path: root/drivers/video/cyber2000fb.c
2011-02-11VIDEO: cyberpro: remove unused cyber2000fb_get_fb_var()Russell King
2011-02-11VIDEO: cyberpro: remove useless function extreg pointersRussell King
Sub-drivers can call these functions directly, there's no need for this kind of indirection. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-11VIDEO: cyberpro: update handling of device structuresRussell King
Provide the framebuffer device with its correct parent (the PCI device for PCI connected cards.) Also, use this struct device to pass to sub-drivers rather than the pci_dev structure, which is really what they want. Also propagate the assigned IRQ, which they were getting direct from the PCI device structure. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-11VIDEO: cyberpro: add support for video capture I2CRussell King
2011-02-11VIDEO: cyberpro: make 'reg_b0_lock' always presentRussell King
Rather than conditionally compiling out reg_b0_lock, always keep it available, and always take it when changing the PLL rates. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-11VIDEO: cyberpro: add I2C supportOndrej Zary
Add I2C support for the DDC bus to cyber2000fb driver. This is only bus support, driver does not use EDID. Tested on two different CyberPro 2000 cards with i2cdetect and decode-edid. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> [removed i2c-id.h include - rmk] Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-01-28VIDEO: cyberpro: select lowest multipler/divisor for PLLRussell King
The lowest closest multiplier/divisor combination should be used for the PLL, not the largest. Reverse the search order. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-30cyber2000fb: fix console in truecolor modesOndrej Zary
Return value was not set to 0 in setcolreg() with truecolor modes. This causes fb_set_cmap() to abort after first color, resulting in blank palette - and blank console in 24bpp and 32bpp modes. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2010-07-30cyber2000fb: fix machine hang on module loadOndrej Zary
I was testing two CyberPro 2000 based PCI cards on x86 and the machine always hanged completely when the cyber2000fb module was loaded. It seems that the card hangs when some registers are accessed too quickly after writing RAMDAC control register. With this patch, both card work. Add delay after RAMDAC control register write to prevent hangs on module load. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-12-24VIDEO: cyberpro: pci_request_regions needs a persistent nameRussell King
Don't pass a name pointer from the kernel stack, it will not survive and will result in corrupted /proc/iomem output. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-06-12cyber2000fb.c: use proper method for stopping unload if CONFIG_ARCH_SHARKRusty Russell
Russell explains the __module_get(): > cyber2000fb.c does it in its module initialization function > to prevent the module (when built for Shark) from being unloaded. It > does this because it's from the days of 2.2 kernels and no one bothered > writing the module unload support for Shark. Since 2.4, the correct answer has been to not define an unload fn. Cc: Russell King <rmk+lkml@arm.linux.org.uk> Cc: alex@shark-linux.de Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2009-03-25[ARM] acorn,ebsa110,footbridge,integrator,sa1100: Convert asm/io.h to linux/io.hRussell King
2009-02-19[ARM] 5363/1: Shark cleanup and new defconfigAlexander Schulz
This includes a new defconfig for the Shark and some changes to the mach-shark directory to avoid namespace pollution and to switch the rtc to the newer driver. Signed-off-by: Alexander Schulz <alex@shark-linux.de> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2009-01-06pci: use pci_ioremap_bar() in drivers/videoArjan van de Ven
Use the newly introduced pci_ioremap_bar() function in drivers/video. pci_ioremap_bar() just takes a pci device and a bar number, with the goal of making it really hard to get wrong, while also having a central place to stick sanity checks. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-08cyber2000fb: Kill the one modular sparc prom_printf call.David S. Miller
Noticed by Robert Reif and Sam Ravnborg. Signed-off-by: David S. Miller <davem@davemloft.net>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-11-08[ARM] 4645/1: Cyberpro: Trivial fix to restore 16bpp mode.Jan Rinze
Cyberpro: when user requests 16bpp, use it and not 24bpp. There was a missing break causing requests for 16bpp mode to end up in 24bpp mode. Signed-off-by: Jan Rinze Peterzon <janrinze@home.nl> Acked-by: Ralph Siemsen <ralphs@netwinder.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-19cyber2000fb: checkpatch fixesKrzysztof Helt
This patch fixes errors and warnings pointed out by the checkpatch.pl script. Antonino Daplas replaced BIT with ENCODE_BIT. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19cyber2000fb, rename BIT macroJiri Slaby
cyber2000fb, rename BIT macro BIT will be global macro for (1 << x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fbdev: change asm/uaccess.h to linux/uaccess.hKrzysztof Helt
This patch replaces <asm/uaccess.h> with <linux/uaccess.h> after the checkpatch.pl hint. The include of <asm/uaccess.h> is removed if the driver does not use it. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] cyber2010 framebuffer on ARM Netwinder fixWoody Suwalski
The Netwinder machines with Cyber2010 crash badly when starting Xserver. The workaround is to disable pci burst option for this revision of video chip. [akpm@osdl.org: cleanup] Signed-off-by: Woody Suwalski <woodys@xandros.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: James Simmons <jsimmons@infradead.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-10[PATCH] vt: Remove VT-specific declarations and definitions from tty.hJon Smirl
MAX_NR_CONSOLES, fg_console, want_console and last_console are more of a function of the VT layer than the TTY one. Moving these to vt.h and vt_kern.h allows all of the framebuffer and VT console drivers to remove their dependency on tty.h. [akpm@osdl.org: fix alpha build] Signed-off-by: Jon Smirl <jonsmir@gmail.com> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[ARM] Remove asm/irq.h includes from ARM driversRussell King
Many ARM drivers do not need to include asm/irq.h - remove this unnecessary include from some ARM drivers. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-15[PATCH] cyber2000fb.c __iomem annotationsAl Viro
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-03[PATCH] ARM: Cleanup kmalloc in cyber2000fbRussell King
We use one kmalloc to allocate two structures needlessly. Combine these two structures into one. Signed-off-by: Russell King <rmk@arm.linux.org.uk>
