path: root/drivers/video/aty
2007-11-26radeonfb: add chip definition for RV370 5b63Andreas Herrmann
... which I've found on a Sapphire X550 (Silent). Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andreas Herrmann <aherrman@arcor.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-30radeonfb: remove warning with CONFIG_PM=nOlof Johansson
Remove warning from powerpc ppc64_defconfig builds: drivers/video/aty/radeon_pm.c:30: warning: 'radeon_reinitialize_M10' declared 'static' but never defined It's used only under CONFIG_PM, and only with CONFIG_X86 before it is defined, so the forward declaration can be moved under the ifdef. Signed-off-by: Olof Johansson <olof@lixom.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16Radeonfb Xpress 200M RC410 supportSellout Bessie
Make radeonfb work ith the 200m Xpress RC410. In my tests it was terribly unstable and would freeze until I set a refresh rate in the kernel argument to 75. e.g video=radeonfb:1280x800@75 Now it is rock solid. Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16atyfb: atyfb: Unshare pseudo_paletteGeert Uytterhoeven
atyfb: Move the pseudo palette into the card-specific atyfb_par, so it's no longer shared among multiple cards Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-13radeonfb: fix chip definition for Radeon Xpress 200M 0x5975aherrman@arcor.de
This fixes a problem introduced with commit b5f2f4d1a6d7efde39cfb5e1d034981c69f2214c The commit added a wrong chip definition to radeonfb which causes a blank console on my Laptop if radeonfb is loaded. The patch - renames PCI_CHIP_RS485_5975 to PCI_CHIP_RS482_5975 - corrects the chip family (RS480 instead of R300) for 0x5975 - ensures that PCI IDs are in ascending order in ati_ids.h Signed-off-by: Andreas Herrmann <aherrman@arcor.de> Tentatively-acked-by: Ben Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-13radeonfb: fix setting of PPLL_REF_DIV for RV370 5B60.aherrman@arcor.de
As observed with various Radeon X300 cards console goes blank without that fix. Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andreas Herrmann <aherrman@arcor.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-22Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlightLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight: leds: cr_bllcd.c: build fix backlight: Convert from struct class_device to struct device backlight: Fix order of Kconfig entries
2007-07-20[SPARC]: Fix serial console device detection.David S. Miller
The current scheme works on static interpretation of text names, which is wrong. The output-device setting, for example, must be resolved via an alias or similar to a full path name to the console device. Paths also contain an optional set of 'options', which starts with a colon at the end of the path. The option area is used to specify which of two serial ports ('a' or 'b') the path refers to when a device node drives multiple ports. 'a' is assumed if the option specification is missing. This was caught by the UltraSPARC-T1 simulator. The 'output-device' property was set to 'ttya' and we didn't pick upon the fact that this is an OBP alias set to '/virtual-devices/console'. Instead we saw it as the first serial console device, instead of the hypervisor console. The infrastructure is now there to take advantage of this to resolve the console correctly even in multi-head situations in fbcon too. Thanks to Greg Onufer for the bug report. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17radeonfb: the pseudo_palette is only 16 elements longAntonino A. Daplas
The pseudo_palette is only 16 elements long. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17atyfb: the pseudo_palette is only 16 elements longAntonino A. Daplas
2007-07-17radeonfb: Add support for Radeon Xpress 200M (RS485)Stephan Wolf
Add PCI ids for the Radeon Xpress 200M (RS485). Signed-off-by: Antonino Daplas <adaplas@gmail.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16backlight: Convert from struct class_device to struct deviceRichard Purdie
Convert the backlight and LCD classes from struct class_device to struct device since class_device is scheduled for removal. One nasty API break is the backlight power attribute has had to be renamed to bl_power and the LCD power attribute has had to be renamed to lcd_power since the original names clash with the core. I can't see a way around this. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Acked-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: add parameter "struct bin_attribute *" in .read/.write methods for ↵Zhang Rui
sysfs binary attributes Well, first of all, I don't want to change so many files either. What I do: Adding a new parameter "struct bin_attribute *" in the .read/.write methods for the sysfs binary attributes. In fact, only the four lines change in fs/sysfs/bin.c and include/linux/sysfs.h do the real work. But I have to update all the files that use binary attributes to make them compatible with the new .read and .write methods. I'm not sure if I missed any. :( Why I do this: For a sysfs attribute, we can get a pointer pointing to the struct attribute in the .show/.store method, while we can't do this for the binary attributes. I don't know why this is different, but this does make it not so handy to use the binary attributes as the regular ones. So I think this patch is reasonable. :) Who benefits from it: The patch that exposes ACPI tables in sysfs requires such an improvement. All the table binary attributes share the same .read method. Parameter "struct bin_attribute *" is used to get the table signature and instance number which are used to distinguish different ACPI table binary attributes. Without this parameter, we need to offer different .read methods for different ACPI table binary attributes. This is impossible as there are various ACPI tables on different platforms, and we don't know what they are until they are loaded. Signed-off-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-11sysfs: kill unnecessary attribute->ownerTejun Heo
sysfs is now completely out of driver/module lifetime game. After deletion, a sysfs node doesn't access anything outside sysfs proper, so there's no reason to hold onto the attribute owners. Note that often the wrong modules were accounted for as owners leading to accessing removed modules. This patch kills now unnecessary attribute->owner. Note that with this change, userland holding a sysfs node does not prevent the backing module from being unloaded. For more info regarding lifetime rule cleanup, please read the following message. http://article.gmane.org/gmane.linux.kernel/510293 (tweaked by Greg to not delete the field just yet, to make it easier to merge things properly.) Signed-off-by: Tejun Heo <htejun@gmail.com> Cc: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-06-28atyfb: Fix XCLK frequency on Apple iBook1Ville Syrjala
Fix a regression on Apple iBook1. Changes in the clock init code caused an incorrect XCLK frequency to be used leading to a corrupted display. Signed-off-by: Ville Syrjala <syrjala@sci.fi> Cc: Olaf Hering <olaf@aepfle.de> Cc: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08[ATYFB]: Fix sparc includes.David S. Miller
No need to use asm/pbm.h here. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-05-08Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (77 commits) [POWERPC] Abolish powerpc_flash_init() [POWERPC] Early serial debug support for PPC44x [POWERPC] Support for the Ebony 440GP reference board in arch/powerpc [POWERPC] Add device tree for Ebony [POWERPC] Add powerpc/platforms/44x, disable platforms/4xx for now [POWERPC] MPIC U3/U4 MSI backend [POWERPC] MPIC MSI allocator [POWERPC] Enable MSI mappings for MPIC [POWERPC] Tell Phyp we support MSI [POWERPC] RTAS MSI implementation [POWERPC] PowerPC MSI infrastructure [POWERPC] Rip out the existing powerpc msi stubs [POWERPC] Remove use of 4level-fixup.h for ppc32 [POWERPC] Add powerpc PCI-E reset API implementation [POWERPC] Holly bootwrapper [POWERPC] Holly DTS [POWERPC] Holly defconfig [POWERPC] Add support for 750CL Holly board [POWERPC] Generalize tsi108 PCI setup [POWERPC] Generalize tsi108 PHY types ... Fixed conflict in include/asm-powerpc/kdebug.h manually Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atyfb: halve XCLK with Mobility and 32bit memoryVille Syrjala
Laptops with Rage Mobility and 32bit memory interface seem to require halved XCLK to operate correctly. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atyfb: reorganize clock initVille Syrjala
Reorganize atyfb clock init code so command line clock overrides are effective for all chips. The old code would silently ignore some of the command line clock overrides with some chips. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atyfb: increase SPLL delayVille Syrjala
Wait 5 ms instead of 500 us for the SPLL to lock. This matches the recommendation in mach64 programmer's guide. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08radeonfb: Add support for Radeon xpress 200mjohan henriksson
Added support for radeon xpress 200m(rs480). Note that the card doesn't like dynclk turned on. Signed-off-by: Johan Henriksson <jhn98032@gmail.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08atyfb: kill dead codeAntonino A. Daplas
Coverity Bug 68, kill dead code. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08aty128fb: fix blankingWitold Filipczyk
I have a problem with blanking. The soundcard uses speakers of the monitor. Sound is muted when the screen blanks due to a bug in aty128fb.c. Here is a fragment of linux/fb.h /* VESA Blanking Levels */ #define VESA_NO_BLANKING 0 #define VESA_VSYNC_SUSPEND 1 #define VESA_HSYNC_SUSPEND 2 #define VESA_POWERDOWN 3 enum { /* screen: unblanked, hsync: on, vsync: on */ FB_BLANK_UNBLANK = VESA_NO_BLANKING, /* screen: blanked, hsync: on, vsync: on */ FB_BLANK_NORMAL = VESA_NO_BLANKING + 1, /* screen: blanked, hsync: on, vsync: off */ FB_BLANK_VSYNC_SUSPEND = VESA_VSYNC_SUSPEND + 1, /* screen: blanked, hsync: off, vsync: on */ FB_BLANK_HSYNC_SUSPEND = VESA_HSYNC_SUSPEND + 1, /* screen: blanked, hsync: off, vsync: off */ FB_BLANK_POWERDOWN = VESA_POWERDOWN + 1 }; So FB_BLANK_NORMAL is 1, FB_BLANK_VSYNC_SUSPEND is 2, FB_BLANK_HSYNC_SUSPEND is 3, FB_BLANK_POWERDOWN is 4. And now: blank = FB_BLANK_NORMAL (1) blank & FB_BLANK_HSYNC_SUSPEND (1 & 3) is true, so normal blank caused hsync suspend and sound is muted. Cc: James Simmons <jsimmons@infradead.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Merge branch 'linux-2.6'Paul Mackerras
2007-05-02PCI: Cleanup the includes of <linux/pci.h>Jean Delvare
I noticed that many source files include <linux/pci.h> while they do not appear to need it. Here is an attempt to clean it all up. In order to find all possibly affected files, I searched for all files including <linux/pci.h> but without any other occurence of "pci" or "PCI". I removed the include statement from all of these, then I compiled an allmodconfig kernel on both i386 and x86_64 and fixed the false positives manually. My tests covered 66% of the affected files, so there could be false positives remaining. Untested files are: arch/alpha/kernel/err_common.c arch/alpha/kernel/err_ev6.c arch/alpha/kernel/err_ev7.c arch/ia64/sn/kernel/huberror.c arch/ia64/sn/kernel/xpnet.c arch/m68knommu/kernel/dma.c arch/mips/lib/iomap.c arch/powerpc/platforms/pseries/ras.c arch/ppc/8260_io/enet.c arch/ppc/8260_io/fcc_enet.c arch/ppc/8xx_io/enet.c arch/ppc/syslib/ppc4xx_sgdma.c arch/sh64/mach-cayman/iomap.c arch/xtensa/kernel/xtensa_ksyms.c arch/xtensa/platform-iss/setup.c drivers/i2c/busses/i2c-at91.c drivers/i2c/busses/i2c-mpc.c drivers/media/video/saa711x.c drivers/misc/hdpuftrs/hdpu_cpustate.c drivers/misc/hdpuftrs/hdpu_nexus.c drivers/net/au1000_eth.c drivers/net/fec_8xx/fec_main.c drivers/net/fec_8xx/fec_mii.c drivers/net/fs_enet/fs_enet-main.c drivers/net/fs_enet/mac-fcc.c drivers/net/fs_enet/mac-fec.c drivers/net/fs_enet/mac-scc.c drivers/net/fs_enet/mii-bitbang.c drivers/net/fs_enet/mii-fec.c drivers/net/ibm_emac/ibm_emac_core.c drivers/net/lasi_82596.c drivers/parisc/hppb.c drivers/sbus/sbus.c drivers/video/g364fb.c drivers/video/platinumfb.c drivers/video/stifb.c drivers/video/valkyriefb.c include/asm-arm/arch-ixp4xx/dma.h sound/oss/au1550_ac97.c I would welcome test reports for these files. I am fine with removing the untested files from the patch if the general opinion is that these changes aren't safe. The tested part would still be nice to have. Note that this patch depends on another header fixup patch I submitted to LKML yesterday: [PATCH] scatterlist.h needs types.h http://lkml.org/lkml/2007/3/01/141 Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-02[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
These are all the remaining instances of get_property. Simple rename of get_property to of_get_property. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30Merge branch 'linux-2.6' into for-2.6.22Paul Mackerras
2007-04-26Revert "[POWERPC] Rename get_property to of_get_property: drivers"Paul Mackerras
This reverts commit d05c7a80cf39ae7d0f8d0c3e47c93d51fcd393d3, which included changes which should go via other subsystem maintainers.
2007-04-26[ATYFB]: Use pci_device_to_OF_node() in sparc.David S. Miller
2007-04-26[RADEON]: Probe clocks and monitor using OF properties on sparc.David S. Miller
Just like powerpc does. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-13[POWERPC] Rename get_property to of_get_property: driversStephen Rothwell
Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-13[POWERPC] get_property returns constStephen Rothwell
This just tidies up some of the remains. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-03-06[PATCH] atyfb: fix kconfig error part 2Randy Dunlap
Fix implicit declarations and missing code in atyfb. drivers/video/aty/atyfb_base.c:2137: warning: implicit declaration of function 'a ty_ld_lcd' drivers/video/aty/atyfb_base.c:2154: warning: implicit declaration of function 'a ty_st_lcd' atyfb_base.c:(.text+0x33e5c): undefined reference to `aty_ld_lcd' atyfb_base.c:(.text+0x33eb2): undefined reference to `aty_st_lcd' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlightLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight: backlight: Allow enable/disable of fb backlights, fixing regressions backlight: Fix nvidia backlight initial brightness
2007-03-05[PATCH] video/aty/mach64_ct.c: fix bogus delay loopDavid Miller
CT based mach64 cards were reported to hang on sparc64 boxes when compiled with gcc-4.1.x and later. Looking at this piece of code, it's no surprise. A critical delay was implemented as an empty for() loop, and gcc 4.0.x and previous did not optimize it away, so we did get a delay. But gcc-4.1.x and later can optimize it away, and we get crashes. Use a real udelay() to fix this. Fix verified on SunBlade100. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05[PATCH] atyfb: Fix kconfig errorAntonino A. Daplas
Fix the following compile error: MODPOST 327 modules WARNING: "aty_st_lcd" [drivers/video/aty/atyfb.ko] undefined! WARNING: "aty_ld_lcd" [drivers/video/aty/atyfb.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-05backlight: Allow enable/disable of fb backlights, fixing regressionsRichard Purdie
Enabling the backlight by default appears to cause problems for many users. This patch disables backlight controls unless explicitly enabled by users via a module parameter. Since PMAC users are known to work, default to enabled in that case. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-03-02[RADEON]: Fix blanking return value.David S. Miller
If you'll recall, over a year ago, I pointed out that the current Radeon driver erroneously returns -EINVAL for valid blanking codes, here is a link to that thread: http://lkml.org/lkml/2006/1/28/6 No other driver does this, and it confuses the X server into thinking that the device does not support blanking properly. I looked again and there is simply no reason for the Radeon driver to return -EINVAL for FB_BLANK_NORMAL. It claims it wants to do this in order to convince fbcon to blank in software, right here: if (fb_blank(info, blank)) fbcon_generic_blank(vc, info, blank); to software blank the screen. But it only causes that to happen in the FB_BLANK_NORMAL case. That makes no sense because the Radeon code does this: val |= CRTC_DISPLAY_DIS; in the FB_BLANK_NORMAL case so should be blanking the hardware, and there is therefore no reason to SW blank by returning -EINVAL. Signed-off-by: David S. Miller <davem@davemloft.net> Acked-by: Antonino Daplas <adaplas@gmail.com>
2007-02-20backlight: Separate backlight properties from backlight ops pointersRichard Purdie
Per device data such as brightness belongs to the indivdual device and should therefore be separate from the the backlight operation function pointers. This patch splits the two types of data and allows simplifcation of some code. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Clean up pmac_backlight handlingRichard Purdie
Move the setting/unsetting of pmac_backlight into the backlight core instead of doing it in each driver. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Rework backlight/fb interaction simplifying, lotsRichard Purdie
fb_info->bl_mutex is badly thought out and the backlight class doesn't need it if the framebuffer/backlight register/unregister order is consistent, particularly after the backlight locking fixes. Fix the drivers to use the order: backlight_device_register() register_framebuffer() unregister_framebuffer() backlight_device_unregister() and turn bl_mutex into a lock for the bl_curve data only. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Remove unneeded backlight update_status callsRichard Purdie
The backlight core listens for blanking events and triggers a backlight_update_status call so these extra calls are not needed and can be removed. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Fix external uses of backlight internal semaphoreRichard Purdie
backlight_device->sem has a very specific use as documented in the header file. The external users of this are using it for a different reason, to serialise access to the update_status() method. backlight users were supposed to implement their own internal serialisation of update_status() if needed but everyone is doing things differently and incorrectly. Therefore add a global mutex to take care of serialisation for everyone, once and for all. Locking for get_brightness remains optional since most users don't need it. Also update the lcd class in a similar way. Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-20backlight: Remove unneeded owner fieldRichard Purdie
Remove uneeded owner field from backlight_properties structure. Nothing uses it and it is unlikely that it will ever be used. The backlight class uses other means to ensure that nothing references unloaded code. Based on a patch from Dmitry Torokhov <dtor@insightbb.com> Signed-off-by: Richard Purdie <rpurdie@rpsys.net>
2007-02-12[PATCH] Correct apparent typo CONFIG_ATY_CT in ATY videoRobert P. J. Day
Replace the apparent typo CONFIG_ATY_CT with CONFIG_FB_ATY_CT. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: James Simmons <jsimmons@infradead.org> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Antonino A. Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] remove bogus con_is_present() prototypesAdrian Bunk
Although gcc seems to accept "extern" prototypes after it has seen the "static inline" function, that's not really correct. Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
