path: root/drivers/video/bfin-t350mcqb-fb.c
2011-03-22backlight: add backlight typeMatthew Garrett
There may be multiple ways of controlling the backlight on a given machine. Allow drivers to expose the type of interface they are providing, making it possible for userspace to make appropriate policy decisions. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: David Airlie <airlied@linux.ie> Cc: Alex Deucher <alexdeucher@gmail.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Len Brown <lenb@kernel.org> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-09fix printk typo 'faild'Paul Bolle
Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-27fbdev: bfin-t350mcqb-fb: avoid unused warnings in backlight codeMike Frysinger
The current backlight code is stubbed out, so the new props changes added some warnings about unused label/prop. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-11fbdev: bfin-t350mcqb-fb: fix fbmem allocation with blanking linesMichael Hennerich
The current allocation does not include the memory required for blanking lines. So avoid memory corruption when multiple devices are using the DMA memory near each other. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-16backlight: blackfin - Fix missing registration failure handlingBruno Prémont
Check newly registered backlight_device for error and properly return error to parent Mark struct backlight_ops as const. Signed-off-by: Bruno Prémont <bonbons@linux-vserver.org> Acked-by: Mike Frysinger <vapier@gentoo.org> (constify struct backlight_ops) Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-03-16backlight: Allow properties to be passed at registrationMatthew Garrett
Values such as max_brightness should be set before backlights are registered, but the current API doesn't allow that. Add a parameter to backlight_device_register and update drivers to ensure that they set this correctly. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-03-12fbdev: bf54x-lq043fb/bfin-t350mcqb-fb: drop custom mmap() handlerMichael Hennerich
The common Blackfin code implements the get_fb_unmapped_area() function, so we no longer need to have our own mmap() handler. The common fb code will take care of everything for us now. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16fbdev: bfin-t350mcqb-fb: fix LCD dimensionsMichael Hennerich
The height/width framebuffer members need to be set in millimeters so that software can do proper scaling. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16fbdev: bfin-t350mcqb-fb: handle all resources in suspend/resumeMichael Hennerich
The LCD commands DMA/timers as well as PPI which we need to save/restore. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: *bfin*: fix __dev{init,exit} markingsMike Frysinger
The remove member of the platform_driver bfin_t350mcqb_driver should use __devexit_p() to refer to the remove function, and that function should get __devexit markings. Likewise, the probe function should be marked with __devinit and not __init. Also, module_init() functions should be marked with __init rather than __devinit. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: *bfin*: drop unnecessary calls to memsetVivek Kutal
The dma_alloc_* functions sets the memory to 0 before returning so there is no need to call memset after the allocation. Also no point in clearing the memory when disabling the buffer. Signed-off-by: Vivek Kutal <vivek.kutal@azingo.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-16fbdev: bfin-t350mcqb-fb: drop unused local variablesMike Frysinger
The local fbinfo/info vars in the suspend functions don't actually get used which cause ugly gcc warnings, so drop them. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-02-11video/framebuffer: move the probe func into .devinit.text in Blackfin LCD driverUwe Kleine-Koenig
Signed-off-by: Uwe Kleine-Koenig <ukleinek@strlen.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-15video/framebuffer: fix bug: jpegview cannot work on framebuffer device other ↵Michael Hennerich
than 16BPP Force fb_var_screeninfo color format on all Blackfin Framebuffer Drivers. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06blackfin: remove __FUNCTION__ in video driverHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Acked-by: Bryan Wu <bryan.wu@analog.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24lcd: add lcd_device to check_fb() entry in lcd_opsBen Dooks
Add the lcd_device being checked to the check_fb entry of lcd_ops. This ensures that any driver using this to check against it's own state can do so, and also makes all the calls in lcd_ops more orthogonal in their arguments. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-28blackfin video driver: fix bug when opening/reading/mmaping BF54x and BF52x ↵Michael Hennerich
framebuffer simultaneously http://blackfin.uclinux.org/gf/project/uclinux-dist/tracker/?action=TrackerItemEdit&tracker_item_id=3974 opening/reading/mmaping BF54x and BF52x framebuffer simultaneously triggers BUG: failure at mm/nommu.c:470/add_nommu_vma() Add VM_SHARED to the default vm_flags Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-28blackfin video driver: update the BF52x EZKIT video framebuffer driver ↵Bryan Wu
according to LKML review - Allocate pseudo_palette together with fbinfo - Code cleanup Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10fbdev: add BF52x EZkit Display driverMichael Hennerich
Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
