This is the 4.9.166 stable release
commit 5fb5caee92ba35a4a3baa61d45a78eb057e2c031 upstream.
Before this patch the enable signal was set before the PWM signal and
vice-versa on power off. This sequence is wrong, at least, it is on
the different panels datasheets that I checked, so I inverted the sequence
to follow the specs.
For reference the following panels have the mentioned sequence:
- N133HSE-EA1 (Innolux)
- N116BGE (Innolux)
- N156BGE-L21 (Innolux)
- B101EAN0 (Auo)
- B101AW03 (Auo)
- LTN101NT05 (Samsung)
- CLAA101WA01A (Chunghwa)
Signed-off-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Acked-by: Daniel Thompson <daniel.thompson@linaro.org>
Acked-by: Jingoo Han <jingoohan1@gmail.com>
Acked-by: Thierry Reding <thierry.reding@gmail.com>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Add suspend/resume power management operations for
gpio backlight.
Signed-off-by: Fancy Fang <chen.fang@nxp.com>
Add fb name check function pwm_backlight_check_fb_name(),
pwm driver can banding to fb with fb name when driver working
in device tree architecture.
Signed-off-by: Sandor Yu <Sandor.yu@nxp.com>
commit 2b12dfa124dbadf391cb9a616aaa6b056823bf75 upstream.
Fix child-node lookup during probe, which ended up searching the whole
device tree depth-first starting at the parent rather than just matching
on its children.
This would only cause trouble if the child node is missing while there
is an unrelated node named "backlight" elsewhere in the tree.
Cc: stable <stable@vger.kernel.org> # 3.7
Fixes: eebfdc17cc6c ("backlight: Add TPS65217 WLED driver")
Signed-off-by: Johan Hovold <johan@kernel.org>
commit d1cc0ec3da23e44c23712579515494b374f111c9 upstream.
on its children.
To make things worse, the parent mfd node was also prematurely freed,
while the child backlight node was leaked.
Cc: stable <stable@vger.kernel.org> # 3.9
Fixes: 47ec340cb8e2 ("mfd: max8925: Support dt for backlight")
commit 4a9c8bb2aca5b5a2a15744333729745dd9903562 upstream.
on its children.
To make things worse, the parent mfd node was also prematurely freed.
Cc: stable <stable@vger.kernel.org> # 3.10
Fixes: 59eb2b5e57ea ("drivers/video/backlight/as3711_bl.c: add OF support")
[ Upstream commit 7e715c2d9c27c23f3187454157c58cf292ed103e ]
It is possible to update the backlight power and the brightness using
the sysfs and on writing it either returns the count or if the callback
function does not exist then returns the error code 'ENXIO'.
We have a situation where the userspace client is writing to the sysfs
to update the power and since the callback function exists the client
receives the return value as count and considers the operation to be
successful. That is correct as the write to the sysfs was successful.
But there is no way to know if the actual operation was done or not.
backlight_update_status() returns the error code if it fails. Pass that
to the userspace client who is trying to update the power so that the
client knows that the operation failed.
Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk>
[ Upstream commit 2023b0524a6310e9ea80daf085f51c71bff9289f ]
Currently the LCD display (TD035S) on the cm-x300 platform is broken and
remains blank.
The TD0245S specification requires that the chipselect is toggled
between commands sent to the panel. This was also the purpose of the
former patch of commit f64dcac0b124 ("backlight: tdo24m: ensure chip
select changes between transfers").
Unfortunately, the "cs_change" field of a SPI transfer is
misleading. Its true meaning is that for a SPI message holding multiple
transfers, the chip select is toggled between each transfer, but for the
last transfer it remains asserted.
In this driver, all the SPI messages contain exactly one transfer, which
means that each transfer is the last of its message, and as a
consequence the chip select is never toggled.
Actually, there was a second bug hidding the first one, hence the
problem was not seen until v4.6. This problem was fixed by commit
a52db659c79c ("spi: pxa2xx: Fix cs_change management") for PXA based
boards.
This fix makes the TD035S work again on a cm-x300 board. The same
applies to other PXA boards, ie. corgi and tosa.
Fixes: a52db659c79c ("spi: pxa2xx: Fix cs_change management")
Reported-by: Andrea Adami <andrea.adami@gmail.com>
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
[ Upstream commit 5d0c49acebc9488e37db95f1d4a55644e545ffe7 ]
This fixes an overflow condition that can happen with high max
brightness and period values in compute_duty_cycle. This fixes it by
using a 64 bit variable for computing the duty cycle.
Signed-off-by: Derek Basehore <dbasehore@chromium.org>
Reviewed-by: Brian Norris <briannorris@chromium.org>
[ Upstream commit 0eb3fba8c68275f0122f65f7316efaaf86448016 ]
If adp5520_bl_setup() fails, sysfs group left unremoved.
By the way, fix overcomplicated assignement of error code.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Acked-by: Michael Hennerich <michael.hennerich@analog.com>
[ Upstream commit cc21942bce652d1a92dae85b785378256e1df1f7 ]
Once device_register is called for a device its attributes might be
accessed. As the callbacks of a lcd device's attributes make use of the
lcd_ops, the respective member must be setup before calling
device_register.
Some backlight GPIOs might be connected to some i2c based expanders whose
access might sleep.
Since it's not in any critical path, use the cansleep variant of the GPIO
API.
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
The field "owner" is set by the core.
Thus delete an unneeded initialisation.
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Signed-off-by: Markus Elfring <elfring@users.sourceforge.net>
The LP8556 datasheet describes an EN/VDDIO input, which serves "both as
a chip enable and as a power supply reference for PWM, SDA, and SCL
inputs." The LP8556 that I'm testing doesn't respond properly if I try
to talk I2C to it too quickly after enabling VDDIO, and the LP8555
datasheet mentions a t_RESPONSE delay of up to 1 millisecond.
Support this EN/VDDIO by adding a regulator property to the binding;
enabling this regulator at probe time; and sleeping for 1 to 2ms, if the
EN/VDDIO regulator was provided.
Signed-off-by: Brian Norris <briannorris@chromium.org>
Acked-by: Rob Herring <robh@kernel.org>
Acked-by: Milo Kim <milo.kim@ti.com>
Reviewed-by: Stephen Barber <smbarber@chromium.org>
git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm
Pull pwm updates from Thierry Reding:
"This set of changes introduces an atomic API to the PWM subsystem.
This is influenced by the DRM atomic API that was introduced a while
back, though it is obviously a lot simpler. The fundamental idea
remains the same, though: drivers provide a single callback to
implement the atomic configuration of a PWM channel.
As a side-effect the PWM subsystem gains the ability for initial state
retrieval, so that the logical state mirrors that of the hardware.
Many use-cases don't care about this, but for others it is essential.
These new features require changes in all users, which these patches
take care of. The core is transitioned to use the atomic callback if
available and provides a fallback mechanism for other drivers.
Changes to transition users and drivers to the atomic API are
postponed to v4.8"
* tag 'pwm/for-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/thierry.reding/linux-pwm: (30 commits)
pwm: Add information about polarity, duty cycle and period to debugfs
pwm: Switch to the atomic API
pwm: Update documentation
pwm: Add core infrastructure to allow atomic updates
pwm: Add hardware readout infrastructure
pwm: Move the enabled/disabled info into pwm_state
pwm: Introduce the pwm_state concept
pwm: Keep PWM state in sync with hardware state
ARM: Explicitly apply PWM config extracted from pwm_args
drm: i915: Explicitly apply PWM config extracted from pwm_args
input: misc: pwm-beeper: Explicitly apply PWM config extracted from pwm_args
input: misc: max8997: Explicitly apply PWM config extracted from pwm_args
backlight: lm3630a: explicitly apply PWM config extracted from pwm_args
backlight: lp855x: Explicitly apply PWM config extracted from pwm_args
backlight: lp8788: Explicitly apply PWM config extracted from pwm_args
backlight: pwm_bl: Use pwm_get_args() where appropriate
fbdev: ssd1307fb: Use pwm_get_args() where appropriate
regulator: pwm: Use pwm_get_args() where appropriate
leds: pwm: Use pwm_get_args() where appropriate
input: misc: max77693: Use pwm_get_args() where appropriate
Call pwm_apply_args() just after requesting the PWM device so that the
polarity and period are initialized according to the information
provided in pwm_args.
This is an intermediate state, and pwm_apply_args() should be dropped as
soon as the atomic PWM infrastructure is in place and the driver makes
use of it.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Signed-off-by: Thierry Reding <thierry.reding@gmail.com>
use of it.
use of it.
The PWM framework has clarified the concept of reference PWM config (the
platform dependent config retrieved from the DT or the PWM lookup table)
and real PWM state.
Use pwm_get_args() when the PWM user wants to retrieve this reference
config and not the current state.
This is part of the rework allowing the PWM framework to support
hardware readout and expose real PWM state even when the PWM has just
been requested (before the user calls pwm_config/enable/disable()).
pwm->period field is not supposed to be changed by PWM users. The only
ones authorized to change it are the PWM core and PWM drivers.
Acked-by: Lee Jones <lee.jones@linaro.org>
The PWM period will be set when calling pwm_config. Remove this useless
call to pwm_set_period(), which might mess up the internal PWM state.
Since we will need the backlight_device_get_by_type API, we can use it
instead of the backlight_device_registered API whenever necessary so
remove the backlight_device_registered API.
Signed-off-by: Aaron Lu <aaron.lu@intel.com>
Acked-by: Jingoo Han <jg1.han@samsung.com>
It is useful to get the backlight device's pointer and use it to set
backlight in some cases(the following patch will make use of it) so add
the two APIs and export them.
If pwm is requested by legacy pwm_request() and if the following
backlight_device_register() call fails, add pwm_free() clean-up.
Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com>
A recent patch I did fixed two potential uses of uninitialized
variables in the adp8870 and adp8860 drivers. Unfortunately,
I missed another one:
drivers/video/backlight/adp8860_bl.c: In function 'adp8860_bl_ambient_light_level_show':
drivers/video/backlight/adp8860_bl.c:570:11: warning: 'reg_val' may be used uninitialized in this function
This does the same change as before in one additional function,
and also changes the check for the return value in a way that
avoids another false positive warning with a similar message.
Fixes: 6be3a5a9cd91 ("backlight: adp88x0: Fix uninitialized variable use")
There are situations where the backlight should be on at boot time
(e.g. if the boot loader already turned the display on). The DT
bindings specify the "default-on" property for that purpose.
Currently, the initial state of the GPIO at request time is always
set to logical off (high or low depending on whether it is an
active high or low GPIO). Since the GPIO is requested as an output,
the GPIO will be driven low for a short period of time, which leads
to a flickering display in the above use-case.
Initialize the GPIO depending on the default-on property to be
logical on or off.
Signed-off-by: Stefan Agner <stefan@agner.ch>
Commit ee65ad0e2a9e ("backlight: pwm_bl: Avoid backlight flicker when
probed from DT") tries to dereference the device of_node pointer
unconditionally, causing a NULL pointer dereference on non-dt platforms.
Fix it by replacing the phandle variable with a node variable and
by checking that for NULL before dereferencing it.
Reported-by: Robert Jarzmik <robert.jarzmik@free.fr>
Signed-off-by: Philipp Zabel <p.zabel@pengutronix.de>
Tested-by: Robert Jarzmik <robert.jarzmik@free.fr>
The device table is required to load modules based on modaliases.
If the driver is probed from the device tree, and there is a phandle
property set on it, and the enable GPIO is already configured as output,
and the backlight is currently disabled, keep it disabled.
If all these conditions are met, assume there will be some other driver
that can enable the backlight at the appropriate time.
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Tested-by: Heiko Stuebner <heiko@sntech.de>
gcc correctly warns about both the adp8860 and adp8870 backlight
drivers using an uninitialized variable in their error handling
path:
drivers/video/backlight/adp8870_bl.c: In function 'adp8870_bl_ambient_light_zone_store':
drivers/video/backlight/adp8870_bl.c:811:11: warning: 'reg_val' may be used uninitialized in this function
This changes the code to only write back the data if it was
correctly read to start with.
As a side-note, the drivers are mostly identical, so I think they
should really be merged into one file to avoid having to fix every
bug twice.
git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight
Pull backlight updates from Lee Jones:
"New Device Support
- None
New Functionality:
- None
Core Frameworks:
- Reject legacy PWM request for device defined in DT
Fix-ups:
- Remove unnecessary MODULE_ALIAS(); adp8860_bl, adp8870_bl
- Simplify code: pm8941-wled
- Supply default-brightness logic; pm8941-wled
Bug Fixes:
- Clean up OF node; 88pm860x_bl
- Ensure struct is zeroed; lp855x_bl"
* tag 'backlight-for-linus-4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight:
backlight: pm8941-wled: Add default-brightness property
backlight: pm8941-wled: Fix ptr_ret.cocci warnings
backlight: pwm: Reject legacy PWM request for device defined in DT
backlight: 88pm860x_bl: Add missing of_node_put
backlight: adp8870: Remove unnecessary MODULE_ALIAS()
backlight: adp8860: Remove unnecessary MODULE_ALIAS()
backlight: lp855x: Make sure props struct is zeroed
Default the brightness to 2048 and add possibility to override this in
device tree.
Suggested-by: Rob Clark <robdclark@gmail.com>
Signed-off-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
An spi_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Acked-by: Jonathan Cameron <jic23@kernel.org>
Signed-off-by: Mark Brown <broonie@kernel.org>
drivers/video/backlight/pm8941-wled.c:404:1-3: WARNING: PTR_ERR_OR_ZERO can be used
Use PTR_ERR_OR_ZERO rather than if(IS_ERR(...)) + PTR_ERR
Generated by: scripts/coccinelle/api/ptr_ret.cocci
Acked-by: Bjorn Andersson <bjorn.andersson@sonymobile.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Platform PWM backlight data provided by board's device tree should be
complete enough to successfully request a pwm device using pwm_get()
API. This change fixes a bug, when an arbitrary (first found) PWM is
connected to a "pwm-backlight" compatible device, when explicit PWM
device reference is not given.
Documentation/devicetree/bindings/video/backlight/pwm-backlight.txt
already describes "pwms" as a required property, instead of blind
selection of a potentially wrong PWM reject legacy PWM device
registration request, leave legacy API only for non-dt cases.
Based on initial implementation done by Dmitry Eremin-Solenikov.
Reported-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
The semantic patch that fixes this problem is as follows
(http://coccinelle.lip6.fr):
// <smpl>
expression root,e;
local idexpression child;
iterator name for_each_child_of_node;
for_each_child_of_node(root, child) {
... when != of_node_put(child)
when != e = child
+ of_node_put(child);
? break;
... when != child
// </smpl>
Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
The driver has a I2C device id table that is used to create the modaliases
and also "adp8870-backlight" is not a supported I2C id, so it's never used.
Signed-off-by: Javier Martinez Canillas <javier@osg.samsung.com>
and also "adp8860-backlight" is not a supported I2C id, so it's never used.
The driver occasionally got stuck in suspend mode or other strange
states as those parts of the props struct were never initialized.
Signed-off-by: Werner Johansson <werner.johansson@sonymobile.com>
The I2C core always reports the MODALIAS uevent as "i2c:<modalias>"
regardless of the mechanism that was used to register the device
(i.e: OF or board code) and the table that is used later to match
the driver with the device (i.e: I2C id table or OF match table).
So drivers needs to export the I2C id table and this be built into
the module or udev won't have the necessary information to autoload
the needed driver module when the device is added.
The backlight_device_unregister() function tests whether its argument
is NULL and then returns immediately. Thus the test around the call is
not needed.
This issue was detected by using the Coccinelle software.
IS_ERR_VALUE() makes sense only *if* there could be valid values in
negative error range.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
The Qualcomm PM8941 WLED block is used for backlight and should therefor
be in the backlight framework and not in the LED framework. This moves
the driver and adapts to the backlight api instead.
Tested-by: Rob Clark <robdclark@gmail.com>
Acked-by: Jacek Anaszewski <j.anaszewski@samsung.com>
LP855x backlight device can be enabled by external VDD input. The
'supply' data is used for this purpose. It's kind of private data
which runs internally, so there is no reason to expose to the
platform data.
And devm_regulator_get() is moved from _parse_dt() to _probe().
Regulator consumer(lp855x) can control regulator not only from DT
but also from platform data configuration in a source file such
like board-*.c.
Signed-off-by: Milo Kim <milo.kim@ti.com>
Acked-by: Sean Paul <seanpaul@chromium.org>
"Changes to existing drivers:
- supply MODULE_DEVICE_TABLE() to ensure probing
- constify struct; da9052_bl
- enable compile test; lcd_l4f00242t03, lcd_lms283fg05, backlight_gpio
- suspend/resume bugfix; lp855x_bl
- devm_gpiod_get_optional() API fixup; pwm_bl
- error handling fixup; backlight"
* tag 'backlight-for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/lee/backlight:
backlight: Change the return type of backlight_update_status() to int
backlight: pwm_bl: Simplify usage of devm_gpiod_get_optional
backlight: lp855x: Don't clear level on suspend/blank
backlight: Allow compile test of GPIO consumers if !GPIOLIB
video: backlight: da9052: Constify platform_device_id
gpio-backlight: Discover driver during boot time
Since 39b2bbe3d715 (gpio: add flags argument to gpiod_get*() functions),
the gpiod_get* functions take an additional parameter that allows to
specify direction and initial value for output.
Simplify the usage of devm_gpiod_get_optional accordingly.
Don't clear the backlight level when we're going into suspend or
blanking. Instead, just temporarily set the level to 0 so we retain
the value when we resume.
Reported-by: Benson Leung <bleung@chromium.org>
Signed-off-by: Sean Paul <seanpaul@chromium.org>
Tested-by: Stephen Barber <smbarber@chromium.org>
Reviewed-by: Benson Leung <bleung@chromium.org>
The GPIO subsystem provides dummy GPIO consumer functions if GPIOLIB is
not enabled. Hence drivers that depend on GPIOLIB, but use GPIO consumer
functionality only, can still be compiled if GPIOLIB is not enabled.
Relax the dependency on GPIOLIB if COMPILE_TEST is enabled, where
appropriate.
Cc: Jingoo Han <jg1.han@samsung.com>
The platform_device_id is not modified by the driver and core uses it as
const.
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
