path: root/drivers/video/cg3.c
2009-06-16cg3: use standard fields for framebuffer physical address and lengthKrzysztof Helt
Use standard fields fbinfo.fix.smem_start and fbinfo.fix.smem_len for physical address and length of framebuffer. This also fixes output of the 'fbset -i' command - address and length of the framebuffer is displayed correctly. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-31sparc: Annotate of_device_id arrays with const or __initdata.David S. Miller
As suggested by Stephen Rothwell. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-08sparc video: remove open boot prom codeRobert Reif
Replace remaining open boot prom code with of. Boot tested on sparc32 and compile tested on sparc64. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-05-03sparc video: make blank use proper constantRobert Reif
Make blank functions use proper constant for unblanking. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-27sparc: video drivers: add facility levelRobert Reif
Add KERN_ facility level to sparc video drivers. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-08-26[VIDEO]: Do not prom_halt() in cg3 and bw2 device probe.David S. Miller
Just give a normal kernel log message of the problem and return failure. Based upon a patch from Mark Fortescue. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-30[VIDEO]: Fix OOPS in all SBUS framebuffer drivers.David S. Miller
All of these drivers use a silly: struct all_info { struct fb_info info; struct foo_par par; }; struct all_info *all = kzalloc(sizeof(*all), GFP_KERNEL); all->info.par = &all->par; etc. etc. code sequence, basically replicating the provided framebuffer_alloc()/framebuffer_release(), and doing it badly. Not only is this massive code duplication, it also caused a bug in that we weren't setting the fb_info->device pointer which results in an OOPS when fb_is_primary_device() runs. Fix all of this by using framebuffer_{alloc,release}() and passing in "&of_device->dev" as the device pointer. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[SPARC/64] constify of_get_property return: driversStephen Rothwell
The only unfortunate bit here is that the name field of struct map_info is not const, so for now we put a cast on the assignment of it. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-28[VIDEO]: Fix section mismatch in cg3.cRobert Reif
Fix section mismatch warning by moving data into __devinitdata section. Add __devinit to initialization functions. Signed-off-by: Robert Reif <reif@earthlink.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-12-31[SPARC64]: Fix of_iounmap() region release.David S. Miller
We need to pass in the resource otherwise we cannot release the region properly. We must know whether it is an I/O or MEM resource. Spotted by Eric Brower. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-06-29[SPARC]: Convert all FB SBUS drivers to of_driver framework.David S. Miller
2006-01-14[PATCH] fbdev: Sanitize ->fb_mmap prototypeChristoph Hellwig
No need for a file argument. If we'd really need it it's in vma->vm_file already. gbefb and sgivwfb used to set vma->vm_file to the file argument, but the kernel alrady did that. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] fbdev: Sanitize ->fb_ioctl prototypeChristoph Hellwig
The ioctl and file arguments to ->fb_mmap are totally unused and there's not reason a driver should need them. Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-12[SBUSFB]: Kill 'list' member from foo_par structs, totally unused.David S. Miller
Based upon a patch from Hareesh Nagarajan. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-12[SBUSFB]: implement ->compat_ioctlChristoph Hellwig
This patch adds a new function, sbusfb_compat_ioctl() to drivers/video/sbuslib.c and uses it as compat_ioctl in all sbus fb drivers This remove the last per-arch compat ioctl bits in arch/sparc64/kernel/ioctl32.c so it would be nice if people could test if this actually copiles and works and if yes apply it :) Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
