path: root/drivers/video/cyblafb.c
2007-07-17cyblafb: fix pseudo_palette array overrun in setcolregAntonino A. Daplas
The pseudo_palette has only 16 elements. Do not write if regno (the array index) is more than 15. Signed-off-by: Antonino Daplas <adaplas@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-31[PATCH] PCI: cyblafb: remove pci_module_init() return, really.Arthur Othieno
Richard Knutsson <ricknu-0@student.ltu.se> did the original pci_module_init() cleanups: http://marc.theaimsgroup.com/?l=linux-kernel&m=113330872125068&w=2 http://marc.theaimsgroup.com/?l=linux-kernel&m=113330888507321&w=2 Greg, on it's way upstream, pci_module_init() return sneaked back in for cyblafb? http://marc.theaimsgroup.com/?l=linux-pci&m=113652969209562&w=2 http://marc.theaimsgroup.com/?l=linux-pci&m=113683930220421&w=2 Remove for good. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] drivers/*rest*: Replace pci_module_init() with pci_register_driver()Richard Knutsson
Replace obsolete pci_module_init() with pci_register_driver(). Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-09[PATCH] Update cyblafb driverKnut Petersen
This is a major update to the cyblafb framebuffer driver. Most of the stuff has been tested in the mm tree. Main advantages: ============ - vxres > xres support - ywrap and xpan support - much faster for almost all modes (e.g. 1280x1024-16bpp draws more than 41 full screens of text instead of about 25 full screens of text per second on authors Epia 5000) - module init/exit code fixed - bugs triggered by console rotation fixed - lots of minor improvements - startup modes suitable for high performance scrolling in all directions This diff also contains a lot of white space fixes. No side effects are possible, only one single graphics core is affected. Signed-off-by: Knut Petersen <Knut_Petersen@t-online.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fbcon/fbdev: Move softcursor out of fbdev to fbconAntonino A. Daplas
According to Jon Smirl, filling in the field fb_cursor with soft_cursor for drivers that do not support hardware cursors is redundant. The soft_cursor function is usable by all drivers because it is just a wrapper around fb_imageblit. And because soft_cursor is an fbcon-specific hook, the file is moved to the console directory. Thus, drivers that do not support hardware cursors can leave the fb_cursor field blank. For drivers that do, they can fill up this field with their own version. The end result is a smaller code size. And if the framebuffer console is not loaded, module/kernel size is also reduced because the soft_cursor module will also not be loaded. Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-29[PATCH] cyblafb: portability fixes, sanitized work with pointersAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Knut Petersen <Knut_Petersen@t-online.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] framebuffer: new driver for cyberblade/i1 graphics coreKnut Petersen
This is a framebuffer driver for the Cyberblade/i1 graphics core. Currently tridenfb claims to support the cyberblade/i1 graphics core. This is of very limited truth. Even vesafb is faster and provides more working modes and a much better quality of the video signal. There is a great number of bugs in tridentfb ... but most often it is impossible to decide if these bugs are real bugs or if fixing them for the cyberblade/i1 core would break support for one of the other supported chips. Tridentfb seems to be unmaintained,and documentation for most of the supported chips is not available. So "fixing" cyberblade/i1 support inside of tridentfb was not an option, it would have caused numerous if(CYBERBLADEi1) else ... cases and would have rendered the code to be almost unmaintainable. A first version of this driver was published on 2005-07-31. A fix for a bug reported by Jochen Hein was integrated as well as some changes requested by Antonino A. Daplas. A message has been added to tridentfb to inform current users of tridentfb to switch to cyblafb if the cyberblade/i1 graphics core is detected. This patch is one logical change, but because of the included documentation it is bigger than 70kb. Therefore it is not sent to lkml and linux-fbdev-devel, Signed-off-by: Knut Petersen <Knut_Petersen@t-online.de> Cc: Muli Ben-Yehuda <mulix@mulix.org> Acked-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
