Make resume from suspend-to-ram possible for Samsung P35 laptops.
The radeon mobility 9700 chip on Samsung P35 laptops locks up everything on
resume from suspend-to-ram if it is not reinitialized.
VGA compatible controller: ATI Technologies Inc RV350 [Mobility Radeon 9600 M10]
Class 0300: 1002:4e50
Subsystem: 144d:c00c
Unfortunately, the DMI strings are mostly identical for all Samsung
laptops. So we match the PCI ID and subsystem ID of the graphics card
which is unique for each Samsung laptop model.
Signed-off-by: Carl-Daniel Hailfinger <c-d.hailfinger.devel.2006@gmx.net>
This makes it possible to build kernels for PReP and/or CHRP
with ARCH=ppc by removing the (non-building) powermac support.
It's now also possible to select PReP and CHRP independently.
Powermac users should now build with ARCH=powerpc instead of
ARCH=ppc. (This does mean that it is no longer possible to
build a 32-bit kernel for a G5.)
This adds suspend support for the Radeon M11 chip in 12" iBooks
manufactured after July 2005. I don't know if the new 14" iBooks also
have that chip, so they might also be supported.
The chip identifies itself as "RV350 NV" (pci id 0x4e56), revision 0x80.
Apple calls it "Snowy", xfree86 names it "ATI FireGL Mobility T2 (M11)
NV (AGP)". So, we seem to be lucky here: The suspend-code for the M10
(which also is a "RV350 NV") works flawless for that chip.
Signed-off-by: Sven Henkel <shenkel@gmail.com>
This adds type-checking to pm_message_t, so that people can't confuse it
with int or u32. It also allows us to fix "disk yoyo" during suspend (disk
spinning down/up/down).
[We've tried that before; since that cpufreq problems were fixed and I've
tried make allyes config and fixed resulting damage.]
Signed-off-by: Pavel Machek <pavel@suse.cz>
Signed-off-by: Alexander Nyberg <alexn@telia.com>
My previous patch that added sleep support for uninorth-agp and some AGP
"off" stuff in radeonfb and aty128fb is breaking some configs. More
specifically, it has problems with rage128 setups since the DRI code for
these in X doesn't properly re-enable AGP on wakeup or console switch
(unlike the radeon DRM).
This patch fixes the problem for pmac once for all by using a different
approach. The AGP driver "registers" special suspend/resume callbacks with
some arch code that the fbdev's can later on call to suspend and resume
AGP, making sure it's resumed back in the same state it was when suspended.
This is platform specific for now. It would be too complicated to try to
do a generic implementation of this at this point due to all sort of weird
things going on with AGP on other architectures. We'll re-work that whole
problem cleanly once we finally merge fbdev's and DRI.
In the meantime, please apply this patch which brings back some r128 based
laptops into working condition as far as system sleep is concerned.
infrastructure for it.
Let it rip!
