path: root/drivers/video/console/fbcon.c
2005-09-13[PATCH] fbcon: constify font dataJan Beulich
const-ify the font control structures and data, to make somewhat better guarantees that these are not modified anywhere in the kernel. Specifically for a kernel debugger to share this information from the normal kernel code, such a guarantee seems rather desirable. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: "Antonino A. Daplas" <adaplas@hotpop.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] minor fbcon_scroll adjustmentJan Beulich
An adjustment to the SM_DOWN case of fbcon_scroll to match the behavior of SM_UP. Signed-off-by: Jan Beulich <jbeulich@novell.com> Cc: "Antonino A. Daplas" <adaplas@hotpop.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] fbcon: Stop cursor timer if console is inactiveAntonino A. Daplas
If console is blanked or in KD_GRAPHICS mode, delete cursor timer. No sense flashing the cursor when there's nothing to be seen. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] fbcon: Saner 16-color to 4-color conversionAntonino A. Daplas
Currently, the default linux 16-colors are converted to 4-colors by simply dividing the values by 4. However, this is not necessarily correct since the first 4 colors are converted to black, rendering them invisible. So, for black, no conversion; for light colors, convert to gray, for normal text color, no conversion, and for bright colors, convert to intense white. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] fbdev: Fix greater than 1 bit monochrome color handlingAntonino A. Daplas
Currently, fbcon assumes that the visual FB_VISUAL_MONO* is always 1 bit. According to Geert, there are old hardware where it's possible to have monochrome at 8-bit, but has only 2 colors, black - 0x00 and white - 0xff. Fix color handlers (fb_get_color_depth, and get_color) for this special case. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] fbdev: Add fbset -a supportAntonino A. Daplas
Add capability to fbdev to listen to the FB_ACTIVATE_ALL flag. If set, it notifies fbcon that all consoles must be set to the current var. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] fbcon: don't repaint the cursor when it is disabled.Michal Januszewski
Currently even when the cursor is disabled (`setterm -cursor off`), it is still repainted as a black rectangle the size of a single char. This can be seen, for example, by chvt'ing to a free tty, disabling the cursor and doing `dd if=3D/dev/urandom of=3D/dev/fb0`. The patch changes this behaviour by avoiding painting anything when the cursor is disabled. Signed-off-by: Michal Januszewski <spock@gentoo.org> Cc: <linux-fbdev-devel@lists.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] ARM: Acornfb: Don't claim IRQ fbcon for cursorRussell King
The generic fbcon code tries to register and use the vsync IRQ for ARM platforms with acornfb, but forgets to disable its own cursor timer. The result is a flickering flashing cursor. Remove the code from the fbcon core to register this platform private interrupt. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-05-01[PATCH] fbcon: Fix check after useAdrian Bunk
This patch fixes a check after use found by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@fs.tum.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
