value is within bounds is incorrect. It ensures that the lcdc core clock is at least (bytes per pixel) times higher than the pixel clock rather than just greater than or equal to. There are tighter restrictions on the pixclock value as a function of bus width for STN panels but even then it isn't a simple relationship as currently checked for. IMO either something like the below patch should be applied or else more detailed checking logic should be implemented which takes in to account the panel type as well. Signed-off-by: Ben Nizette <bn@niasdigital.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Daniel Glockner <dg@emlix.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-05-29atmel_lcdfb: correct fifo size for some productsNicolas Ferre
Remove wrong fifo size definition for some AT91 products. Due to a misunderstanding of some AT91 datasheets, a fifo size of 2048 (words) has been introduced by mistake. In fact, all products (AT91/AT32) are sharing the same fifo size of 512 words. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Andrew Victor <avictor.za@gmail.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-11-19drivers/video: bad error test before a dereferenceJulien Brunel
The error test that follows the call to backlight_device_register semms not to concern the right variable. A simplified version of the semantic match that finds this problem is as follows: (http://www.emn.fr/x-info/coccinelle/) // <smpl> @def0@ expression x; position p0; @@ x@p0 = backlight_device_register(...) @protected@ expression def0.x,E; position def0.p0; position p; statement S; @@ x@p0 ... when != x = E if (!IS_ERR(x) && ...) {<... x@p ...>} else S @unprotected@ expression def0.x; identifier fld; position def0.p0; position p != protected.p; @@ x@p0 ... when != x = E * x@p->fld // </smpl> Signed-off-by: Julien Brunel <brunel@diku.dk> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16atmel_lcdfb: disallow setting larger resolution than the framebuffer memory ↵Stanislaw Gruszka
can handle Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-09Merge branch 'for-rmk' of git://source.mvista.com/git/linux-davinci-2.6.gitRussell King
Merge branch 'davinci' into devel
2008-09-18[ARM] 5228/1: Add the RGB555 wiring for the atmel LCDGuillaume GARDET
Add the RGB555 wiring for the atmel LCD. Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-09-13atmel_lcdfb: disable LCD and DMA engines when suspendingHaavard Skinnemoen
When suspending the system with atmel_lcdfb enabled, I sometimes see this: atmel_lcdfb atmel_lcdfb.0: FIFO underflow 0x10 Which can be explained by the fact that we're not stopping the LCD controller and its DMA engine when suspending, we're just gating the clocks to them. There's another potential issue which may be harder to trigger but much more nasty: If we gate the clocks at _just_ the right moment, e.g. when the DMA engine is doing a bus transaction, we may cause the DMA engine to violate the system bus protocol and cause a lockup. Avoid these issues by shutting down the LCD controller before entering suspend (and restarting it when resuming). This prevents the underrun from happening in the first place, and prevents whatever nastiness is happening when the bus clock stops in the middle of a DMA transfer. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-09-05atmel_lcdfb: fix oops in rmmod when framebuffer fails to registerStanislaw Gruszka
If framebuffer registration failed in platform driver ->probe() callback, dev_get_drvdata() points to freed memory region, but ->remove() function try to use it and the following oops occurs: Unable to handle kernel NULL pointer dereference at virtual address 00000228 pgd = c3a20000 [00000228] *pgd=23a2b031, *pte=00000000, *ppte=00000000 Internal error: Oops: 17 [#1] Modules linked in: atmel_lcdfb(-) cfbcopyarea cfbimgblt cfbfillrect [last unloaded: atmel_lcdfb] CPU: 0 Not tainted (2.6.27-rc2 #116) PC is at atmel_lcdfb_remove+0x14/0xf8 [atmel_lcdfb] LR is at platform_drv_remove+0x20/0x24 pc : [<bf006bc4>] lr : [<c0157d28>] psr: a0000013 sp : c3a45e84 ip : c3a45ea0 fp : c3a45e9c r10: 00000002 r9 : c3a44000 r8 : c0026c04 r7 : 00000880 r6 : c02bb228 r5 : 00000000 r4 : c02bb230 r3 : bf007e3c r2 : c02bb230 r1 : 00000004 r0 : c02bb228 Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user Control: 0005317f Table: 23a20000 DAC: 00000015 Process rmmod (pid: 6799, stack limit = 0xc3a44260) Stack: (0xc3a45e84 to 0xc3a46000) 5e80: c02bb230 bf007e3c bf007e3c c3a45eac c3a45ea0 c0157d28 bf006bc0 5ea0: c3a45ec4 c3a45eb0 c0156d20 c0157d18 c02bb230 c02bb2d8 c3a45ee0 c3a45ec8 5ec0: c0156da8 c0156cb8 bf007e3c bf007ee0 c02c8e14 c3a45efc c3a45ee4 c0156018 5ee0: c0156d50 bf007e3c bf007ee0 00000000 c3a45f18 c3a45f00 c0157220 c0155f9c 5f00: 00000000 bf007ee0 bf008000 c3a45f28 c3a45f1c c0157e34 c01571ec c3a45f38 5f20: c3a45f2c bf006ba8 c0157e30 c3a45fa4 c3a45f3c c005772c bf006ba4 656d7461 5f40: 636c5f6c 00626664 c004c988 c3a45f80 c3a45f5c 00000000 c3a45fb0 00000000 5f60: ffffffff becaccd8 00000880 00000000 000a5e80 00000001 bf007ee0 00000880 5f80: c3a45f84 00000000 becaccd4 00000002 000003df 00000081 00000000 c3a45fa8 5fa0: c0026a60 c0057584 00000002 000003df 00900081 000a5e80 00000880 00000000 5fc0: becaccd4 00000002 000003df 00000000 000a5e80 00000001 00000002 0000005f 5fe0: 4004f5ec becacbe8 0001a158 4004f5fc 20000010 00900081 f9ffbadf 7bbfb2bb Backtrace: [<bf006bb0>] (atmel_lcdfb_remove+0x0/0xf8 [atmel_lcdfb]) from [<c0157d28>] (platform_drv_remove+0x20/0x24) r6:bf007e3c r5:bf007e3c r4:c02bb230 [<c0157d08>] (platform_drv_remove+0x0/0x24) from [<c0156d20>] (__device_release_driver+0x78/0x98) [<c0156ca8>] (__device_release_driver+0x0/0x98) from [<c0156da8>] (driver_detach+0x68/0x90) r5:c02bb2d8 r4:c02bb230 [<c0156d40>] (driver_detach+0x0/0x90) from [<c0156018>] (bus_remove_driver+0x8c/0xb4) r6:c02c8e14 r5:bf007ee0 r4:bf007e3c [<c0155f8c>] (bus_remove_driver+0x0/0xb4) from [<c0157220>] (driver_unregister+0x44/0x48) r6:00000000 r5:bf007ee0 r4:bf007e3c [<c01571dc>] (driver_unregister+0x0/0x48) from [<c0157e34>] (platform_driver_unregister+0x14/0x18) r6:bf008000 r5:bf007ee0 r4:00000000 [<c0157e20>] (platform_driver_unregister+0x0/0x18) from [<bf006ba8>] (atmel_lcdfb_exit+0x14/0x1c [atmel_lcdfb]) [<bf006b94>] (atmel_lcdfb_exit+0x0/0x1c [atmel_lcdfb]) from [<c005772c>] (sys_delete_module+0x1b8/0x22c) [<c0057574>] (sys_delete_module+0x0/0x22c) from [<c0026a60>] (ret_fast_syscall+0x0/0x2c) r7:00000081 r6:000003df r5:00000002 r4:becaccd4 Code: e92dd870 e24cb004 e59050c4 e1a06000 (e5954228) ---[ end trace 85476b184d9e68d8 ]--- This patch fixes the oops. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12atmel_lcdfb: add board parameter specify framebuffer memory sizeHaavard Skinnemoen
Specify how much physically continuous, DMA capable memory will be allocated at driver initialization time. This allow to create framebuffer device with larger virtual resolution. Combine with y-panning this can be used to implement double buffering acceleration method. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12atmel_lcdfb: set ypanstep to 1 and enable y-panning on AT91Haavard Skinnemoen
Panning in the y-direction can be done by simply changing the DMA base address. This code is already in place, but FBIOPAN_DISPLAY will currently fail because ypanstep is 0. Set ypanstep to 1 to indicate that we do support y-panning and also set the necessary acceleration flags on AT91 (AVR32 already have them.) Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-24atmel_lcdfb: avoid division by zeroNicolas Ferre
Avoid division by zero in atmel_lcdfb_check_var() function. If pixclock is not specified while passing a var structure in the check_var() funtion, a division by zero occurs (when translating pixclock to KHz). This patch adds a checking of this value and try to choose a video mode in the modelist. The mode found in the probe function in added to the modelist. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24atmel_lcdfb: FIFO underflow managementNicolas Ferre
Manage atmel_lcdfb FIFO underflow Resetting the LCD and DMA allows to fix screen shifting after a FIFO underflow. It follows reset sequence from errata "LCD Screen Shifting After a Reset". Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13atmel_lcdfb: fix pixclock divider calculationNicolas Ferre
Fix divider calculation and allow CLKVAL = 0 (divisor 2) It was not possible to get the clock value 0 (divisor 2) because the test "<=0" force the BYPASS bit to be activated instead. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Per Hedblom <per.hedblom@abem.se> Cc: Roel Kluin <12o3l@tiscali.nl> Cc: Jan Weber <jw022609@uni-greifswald.de> Cc: Andrew Victor <linux@maxim.org.za> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28atmel_lcdfb: adjust fifo size for at91sam9rlNicolas Ferre
AT91SAM9RL soc has a 2048 bytes deep FIFO, like AT91SAM9263. [bn@niasdigital.com: fix build breakage in atmel_lcdfb] Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Nicolas FERRE <nicolas.ferre@rfo.atmel.com> Cc: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28atmel_lcdfb: wiring BGR to RGB color modeNicolas Ferre
Adds different wiring mode for the LCD screen. The legacy atmel LCDC IP uses a non standard color mode, "BGR-555.1" instead "RGB-565". The major part of graphic stacks for embedded systems uses only "RGB-565". It is possible to swap LCD IOs instead of doing this bit swapping by software (See application note AT91SAM9 LCD Controller http://www.atmel.com/dyn/resources/prod_documents/doc6300.pdf) This wire swapping is done on the at91sam9rl-ek board (board code using this patch will come later). Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <avictor.za@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28atmel_lcdfb: suspend/resume supportDavid Brownell
Teach atmel_lcdfb driver how to suspend/resume. Note that the backlight control should probably do more of the same stuff: turning off display power (more than just the backlight) and stopping the clocks (and dma to drive the no-longer-seen display). No point in wasting power to generate images that can't be observed, after all... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Andrew Victor <avictor.za@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28atmel_lcdfb: don't initialize a pre-allocated framebufferHaavard Skinnemoen
If the user specified a fixed framebuffer address on the command line, it may have been initialized already with a splash image or something, so we shouldn't clear it. Therefore, we should only initialize the framebuffer if we allocated it ourselves. This patch also updates the AVR32 setup code to clear the framebuffer if it allocated it itself, i.e. the user didn't provide a fixed address or the reservation failed. I've updated the at91 platform code as well so that it initializes the framebuffer if it is located in SRAM, but I haven't tested that it actually works. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Nicolas FERRE <nicolas.ferre@rfo.atmel.com> Cc: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06atmel_lcdfb: backlight controlDavid Brownell
On the sam9 EK boards, the LCD backlight is hooked up to a PWM output from the LCD controller. It's controlled by "contrast" registers though. This patch lets boards declare that they have that kind of backlight control. The driver can then export this control, letting screenblank and other operations actually take effect ... reducing the typically substantial power drain from the backlight. Note that it's not fully cooked - doesn't force backlight off during system suspend - the "power" and "blank" events may not be done right This should be easily added in the future. [nicolas.ferre@atmel.com: remove unneeded inline and rename functions] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Cc: Andrew Victor <linux@maxim.org.za> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06atmel_lcdfb: validate display timingsHaavard Skinnemoen
Setting a display timing parameter too high or too low may cause it to wrap around and thus become completely wrong. Validate the timings in atmel_lcdfb_check_var() and saturate to the highest or lowest possible value if necessary. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-26[ARM] 4764/1: [AT91] AT91CAP9 core supportAndrew Victor
Add support for Atmel's AT91CAP9 Customizable Microcontroller family. <http://www.atmel.com/products/AT91CAP/Default.asp> Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Andrew Victor <linux@maxim.org.za> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-01-14MAINTAINERS: email update and add missing entryNicolas Ferre
- MAINTAINERS email update - add atmel_lcdfb entry Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29atmel_lcdfb: LCDC startup fixAnti Sullin
This patch adds an additional loop, that delays turning off the DMA until the LCDC core has been turned off. This prevents the picture to be shifted some random length when the kernel re-initializes the LCDC. Without this patch, the LCDC keeps running for some small time after the PWRCON:LCD_PWR has been cleared ; the FIFO suffers an underrun and on re-starting the LCDC the FIFO data stays shifted. This behavior has been seen and fixed on AT91SAM9261-EK and two custom AT91SAM9261 boards, all of them having different LCD panels. Thanks a lot to Anti Sullin for submitting this patch (long time ago). Signed-off-by: Anti Sullin <anti.sullin@artecdesign.ee> Signed-off-by: Andrew Victor <andrew@sanpeople.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21atmel_lcdfb: use spare bits in 32bpp mode as alpha channelHaavard Skinnemoen
Set var->transp.offset and var->transp.length in 32bpp mode to indicate that the 8 otherwise unused bits can be used for transparency. Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-21atmel_lcdfb: Fix STN LCD supportNicolas Ferre
Fixes STN LCD support for the atmel_lcdfb framebuffer driver. This patch is the result of a work from Jan Altenberg and has been tested on a Hitachi SP06Q002 on at91sam9261ek. It adds a Kconfig switch that enables the proper LCD in the board configuration file (STN or TFT). The switch is used in arch/arm/mach-at91/at91sam9261_devices.c & board-sam9261ek.c as an example. This patch includes the "Fix wrong line_length calculation" little one from Jan and Haavard (submitted earlier). AT91 platform informations are directly submitted trough the at91 maintainer, here : http://article.gmane.org/gmane.linux.kernel/543158 Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Cc: "Antonino A. Daplas" <adaplas@gmail.com> Cc: Jan Altenberg <jan.altenberg@linutronix.de> Cc: Patrice Vilchez <patrice.vilchez@rfo.atmel.com> Cc: Andrew Victor <andrew@sanpeople.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11atmel_lcdfb: AT91/AT32 LCD Controller framebuffer driverNicolas Ferre
Adds a framebuffer driver to ATMEL AT91SAM9x and AT32 aka AVR32 platforms. Those chips share quite the same IP and this code is suitable for both architectures. Signed-off-by: Nicolas Ferre <nicolas.ferre@rfo.atmel.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
