path: root/drivers/video/cfbimgblt.c
2008-04-28video: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Antonino Daplas <adaplas@gmail.com> Cc: Antonino A. Daplas <adaplas@gmail.com> Cc: Antonino Daplas <adaplas@pol.net> Cc: Richard Purdie <rpurdie@rpsys.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Adrian Bunk <bunk@stusta.de> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ben Dooks <ben-linux@fluff.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28fb: add support for foreign endiannessAnton Vorontsov
Add support for the framebuffers with non-native endianness. This is done via FBINFO_FOREIGN_ENDIAN flag that will be used by the drivers. Depending on the host endianness this flag will be overwritten by FBINFO_BE_MATH internal flag, or cleared. Tested to work on MPC8360E-RDK (BE) + Fujitsu MINT framebuffer (LE). Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: <Valdis.Kletnieks@vt.edu> Cc: Clemens Koller <clemens.koller@anagramm.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: Support for byte-reversed framebuffer formatsPavel Pisa
Allow generic frame-buffer code to correctly write texts and blit images for 1, 2 and 4 bit per pixel frame-buffer organizations when pixels in bytes are organized to in opposite order than bytes in long type. Overhead should be reasonable. If option is not selected, than compiler should eliminate completely all overhead. The feature is disabled at compile time if CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set. [adaplas] Convert helper functions to macros if feature is not enabled. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] various fbdev files: mark structs and array read-onlyHelge Deller
- move some structs and arrays to the read-only (.rodata) section [akpm@osdl.org: build fix] Signed-off-by: Helge Deller <deller@gmx.de> Acked-by: James Simmons <jsimmons@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-26[PATCH] fbdev: Coverity Bug 85Antonino A. Daplas
It's a false positive, but let's suppress it anyway. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-31[PATCH] fbcon: Fix big-endian bogosity in slow_imageblit()Antonino A. Daplas
The monochrome->color expansion routine that handles bitmaps which have (widths % 8) != 0 (slow_imageblit) produces corrupt characters in big-endian. This is caused by a bogus bit test in slow_imageblit(). Fix. This patch may deserve to go to the stable tree. The code has already been well tested in little-endian machines. It's only in big-endian where there is uncertainty and Herbert confirmed that this is the correct way to go. It should not introduce regressions. Signed-off-by: Antonino Daplas <adaplas@pol.net> Acked-by: Herbert Poetzl <herbert@13thfloor.at> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] fbdev: Fix incorrect unaligned access in little-endian machinesAntonino A. Daplas
The drawing function cfbfillrect does not work correctly when access is not unsigned-long aligned. It manifests as extra lines of pixels that are not complete drawn. Reversing the shift operator solves the problem, so I would presume that this bug would manifest only on little endian machines. The function cfbcopyarea may also have this bug. Aligned access should present no problems. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[PATCH] fbdev: Shift pixel value before entering loop in cfbimageblitAntonino A. Daplas
In slow imageblit, the pixel value is shifted by a certain amount (dependent on the bpp and endianness) for each iteration. This is inefficient. Better do the shifting once before going into the loop. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] fbdev: Possible endian fix in cfbimageblitAntonino A. Daplas
Fix possible endian bug(?) when bit testing in slow_imageblit(). This function is rarely called (only if (width * bpp) % 32 != 0) thus the bug is not triggered. However, if the console is rotated at 90 or 270 degrees, the height becomes the width, and a variety of fonts have heights that will force a call to slow_imageblit(). Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbdev: Remove software clipping from drawing functionsAntonino A. Daplas
Remove software clipping from imageblit, fillrect and copyarea. Clipping is not needed because the console layer assures that reads/writes doest not happen beyond the extents of the framebuffer. And software clipping tends to hide bugs, if they do exist. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
